Project 3059 (Run 4, Clone 75, Gen 25)
DocJonz
Post by DocJonz »
Have had issues with Project 3059 (Run 4, Clone 75, Gen 25) - it has cropped up on a couple of my 64-bit Linux boxes and has dropped out right at the start each time - here's one of them....
[17:31:26] *------------------------------*
[17:31:26] Folding@Home Gromacs SMP Core
[17:31:26] Version 1.74 (November 27, 2006)
[17:31:26]
[17:31:26] Preparing to commence simulation
[17:31:26] - Ensuring status. Please wait.
[17:31:43] - Assembly optimizations manually forced on.
[17:31:43] - Not checking prior termination.
[17:31:43] - Expanded 530964 -> 2922581 (decompressed 550.4 percent)
[17:31:43] - Starting from initial work packet
[17:31:43]
[17:31:43] Project: 3059 (Run 4, Clone 75, Gen 25)
[17:31:43]
[17:31:43] Assembly optimizations on if available.
[17:31:43] Entering M.D.
NNODES=4, MYRANK=1, HOSTNAME=AkasaC2Q2
NNODES=4, MYRANK=2, HOSTNAME=AkasaC2Q2
NNODES=4, MYRANK=3, HOSTNAME=AkasaC2Q2
NNODES=4, MYRANK=0, HOSTNAME=AkasaC2Q2
NODEID=1 argc=15
NODEID=3 argc=15
NODEID=2 argc=15
NODEID=0 argc=15
      Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
       Copyright (c) 1991-2000, University of Groningen, The Netherlands.
             Copyright (c) 2001-2004, The GROMACS development team,
            check out http://www.gromacs.org for more information.
        This inclusion of Gromacs code in the Folding@Home Core is under
        a special license (see http://folding.stanford.edu/gromacs.html)
         specially granted to Stanford by the copyright holders. If you
          are interested in using Gromacs, visit www.gromacs.org where
                you can download a free version of Gromacs under
         the terms of the GNU General Public License (GPL) as published
       by the Free Software Foundation; either version 2 of the License,
                     or (at your option) any later version.
[17:31:49] Protein: 19884 p3059_supervillin_newbox
[17:31:49] Writing local files
starting mdrun '19884 p3059_supervillin_newbox'
5000000 steps,  10000.0 ps.
[17:31:49] Extra SSE boost OK.
[17:31:49]
[17:31:49] Warning:  long 1-4 interactions
[17:31:49] Completed 0 out of 5000000 steps  (0 percent)
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 0, signaled with Segmentation fault
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Segmentation fault
[17:31:53] CoreStatus = 0 (0)
[17:31:53] Client-core communications error: ERROR 0x0
[17:31:53] - Attempting to download new core...
[17:31:53] + Downloading new core: FahCore_a1.exe
[17:31:53] Downloading core (/~pande/Linux/x86//Core_a1.fah from www.stanford.edu)
[17:31:55] Initial: AFDE; + 10240 bytes downloaded
[17:31:55] Initial: B54E; + 20480 bytes downloaded
uncle_fungus
Post by uncle_fungus »
So far no one has returned this WU, successfully or otherwise.
Flathead74
Post by Flathead74 »
Members of our team have received this WU ten different times,
with the same result every time.
Guess what, the Fahlog report is identical to that of DocJonz.
The following link points to a list of WUs that has been troublesome to our team.
http://www.fold4life.com/forum/viewtopic.php?t=886
DocJonz
Post by DocJonz »
One of my other Linux boxes has tried to pull this WU down today - exactly the same outcome as before ....
kasson
Pande Group Member
Post by kasson »
Thanks for the reports. We're looking at ways to deal with such problems better; the concept is easy, but the implementation is hard, so it may take a while. :(
Flathead74
Got this WU again today.
Same results as always, immediate failure.
