Project: 6701 (Run 46, Clone 5, Gen 103)
Tobit
Post by Tobit »
AMD X4 Processor @ 3 GHz on Gentoo Linux
2.29 Linux Unified Client, 2.22 A3 Core
Do to bug in Linux client, I have to change machine ID to get different work assigned.
Error messages displayed on console output, not in log, are as follows:
step 207660851: Water molecule starting at atom 8338 can not be settled.
Check for bad contacts and/or reduce the timestep if appropriate.
step 207660851: Water molecule starting at atom 17227 can not be settled.
FAHlog:
[18:59:28] + Working ...
[18:59:28] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 4 -checkpoint 15 -verbose -lifeline 7318 -version 629'
[18:59:28]
[18:59:28] *------------------------------*
[18:59:28] Folding@Home Gromacs SMP Core
[18:59:29] Version 2.22 (June 10, 2010)
[18:59:29]
[18:59:29] Preparing to commence simulation
[18:59:29] - Looking at optimizations...
[18:59:29] - Created dyn
[18:59:29] - Files status OK
[18:59:29] - Expanded 763330 -> 1404481 (decompressed 183.9 percent)
[18:59:29] Called DecompressByteArray: compressed_data_size=763330 data_size=1404481, decompressed_data_size=1404481 diff=0
[18:59:29] - Digital signature verified
[18:59:29]
[18:59:29] Project: 6701 (Run 46, Clone 5, Gen 103)
[18:59:29]
[18:59:29] Assembly optimizations on if available.
[18:59:29] Entering M.D.
[18:59:36] Completed 0 out of 2000000 steps  (0%)
[19:10:48] Completed 20000 out of 2000000 steps  (1%)
... snip ..
[10:26:59] Completed 1660000 out of 2000000 steps  (83%)
[10:27:29] CoreStatus = 0 (0)
[10:27:29] Sending work to server
[10:27:29] Project: 6701 (Run 46, Clone 5, Gen 103)
[10:27:29] - Error: Could not get length of results file work/wuresults_01.dat
[10:27:29] - Error: Could not read unit 01 file. Removing from queue.
Re: Project: 6701 (Run 46, Clone 5, Gen 103)
The server has received no report, so it won't be reassigned until it times out (4.9 days after it was assigned to you) so it will be maybe a week or so before someone else has a chance to report on this WU. Very likely that next person will be running Windows and we'll see if this has been fixed in the Windows version of FahCore_a3.
In any case, the messages about Water molecule not being settled indicate that it's very likely a bad WU. The lack of a report to the server, which also leads to repeated reassignment of the same WU, will very likely be fixed in the next version of the core.
Probably about time to check this WU again.
It's now in the DB, and successfully completed :
Hi Tobit (team 33),
Your WU (P6701 R46 C5 G103) was added to the stats database on 2010-12-25 14:05:47 for 5256.15 points of credit.
