Subject says it all. Projects 10300 thru 10308 are not currently listed. Server communication issues?
Details for them are HERE.
Projects 10300 - 10308 missing from Project Summary
codysluder
Re: Projects 10300 - 10308 missing from Project Summary
Are you sure those projects are actively being assigned? When a server goes down or a project is suspended for some reason, they stop being on psummary. (You can still be running a WU from that project which was assigned before the server went down.)
Yes, I've done several of them over the last week. Last one was assigned yesterday. HFM has no benchmarks for any of them, which would indicate that they were never in Project Summary.
Server (171.67.108.38) appears to have been up since November. Server Log
This was also reported HERE.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
re: the reference to my posting when I received the work unit at about 5pm PST on Sunday 12 December. http://foldingforum.org/viewtopic.php?f=19&t=17020
Short form answer to codysluder: this WU was just assigned on Sunday 12 Dec PST, and the client finished and normally uploaded the results in just under 10 hours. I have two classic CPU clients on different machines, and my HFM log doesn't show any of the Projects 10300 - 10308 WUs since I started in June 2010.
Here's an amplified extract from the HFM Work Unit History (amplified to include some of the column headers).
It finished in 9 hours, 42 minutes, netting about 160 ppd for that work unit, a record for this classic client secondary to a GPU client in a P4 uniprocessor environment. F@H credited me with the full 145 points.
Besides the project not being in the project summary and not being in the projectinfo.tab file that HFM seems to use to "fill in the blanks" for project metadata, my F@H official statistics seems to have come in with an additional client about the time this WU was completed and uploaded. That's curious since this WU is in a normal queue position, and the local log is showing this as my 29th WU (I just started folding with this classic client about a month ago when I no longer had to worry about the classic client stealing cpu cycles and PPD from my ATI GPU client. The CPU client coexists excellently with the 511 point GPU WUs, but absolutely clobbered the GPU PPD results when the 384 point WUs were being served).
Finally, I've pulled out of the server log salient info from around the time the WU was assigned to me. The curious thing (to an un-initiated me) from the log are the "WUs AVAIL", "WUs to go", "WUs WAIT" fields. in each row, these all have the same value, and very small values (ranging from 101 to 66). Maybe there were some test WUs that just got loose??
[22:41:21] + Attempting to send results [December 13 22:41:21 UTC]
[22:41:21] - Reading file work/wuresults_00.dat from core
[22:41:21] (Read 4240207 bytes from disk)
[22:41:21] Connecting to http://171.67.108.38:8080/
[22:41:31] Posted data.
[22:41:31] Initial: 0000; - Uploaded at ~414 kB/s
[22:41:31] - Averaged speed for that direction ~387 kB/s
[22:41:31] + Results successfully sent
[22:41:31] Thank you for your contribution to Folding@Home.
[22:41:31] + Number of Units Completed: 29
HFM Log Extract
Project: 10306 GreyWhiskers Client type: Unknown Core: 1.91 TPF: 00:12:59 Credit: 0 PPD: 0.0 Download (UTC) : 12/13/2010 12:59 AM Completion date (UTC) 12/13/2010 10:41 PM FinishedUnit Atoms: 0 4 6 58
Extract from [url]http://fah-web.stanford.edu/logs/171.67.108.38.log.html[/url] just before this WU was assigned to me.
Sun Dec 12 23:25:10 PST 2010 171.67.108.38 classic vsp08b dsglazer full Accepting 0.01 3 0 72 26813 21514 0 0 101 101 101 - - - - 6 0 - - 1 - - 0 1 LW; ; 1; 4; - 5000; 64; - - ; A; 80; - - - - 0 dsglazer 1 vsp08b
Sun Dec 12 23:50:10 PST 2010 171.67.108.38 classic vsp08b dsglazer full Accepting 0.02 1 0 157 26813 21514 0 0 66 66 66 5 - - - 0 0 - - 1 - - 0 1 LW; ; 1; 4; - 5000; 64; - - ; A; 80; - - - - 0 dsglazer 1 vsp08b
Mon Dec 13 00:15:10 PST 2010 171.67.108.38 classic vsp08b dsglazer full Accepting 0.01 1 0 157 26813 21514 -1 0 68 68 68 - - - - 3 0 - - 1 - - 0 1 LW; ; 1; 4; - 5000; 64; - - ; A; 80; - - - - 0 dsglazer 1 vsp08b
Mon Dec 13 00:40:10 PST 2010 171.67.108.38 classic vsp08b dsglazer full Accepting 0.02 1 0 157 26813 21514 0 0 69 69 69 - - - - 3 0 - - 1 - - 0 1 LW; ; 1; 4; - 5000; 64; - - ; A; 80; - - - - 0 dsglazer 1 vsp08b
Mon Dec 13 01:05:10 PST 2010 171.67.108.38 classic vsp08b dsglazer full Accepting 0.03 5 0 157 26813 21514 0 0 72 72 72 - - - - 4 0 - - 1 - - 0 1 LW; ; 1; 4; - 5000; 64; - - ; A; 80; - - - - 0 dsglazer 1 vsp08b
