Project: 6513 (Run 18, Clone 247, Gen 14)
Tobit
Post by Tobit »
Posting on behalf of a teammate... might be a bad WU.
Pentium 4 w/HT 3.4ghz
2gigs of Corsair ddr3200 ram - stock timings
Windows Server 2003 Standard - all patches are applied
F@H Client: 6.30
Username: dmolter
[05:38:45] + Processing work unit
[05:38:45] Core required: FahCore_78.exe
[05:38:45] Core found.
[05:38:45] Working on queue slot 07 [December 26 05:38:45 UTC]
[05:38:45] + Working ...
[05:38:46]
[05:38:46] *------------------------------*
[05:38:46] Folding@Home Gromacs Core
[05:38:46] Version 1.90 (March 8, 2006)
[05:38:46]
[05:38:46] Preparing to commence simulation
[05:38:46] - Looking at optimizations...
[05:38:46] - Created dyn
[05:38:46] - Files status OK
[05:38:46] - Expanded 518872 -> 2531881 (decompressed 487.9 percent)
[05:38:46] - Starting from initial work packet
[05:38:46]
[05:38:46] Project: 6513 (Run 18, Clone 247, Gen 14)
[05:38:46]
[05:38:46] Assembly optimizations on if available.
[05:38:46] Entering M.D.
[05:38:53] Protein: TR462_B_19 in water
[05:38:53]
[05:38:53] Writing local files
[05:38:53] Extra SSE boost OK.
[05:38:53] Completed 0 out of 250000 steps  (0%)
[05:51:48] Writing local files
[05:51:48] Completed 2500 out of 250000 steps  (1%)
[06:04:41] Writing local files
--- snip ---
[14:01:20] Completed 97500 out of 250000 steps  (39%)
[14:13:26] Gromacs cannot continue further.
[14:13:26] Going to send back what have done.
[14:13:26] logfile size: 26354
[14:13:26] - Writing 26890 bytes of core data to disk...
[14:13:26] Done: 26378 -> 5245 (compressed to 19.8 percent)
[14:13:26]   ... Done.
[14:13:26]
[14:13:26] Folding@home Core Shutdown: EARLY_UNIT_END
[14:13:30] CoreStatus = 72 (114)
[14:13:30] Sending work to server
Re: Project: 6513 (Run 18, Clone 247, Gen 14)
Hi dmolter (team 33),
Your WU (P6513 R18 C247 G14) was added to the stats database on 2010-12-26 07:03:17 for 29.95 points of credit.
This looks like a bad WU ... there's another report in the DB with the exact same amount of point ...
