Missing Points - Project 6900 (Run 19, Clone 0, Gen 15)
IceMan62
Post by IceMan62 »
Hi,
I missing all of the Points for this BigWu. I hope this part from the LogFile is helpful. If you need more information, please let me know.
Best regards
IceMan62
[20:22:46] Completed 217500 out of 250000 steps  (87%)
[20:45:43] Completed 220000 out of 250000 steps  (88%)
[21:00:30] - Autosending finished units... [December 28 21:00:30 UTC]
[21:00:30] Trying to send all finished work units
[21:00:30] + No unsent completed units remaining.
[21:00:30] - Autosend completed
[21:08:41] Completed 222500 out of 250000 steps  (89%)
[21:31:41] Completed 225000 out of 250000 steps  (90%)
[21:54:28] Completed 227500 out of 250000 steps  (91%)
[22:17:24] Completed 230000 out of 250000 steps  (92%)
[22:40:19] Completed 232500 out of 250000 steps  (93%)
[23:03:18] Completed 235000 out of 250000 steps  (94%)
[23:26:00] Completed 237500 out of 250000 steps  (95%)
[23:49:06] Completed 240000 out of 250000 steps  (96%)
[00:12:01] Completed 242500 out of 250000 steps  (97%)
[00:34:57] Completed 245000 out of 250000 steps  (98%)
[00:57:40] Completed 247500 out of 250000 steps  (99%)
[01:20:46] Completed 250000 out of 250000 steps  (100%)
[01:20:56] DynamicWrapper: Finished Work Unit: sleep=10000
[01:21:06]
[01:21:06] Finished Work Unit:
[01:21:06] - Reading up to 52713120 from "work/wudata_06.trr": Read 52713120
[01:21:07] trr file hash check passed.
[01:21:07] - Reading up to 47029364 from "work/wudata_06.xtc": Read 47029364
[01:21:07] xtc file hash check passed.
[01:21:07] edr file hash check passed.
[01:21:07] logfile size: 204122
[01:21:07] Leaving Run
[01:21:09] - Writing 100114546 bytes of core data to disk...
[01:21:10]   ... Done.
[01:21:17] - Shutting down core
[01:21:17]
[01:21:17] Folding@home Core Shutdown: FINISHED_UNIT
[01:21:22] CoreStatus = 64 (100)
[01:21:22] Unit 6 finished with 71 percent of time to deadline remaining.
[01:21:22] Updated performance fraction: 0.719673
[01:21:22] Sending work to server
[01:21:22] Project: 6900 (Run 19, Clone 0, Gen 15)
[01:21:22] + Attempting to send results [December 29 01:21:22 UTC]
[01:21:22] - Reading file work/wuresults_06.dat from core
[01:21:22]   (Read 100114546 bytes from disk)
[01:21:22] Connecting to http://130.237.232.141:8080/
[01:34:40] Posted data.
[01:34:40] Initial: 0000; - Uploaded at ~122 kB/s
[01:34:40] - Averaged speed for that direction ~120 kB/s
[01:34:40] + Results successfully sent
[01:34:40] Thank you for your contribution to Folding@Home.
[01:34:40] + Number of Units Completed: 70
[01:34:47] Trying to send all finished work units
[01:34:47] + No unsent completed units remaining.
[01:34:47] - Preparing to get new work unit...
[01:34:47] Cleaning up work directory
[01:34:50] + Attempting to get work packet
[01:34:50] Passkey found
[01:34:50] - Will indicate memory of 12286 MB
[01:34:50] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[01:34:50] - Connecting to assignment server
[01:34:50] Connecting to http://assign.stanford.edu:8080/
[01:34:51] Posted data.
[01:34:51] Initial: ED82; - Successful: assigned to (130.237.232.141).
[01:34:51] + News From Folding@Home: Welcome to Folding@Home
[01:34:52] Loaded queue successfully.
[01:34:52] Sent data
[01:34:52] Connecting to http://130.237.232.141:8080/
[01:34:57] Posted data.
[01:34:57] Initial: 0000; - Receiving payload (expected size: 24868953)
[01:35:23] - Downloaded at ~934 kB/s
[01:35:23] - Averaged speed for that direction ~958 kB/s
[01:35:23] + Received work.
[01:35:23] Trying to send all finished work units
[01:35:23] + No unsent completed units remaining.
[01:35:23] + Closed connections
[01:35:23]
[01:35:23] + Processing work unit
[01:35:23] Core required: FahCore_a3.exe
[01:35:23] Core found.
[01:35:23] Working on queue slot 07 [December 29 01:35:23 UTC]
[01:35:23] + Working ...
[01:35:23] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 3780 -version 630'
[01:35:23]
[01:35:23] *------------------------------*
[01:35:23] Folding@Home Gromacs SMP Core
[01:35:23] Version 2.22 (Mar 12, 2010)
[01:35:23]
[01:35:23] Preparing to commence simulation
[01:35:23] - Looking at optimizations...
[01:35:23] - Created dyn
[01:35:23] - Files status OK
[01:35:27] - Expanded 24868441 -> 30796293 (decompressed 123.8 percent)
[01:35:27] Called DecompressByteArray: compressed_data_size=24868441 data_size=30796293, decompressed_data_size=30796293 diff=0
[01:35:27] - Digital signature verified
[01:35:27]
[01:35:27] Project: 6900 (Run 14, Clone 7, Gen 12)
[01:35:27]
[01:35:27] Assembly optimizations on if available.
[01:35:27] Entering M.D.
[01:35:36] Completed 0 out of 250000 steps  (0%)
[01:58:20] Completed 2500 out of 250000 steps  (1%)
[02:21:15] Completed 5000 out of 250000 steps  (2%)
Re: Missing Points - Project 6900 (Run 19, Clone 0, Gen 15)
Welcome to the foldingforum, IceMan62.
The real question is why you keep running the same WU over and over. You'll only get credit for it once.
Hi IceMan62 (team 70911),
Your WU (P6900 R19 C0 G15) was added to the stats database on 2010-12-28 06:06:01 for 6720.51 points of credit.
Your WU (P6900 R19 C0 G15) was added to the stats database on 2010-12-28 18:05:37 for 0 points of credit.
Your WU (P6900 R19 C0 G15) was added to the stats database on 2010-12-29 11:06:43 for 0 points of credit.
Grandpa_01
Post by Grandpa_01 »
Let me guess saved the file at around 70% then crashed Stanford sent the same WU to you again. Deleted the new one started the saved one finshed the file on 12/28 at 6:06 light bulb goes off in head started the saved file again complete it, another light bulb run it again. Oooops that did not work too well, wasted computer time, complaine about not getting points. Just 1 possibility. :wink: :lol:
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
IceMan62
Post by IceMan62 »
thanks for this information, that the Wu was sent to the server. Why the Points are not correct, maybe you can tell me that. HFM.NET show me for the Wu 6900 Credit Points from ~87500 and over 52000 PPD. The Wu was finished long in front of the Deadline (the TPF was a little under 23:00). This problem with correct finshed BigWu´s and no points for it is for me not the first time. Sometimes i become over 24h later only the 8955 ground points (and no total Credit points from over 85000). So I`ll you tell why i send this last BigWu 6900 three times.
For some weeks I have a lot of Blue Screens and lost some BigWu´s (one of the Memory was demaged). Some of the Project was over 90% and after the restart from the PC and the Folding program the program was loading a new Project - it was missing the Project with over 90%. So befor this was happend again I`ll save the complete smp Client files. So I save each work for the time if I become problems again and know I see the WU was finished but no points for it. Not after 9h or 12h. I think somethink was wrong with the Server or the connection (upload) and I load a save from this WU to be become the correct points and not to be become the points 3 times!
Best regards
IceMan62
sorry for my english, it´s not my language ;)
According to the Project Summary, project 6900 has a Preferred Deadline of 4.00, the baseline points are 8955.00, and the KFactor is 26.40. All bigadv WUs are a challenge to complete and hardware MUST BE STABLE. The large KFactor puts a large emphasis on finishing the WU as rapidly as possible.
HFM.NET and other 3rd party tools do their best to estimate how many points you will receive when a WU is completed. Actual points are accrued based entirely on the information that the server receives, which may include information that HFM.NET cannot know. HFM.NET and other tools assume that you'll finish the WU successfully (which did not happen) and that the current rate of production will be continued up to 100% and that the result will be successfully uploaded soon thereafter.
In your case, the WU was processed the first time and had some sort of error when it was about 75%. I have no way of knowing what that error was, but if you have FAHlog.txt or FAHlog-Prev.txt covering 2010-12-28 around 6AM PST which would be around 2PM UTC, we might be able to figure out what kind of error occurred. As long as you've reported Blue Screen (BSOD) errors , however, there's probably no reason to do that. Whatever is causing the BSOD errors MUST be corrected.
After that error, you did receive partial credit for the WU and FAH would have deleted the WU and downloaded a new WU. You must have restoring a backup copy of data for that WU from another source and either tried to reprocess it or tried to resubmit it. Manipulating the files that FAH creates is not a good idea. It is specifically prohibited by the EULA, but if you do it anyway, you're very likely to receive zero points for your efforts -- and that's apparently what happened here.
What happened to the next WU that was assigned? Next time something like this happens, let the system work on the assignment that you've been given and don't try to reprocess the earlier WU.
Your BSOD errors are probably caused by a hardware problem, (including things like overheating as well as faulty hardware). For more information, see http://en.wikipedia.org/wiki/Bsod
IceMan62
Post by IceMan62 »
The BSOD come from a bad Memory and I change it for 2 Weeks - from this time no more BSOD. I find something in the FAHlog-Prev.txt and I remember there was a problem with the Folding@home-Win32-x86.exe. There come a message like "16bit software can not run under 32 or 64bit OS. Please check your OS". Here what I found in the Log
--- Opening Log file [December 28 14:42:21 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: D:\Program Files (x86)\smp
Executable: D:\Program Files (x86)\smp\Folding@home-Win32-x86.exe
Arguments: -smp 11 -verbosity 9 -bigadv
[14:42:21] - Ask before connecting: No
[14:42:21] - User name: IceMan62 (Team 70911)
[14:42:21] - User ID: 4E562CBA4D29348D
[14:42:21] - Machine ID: 1
[14:42:21]
[14:42:21] Loaded queue successfully.
[14:42:21]
[14:42:21] - Autosending finished units... [December 28 14:42:21 UTC]
[14:42:21] + Processing work unit
[14:42:21] Trying to send all finished work units
[14:42:21] Core required: FahCore_a3.exe
[14:42:21] + No unsent completed units remaining.
[14:42:21] - Autosend completed
[14:42:21] Core found.
[14:42:21] Working on queue slot 06 [December 28 14:42:21 UTC]
[14:42:21] + Working ...
[14:42:21] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 3588 -version 630'
[14:42:32] CoreStatus = 63 (99)
[14:42:32] + Error starting Folding@Home core.
[14:42:37]
[14:42:37] + Processing work unit
[14:42:37] Core required: FahCore_a3.exe
[14:42:37] Core found.
[14:42:37] Working on queue slot 06 [December 28 14:42:37 UTC]
[14:42:37] + Working ...
[14:42:37] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 3588 -version 630'
[14:42:41] Killing all core threads
[14:42:41] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[14:42:41] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [December 28 14:55:33 UTC]
[14:55:33] - Ask before connecting: No
[14:55:33] - User name: IceMan62 (Team 70911)
[14:55:33] - User ID: 4E562CBA4D29348D
[14:55:33] - Machine ID: 1
[14:55:33]
[14:55:33] Loaded queue successfully.
[14:55:33]
[14:55:33] - Autosending finished units... [December 28 14:55:33 UTC]
[14:55:33] + Processing work unit
[14:55:33] Trying to send all finished work units
[14:55:33] Core required: FahCore_a3.exe
[14:55:33] + No unsent completed units remaining.
[14:55:33] - Autosend completed
[14:55:33] Core found.
[14:55:33] Working on queue slot 06 [December 28 14:55:33 UTC]
[14:55:33] + Working ...
[14:55:33] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 4524 -version 630'
[14:56:10] CoreStatus = 63 (99)
[14:56:10] + Error starting Folding@Home core.
[14:56:15]
[14:56:15] + Processing work unit
[14:56:15] Core required: FahCore_a3.exe
[14:56:15] Core found.
[14:56:15] Working on queue slot 06 [December 28 14:56:15 UTC]
[14:56:15] + Working ...
[14:56:15] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 4524 -version 630'
[14:56:18] Killing all core threads
[14:56:18] Could not get process id information.  Please kill core process manually
[14:56:18] ***** Got a SIGTERM signal (2)
--- Opening Log file [December 28 15:00:30 UTC]
[15:00:30] - Ask before connecting: No
[15:00:30] - User name: IceMan62 (Team 70911)
[15:00:30] - User ID: 4E562CBA4D29348D
[15:00:30] - Machine ID: 1
[15:00:30]
[15:00:30] Loaded queue successfully.
[15:00:30]
[15:00:30] - Autosending finished units... [December 28 15:00:30 UTC]
[15:00:30] + Processing work unit
[15:00:30] Trying to send all finished work units
[15:00:30] Core required: FahCore_a3.exe
[15:00:30] + No unsent completed units remaining.
[15:00:30] Core found.
[15:00:30] - Autosend completed
[15:00:30] Working on queue slot 06 [December 28 15:00:30 UTC]
[15:00:30] + Working ...
[15:00:30] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 11 -priority 1 -checkpoint 15 -verbose -lifeline 3780 -version 630'
[15:00:31]
[15:00:31] *------------------------------*
[15:00:31] Folding@Home Gromacs SMP Core
[15:00:31] Version 2.22 (Mar 12, 2010)
[15:00:31]
[15:00:31] Preparing to commence simulation
[15:00:31] - Ensuring status. Please wait.
[15:00:40] - Looking at optimizations...
[15:00:40] - Working with standard loops on this execution.
[15:00:40] - Files status OK
[15:00:44] - Expanded 24863233 -> 30796293 (decompressed 123.8 percent)
[15:00:44] Called DecompressByteArray: compressed_data_size=24863233 data_size=30796293, decompressed_data_size=30796293 diff=0
[15:00:44] - Digital signature verified
[15:00:44]
[15:00:44] Project: 6900 (Run 19, Clone 0, Gen 15)
[15:00:44]
[15:00:44] Entering M.D.
[15:00:50] Using Gromacs checkpoints
[15:00:54] Resuming from checkpoint
[15:00:55] Verified work/wudata_06.log
[15:00:56] Verified work/wudata_06.trr
[15:00:56] Verified work/wudata_06.xtc
[15:00:56] Verified work/wudata_06.edr
[15:00:57] Completed 182375 out of 250000 steps  (72%)
[15:02:15] Completed 182500 out of 250000 steps  (73%)
[15:25:02] Completed 185000 out of 250000 steps  (74%)
[15:47:59] Completed 187500 out of 250000 steps  (75%)
[16:10:58] Completed 190000 out of 250000 steps  (76%)
[16:33:54] Completed 192500 out of 250000 steps  (77%)
[16:56:43] Completed 195000 out of 250000 steps  (78%)
[17:19:37] Completed 197500 out of 250000 steps  (79%)
[17:42:30] Completed 200000 out of 250000 steps  (80%)
[18:05:28] Completed 202500 out of 250000 steps  (81%)
[18:28:11] Completed 205000 out of 250000 steps  (82%)
[18:51:09] Completed 207500 out of 250000 steps  (83%)
[19:14:05] Completed 210000 out of 250000 steps  (84%)
[19:37:02] Completed 212500 out of 250000 steps  (85%)
[19:59:49] Completed 215000 out of 250000 steps  (86%)
[01:21:06]
[01:21:17]
[01:35:23]
[01:35:23]
[01:35:23]
[01:35:27]
[01:35:27]
I think the Folding@home exe was crashed and I have to install the Folding client again. From there up the Client was running fine and the next Project (6900 R8-C4-G15) where I become on 29.12.2010 01:35 UTC (finished on 30.12.2010 22:43 UTC) was finished with 53066,6 PPD. For the future I let the system work and if I find something is wrong I´ll correct it here a little earlier.
Best regards
