I have 3 different computers running F@H. They all seem to be working on the same project, according the log they are each working on project 6887, the run and clone and gen are different, does this mean they are woking on the same thing? I just want to make sure each computer is woking on something different and not wasting resources.
Thank you
Multiple Computers
Re: Multiple Computers
Welcome to the F@H Forum jrezuchajr,
There are several WUs (Work Units) in a single Project. As long as the Run, Clone, Gen are different, they are working on different WUs. If you want, you can read this post -> viewtopic.php?p=160883#p160883
Zagen30
More like tens of thousands or hundreds of thousands.PantherX wrote:There are several WUs (Work Units) in a single Project.
jrezuchajr
Thank you for the response..
