Server not passing WU
RASMAN
Post by RASMAN »
[12:21:47] + Attempting to send results [December 5 12:21:47 UTC]
[12:21:47] Gpu type=1 species=3.
[12:21:48] - Couldn't send HTTP request to server
[12:21:48] (Got status 503)
[12:21:48] + Could not connect to Work Server (results)
[12:21:48] (171.67.108.17:8080)
[12:21:48] + Retrying using alternative port
[12:21:48] (171.67.108.17:80)
[12:21:48] Could not transmit unit 07 to Collection server; keeping in queue.
[12:22:02] + Attempting to get work packet
[12:22:02] Gpu type=1 species=3.
[12:22:02] - Connecting to assignment server
[12:22:02] + No appropriate work server was available; will try again in a bit.
[12:22:02] + Couldn't get work instructions.
[12:22:02] - Attempt #2 to get work failed, and no other work to do.
Waiting before retry.
[12:22:15] + Attempting to get work packet
[12:22:15] Gpu type=1 species=3.
[12:22:15] - Connecting to assignment server
[12:22:16] + No appropriate work server was available; will try again in a bit.
[12:22:16] + Couldn't get work instructions.
[12:22:16] - Attempt #3 to get work failed, and no other work to do.
Qeldroma
Re: Server not passing WU
Post by Qeldroma »
^^^^ I think my problem is related- and then some.
[13:22:43] Folding@home Core Shutdown: FINISHED_UNIT
[13:22:46] CoreStatus = 64 (100)
[13:22:46] Sending work to server
[13:22:46] Project: 5737 (Run 4, Clone 548, Gen 33)
[13:22:46] + Attempting to send results [December 5 13:22:46 UTC]
[13:22:47] - Couldn't send HTTP request to server
[13:22:47] + Could not connect to Work Server (results)
[13:22:47] (171.64.65.102:8080)
[13:22:47] + Retrying using alternative port
[13:22:48] - Couldn't send HTTP request to server
[13:22:48] + Could not connect to Work Server (results)
[13:22:48] (171.64.65.102:80)
[13:22:48] - Error: Could not transmit unit 01 (completed December 5) to work server.
[13:22:48] Keeping unit 01 in queue.
[13:22:48] Project: 5737 (Run 4, Clone 548, Gen 33)
[13:22:48] + Attempting to send results [December 5 13:22:48 UTC]
[13:22:50] - Couldn't send HTTP request to server
[13:22:50] + Could not connect to Work Server (results)
[13:22:50] (171.64.65.102:8080)
[13:22:50] + Retrying using alternative port
[13:22:51] - Couldn't send HTTP request to server
[13:22:51] + Could not connect to Work Server (results)
[13:22:51] (171.64.65.102:80)
[13:22:51] - Error: Could not transmit unit 01 (completed December 5) to work server.
[13:22:51] + Attempting to send results [December 5 13:22:51 UTC]
[13:22:51] (171.67.108.17:8080)
[13:22:51] + Retrying using alternative port
[13:22:51] (Got status 503)
[13:22:51] (171.67.108.17:80)
[13:22:51] Could not transmit unit 01 to Collection server; keeping in queue.
[13:22:51] - Preparing to get new work unit...
[13:22:51] + Attempting to get work packet
[13:22:51] - Connecting to assignment server
[13:22:51] + No appropriate work server was available; will try again in a bit.
[13:22:51] + Couldn't get work instructions.
[13:22:51] - Attempt #1 to get work failed, and no other work to do.
[13:23:04] + Attempting to get work packet
[13:23:04] - Connecting to assignment server
[13:23:05] + No appropriate work server was available; will try again in a bit.
[13:23:05] + Couldn't get work instructions.
[13:23:05] - Attempt #2 to get work failed, and no other work to do.
[13:23:25] + Attempting to get work packet
[13:23:25] - Connecting to assignment server
[13:23:26] + No appropriate work server was available; will try again in a bit.
[13:23:26] + Couldn't get work instructions.
And still going like this
The server seems to be accepting connection now ... did you see an improvement ?
Qeldroma
Post by Qeldroma »
toTOW wrote:The server seems to be accepting connection now ... did you see an improvement ?
Yes, thank you.
