Project: 10040 (Run 319, Clone 0, Gen 45)
^w^ing
Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3
Post by ^w^ing »
--- Opening Log file [November 30 08:46:50 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Folding@Home\CPU\Core1
Executable: C:\Folding@Home\CPU\Core1\Folding@Home-Core1.exe
Arguments: -local -forceasm -verbosity 9
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[08:46:50] - Ask before connecting: No
[08:46:50] - User name: ^w^ing (Team 0)
[08:46:50] - User ID:
[08:46:50] - Machine ID: 1
[08:46:50]
[08:46:50] Loaded queue successfully.
[08:46:50]
[08:46:50] - Autosending finished units... [November 30 08:46:50 UTC]
[08:46:50] + Processing work unit
[08:46:50] Trying to send all finished work units
[08:46:50] Core required: FahCore_b4.exe
[08:46:50] + No unsent completed units remaining.
[08:46:50] - Autosend completed
[08:46:50] Core found.
[08:46:50] Working on queue slot 07 [November 30 08:46:50 UTC]
[08:46:50] + Working ...
[08:46:50] - Calling '.\FahCore_b4.exe -dir work/ -suffix 07 -checkpoint 10 -forceasm -verbose -lifeline 2796 -version 623'
[08:46:56] *********************** Log Started 30/Nov/2010 08:46:55 ***********************
[08:46:56] ************************** ProtoMol Folding@Home Core **************************
[08:46:56]   Version: 25
[08:46:56]      Type: 180
[08:46:56]      Core: ProtoMol
[08:46:56]   Website: http://folding.stanford.edu/
[08:46:56] Copyright: (c) 2009 Stanford University
[08:46:56]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:46:56]      Args: -dir work/ -suffix 07 -checkpoint 10 -forceasm -verbose -lifeline
[08:46:56]            2796 -version 623
[08:46:56] ************************************ Build *************************************
[08:46:56]      Date: May 18 2010
[08:46:56]      Time: 23:43:52
[08:46:56]  Revision: 1819
[08:46:56]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:46:56]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:46:56]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:46:56]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[08:46:56]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[08:46:56]  Platform: Windows XP
[08:46:56]      Bits: 32
[08:46:56]      Mode: Release
[08:46:56] ************************************ System ************************************
[08:46:56]        OS: Microsoft Windows Vista Ultimate
[08:46:56]       CPU: Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz
[08:46:56]    CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
[08:46:56]      CPUs: 2 Logical, 1 Physical
[08:46:56]    Memory: 3.00 GB
[08:46:56]   Threads: Windows
[08:46:56] ********************************************************************************
[08:46:56] Project: 10040 (Run 319, Clone 0, Gen 45)
[08:46:56] Unit: 0x000000460001329c4be590a90000013b
[08:46:56] User: 0x00000000000000000000000000000000
[08:46:56] Machine: 1
[08:46:56] Digital signatures verified
[08:46:59] GUI Server started
[08:46:59] Completed 1452300 out of 2000000 steps (72%)
[08:55:49] Completed 1460000 out of 2000000 steps (73%)
[09:13:49] ERROR: ProtoMol ERROR: Corrupt DCD file. Size is 380292, should be >= 386844.
[09:13:49] Saving result file logfile_07.txt
[09:13:49] Saving result file checkpt
[09:13:49] Saving result file checkpt.crc
[09:13:49] Saving result file log.txt
[09:13:49] Saving result file protomol.conf
[09:13:49] Saving result file ww.dcd
[09:13:49] Saving result file ww_exteq_nowater1.9755.pos
[09:13:49] Saving result file ww_exteq_nowater1.9755.vel
[09:13:50] WARNING: While cleaning up: 0: Failed to remove directory '07': boost::filesystem::remove: Proces nemá přístup k souboru, neboť jej právě využívá jiný proces: "07\ww.dcd"
[09:13:50] Folding@home Core Shutdown: BAD_WORK_UNIT
[09:13:53] CoreStatus = 72 (114)
[09:13:53] Sending work to server
[09:13:53] Project: 10040 (Run 319, Clone 0, Gen 45)
[09:13:53] - Read packet limit of 540015616... Set to 524286976.
[09:13:53] + Attempting to send results [November 30 09:13:53 UTC]
[09:13:53] - Reading file work/wuresults_07.dat from core
[09:13:53]   (Read 373647 bytes from disk)
[09:13:53] Connecting to http://129.74.85.15:8080/
[09:14:15] Posted data.
[09:14:15] Initial: 0000; - Uploaded at ~16 kB/s
[09:14:15] - Averaged speed for that direction ~85 kB/s
[09:14:15] + Results successfully sent
Re: Project: 10040 (Run 319, Clone 0, Gen 45)
Two reports of EUE and one success for this WU are in the DB ...
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
so many multiple assignments... one can't help to wonder how "unique" all of his WUs actually are... well in this case it's not so surprising considering the core throws away most of it's units. damn I hate it so much.
I don't understand your hate of reassigning failed work. The WU failed on two computers and succeeded on a third. The whole point of reassigning it is to get it completed and the system worked as designed, accomplishing what it was supposed to accomplish.
What we don't know is why the first two machines failed. Specifically, of those three, what is different about the machine that succeeded? I'm sure everyone would like to eliminate those two failures and go directly to a successful completion.
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
I don't hate reassigning failed work, I hate the protomol core (which is apparently coincidentally causing unnecessary WU multiplication, but thats beside the point really). the only way these units work is when the client isn't ever shut down, which is unacceptable for my laptop and generally unacceptable for a released (non-beta) software. Same thing on my other machines which aren't shutdown/restarted as often so it might be a more rare occurrence, but theres no way I'm letting these units on those. and I just noticed... where the HELL is my rage driven comment on the WU failure? are you pruning my posts now? that might be the last straw for me really. for the record, I said in the first post that this is BS. I let my laptop overnight to meet the short deadline just so it can crap out on me after moving the laptop elsewhere. also mentioned something about blinding rage, even more so now when it disappeared... and don't you dare touch this post!
The inability to restart was fixed in a recent version of the core. Please post your hardware description and the FAHlog showing the failure, starting from the download.
