Trying to log in another computer.
Sandman192
I'm trying to log in to this form from another computer and can"t, I've even tried to reset password from the other computer and it says E-mail is not even found, but the first computer I logged in to has not problems like right now when I'm posting this.
gwildperson
Re: Trying to log in another computer.
Are you confusing the User Name that you use in your FAH client with the name you use on the forum? The two can be different. The client has a Passkey which is assigned by Stanford based on your username, etc. but the forum password is whatever you set it to.
I wonder if there is a hang-up in the logout from the other computer; I believe you can only have one logged on at a time with the same credentials (User Name/Password).
(Been there - done that - got the T-Shirt!)
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
uncle fuzzy
I have multiple boxes and have logged into the forum from more than 1 at a time. I think the most was 4 at once. The forum may or may not log off the older connections as you make new ones.
