I was just assigned Project: 10306 (Run 4, Clone 6, Gen 58) for my classic uniprocessor client. HFM can't find the project description in the projectinfo.tab file, so can't give me stats on the WU.
This project has an excellent description at http://fah-web.stanford.edu/cgi-bin/fah ... ed?p=10306, but doesn't seem to be in the ProjectInfo.tab file, so HFM doesn't know how many points to assign, or how many PPD are being generated.
There is no issue with the work unit. My processor is happily beavering away with 12:10 TPF, so that given a 145 point WU value, per the project description, this seems one of the most efficient WUs on my old HP rig (I'm running a classic client on the P4 3.2 GHz single core HT CPU secondary to a GPU client supporting my ATI 4760 AGP GPU). I typically get ~1230 PPD on the GPU client, and ~78 PPD on the CPU client.
							P10306 (Run 4, Clone 6, Gen 58) Not in ProjectInfo.tab
				GreyWhiskers
 --i7 2600K@4.2 GHz
 --ASUS P8P67 DeluxeB3
 --4GB ADATA 1600 RAM
 --750W Corsair PS
 --MSI GTX560Ti @900MHz
				sortofageek
Re: P10306 (Run 4, Clone 6, Gen 58) Not in ProjectInfo.tab
This appears to be a 145-point WU, judging by what I see in the database.
As none of the 103XX projects are showing up in the Project Summary, this looks like a server issue.
viewtopic.php?f=18&t=17029
