Amaruk
Posts: 254 Joined: Fri Jun 20, 2008 3:57 am
Post
by Amaruk » Sat Dec 11, 2010 7:40 am
Died in six seconds. UNKNOWN_ERROR, CoreStatus = 79 (121), Client-core communications error: ERROR 0x79
This was the fifth attempt before changing MID:
--- Opening Log file [December 10 10:41:30 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Chow\Application Data\Folding@home-x86
[10:43:10] - Ask before connecting: No
[10:43:10] - User name: Amaruk (Team 50625)
[10:43:10] - User ID: 2D76848CXXXXXXXX
[10:43:10] - Machine ID: 1
[10:43:10]
[10:43:10] Work directory not found. Creating...
[10:43:10] Could not open work queue, generating new queue...
[10:43:11] Initialization complete
[10:43:11] - Preparing to get new work unit...
[10:43:11] + Attempting to get work packet
[10:43:11] - Autosending finished units... [December 10 10:43:11 UTC]
[10:43:11] Trying to send all finished work units
[10:43:11] + No unsent completed units remaining.
[10:43:11] - Autosend completed
[10:43:11] - Will indicate memory of 1023 MB
[10:43:11] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[10:43:11] - Connecting to assignment server
[10:43:11] Connecting to http://assign.stanford.edu:8080/
[10:43:11] Posted data.
[10:43:11] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[10:43:11] + News From Folding@Home: Welcome to Folding@Home
[10:43:11] Loaded queue successfully.
[10:43:11] Connecting to http://171.64.65.62:8080/
[10:43:12] Posted data.
[10:43:12] Initial: 0000; - Receiving payload (expected size: 412411)
[10:43:13] - Downloaded at ~402 kB/s
[10:43:13] - Averaged speed for that direction ~402 kB/s
[10:43:13] + Received work.
[10:43:13] + Closed connections
[10:43:13]
[10:43:13] + Processing work unit
[10:43:13] Core required: FahCore_78.exe
[10:43:13] Core not found.
[10:43:13] - Core is not present or corrupted.
[10:43:13] - Attempting to download new core...
[10:43:13] + Downloading new core: FahCore_78.exe
[10:43:13] Downloading core (/~pande/Win32/x86/Core_78.fah from www.stanford.edu)
[10:43:13] Initial: AFDE; + 10240 bytes downloaded
<SNIP>
[10:43:13] Initial: C1AC; + 825633 bytes downloaded
[10:43:13] Verifying core Core_78.fah...
[10:43:13] Signature is VALID
[10:43:13]
[10:43:13] Trying to unzip core FahCore_78.exe
[10:43:14] Decompressed FahCore_78.exe (2338816 bytes) successfully
[10:43:19] + Core successfully engaged
[10:43:24]
[10:43:24] + Processing work unit
[10:43:24] Core required: FahCore_78.exe
[10:43:24] Core found.
[10:43:24] Working on queue slot 01 [December 10 10:43:24 UTC]
[10:43:24] + Working ...
[10:43:24] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 417236 -version 623'
[10:43:27]
[10:43:27] *------------------------------*
[10:43:27] Folding@Home Gromacs Core
[10:43:27] Version 1.90 (March 8, 2006)
[10:43:27]
[10:43:27] Preparing to commence simulation
[10:43:27] - Looking at optimizations...
[10:43:27] - Created dyn
[10:43:27] - Files status OK
[10:43:28] - Expanded 411899 -> 2807325 (decompressed 681.5 percent)
[10:43:28] - Starting from initial work packet
[10:43:28]
[10:43:28] Project: 6507 (Run 18, Clone 160, Gen 37)
[10:43:28]
[10:43:28] Assembly optimizations on if available.
[10:43:28] Entering M.D.
[10:43:34] Gromacs error.
[10:43:34]
[10:43:34] Folding@home Core Shutdown: UNKNOWN_ERROR
[10:43:38] CoreStatus = 79 (121)
[10:43:38] Client-core communications error: ERROR 0x79
[10:43:38] This is a sign of more serious problems, shutting down.
sortofageek
Posts: 3110 Joined: Fri Nov 30, 2007 8:06 pm
Post
by sortofageek » Sat Dec 11, 2010 10:02 am
Thanks for the report. So far, no data back from a query of the database, but we'll keep an eye on it and let you know if we see something conclusive either way.
Amaruk
Post
by Amaruk » Sat Dec 11, 2010 10:23 pm
Thank you for checking. Initially assigned on December 9 at 16:24:37 UTC, so 18 day preferred should put reassign on/near the 27th.
Did made one final attempt to fold this WU. Same result.
--- Opening Log file [December 10 10:44:33 UTC]
[10:45:24] - Ask before connecting: No
[10:45:24] - User name: Amaruk (Team 50625)
[10:45:24] - User ID: 2D76848CXXXXXXXX
[10:45:24] - Machine ID: 2
[10:45:24]
[10:45:24] Work directory not found. Creating...
[10:45:24] Could not open work queue, generating new queue...
[10:45:24] Initialization complete
[10:45:24] - Preparing to get new work unit...
[10:45:24] + Attempting to get work packet
[10:45:24] - Autosending finished units... [December 10 10:45:24 UTC]
[10:45:24] Trying to send all finished work units
[10:45:24] + No unsent completed units remaining.
[10:45:24] - Autosend completed
[10:45:24] - Will indicate memory of 1023 MB
[10:45:24] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[10:45:24] - Connecting to assignment server
[10:45:24] Connecting to http://assign.stanford.edu:8080/
[10:45:25] Posted data.
[10:45:25] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[10:45:25] + News From Folding@Home: Welcome to Folding@Home
[10:45:25] Loaded queue successfully.
[10:45:25] Connecting to http://171.64.65.62:8080/
[10:45:26] Posted data.
[10:45:26] Initial: 0000; - Receiving payload (expected size: 519390)
[10:45:26] Conversation time very short, giving reduced weight in bandwidth avg
[10:45:26] - Downloaded at ~1014 kB/s
[10:45:26] - Averaged speed for that direction ~1014 kB/s
[10:45:26] + Received work.
[10:45:26] + Closed connections
[10:45:26]
[10:45:26] + Processing work unit
[10:45:26] Core required: FahCore_78.exe
[10:45:26] Core not found.
[10:45:26] - Core is not present or corrupted.
[10:45:26] - Attempting to download new core...
[10:45:26] + Downloading new core: FahCore_78.exe
[10:45:26] Downloading core (/~pande/Win32/x86/Core_78.fah from www.stanford.edu)
[10:45:26] Initial: AFDE; + 10240 bytes downloaded
<SNIP>
[10:45:27] Initial: C1AC; + 825633 bytes downloaded
[10:45:27] Verifying core Core_78.fah...
[10:45:27] Signature is VALID
[10:45:27]
[10:45:27] Trying to unzip core FahCore_78.exe
[10:45:28] Decompressed FahCore_78.exe (2338816 bytes) successfully
[10:45:33] + Core successfully engaged
[10:45:38]
[10:45:38] + Processing work unit
[10:45:38] Core required: FahCore_78.exe
[10:45:38] Core found.
[10:45:38] Working on queue slot 01 [December 10 10:45:38 UTC]
[10:45:38] + Working ...
[10:45:38] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 411536 -version 623'
[10:45:41]
[10:45:41] *------------------------------*
[10:45:41] Folding@Home Gromacs Core
[10:45:41] Version 1.90 (March 8, 2006)
[10:45:41]
[10:45:41] Preparing to commence simulation
[10:45:41] - Looking at optimizations...
[10:45:41] - Created dyn
[10:45:41] - Files status OK
[10:45:42] - Expanded 518878 -> 2533093 (decompressed 488.1 percent)
[10:45:42] - Starting from initial work packet
[10:45:42]
[10:45:42] Project: 6503 (Run 17, Clone 482, Gen 46)
[10:45:42]
[10:45:42] Assembly optimizations on if available.
[10:45:42] Entering M.D.
[10:45:49] Protein: TR462_B_18 in water
[10:45:49]
[10:45:49] Writing local files
[10:45:49] Extra SSE boost OK.
[10:45:49] Completed 0 out of 250000 steps (0%)
<SNIP>
[05:03:46] Completed 250000 out of 250000 steps (100%)
[05:03:46] Writing final coordinates.
[05:03:46] Past main M.D. loop
[05:04:47]
[05:04:47] Finished Work Unit:
[05:04:47] - Reading up to 408960 from "work/wudata_01.arc": Read 408960
[05:04:47] - Reading up to 218760 from "work/wudata_01.xtc": Read 218760
[05:04:47] goefile size: 0
[05:04:47] logfile size: 55456
[05:04:47] Leaving Run
[05:04:48] - Writing 751996 bytes of core data to disk...
[05:04:48] Done: 751484 -> 652113 (compressed to 86.7 percent)
[05:04:48] ... Done.
[05:04:49] - Shutting down core
[05:04:49]
[05:04:49] Folding@home Core Shutdown: FINISHED_UNIT
[05:04:51] CoreStatus = 64 (100)
[05:04:51] Unit 1 finished with 96 percent of time to deadline remaining.
[05:04:51] Updated performance fraction: 0.963644
[05:04:51] Sending work to server
[05:04:51] Project: 6503 (Run 17, Clone 482, Gen 46)
[05:04:51] - Read packet limit of 540015616... Set to 524286976.
[05:04:51] + Attempting to send results [December 11 05:04:51 UTC]
[05:04:51] - Reading file work/wuresults_01.dat from core
[05:04:51] (Read 652625 bytes from disk)
[05:04:51] Connecting to http://171.64.65.62:8080/
[05:04:54] Posted data.
[05:04:54] Initial: 0000; - Uploaded at ~212 kB/s
[05:04:54] - Averaged speed for that direction ~212 kB/s
[05:04:54] + Results successfully sent
[05:04:54] Thank you for your contribution to Folding@Home.
[05:04:54] + Starting local stats count at 1
[05:05:00] Trying to send all finished work units
[05:05:00] + No unsent completed units remaining.
[05:05:00] + Closed connections
[05:05:00] + Paused after finishing unit
[05:29:55] ***** Got a SIGTERM signal (2)
[05:29:55] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [December 11 05:41:17 UTC]
Arguments: -advmethods -verbosity 9
[05:41:17] - Ask before connecting: No
[05:41:17] - User name: Amaruk (Team 50625)
[05:41:17] - User ID: 2D76848CXXXXXXXX
[05:41:17] - Machine ID: 1
[05:41:17]
[05:41:17] Loaded queue successfully.
[05:41:17] Initialization complete
[05:41:17] - Preparing to get new work unit...
[05:41:17] + Attempting to get work packet
[05:41:17] - Autosending finished units... [December 11 05:41:17 UTC]
[05:41:17] Trying to send all finished work units
[05:41:17] + No unsent completed units remaining.
[05:41:17] - Autosend completed
[05:41:17] - Will indicate memory of 1023 MB
[05:41:17] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[05:41:17] - Connecting to assignment server
[05:41:17] Connecting to http://assign.stanford.edu:8080/
[05:41:18] Posted data.
[05:41:18] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[05:41:18] + News From Folding@Home: Welcome to Folding@Home
[05:41:18] Loaded queue successfully.
[05:41:18] Connecting to http://171.64.65.62:8080/
[05:41:19] Posted data.
[05:41:19] Initial: 0000; - Receiving payload (expected size: 412411)
[05:41:19] Conversation time very short, giving reduced weight in bandwidth avg
[05:41:19] - Downloaded at ~805 kB/s
[05:41:19] - Averaged speed for that direction ~944 kB/s
[05:41:19] + Received work.
[05:41:19] + Closed connections
[05:41:19]
[05:41:19] + Processing work unit
[05:41:19] Core required: FahCore_78.exe
[05:41:19] Core found.
[05:41:19] Working on queue slot 02 [December 11 05:41:19 UTC]
[05:41:19] + Working ...
[05:41:19] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 417396 -version 623'
[05:41:20]
[05:41:20] *------------------------------*
[05:41:20] Folding@Home Gromacs Core
[05:41:20] Version 1.90 (March 8, 2006)
[05:41:20]
[05:41:20] Preparing to commence simulation
[05:41:20] - Looking at optimizations...
[05:41:20] - Created dyn
[05:41:20] - Files status OK
[05:41:20] - Expanded 411899 -> 2807325 (decompressed 681.5 percent)
[05:41:20] - Starting from initial work packet
[05:41:20]
[05:41:20] Project: 6507 (Run 18, Clone 160, Gen 37)
[05:41:20]
[05:41:20] Assembly optimizations on if available.
[05:41:20] Entering M.D.
[05:41:27] Gromacs error.
[05:41:27]
[05:41:27] Folding@home Core Shutdown: UNKNOWN_ERROR
[05:41:30] CoreStatus = 79 (121)
[05:41:30] Client-core communications error: ERROR 0x79
[05:41:30] This is a sign of more serious problems, shutting down.
On the bright side, AS is functioning as expected.
sortofageek
Post
by sortofageek » Tue Dec 28, 2010 12:39 am
Still nothing, so ...
The WU (P6507,R18,C160,G37) has been reported as a bad WU.
