[19:36:13] Completed 289700 out of 499375 steps (58%)
[19:44:28] Completed 294600 out of 499375 steps (58%)
[19:50:20] WARNING: Console control signal 5 on PID 652
[19:50:20] Service ignoring hangup/logoff signal.
[19:50:24] WARNING: Console control signal 5 on PID 652
[19:50:24] Service ignoring hangup/logoff signal.
[19:50:26] WARNING: Console control signal 6 on PID 652
[19:50:26] Exiting, please wait. . .
[19:50:32] GUI Server closing
[19:50:32] GUI Server exiting
[19:50:32] Folding@home Core Shutdown: INTERRUPTED
[19:50:36] CoreStatus = 66 (102)
[19:50:36] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[19:50:36] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [January 2 19:55:08 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding1\Folding@home-Win32-x86-623
Service: C:\Program Files\Folding1\Folding@home-Win32-x86-623\Folding@home-Win32-x86.exe
Arguments: -svcstart -d C:\Program Files\Folding1\Folding@home-Win32-x86-623 -verbosity 9 -forceasm
Launched as a service.
Entered C:\Program Files\Folding1\Folding@home-Win32-x86-623 to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[19:55:08] - Ask before connecting: No
[19:55:08] - User name: John_Weatherman (Team 48913)
[19:55:08] - User ID: 56FD91C778A0AD89
[19:55:08] - Machine ID: 1
[19:55:08]
[19:55:08] Loaded queue successfully.
[19:55:08]
[19:55:08] + Processing work unit
[19:55:08] Core required: FahCore_b4.exe
[19:55:08] Core found.
[19:55:08] - Autosending finished units... [January 2 19:55:08 UTC]
[19:55:08] Trying to send all finished work units
[19:55:08] + No unsent completed units remaining.
[19:55:08] - Autosend completed
[19:55:08] Working on queue slot 02 [January 2 19:55:08 UTC]
[19:55:08] + Working ...
[19:55:08] - Calling '.\FahCore_b4.exe -dir work/ -suffix 02 -checkpoint 10 -service -forceasm -verbose -lifeline 572 -version 623'
[19:55:43] *********************** Log Started 02/Jan/2011 19:55:42 ***********************
[19:55:43] ************************** ProtoMol Folding@Home Core **************************
[19:55:43]   Version: 25
[19:55:43]      Type: 180
[19:55:43]      Core: ProtoMol
[19:55:43]   Website: http://folding.stanford.edu/
[19:55:43] Copyright: (c) 2009 Stanford University
[19:55:43]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[19:55:43]      Args: -dir work/ -suffix 02 -checkpoint 10 -service -forceasm -verbose
[19:55:43]            -lifeline 572 -version 623
[19:55:43] ************************************ Build *************************************
[19:55:43]      Date: May 18 2010
[19:55:43]      Time: 23:43:52
[19:55:43]  Revision: 1819
[19:55:43]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[19:55:43]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[19:55:43]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[19:55:43]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[19:55:43]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[19:55:43]  Platform: Windows XP
[19:55:43]      Bits: 32
[19:55:43]      Mode: Release
[19:55:43] ************************************ System ************************************
[19:55:43]        OS: Microsoft Windows XP Professional
[19:55:43]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[19:55:43]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[19:55:43]      CPUs: 2 Logical, 1 Physical
[19:55:43]    Memory: 1023 MB
[19:55:43]   Threads: Windows
[19:55:43] ********************************************************************************
[19:55:43] Project: 10045 (Run 194, Clone 0, Gen 93)
[19:55:43] Unit: 0x000000720001329c4c6190c000000c76
[19:55:43] User: 0x00000000000000000000000000000000
[19:55:43] Machine: 1
[19:55:43] Digital signatures verified
[19:55:51] GUI Server started
[19:55:51] Completed 298400 out of 499375 steps (59%)
[19:57:04] ERROR: ProtoMol ERROR: Corrupt DCD file. Size is 2935572, should be >= 2942124.
[19:57:04] Saving result file logfile_02.txt
[19:57:04] Saving result file checkpt
[19:57:04] Saving result file checkpt.crc
[19:57:04] Saving result file log.txt
[19:57:04] Saving result file protomol.conf
[19:57:04] Saving result file ww.6457.pos
[19:57:04] Saving result file ww.6457.vel
[19:57:04] Saving result file ww.dcd
[19:57:06] WARNING: While cleaning up: 0: Failed to remove directory '02': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "02\ww.dcd"
[19:57:06] Folding@home Core Shutdown: BAD_WORK_UNIT
[19:57:08] CoreStatus = 72 (114)
[19:57:08] Sending work to server
[19:57:08] Project: 10045 (Run 194, Clone 0, Gen 93)
[19:57:08] - Read packet limit of 540015616... Set to 524286976.
[19:57:08] + Attempting to send results [January 2 19:57:08 UTC]
[19:57:08] - Reading file work/wuresults_02.dat from core
[19:57:08]   (Read 2506427 bytes from disk)
[19:57:08] Connecting to http://129.74.85.15:8080/
[19:57:36] Posted data.
[19:57:37] Initial: 0000; - Uploaded at ~84 kB/s
[19:57:37] - Averaged speed for that direction ~36 kB/s
[19:57:37] + Results successfully sent
