Note: I'm still running v7.1.21 on my uniprocessor laptop that this report is from.
Odd sequence for several reasons:
1. The PRCG is old - I was surprised to see there already was a thread for this exact WU from Dec 2010, with a note from Jan 2011.
2. After normal v7 download of this WU at 99% of the previous WU, and start of this WU at the finish of the previous, it went into four "Gromacs error -- UNKNOWN ERROR" loops
3. It wasn't an immediate error - there are 6 seconds between "Entering MD" and the "UNKNOWN ERROR"
4. Reported the "Too many errors" message. There have been several other references to this error in the forum
5. Reported the "Work server too old for fail report". This has been reported before - latest report on 21 April. One of my own forum posts on a totally unrelated issue from 7 April on starting multiple FAH Console and Clients included this message in its log
6. Reported the "FahCore type in core package seems to be in wrong byte order" error - this also has hit the forum several times, mostly it seems in relation to the multiple GPU issues
7. After this sequence, terminating with attempting to load a new core 78, it started the "Project: 6508 (Run 2, Clone 240, Gen 94)", and is happily folding at 36%
The old laptop has been pretty stable. The error occurred at 4:27am local time when no one was on it and the room was pretty cool - low to mid 60s (deg F). I haven't seen any thermal problems - with my laptop cooler, the CPU temp runs 70-78 deg C.
I can't see anything actionable on my own part right now - should I be doing something?
11:19:39:Unit 00:Entering M.D.
11:19:45:Unit 00:Gromacs error.
11:19:45:Unit 00:
11:19:45:Unit 00:Folding@home Core Shutdown: UNKNOWN_ERROR
11:19:45:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
11:20:03:Unit 00:Entering M.D.
11:20:09:Unit 00:Gromacs error.
11:20:09:Unit 00:
11:20:09:Unit 00:Folding@home Core Shutdown: UNKNOWN_ERROR
11:20:09:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
11:21:03:Unit 00:Entering M.D.
11:21:09:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
11:22:22:Starting Unit 00
11:25:19:Unit 00:Entering M.D.
11:25:25:Unit 00:Gromacs error.
11:25:25:Unit 00:
11:25:25:Unit 00:Folding@home Core Shutdown: UNKNOWN_ERROR
11:25:26:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
11:25:26:
WARNING: Unit 00 Too many errors, failing
11:25:27:Sending unit results: id:00 state:SEND project:6505 run:2 clone:57 gen:85 core:0x78 unit:0x196ad5c54dce63420055003900021969
11:25:27:WARNING: Work server too old for fail report, dumping
11:25:27:Cleaning up Unit 00
11:25:28:Connecting to assign3.stanford.edu:8080
11:25:29:News: Welcome to Folding@Home
11:25:29:Assigned to work server 171.64.65.62
11:25:29:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
11:25:29:Connecting to 171.64.65.62:8080
11:25:30:Slot 00: Downloading 467.30KiB
11:25:31:Slot 00: Download complete
11:25:31:Received Unit: id:00 state:DOWNLOAD project:6508 run:2 clone:240 gen:94 core:0x78 unit:0x0b3082f04dce66ab005e00f00002196c
11:27:04:Downloading core from
http://www.stanford.edu/~pande/Win32/x86/Core_78.fah
11:27:04:Connecting to
http://www.stanford.edu:80
11:27:04:WARNING: FahCore type in core package seems to be in wrong byte order.
11:27:04:FahCore 78: Downloading 805.62KiB
11:27:05:FahCore 78: Download complete
11:27:05:Valid core signature
11:27:05:WARNING: FahCore has not changed since last download, aborting core update
11:27:05:Starting Unit 00
11:27:05:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/
www.stanford.edu/~pande/Win32/x86/Core_ ... ore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:27:05:Started core on PID 2608
11:27:05:FahCore 0x78 started
*********************** Log Started 10/May/2011-15:47:15 ***********************
15:47:15:************************* Folding@home Client *************************
15:47:15: Website: http://folding.stanford.edu/
15:47:15: Copyright: (c) 2009,2010 Stanford University
15:47:15: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:47:15: Args: --lifeline 3864
15:47:15: Config: C:/Documents and Settings/Admin/Application
15:47:15: Data/FAHClient/config.xml
15:47:15:******************************** Build ********************************
15:47:15: Version: 7.1.21
15:47:15: Date: Mar 23 2011
15:47:15: Time: 15:13:48
15:47:15: SVN Rev: 2883
15:47:15: Branch: fah/trunk/client
15:47:15: Compiler: Intel(R) C++ MSVC 1500 mode 1110
15:47:15: Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
15:47:15: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
15:47:15: Platform: win32 XP
15:47:15: Bits: 32
15:47:15: Mode: Release
15:47:15:******************************* System ********************************
15:47:15: OS: Microsoft Windows XP Home Edition
15:47:15: CPU: Intel(R) Pentium(R) M processor 1.73GHz
15:47:15: CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
15:47:15: CPUs: 1
15:47:15: Memory: 1.99GiB
15:47:15: Free Memory: 1.17GiB
15:47:15: Threads: WINDOWS_THREADS
15:47:15: GPUs: 0
15:47:15: CUDA: Not detected
15:47:15: On Battery: false
15:47:15: UTC offset: -7
15:47:15: PID: 2576
15:47:15: CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
15:47:15:Win32 Service: false
15:47:15:***********************************************************************
15:47:15:<config>
15:47:15: <service-description v='Folding@home Client'/>
15:47:15: <service-restart v='true'/>
15:47:15: <service-restart-delay v='5000'/>
15:47:15:
15:47:15: <!-- Client Control -->
15:47:15: <cycle-rate v='4'/>
15:47:15: <cycles v='-1'/>
15:47:15: <data-directory v='.'/>
15:47:15: <exec-directory v='C:\Program Files\FAHClient'/>
15:47:15: <exit-when-done v='false'/>
15:47:15: <max-delay v='21600'/>
15:47:15: <min-delay v='60'/>
15:47:15: <threads v='4'/>
15:47:15:
15:47:15: <!-- Configuration -->
15:47:15: <config-rotate v='true'/>
15:47:15: <config-rotate-dir v='configs'/>
15:47:15: <config-rotate-max v='16'/>
15:47:15:
15:47:15: <!-- Debugging -->
15:47:15: <assignment-servers>
15:47:15: assign3.stanford.edu:8080 assign4.stanford.edu:80
15:47:15: </assignment-servers>
15:47:15: <capture-directory v='capture'/>
15:47:15: <capture-sockets v='false'/>
15:47:15: <debug-sockets v='false'/>
15:47:15: <exception-locations v='true'/>
15:47:15: <gpu-assignment-servers>
15:47:15: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
15:47:15: </gpu-assignment-servers>
15:47:15: <stack-traces v='false'/>
15:47:15:
15:47:15: <!-- Error Handling -->
15:47:15: <max-slot-errors v='5'/>
15:47:15: <max-unit-errors v='5'/>
15:47:15:
15:47:15: <!-- FahCore Control -->
15:47:15: <checkpoint v='15'/>
15:47:15: <core-dir v='cores'/>
15:47:15: <core-priority v='idle'/>
15:47:15: <cpu-affinity v='false'/>
15:47:15: <cpu-usage v='100'/>
15:47:15: <no-assembly v='false'/>
15:47:15:
15:47:15: <!-- Folding Slot Configuration -->
15:47:15: <client-subtype v='STDCLI'/>
15:47:15: <client-type v='normal'/>
15:47:15: <cpu-species v='X86_PENTIUM_II'/>
15:47:15: <cpu-type v='X86'/>
15:47:15: <cpus v='1'/>
15:47:15: <extra-core-args v='-forceasm'/>
15:47:15: <gpu v='false'/>
15:47:15: <gpu-id v='0'/>
15:47:15: <max-packet-size v='normal'/>
15:47:15: <os-species v='WIN_XP'/>
15:47:15: <os-type v='WIN32'/>
15:47:15: <project-key v='0'/>
15:47:15: <smp v='false'/>
15:47:15:
15:47:15: <!-- Logging -->
15:47:15: <log v='log.txt'/>
15:47:15: <log-color v='false'/>
15:47:15: <log-crlf v='true'/>
15:47:15: <log-date v='false'/>
15:47:15: <log-debug v='true'/>
15:47:15: <log-domain v='false'/>
15:47:15: <log-header v='true'/>
15:47:15: <log-level v='true'/>
15:47:15: <log-no-info-header v='true'/>
15:47:15: <log-redirect v='false'/>
15:47:15: <log-rotate v='true'/>
15:47:15: <log-rotate-dir v='logs'/>
15:47:15: <log-rotate-max v='16'/>
15:47:15: <log-short-level v='false'/>
15:47:15: <log-simple-domains v='true'/>
15:47:15: <log-thread-id v='false'/>
15:47:15: <log-time v='true'/>
15:47:15: <log-to-screen v='true'/>
15:47:15: <log-truncate v='false'/>
15:47:15: <verbosity v='5'/>
15:47:15:
15:47:15: <!-- Process Control -->
15:47:15: <child v='false'/>
15:47:15: <daemon v='false'/>
15:47:15: <pid v='false'/>
15:47:15: <pid-file v='Folding@home Client.pid'/>
15:47:15: <respawn v='false'/>
15:47:15: <service v='false'/>
15:47:15:
15:47:15: <!-- Remote Command Server -->
15:47:15: <command-address v='0.0.0.0'/>
15:47:15: <command-allow v='127.0.0.1'/>
15:47:15: <command-allow-no-pass v='127.0.0.1'/>
15:47:15: <command-deny v='0.0.0.0/0'/>
15:47:15: <command-deny-no-pass v='0.0.0.0/0'/>
15:47:15: <command-port v='36330'/>
15:47:15: <password v=''/>
15:47:15:
15:47:15: <!-- Slot Control -->
15:47:15: <max-shutdown-wait v='60'/>
15:47:15: <pause-on-battery v='true'/>
15:47:15: <pause-on-start v='false'/>
15:47:15:
15:47:15: <!-- User Information -->
15:47:15: <machine-id v='0'/>
15:47:15: <passkey v='********************************'/>
15:47:15: <team v='0'/>
15:47:15: <user v='GreyWhiskers'/>
15:47:15:
15:47:15: <!-- Work Unit Control -->
15:47:15: <dump-after-deadline v='true'/>
15:47:15: <max-queue v='16'/>
15:47:15: <max-units v='0'/>
15:47:15: <next-unit-percentage v='99'/>
15:47:15:
15:47:15: <!-- Folding Slots -->
15:47:15: <slot id='0' type='UNIPROCESSOR'>
15:47:15: <client-type v='advanced'/>
15:47:15: </slot>
15:47:15:</config>
SNIP
19:37:29:Saving configuration to config.xml
19:37:29:<config>
19:37:29: <!-- Folding Slot Configuration -->
19:37:29: <extra-core-args v='-forceasm'/>
19:37:29: <smp v='false'/>
19:37:29:
19:37:29: <!-- Logging -->
19:37:29: <verbosity v='4'/>
19:37:29:
19:37:29: <!-- Remote Command Server -->
19:37:29: <password v=''/>
19:37:29:
19:37:29: <!-- Slot Control -->
19:37:29: <pause-on-battery v='true'/>
19:37:29:
19:37:29: <!-- User Information -->
19:37:29: <passkey v='********************************'/>
19:37:29: <user v='GreyWhiskers'/>
19:37:29:
19:37:29: <!-- Folding Slots -->
19:37:29: <slot id='0' type='UNIPROCESSOR'>
19:37:29: <client-type v='advanced'/>
19:37:29: </slot>
19:37:29:</config>
SNIP
11:03:22:Unit 01:Writing local files
11:03:22:Unit 01:Completed 245000 out of 250000 steps (98%)
11:10:56:Unit 01:Writing local files
11:10:56:Unit 01:Completed 247500 out of 250000 steps (99%)
11:10:56:Connecting to assign3.stanford.edu:8080
11:10:56:News: Welcome to Folding@Home
11:10:56:Assigned to work server 171.64.65.62
11:10:56:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
11:10:56:Connecting to 171.64.65.62:8080
11:10:57:Slot 00: Downloading 495.18KiB
11:10:57:Slot 00: Download complete
11:10:57:Received Unit: id:00 state:DOWNLOAD project:6505 run:2 clone:57 gen:85 core:0x78 unit:0x196ad5c54dce63420055003900021969
11:18:31:Unit 01:Writing local files
11:18:31:Unit 01:Completed 250000 out of 250000 steps (100%)
11:18:31:Unit 01:Writing final coordinates.
11:18:32:Unit 01:Past main M.D. loop
11:19:32:Unit 01:
11:19:32:Unit 01:Finished Work Unit:
11:19:32:Unit 01:- Reading up to 322680 from "01/wudata_01.arc": Read 322680
11:19:32:Unit 01:- Reading up to 152548 from "01/wudata_01.xtc": Read 152548
11:19:32:Unit 01:goefile size: 0
11:19:32:Unit 01:logfile size: 59474
11:19:32:Unit 01:Leaving Run
11:19:37:Unit 01:- Writing 602698 bytes of core data to disk...
11:19:37:Unit 01:Done: 602186 -> 512379 (compressed to 85.0 percent)
11:19:37:Unit 01: ... Done.
11:19:37:Unit 01:- Shutting down core
11:19:37:Unit 01:
11:19:37:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
11:19:37:FahCore running Unit 01 returned: FINISHED_UNIT (100)
11:19:38:Sending unit results: id:01 state:SEND project:6500 run:15 clone:141 gen:88 core:0x78 unit:0x354007bf4dcda99c0058008d000f1964
11:19:38:Starting Unit 00
11:19:38:Unit 01: Uploading 500.87KiB
11:19:38:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:19:38:Connecting to 171.64.65.62:8080
11:19:38:Started core on PID 5476
11:19:38:FahCore 0x78 started
11:19:38:Unit 00:
11:19:38:Unit 00:*------------------------------*
11:19:38:Unit 00:Folding@Home Gromacs Core
11:19:38:Unit 00:Version 1.90 (March 8, 2006)
11:19:38:Unit 00:
11:19:38:Unit 00:Preparing to commence simulation
11:19:38:Unit 00:- Assembly optimizations manually forced on.
11:19:38:Unit 00:- Not checking prior termination.
11:19:38:Unit 00:- Expanded 506550 -> 2495429 (decompressed 492.6 percent)
11:19:38:Unit 00:- Starting from initial work packet
11:19:39:Unit 00:
11:19:39:Unit 00:Project: 6505 (Run 2, Clone 57, Gen 85)
11:19:39:Unit 00:
11:19:39:Unit 00:Assembly optimizations on if available.
11:19:40:Unit 01: Upload complete
11:19:40:Server responded WORK_ACK (400)
11:19:40:Cleaning up Unit 01
11:19:45:Unit 00:
11:19:45:Starting Unit 00
11:19:45:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:19:45:Started core on PID 5236
11:19:45:FahCore 0x78 started
11:19:46:Unit 00:
11:19:46:Unit 00:*------------------------------*
11:19:46:Unit 00:Folding@Home Gromacs Core
11:19:46:Unit 00:Version 1.90 (March 8, 2006)
11:19:46:Unit 00:
11:19:46:Unit 00:Preparing to commence simulation
11:19:46:Unit 00:- Ensuring status. Please wait.
11:20:02:Unit 00:- Assembly optimizations manually forced on.
11:20:02:Unit 00:- Not checking prior termination.
11:20:03:Unit 00:- Expanded 506550 -> 2495429 (decompressed 492.6 percent)
11:20:03:Unit 00:- Starting from initial work packet
11:20:03:Unit 00:
11:20:03:Unit 00:Project: 6505 (Run 2, Clone 57, Gen 85)
11:20:03:Unit 00:
11:20:03:Unit 00:Assembly optimizations on if available.
11:20:09:Unit 00:
11:20:45:Starting Unit 00
11:20:45:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:20:45:Started core on PID 1296
11:20:45:FahCore 0x78 started
11:20:46:Unit 00:
11:20:46:Unit 00:*------------------------------*
11:20:46:Unit 00:Folding@Home Gromacs Core
11:20:46:Unit 00:Version 1.90 (March 8, 2006)
11:20:46:Unit 00:
11:20:46:Unit 00:Preparing to commence simulation
11:20:46:Unit 00:- Ensuring status. Please wait.
11:21:03:Unit 00:- Assembly optimizations manually forced on.
11:21:03:Unit 00:- Not checking prior termination.
11:21:03:Unit 00:- Expanded 506550 -> 2495429 (decompressed 492.6 percent)
11:21:03:Unit 00:- Starting from initial work packet
11:21:03:Unit 00:
11:21:03:Unit 00:Project: 6505 (Run 2, Clone 57, Gen 85)
11:21:03:Unit 00:
11:21:03:Unit 00:Assembly optimizations on if available.
11:22:22:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:22:23:Started core on PID 5416
11:22:23:FahCore 0x78 started
11:22:23:Unit 00:
11:22:23:Unit 00:*------------------------------*
11:22:23:Unit 00:Folding@Home Gromacs Core
11:22:23:Unit 00:Version 1.90 (March 8, 2006)
11:22:23:Unit 00:
11:22:23:Unit 00:Preparing to commence simulation
11:22:23:Unit 00:- Ensuring status. Please wait.
11:22:40:Unit 00:- Assembly optimizations manually forced on.
11:22:40:Unit 00:- Not checking prior termination.
11:22:40:Unit 00:- Expanded 506550 -> 2495429 (decompressed 492.6 percent)
11:22:40:Unit 00:- Starting from initial work packet
11:22:40:Unit 00:
11:22:40:Unit 00:Project: 6505 (Run 2, Clone 57, Gen 85)
11:22:40:Unit 00:
11:22:40:Unit 00:Assembly optimizations on if available.
11:22:40:Unit 00:Entering M.D.
11:22:46:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
11:25:00:Starting Unit 00
11:25:00:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:25:00:Started core on PID 1416
11:25:00:FahCore 0x78 started
11:25:01:Unit 00:
11:25:01:Unit 00:*------------------------------*
11:25:01:Unit 00:Folding@Home Gromacs Core
11:25:01:Unit 00:Version 1.90 (March 8, 2006)
11:25:01:Unit 00:
11:25:01:Unit 00:Preparing to commence simulation
11:25:01:Unit 00:- Ensuring status. Please wait.
11:25:18:Unit 00:- Assembly optimizations manually forced on.
11:25:18:Unit 00:- Not checking prior termination.
11:25:18:Unit 00:- Expanded 506550 -> 2495429 (decompressed 492.6 percent)
11:25:18:Unit 00:- Starting from initial work packet
11:25:19:Unit 00:
11:25:19:Unit 00:Project: 6505 (Run 2, Clone 57, Gen 85)
11:25:19:Unit 00:
11:25:19:Unit 00:Assembly optimizations on if available.
11:25:25:Unit 00:
11:25:26:WARNING: Unit 00 Too many errors, failing
11:27:04:Downloading core from http://www.stanford.edu/~pande/Win32/x86/Core_78.fah
11:27:04:Connecting to www.stanford.edu:80
11:27:05:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
11:27:06:Unit 00:
11:27:06:Unit 00:*------------------------------*
11:27:06:Unit 00:Folding@Home Gromacs Core
11:27:06:Unit 00:Version 1.90 (March 8, 2006)
11:27:06:Unit 00:
11:27:06:Unit 00:Preparing to commence simulation
11:27:06:Unit 00:- Assembly optimizations manually forced on.
11:27:06:Unit 00:- Not checking prior termination.
11:27:06:Unit 00:- Expanded 478005 -> 2355081 (decompressed 492.6 percent)
11:27:06:Unit 00:- Starting from initial work packet
11:27:06:Unit 00:
11:27:06:Unit 00:Project: 6508 (Run 2, Clone 240, Gen 94)
11:27:06:Unit 00:
11:27:07:Unit 00:Assembly optimizations on if available.
11:27:07:Unit 00:Entering M.D.
11:27:13:Unit 00:Protein: proG_3 in water
11:27:13:Unit 00:
11:27:13:Unit 00:Writing local files
11:27:13:Unit 00:Extra SSE boost OK.
11:27:14:Unit 00:Writing local files
11:27:15:Unit 00:Completed 0 out of 250000 steps (0%)
11:37:43:Unit 00:Writing local files
11:37:43:Unit 00:Completed 2500 out of 250000 steps (1%)
11:46:55:Unit 00:Writing local files
11:46:55:Unit 00:Completed 5000 out of 250000 steps (2%)
11:55:55:Unit 00:Writing local files
11:55:55:Unit 00:Completed 7500 out of 250000 steps (3%)
12:04:58:Unit 00:Writing local files
12:04:58:Unit 00:Completed 10000 out of 250000 steps (4%)
12:13:59:Unit 00:Writing local files
12:13:59:Unit 00:Completed 12500 out of 250000 steps (5%)
12:23:01:Unit 00:Writing local files
12:23:01:Unit 00:Completed 15000 out of 250000 steps (6%)
12:32:03:Unit 00:Writing local files
12:32:03:Unit 00:Completed 17500 out of 250000 steps (7%)
12:41:03:Unit 00:Writing local files
12:41:03:Unit 00:Completed 20000 out of 250000 steps (8%)
12:50:05:Unit 00:Writing local files
12:50:05:Unit 00:Completed 22500 out of 250000 steps (9%)
12:59:05:Unit 00:Writing local files
12:59:05:Unit 00:Completed 25000 out of 250000 steps (10%)
13:08:08:Unit 00:Writing local files
13:08:08:Unit 00:Completed 27500 out of 250000 steps (11%)
13:17:11:Unit 00:Writing local files
13:17:11:Unit 00:Completed 30000 out of 250000 steps (12%)
13:26:11:Unit 00:Writing local files
13:26:11:Unit 00:Completed 32500 out of 250000 steps (13%)
13:35:13:Unit 00:Writing local files
13:35:13:Unit 00:Completed 35000 out of 250000 steps (14%)
13:44:15:Unit 00:Writing local files
13:44:15:Unit 00:Completed 37500 out of 250000 steps (15%)
13:53:17:Unit 00:Writing local files
13:53:17:Unit 00:Completed 40000 out of 250000 steps (16%)
14:02:19:Unit 00:Writing local files
14:02:19:Unit 00:Completed 42500 out of 250000 steps (17%)
14:11:20:Unit 00:Writing local files
14:11:20:Unit 00:Completed 45000 out of 250000 steps (18%)
14:20:22:Unit 00:Writing local files
14:20:22:Unit 00:Completed 47500 out of 250000 steps (19%)
14:29:22:Unit 00:Writing local files
14:29:22:Unit 00:Completed 50000 out of 250000 steps (20%)
14:38:23:Unit 00:Writing local files
14:38:23:Unit 00:Completed 52500 out of 250000 steps (21%)
14:47:31:Unit 00:Writing local files
14:47:31:Unit 00:Completed 55000 out of 250000 steps (22%)
14:56:55:Unit 00:Writing local files
14:56:55:Unit 00:Completed 57500 out of 250000 steps (23%)
15:06:19:Unit 00:Writing local files
15:06:19:Unit 00:Completed 60000 out of 250000 steps (24%)
