P6518 (Run 3, Clone 119, Gen 45) EUE CoreStatus = 72 (114)
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
Got an EUE on this WU after 86%. It was sent back to the server, giving me credit for 63 out of the full 72 points.
01:29:14] + Attempting to get work packet
[01:29:15] - Will indicate memory of 2039 MB
[01:29:15] - Connecting to assignment server
[01:29:15] Connecting to http://assign.stanford.edu:8080/
[01:29:15] Posted data.
[01:29:15] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[01:29:15] + News From Folding@Home: Welcome to Folding@Home
[01:29:15] Loaded queue successfully.
[01:29:15] Connecting to http://171.64.65.62:8080/
[01:29:16] Posted data.
[01:29:16] Initial: 0000; - Receiving payload (expected size: 474671)
[01:29:16] Conversation time very short, giving reduced weight in bandwidth avg
[01:29:16] - Downloaded at ~927 kB/s
[01:29:16] - Averaged speed for that direction ~600 kB/s
[01:29:16] + Received work.
[01:29:16] + Processing work unit
[01:29:16] Core required: FahCore_78.exe
[01:29:16] Core found.
[01:29:16] Working on queue slot 07 [December 19 01:29:16 UTC]
[01:29:16] + Working ...
[01:29:16] - Calling '.\FahCore_78.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 4720 -version 623'
[01:29:16]
[01:29:16] *------------------------------*
[01:29:16] Folding@Home Gromacs Core
[01:29:16] Version 1.90 (March 8, 2006)
[01:29:16]
[01:29:16] Preparing to commence simulation
[01:29:16] - Looking at optimizations...
[01:29:16] - Created dyn
[01:29:16] - Files status OK
[01:29:17] - Expanded 474159 -> 2359121 (decompressed 497.5 percent)
[01:29:17] - Starting from initial work packet
[01:29:17]
[01:29:17] Project: 6518 (Run 3, Clone 119, Gen 45)
[01:29:17]
[01:29:17] Assembly optimizations on if available.
[01:29:17] Entering M.D.
[01:29:24] Protein: proG_4 in water
[01:29:24]
[01:29:24] Writing local files
[01:29:24] Extra SSE boost OK.
[01:29:24] Completed 0 out of 250000 steps  (0%)
[01:40:39] Writing local files
[01:40:39] Completed 2500 out of 250000 steps  (1%)
[16:06:16] Completed 210000 out of 250000 steps  (84%)
[16:16:47] Writing local files
[16:16:47] Completed 212500 out of 250000 steps  (85%)
[16:26:45] Writing local files
[16:26:45] Completed 215000 out of 250000 steps  (86%)
[16:36:10] Gromacs cannot continue further.
[16:36:10] Going to send back what have done.
[16:36:10] logfile size: 19802
[16:36:10] - Writing 20338 bytes of core data to disk...
[16:36:10] Done: 19826 -> 4359 (compressed to 21.9 percent)
[16:36:10]   ... Done.
[16:36:10]
[16:36:10] Folding@home Core Shutdown: EARLY_UNIT_END
[16:36:12] CoreStatus = 72 (114)
[16:36:12] Sending work to server
[16:36:12] Project: 6518 (Run 3, Clone 119, Gen 45)
[16:36:12] - Read packet limit of 540015616... Set to 524286976.
[16:36:12] + Attempting to send results [December 19 16:36:12 UTC]
[16:36:12] - Reading file work/wuresults_07.dat from core
[16:36:12]   (Read 4871 bytes from disk)
[16:36:12] Connecting to http://171.64.65.62:8080/
[16:36:12] Posted data.
[16:36:12] Initial: 0000; - Uploaded at ~5 kB/s
[16:36:13] - Averaged speed for that direction ~222 kB/s
[16:36:13] + Results successfully sent
[16:36:13] Thank you for your contribution to Folding@Home.
This was running on my clunker Toshiba laptop (Pentium M740 / 1.73 GHz). The Toshiba has gotten ~170 work units since June - about one a day. No indication of any hardware issues.
Re: P6518 (Run 3, Clone 119, Gen 45) EUE CoreStatus = 72 (11
You're the only one to have return with WU for the time being ...
