Project: 10502 (Run 347, Clone 0, Gen 295) issue
MrCarBuyer
Post by MrCarBuyer »
the log looks like I should get credit but an upload issue seemed to interfere. could it be ISP issue? if so do I just loose out or is there a remidy for credit and points?
Thank you for your attention to this. I am new.
sean
[11:13:25] + Results successfully sent
[11:13:25] Thank you for your contribution to Folding@Home.
[11:13:25] + Number of Units Completed: 18
[11:13:29] - Preparing to get new work unit...
[11:13:29] + Attempting to get work packet
[11:13:29] - Connecting to assignment server
[11:13:29] - Successful: assigned to (171.67.108.21).
[11:13:29] + News From Folding@Home: Welcome to Folding@Home
[11:13:29] Loaded queue successfully.
[11:13:30] + Closed connections
[11:13:30]
[11:13:30] + Processing work unit
[11:13:30] Core required: FahCore_11.exe
[11:13:30] Core found.
[11:13:30] Working on queue slot 02 [December 1 11:13:30 UTC]
[11:13:30] + Working ...
[11:13:30]
[11:13:30] *------------------------------*
[11:13:30] Folding@Home GPU Core
[11:13:30] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[11:13:30]
[11:13:30] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:13:30] Build host: amoeba
[11:13:30] Board Type: Nvidia
[11:13:30] Core      :
[11:13:30] Preparing to commence simulation
[11:13:30] - Looking at optimizations...
[11:13:30] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[11:13:30] - Created dyn
[11:13:30] - Files status OK
[11:13:30] - Expanded 62943 -> 336763 (decompressed 535.0 percent)
[11:13:30] Called DecompressByteArray: compressed_data_size=62943 data_size=336763, decompressed_data_size=336763 diff=0
[11:13:30] - Digital signature verified
[11:13:30]
[11:13:30] Project: 10502 (Run 347, Clone 0, Gen 295)
[11:13:30]
[11:13:30] Assembly optimizations on if available.
[11:13:30] Entering M.D.
[11:13:36] Tpr hash work/wudata_02.tpr:  3044918794 1022887943 489810885 2744521222 121431369
[11:13:36]
[11:13:36] Calling fah_main args: 14 usage=100
[11:13:36]
[11:13:37] Working on Protein
[11:13:38] Client config found, loading data.
[11:13:38] Starting GUI Server
[11:15:32] Completed 1%
[11:17:27] Completed 2%
[11:19:21] Completed 3%
[11:21:16] Completed 4%
[11:23:10] Completed 5%
[11:25:05] Completed 6%
[11:26:59] Completed 7%
[11:28:54] Completed 8%
[11:30:48] Completed 9%
[11:32:43] Completed 10%
[11:34:37] Completed 11%
[11:36:32] Completed 12%
[11:38:26] Completed 13%
[11:40:20] Completed 14%
[11:42:15] Completed 15%
[11:44:09] Completed 16%
[11:46:04] Completed 17%
[11:47:58] Completed 18%
[11:49:53] Completed 19%
[11:51:47] Completed 20%
[11:53:42] Completed 21%
[11:55:36] Completed 22%
[11:57:30] Completed 23%
[11:59:25] Completed 24%
[12:01:19] Completed 25%
[12:03:14] Completed 26%
[12:05:08] Completed 27%
[12:07:02] Completed 28%
[12:08:57] Completed 29%
[12:10:51] Completed 30%
[12:12:46] Completed 31%
[12:14:40] Completed 32%
[12:16:34] Completed 33%
[12:18:29] Completed 34%
[12:20:23] Completed 35%
[12:22:17] Completed 36%
[12:24:12] Completed 37%
[12:26:06] Completed 38%
[12:28:00] Completed 39%
[12:29:55] Completed 40%
[12:31:49] Completed 41%
[12:33:43] Completed 42%
[12:35:37] Completed 43%
[12:37:32] Completed 44%
[12:39:26] Completed 45%
[12:41:21] Completed 46%
[12:43:12] + Working...
[12:43:15] Completed 47%
[12:45:10] Completed 48%
[12:47:04] Completed 49%
[12:48:58] Completed 50%
[12:50:53] Completed 51%
[12:52:47] Completed 52%
[12:54:41] Completed 53%
[12:56:36] Completed 54%
[12:58:30] Completed 55%
[13:00:25] Completed 56%
[13:02:19] Completed 57%
[13:04:13] Completed 58%
[13:06:08] Completed 59%
[13:08:02] Completed 60%
[13:09:57] Completed 61%
[13:11:51] Completed 62%
[13:13:45] Completed 63%
[13:15:40] Completed 64%
[13:17:35] Completed 65%
[13:19:29] Completed 66%
[13:21:24] Completed 67%
[13:23:18] Completed 68%
[13:25:13] Completed 69%
[13:27:07] Completed 70%
[13:29:02] Completed 71%
[13:30:56] Completed 72%
[13:32:51] Completed 73%
[13:34:45] Completed 74%
[13:36:40] Completed 75%
[13:38:34] Completed 76%
[13:40:29] Completed 77%
[13:42:23] Completed 78%
[13:44:18] Completed 79%
[13:46:12] Completed 80%
[13:48:06] Completed 81%
[13:50:01] Completed 82%
[13:51:55] Completed 83%
[13:53:50] Completed 84%
[13:55:44] Completed 85%
[13:57:38] Completed 86%
[13:59:33] Completed 87%
[14:01:27] Completed 88%
[14:03:22] Completed 89%
[14:05:16] Completed 90%
[14:07:10] Completed 91%
[14:09:05] Completed 92%
[14:10:59] Completed 93%
[14:12:54] Completed 94%
[14:14:48] Completed 95%
[14:16:42] Completed 96%
[14:18:37] Completed 97%
[14:20:31] Completed 98%
[14:22:26] Completed 99%
[14:24:20] Completed 100%
[14:24:20] Successful run
[14:24:20] DynamicWrapper: Finished Work Unit: sleep=10000
[14:24:30] Reserved 109388 bytes for xtc file; Cosm status=0
[14:24:30] Allocated 109388 bytes for xtc file
[14:24:30] - Reading up to 109388 from "work/wudata_02.xtc": Read 109388
[14:24:30] Read 109388 bytes from xtc file; available packet space=786321076
[14:24:30] xtc file hash check passed.
[14:24:30] Reserved 21912 21912 786321076 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[14:24:30] Allocated 21912 bytes for arc file
[14:24:30] - Reading up to 21912 from "work/wudata_02.trr": Read 21912
[14:24:30] Read 21912 bytes from arc file; available packet space=786299164
[14:24:30] trr file hash check passed.
[14:24:30] Allocated 560 bytes for edr file
[14:24:30] Read bedfile
[14:24:30] edr file hash check passed.
[14:24:30] Logfile not read.
[14:24:30] GuardedRun: success in DynamicWrapper
[14:24:30] GuardedRun: done
[14:24:30] Run: GuardedRun completed.
[14:24:35] + Opened results file
[14:24:35] - Writing 132372 bytes of core data to disk...
[14:24:35] Done: 131860 -> 130840 (compressed to 99.2 percent)
[14:24:35]   ... Done.
[14:24:35] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[14:24:35] Shutting down core
[14:24:35]
[14:24:35] Folding@home Core Shutdown: FINISHED_UNIT
[14:24:38] CoreStatus = 64 (100)
[14:24:38] Sending work to server
[14:24:38] Project: 10502 (Run 347, Clone 0, Gen 295)
[14:24:38] - Read packet limit of 540015616... Set to 524286976.
[14:24:38] + Attempting to send results [December 1 14:24:38 UTC]
[15:13:02] + Could not connect to Work Server (results)
[15:13:02]     (171.67.108.21:8080)
[15:13:02] + Retrying using alternative port
[15:13:23] - Couldn't send HTTP request to server
[15:13:23] + Could not connect to Work Server (results)
[15:13:23]     (171.67.108.21:80)
[15:13:23] - Error: Could not transmit unit 02 (completed December 1) to work server.
[15:13:23]   Keeping unit 02 in queue.
[15:13:23] Project: 10502 (Run 347, Clone 0, Gen 295)
[15:13:23] - Read packet limit of 540015616... Set to 524286976.
[15:13:23] + Attempting to send results [December 1 15:13:23 UTC]
[15:13:44] - Couldn't send HTTP request to server
[15:13:44] + Could not connect to Work Server (results)
[15:13:44]     (171.67.108.21:8080)
[15:13:44] + Retrying using alternative port
[15:14:05] - Couldn't send HTTP request to server
[15:14:05] + Could not connect to Work Server (results)
[15:14:05]     (171.67.108.21:80)
[15:14:05] - Error: Could not transmit unit 02 (completed December 1) to work server.
[15:14:05] - Read packet limit of 540015616... Set to 524286976.
[15:14:05] + Attempting to send results [December 1 15:14:05 UTC]
[15:14:26] - Couldn't send HTTP request to server
[15:14:26] + Could not connect to Work Server (results)
[15:14:26]     (171.67.108.26:8080)
[15:14:26] + Retrying using alternative port
[15:14:47] - Couldn't send HTTP request to server
[15:14:47] + Could not connect to Work Server (results)
[15:14:47]     (171.67.108.26:80)
[15:14:47]   Could not transmit unit 02 to Collection server; keeping in queue.
[15:14:47] - Preparing to get new work unit...
[15:14:47] + Attempting to get work packet
[15:14:47] - Connecting to assignment server
[15:14:59] + Could not connect to Assignment Server
[15:15:11] + Could not connect to Assignment Server 2
[15:15:11] + Couldn't get work instructions.
[15:15:11] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[15:15:26] + Attempting to get work packet
[15:15:26] - Connecting to assignment server
[15:15:38] + Could not connect to Assignment Server
[15:15:50] + Could not connect to Assignment Server 2
[15:15:50] + Couldn't get work instructions.
[15:15:50] - Attempt #2  to get work failed, and no other work to do.
[15:16:12] + Attempting to get work packet
[15:16:12] - Connecting to assignment server
[15:16:24] + Could not connect to Assignment Server
[15:16:36] + Could not connect to Assignment Server 2
[15:16:36] + Couldn't get work instructions.
[15:16:36] - Attempt #3  to get work failed, and no other work to do.
[15:16:57] + Attempting to get work packet
[15:16:57] - Connecting to assignment server
[15:17:09] + Could not connect to Assignment Server
[15:17:21] + Could not connect to Assignment Server 2
[15:17:21] + Couldn't get work instructions.
[15:17:21] - Attempt #4  to get work failed, and no other work to do.
[15:18:02] + Attempting to get work packet
[15:18:02] - Connecting to assignment server
[15:18:14] + Could not connect to Assignment Server
[15:18:26] + Could not connect to Assignment Server 2
[15:18:26] + Couldn't get work instructions.
[15:18:26] - Attempt #5  to get work failed, and no other work to do.
[15:19:56] + Attempting to get work packet
[15:19:56] - Connecting to assignment server
[15:20:08] + Could not connect to Assignment Server
[15:20:20] + Could not connect to Assignment Server 2
[15:20:20] + Couldn't get work instructions.
[15:20:20] - Attempt #6  to get work failed, and no other work to do.
[15:23:15] + Attempting to get work packet
[15:23:15] - Connecting to assignment server
[15:23:27] + Could not connect to Assignment Server
[15:23:39] + Could not connect to Assignment Server 2
[15:23:39] + Couldn't get work instructions.
[15:23:39] - Attempt #7  to get work failed, and no other work to do.
[15:29:04] + Attempting to get work packet
[15:29:04] - Connecting to assignment server
[15:29:16] + Could not connect to Assignment Server
[15:29:28] + Could not connect to Assignment Server 2
[15:29:28] + Couldn't get work instructions.
[15:29:28] - Attempt #8  to get work failed, and no other work to do.
[15:40:09] + Attempting to get work packet
[15:40:09] - Connecting to assignment server
[15:40:21] + Could not connect to Assignment Server
[15:40:33] + Could not connect to Assignment Server 2
[15:40:33] + Couldn't get work instructions.
[15:40:33] - Attempt #9  to get work failed, and no other work to do.
[16:01:56] + Attempting to get work packet
[16:01:56] - Connecting to assignment server
[16:02:08] + Could not connect to Assignment Server
[16:02:20] + Could not connect to Assignment Server 2
[16:02:20] + Couldn't get work instructions.
[16:02:20] - Attempt #10  to get work failed, and no other work to do.
Baowoulf
Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
Re: Project: 10502 (Run 347, Clone 0, Gen 295) issue
Post by Baowoulf »
Most likely the server was just busy so your client is keeping the finished WU to retry later. A check of the server status using the link at the top of the page shows both servers running smoothly as far as I can tell. You shouldn't run into any problems the client can hold up to 9 completed WU's at any given time while working on another.
It should just retry later and then send the WU and after an hour or so after a stats update you'll get full credit.
It looks like you can't connect to any server ... I'm afraid the problem is on your end ... :(
MrCarBuyer
So how does it work during this time someone else finished the project?
MrCarBuyer
Baowoulf wrote:Most likely the server was just busy so your client is keeping the finished WU to retry later. A check of the server status using the link at the top of the page shows both servers running smoothly as far as I can tell. You shouldn't run into any problems the client can hold up to 9 completed WU's at any given time while working on another.
So just open the client and hope for the best even though it said it cleared all the stats?
MrCarBuyer
Baowoulf wrote:It should just retry later and then send the WU and after an hour or so after a stats update you'll get full credit.
how do i send the WU manualy? (thank you for the NOOB help guys)
You will have to use the -send all flag (Method)
BTW, welcome to the F@H Forum MrCarBuyer
EDIT -> A much easier method is a simple restart of the Client without any need to add any flags or anything.
Baowoulf
Post by Baowoulf »
MrCarBuyer wrote:So just open the client and hope for the best even though it said it cleared all the stats?
I don't know what you mean by cleared. The client can hold completed WU's for resending on the next attempt and work on another WU during that wait. Have you been able to get another WU yet?
MrCarBuyer
Thank you for the "welcome"
I don't know about the points but I have gotten many new WU's since then.
So I decided to try to configure a multi-gpu client since I am running 2 quadro 4600's with dual x5560 CPU's on an SR-2 EVGA Board to try some bigadv's
Having nothing but issues so I guess it's time to post elseware now! :)
MRCB
