Project: 6526 (Run 5, Clone 76, Gen 22)
Tobit
Post by Tobit »
[18:15:14] CoreStatus = 0 (0)
Generally don't have a problem with GROMACS 78 units these days.
Dell PowerEdge 860 Server with 2.4 GHz Dual Core Xeon, 4GB memory
Gentoo Linux, 2.6.34 Kernel
6.29 Client
[13:39:57] + Working ...
[13:39:57] - Calling './FahCore_78.exe -dir work/ -nice 19 -suffix 07 -np 0 -checkpoint 15 -verbose -lifeline 7279 -version 629'
[13:39:57]
[13:39:57] *------------------------------*
[13:39:57] Folding@Home Gromacs Core
[13:39:57] Version 1.90 (March 8, 2006)
[13:39:57]
[13:39:57] Preparing to commence simulation
[13:39:57] - Ensuring status. Please wait.
[13:40:14] - Looking at optimizations...
[13:40:15] - Working with standard loops on this execution.
[13:40:15] - Created dyn
[13:40:15] - Files status OK
[13:40:15] - Expanded 688011 -> 3405425 (decompressed 494.9 percent)
[13:40:15] - Starting from initial work packet
[13:40:15]
[13:40:15] Project: 6526 (Run 5, Clone 76, Gen 22)
[13:40:15]
[13:40:15] Entering M.D.
[13:40:22] Protein: proA_6 in water
[13:40:22]
[13:40:22] Writing local files
[13:40:23] Completed 0 out of 250000 steps  (0%)
[13:52:46] Writing local files
[13:52:48] Completed 2500 out of 250000 steps  (1%)
[18:13:29] Writing local files
[18:13:30] Completed 55000 out of 250000 steps  (22%)
[18:15:14] Sending work to server
[18:15:14] Project: 6526 (Run 5, Clone 76, Gen 22)
[18:15:14] - Error: Could not get length of results file work/wuresults_07.dat
[18:15:14] - Error: Could not read unit 07 file. Removing from queue.
[18:15:14] Trying to send all finished work units
[18:15:14] + No unsent completed units remaining.
[18:15:14] - Preparing to get new work unit...
Re: Project: 6526 (Run 5, Clone 76, Gen 22)
That sort of error can be caused by an over-zealous anti-virus program. Have you excluded the \work directory from your virus scans?
I also suggest you add the parameter -forceasm to your client.
Tobit
Post by Tobit »
bruce wrote:That sort of error can be caused by an over-zealous anti-virus program. Have you excluded the \work directory from your virus scans?
This is a Linux box, very minimal installation with almost nothing but essential functions for running F@H.. definitely no antivirus.
I forgot about the -forceasm flag on the Linux unified client for classic work, will get that added.
sortofageek
Post by sortofageek »
The WU (P6526,R5,C76,G22) has been reported as a bad WU.
