Project: 2685 (Run 2, Clone 5, Gen 49)
MIBW
Post by MIBW »
Hi guys,
had a new rig folding fine for 11 days, until this unit. Between units I had just rebooted and plugged in a new KVM. Started folding again and got 7 pretty much instant Client-core communications error: ERROR 0xc0000005. Stopped, run memtest and brief Intelburn test, seems fine.
Also had Initial: 0000; - Error: Bad packet type from server, expected work assignment several times.
Unplugged KVM, rebooted, ran my test captured 2686 unit for a bit, no problems, tried FAH with the 2685 again, same problem.
So I changed machine ID, did not delete the unit, (but learnt that changing machine ID has the same effect :( ) and got a 2684 which has just completed two frames.
So it is plausible that bumping the video card etc might have messed something up, but the fact that the 2685 still kept failing under the conditions that a test 2686 and a fresh 2684 can run I thought I would report it just in case.
[00:24:37] Completed 242500 out of 250000 steps  (97%)
[00:35:57] Completed 245000 out of 250000 steps  (98%)
[00:44:27] - Autosending finished units... [November 26 00:44:27 UTC]
[00:44:27] Trying to send all finished work units
[00:44:27] + No unsent completed units remaining.
[00:44:27] - Autosend completed
[00:47:12] Completed 247500 out of 250000 steps  (99%)
[00:58:29] Completed 250000 out of 250000 steps  (100%)
[00:58:41] DynamicWrapper: Finished Work Unit: sleep=10000
[00:58:51]
[00:58:51] Finished Work Unit:
[00:58:51] - Reading up to 52713120 from "work/wudata_05.trr": Read 52713120
[00:58:51] trr file hash check passed.
[00:58:51] - Reading up to 47105568 from "work/wudata_05.xtc": Read 47105568
[00:58:52] xtc file hash check passed.
[00:58:52] edr file hash check passed.
[00:58:52] logfile size: 212719
[00:58:52] Leaving Run
[00:58:52] - Writing 100199347 bytes of core data to disk...
[00:58:53]   ... Done.
[00:59:23] - Shutting down core
[00:59:23]
[00:59:23] Folding@home Core Shutdown: FINISHED_UNIT
[00:59:29] CoreStatus = 64 (100)
[00:59:29] Unit 5 finished with 87 percent of time to deadline remaining.
[00:59:29] Updated performance fraction: 0.868628
[00:59:29] Sending work to server
[00:59:29] Project: 6900 (Run 15, Clone 21, Gen 0)
[00:59:29] + Attempting to send results [November 26 00:59:29 UTC]
[00:59:29] - Reading file work/wuresults_05.dat from core
[00:59:29]   (Read 100199347 bytes from disk)
[00:59:29] Connecting to http://130.237.232.141:8080/
[01:15:59] Posted data.
[01:15:59] Initial: 0000; - Uploaded at ~98 kB/s
[01:16:02] - Averaged speed for that direction ~97 kB/s
[01:16:02] + Results successfully sent
[01:16:02] Thank you for your contribution to Folding@Home.
[01:16:02] + Number of Units Completed: 119
[01:16:09] Trying to send all finished work units
[01:16:09] + No unsent completed units remaining.
[01:16:09] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[01:16:09] Killing all core threads
[01:16:09] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown.
--- Opening Log file [November 26 01:27:55 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: C:\Apps\FAH GPU Tracker V2\SMP
Executable: C:\Apps\FAH GPU Tracker V2\FAH.exe
Arguments: -forceasm -smp -verbosity 9 -bigadv
[01:27:55] - Ask before connecting: No
[01:27:55] - User name: DigitalFX (Team 33)
[01:27:55] - User ID: AE604F034D9882E
[01:27:55] - Machine ID: 8
[01:27:55]
[01:27:55] Loaded queue successfully.
[01:27:55] - Preparing to get new work unit...
[01:27:55] - Autosending finished units... [November 26 01:27:55 UTC]
[01:27:55] Cleaning up work directory
[01:27:55] Trying to send all finished work units
[01:27:55] + No unsent completed units remaining.
[01:27:55] - Autosend completed
[01:28:00] + Attempting to get work packet
[01:28:00] Passkey found
[01:28:00] - Will indicate memory of 12279 MB
[01:28:00] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[01:28:00] - Connecting to assignment server
[01:28:00] Connecting to http://assign.stanford.edu:8080/
[01:28:01] Posted data.
[01:28:01] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:28:01] + News From Folding@Home: Welcome to Folding@Home
[01:28:01] Loaded queue successfully.
[01:28:01] Sent data
[01:28:01] Connecting to http://171.67.108.22:8080/
[01:28:10] Posted data.
[01:28:10] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:29:13] - Downloaded at ~412 kB/s
[01:29:13] - Averaged speed for that direction ~304 kB/s
[01:29:13] + Received work.
[01:29:13] + Closed connections
[01:29:13]
[01:29:13] + Processing work unit
[01:29:13] Core required: FahCore_a3.exe
[01:29:13] Core found.
[01:29:13] Working on queue slot 06 [November 26 01:29:13 UTC]
[01:29:13] + Working ...
[01:29:13] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:29:13]
[01:29:13] *------------------------------*
[01:29:13] Folding@Home Gromacs SMP Core
[01:29:13] Version 2.22 (Mar 12, 2010)
[01:29:13]
[01:29:13] Preparing to commence simulation
[01:29:13] - Assembly optimizations manually forced on.
[01:29:13] - Not checking prior termination.
[01:29:18] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:29:18] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:29:19] - Digital signature verified
[01:29:19]
[01:29:19] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:29:19]
[01:29:19] Assembly optimizations on if available.
[01:29:19] Entering M.D.
[01:29:28] Completed 0 out of 250000 steps  (0%)
[01:29:35] CoreStatus = C0000005 (-1073741819)
[01:29:35] Client-core communications error: ERROR 0xc0000005
[01:29:35] Deleting current work unit & continuing...
[01:29:51] Trying to send all finished work units
[01:29:51] + No unsent completed units remaining.
[01:29:51] - Preparing to get new work unit...
[01:29:51] Cleaning up work directory
[01:29:55] + Attempting to get work packet
[01:29:55] Passkey found
[01:29:55] - Will indicate memory of 12279 MB
[01:29:55] - Connecting to assignment server
[01:29:55] Connecting to http://assign.stanford.edu:8080/
[01:29:56] Posted data.
[01:29:56] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:29:56] + News From Folding@Home: Welcome to Folding@Home
[01:29:56] Loaded queue successfully.
[01:29:56] Sent data
[01:29:56] Connecting to http://171.67.108.22:8080/
[01:30:08] Posted data.
[01:30:08] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:31:19] - Downloaded at ~366 kB/s
[01:31:19] - Averaged speed for that direction ~317 kB/s
[01:31:19] + Received work.
[01:31:19] + Closed connections
[01:31:24]
[01:31:24] + Processing work unit
[01:31:24] Core required: FahCore_a3.exe
[01:31:24] Core found.
[01:31:24] Working on queue slot 07 [November 26 01:31:24 UTC]
[01:31:24] + Working ...
[01:31:24] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:31:24]
[01:31:24] *------------------------------*
[01:31:24] Folding@Home Gromacs SMP Core
[01:31:24] Version 2.22 (Mar 12, 2010)
[01:31:24]
[01:31:24] Preparing to commence simulation
[01:31:24] - Assembly optimizations manually forced on.
[01:31:24] - Not checking prior termination.
[01:31:29] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:31:29] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:31:30] - Digital signature verified
[01:31:30]
[01:31:30] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:31:30]
[01:31:30] Assembly optimizations on if available.
[01:31:30] Entering M.D.
[01:31:38] Completed 0 out of 250000 steps  (0%)
[01:33:07] CoreStatus = C0000005 (-1073741819)
[01:33:07] Client-core communications error: ERROR 0xc0000005
[01:33:07] Deleting current work unit & continuing...
[01:33:23] Trying to send all finished work units
[01:33:23] + No unsent completed units remaining.
[01:33:23] - Preparing to get new work unit...
[01:33:23] Cleaning up work directory
[01:33:28] + Attempting to get work packet
[01:33:28] Passkey found
[01:33:28] - Will indicate memory of 12279 MB
[01:33:28] - Connecting to assignment server
[01:33:28] Connecting to http://assign.stanford.edu:8080/
[01:33:29] Posted data.
[01:33:29] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:33:29] + News From Folding@Home: Welcome to Folding@Home
[01:33:29] Loaded queue successfully.
[01:33:29] Sent data
[01:33:29] Connecting to http://171.67.108.22:8080/
[01:33:43] Posted data.
[01:33:43] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:35:01] - Downloaded at ~333 kB/s
[01:35:01] - Averaged speed for that direction ~320 kB/s
[01:35:01] + Received work.
[01:35:01] + Closed connections
[01:35:06]
[01:35:06] + Processing work unit
[01:35:06] Core required: FahCore_a3.exe
[01:35:06] Core found.
[01:35:06] Working on queue slot 08 [November 26 01:35:06 UTC]
[01:35:06] + Working ...
[01:35:06] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:35:06]
[01:35:06] *------------------------------*
[01:35:06] Folding@Home Gromacs SMP Core
[01:35:06] Version 2.22 (Mar 12, 2010)
[01:35:06]
[01:35:06] Preparing to commence simulation
[01:35:06] - Assembly optimizations manually forced on.
[01:35:06] - Not checking prior termination.
[01:35:11] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:35:11] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:35:11] - Digital signature verified
[01:35:11]
[01:35:11] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:35:11]
[01:35:11] Assembly optimizations on if available.
[01:35:11] Entering M.D.
[01:35:20] Completed 0 out of 250000 steps  (0%)
[01:36:52] CoreStatus = C0000005 (-1073741819)
[01:36:52] Client-core communications error: ERROR 0xc0000005
[01:36:52] - Attempting to download new core...
[01:36:52] + Downloading new core: FahCore_a3.exe
[01:36:52] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[01:36:53] Initial: AFDE; + 10240 bytes downloaded
[01:36:53] Initial: D8B1; + 20480 bytes downloaded
[01:36:53] Initial: 7D98; + 30720 bytes downloaded
[01:36:54] Initial: FB47; + 40960 bytes downloaded
[01:36:54] Initial: C727; + 51200 bytes downloaded
[01:36:54] Initial: 3959; + 61440 bytes downloaded
[01:36:54] Initial: E18D; + 71680 bytes downloaded
[01:36:54] Initial: FBC5; + 81920 bytes downloaded
[01:36:54] Initial: 7A39; + 92160 bytes downloaded
[01:36:54] Initial: 058D; + 102400 bytes downloaded
[01:36:54] Initial: A3E7; + 112640 bytes downloaded
[01:36:54] Initial: 6096; + 122880 bytes downloaded
[01:36:54] Initial: 2128; + 133120 bytes downloaded
[01:36:54] Initial: 1374; + 143360 bytes downloaded
[01:36:54] Initial: B12D; + 153600 bytes downloaded
[01:36:54] Initial: 539B; + 163840 bytes downloaded
[01:36:54] Initial: 85C3; + 174080 bytes downloaded
[01:36:54] Initial: A8E1; + 184320 bytes downloaded
[01:36:54] Initial: 0E78; + 194560 bytes downloaded
[01:36:55] Initial: 6477; + 204800 bytes downloaded
[01:36:55] Initial: 841E; + 215040 bytes downloaded
[01:36:55] Initial: 23C5; + 225280 bytes downloaded
[01:36:55] Initial: CA03; + 235520 bytes downloaded
[01:36:55] Initial: 1B65; + 245760 bytes downloaded
[01:36:55] Initial: 503A; + 256000 bytes downloaded
[01:36:55] Initial: 03CC; + 266240 bytes downloaded
[01:36:55] Initial: 9431; + 276480 bytes downloaded
[01:36:55] Initial: 0AF7; + 286720 bytes downloaded
[01:36:55] Initial: 73A8; + 296960 bytes downloaded
[01:36:55] Initial: DEDA; + 307200 bytes downloaded
[01:36:55] Initial: DB5F; + 317440 bytes downloaded
[01:36:55] Initial: B179; + 327680 bytes downloaded
[01:36:55] Initial: 9D7C; + 337920 bytes downloaded
[01:36:55] Initial: 70B0; + 348160 bytes downloaded
[01:36:56] Initial: CB0F; + 358400 bytes downloaded
[01:36:56] Initial: 7E46; + 368640 bytes downloaded
[01:36:56] Initial: A3B5; + 378880 bytes downloaded
[01:36:56] Initial: 6585; + 389120 bytes downloaded
[01:36:56] Initial: 396A; + 399360 bytes downloaded
[01:36:56] Initial: BFDA; + 409600 bytes downloaded
[01:36:56] Initial: 3CED; + 419840 bytes downloaded
[01:36:56] Initial: 7494; + 430080 bytes downloaded
[01:36:56] Initial: 752B; + 440320 bytes downloaded
[01:36:56] Initial: 19AC; + 450560 bytes downloaded
[01:36:56] Initial: 4E9D; + 460800 bytes downloaded
[01:36:56] Initial: C22D; + 471040 bytes downloaded
[01:36:56] Initial: 1287; + 481280 bytes downloaded
[01:36:56] Initial: 3203; + 491520 bytes downloaded
[01:36:56] Initial: B49B; + 501760 bytes downloaded
[01:36:57] Initial: 4104; + 512000 bytes downloaded
[01:36:57] Initial: 8DF1; + 522240 bytes downloaded
[01:36:57] Initial: DCC1; + 532480 bytes downloaded
[01:36:57] Initial: 7141; + 542720 bytes downloaded
[01:36:57] Initial: 5CF5; + 552960 bytes downloaded
[01:36:57] Initial: 4F40; + 563200 bytes downloaded
[01:36:57] Initial: 81E1; + 573440 bytes downloaded
[01:36:57] Initial: 1376; + 583680 bytes downloaded
[01:36:57] Initial: 70DF; + 593920 bytes downloaded
[01:36:57] Initial: 284C; + 604160 bytes downloaded
[01:36:57] Initial: 1D76; + 614400 bytes downloaded
[01:36:57] Initial: 775F; + 624640 bytes downloaded
[01:36:57] Initial: 422A; + 634880 bytes downloaded
[01:36:57] Initial: E836; + 645120 bytes downloaded
[01:36:57] Initial: 6E43; + 655360 bytes downloaded
[01:36:58] Initial: B979; + 665600 bytes downloaded
[01:36:58] Initial: 8530; + 675840 bytes downloaded
[01:36:58] Initial: 1FF8; + 686080 bytes downloaded
[01:36:58] Initial: 0C0C; + 696320 bytes downloaded
[01:36:58] Initial: 83B0; + 706560 bytes downloaded
[01:36:58] Initial: 6FB5; + 716800 bytes downloaded
[01:36:58] Initial: 949A; + 727040 bytes downloaded
[01:36:58] Initial: 9F7A; + 737280 bytes downloaded
[01:36:58] Initial: 13C6; + 747520 bytes downloaded
[01:36:58] Initial: 2FD0; + 757760 bytes downloaded
[01:36:58] Initial: 6BFE; + 768000 bytes downloaded
[01:36:58] Initial: 8C0F; + 778240 bytes downloaded
[01:36:58] Initial: 916D; + 788480 bytes downloaded
[01:36:58] Initial: A005; + 798720 bytes downloaded
[01:36:58] Initial: 028E; + 808960 bytes downloaded
[01:36:58] Initial: 27F6; + 819200 bytes downloaded
[01:36:59] Initial: B25A; + 829440 bytes downloaded
[01:36:59] Initial: D7FD; + 839680 bytes downloaded
[01:36:59] Initial: 96A1; + 849920 bytes downloaded
[01:36:59] Initial: B7AA; + 860160 bytes downloaded
[01:36:59] Initial: 7EE0; + 870400 bytes downloaded
[01:36:59] Initial: 23D9; + 880640 bytes downloaded
[01:36:59] Initial: 2772; + 890880 bytes downloaded
[01:36:59] Initial: 923D; + 901120 bytes downloaded
[01:36:59] Initial: 65B5; + 911360 bytes downloaded
[01:36:59] Initial: CCC0; + 921600 bytes downloaded
[01:36:59] Initial: 4E70; + 931840 bytes downloaded
[01:36:59] Initial: 4ECA; + 942080 bytes downloaded
[01:36:59] Initial: D737; + 952320 bytes downloaded
[01:36:59] Initial: 80C5; + 962560 bytes downloaded
[01:36:59] Initial: 15A4; + 972800 bytes downloaded
[01:37:00] Initial: ADB7; + 983040 bytes downloaded
[01:37:00] Initial: A2B0; + 993280 bytes downloaded
[01:37:00] Initial: 3EAC; + 1003520 bytes downloaded
[01:37:00] Initial: E831; + 1013760 bytes downloaded
[01:37:00] Initial: FF75; + 1024000 bytes downloaded
[01:37:00] Initial: BCC4; + 1034240 bytes downloaded
[01:37:00] Initial: CA0C; + 1044480 bytes downloaded
[01:37:00] Initial: D751; + 1054720 bytes downloaded
[01:37:00] Initial: EC51; + 1064960 bytes downloaded
[01:37:00] Initial: 9CC1; + 1075200 bytes downloaded
[01:37:00] Initial: 755D; + 1085440 bytes downloaded
[01:37:00] Initial: 59F8; + 1095680 bytes downloaded
[01:37:01] Initial: BF6C; + 1105920 bytes downloaded
[01:37:01] Initial: 4774; + 1116160 bytes downloaded
[01:37:01] Initial: FE4B; + 1126400 bytes downloaded
[01:37:01] Initial: CEB0; + 1136640 bytes downloaded
[01:37:01] Initial: BF2F; + 1146880 bytes downloaded
[01:37:01] Initial: BEAC; + 1157120 bytes downloaded
[01:37:01] Initial: 1251; + 1167360 bytes downloaded
[01:37:01] Initial: 4BC0; + 1177600 bytes downloaded
[01:37:01] Initial: 9648; + 1187840 bytes downloaded
[01:37:01] Initial: 1CDC; + 1198080 bytes downloaded
[01:37:01] Initial: 2821; + 1208320 bytes downloaded
[01:37:01] Initial: F0E5; + 1218560 bytes downloaded
[01:37:01] Initial: 03E1; + 1228800 bytes downloaded
[01:37:02] Initial: 1E3E; + 1239040 bytes downloaded
[01:37:02] Initial: AA8F; + 1249280 bytes downloaded
[01:37:02] Initial: C847; + 1259520 bytes downloaded
[01:37:02] Initial: A745; + 1269760 bytes downloaded
[01:37:02] Initial: 70CD; + 1280000 bytes downloaded
[01:37:02] Initial: 0339; + 1290240 bytes downloaded
[01:37:02] Initial: 239F; + 1300480 bytes downloaded
[01:37:02] Initial: 3633; + 1310720 bytes downloaded
[01:37:02] Initial: 715C; + 1320960 bytes downloaded
[01:37:02] Initial: B308; + 1331200 bytes downloaded
[01:37:02] Initial: 1199; + 1341440 bytes downloaded
[01:37:02] Initial: 7DCF; + 1351680 bytes downloaded
[01:37:02] Initial: 719D; + 1361920 bytes downloaded
[01:37:03] Initial: F8C6; + 1372160 bytes downloaded
[01:37:03] Initial: 503B; + 1382400 bytes downloaded
[01:37:03] Initial: 5F95; + 1392640 bytes downloaded
[01:37:03] Initial: 93DF; + 1402880 bytes downloaded
[01:37:03] Initial: 1E07; + 1413120 bytes downloaded
[01:37:03] Initial: 1C4B; + 1423360 bytes downloaded
[01:37:03] Initial: 6DE6; + 1433600 bytes downloaded
[01:37:03] Initial: B321; + 1443840 bytes downloaded
[01:37:03] Initial: C64F; + 1454080 bytes downloaded
[01:37:03] Initial: 69D1; + 1464320 bytes downloaded
[01:37:03] Initial: 51CA; + 1474560 bytes downloaded
[01:37:03] Initial: 8994; + 1484800 bytes downloaded
[01:37:03] Initial: 96C7; + 1495040 bytes downloaded
[01:37:03] Initial: 0EFD; + 1505280 bytes downloaded
[01:37:03] Initial: FF02; + 1515520 bytes downloaded
[01:37:03] Initial: 376F; + 1525760 bytes downloaded
[01:37:04] Initial: A151; + 1536000 bytes downloaded
[01:37:04] Initial: 813A; + 1546240 bytes downloaded
[01:37:04] Initial: B595; + 1556480 bytes downloaded
[01:37:04] Initial: 1BDB; + 1566720 bytes downloaded
[01:37:04] Initial: 2A28; + 1576960 bytes downloaded
[01:37:04] Initial: 1997; + 1587200 bytes downloaded
[01:37:04] Initial: AA47; + 1597440 bytes downloaded
[01:37:04] Initial: 1A68; + 1607680 bytes downloaded
[01:37:04] Initial: B6A4; + 1617920 bytes downloaded
[01:37:04] Initial: 555E; + 1628160 bytes downloaded
[01:37:04] Initial: C1ED; + 1638400 bytes downloaded
[01:37:04] Initial: 7CBC; + 1648640 bytes downloaded
[01:37:04] Initial: BD98; + 1658880 bytes downloaded
[01:37:04] Initial: 28F3; + 1669120 bytes downloaded
[01:37:04] Initial: 4587; + 1679360 bytes downloaded
[01:37:04] Initial: 2645; + 1689600 bytes downloaded
[01:37:05] Initial: A441; + 1699840 bytes downloaded
[01:37:05] Initial: 53E2; + 1710080 bytes downloaded
[01:37:05] Initial: 430C; + 1720320 bytes downloaded
[01:37:05] Initial: FA09; + 1730560 bytes downloaded
[01:37:05] Initial: C140; + 1740800 bytes downloaded
[01:37:05] Initial: 67D7; + 1751040 bytes downloaded
[01:37:05] Initial: 5028; + 1761280 bytes downloaded
[01:37:05] Initial: 1B33; + 1771520 bytes downloaded
[01:37:05] Initial: 75F2; + 1781760 bytes downloaded
[01:37:05] Initial: D64F; + 1792000 bytes downloaded
[01:37:05] Initial: 483D; + 1802240 bytes downloaded
[01:37:05] Initial: 2C13; + 1812480 bytes downloaded
[01:37:05] Initial: 43E1; + 1822720 bytes downloaded
[01:37:05] Initial: 2D30; + 1832960 bytes downloaded
[01:37:05] Initial: AA8A; + 1843200 bytes downloaded
[01:37:06] Initial: 4456; + 1853440 bytes downloaded
[01:37:06] Initial: 0523; + 1863680 bytes downloaded
[01:37:06] Initial: E639; + 1873920 bytes downloaded
[01:37:06] Initial: A985; + 1884160 bytes downloaded
[01:37:06] Initial: 2AD1; + 1894400 bytes downloaded
[01:37:06] Initial: 3ED9; + 1904640 bytes downloaded
[01:37:06] Initial: AC85; + 1914880 bytes downloaded
[01:37:06] Initial: 97AE; + 1925120 bytes downloaded
[01:37:06] Initial: 2936; + 1935360 bytes downloaded
[01:37:06] Initial: E147; + 1945600 bytes downloaded
[01:37:06] Initial: D38E; + 1955840 bytes downloaded
[01:37:06] Initial: DCFC; + 1966080 bytes downloaded
[01:37:06] Initial: CBE5; + 1976320 bytes downloaded
[01:37:06] Initial: 9377; + 1986560 bytes downloaded
[01:37:06] Initial: 8E96; + 1996800 bytes downloaded
[01:37:07] Initial: 5B37; + 2007040 bytes downloaded
[01:37:07] Initial: B496; + 2017280 bytes downloaded
[01:37:07] Initial: 329D; + 2027520 bytes downloaded
[01:37:07] Initial: A6DF; + 2037760 bytes downloaded
[01:37:07] Initial: 48CD; + 2048000 bytes downloaded
[01:37:07] Initial: 9976; + 2058240 bytes downloaded
[01:37:07] Initial: C763; + 2068480 bytes downloaded
[01:37:07] Initial: 391D; + 2078720 bytes downloaded
[01:37:07] Initial: 5D6E; + 2088960 bytes downloaded
[01:37:07] Initial: 06D0; + 2099200 bytes downloaded
[01:37:07] Initial: 5559; + 2109440 bytes downloaded
[01:37:07] Initial: 2135; + 2119680 bytes downloaded
[01:37:07] Initial: 4571; + 2129920 bytes downloaded
[01:37:07] Initial: 655C; + 2140160 bytes downloaded
[01:37:07] Initial: 33D3; + 2150400 bytes downloaded
[01:37:08] Initial: A251; + 2160640 bytes downloaded
[01:37:08] Initial: 0A61; + 2170880 bytes downloaded
[01:37:08] Initial: ADC5; + 2181120 bytes downloaded
[01:37:08] Initial: F636; + 2191360 bytes downloaded
[01:37:08] Initial: 1299; + 2201600 bytes downloaded
[01:37:08] Initial: C6AF; + 2211840 bytes downloaded
[01:37:08] Initial: AC63; + 2222080 bytes downloaded
[01:37:08] Initial: 815E; + 2232320 bytes downloaded
[01:37:08] Initial: FD1C; + 2242560 bytes downloaded
[01:37:08] Initial: 3509; + 2252800 bytes downloaded
[01:37:08] Initial: 4624; + 2263040 bytes downloaded
[01:37:08] Initial: 0A23; + 2273280 bytes downloaded
[01:37:08] Initial: 52D0; + 2283520 bytes downloaded
[01:37:08] Initial: 0721; + 2293760 bytes downloaded
[01:37:08] Initial: 9160; + 2304000 bytes downloaded
[01:37:09] Initial: 2342; + 2314240 bytes downloaded
[01:37:09] Initial: 6AB8; + 2324480 bytes downloaded
[01:37:09] Initial: D2CB; + 2334720 bytes downloaded
[01:37:09] Initial: FF0F; + 2344960 bytes downloaded
[01:37:09] Initial: 1301; + 2355200 bytes downloaded
[01:37:09] Initial: 2C98; + 2365440 bytes downloaded
[01:37:09] Initial: 251C; + 2375680 bytes downloaded
[01:37:09] Initial: D3EA; + 2385920 bytes downloaded
[01:37:09] Initial: 6A9A; + 2396160 bytes downloaded
[01:37:09] Initial: 5CD3; + 2406400 bytes downloaded
[01:37:09] Initial: 7E55; + 2416640 bytes downloaded
[01:37:09] Initial: 03A5; + 2426880 bytes downloaded
[01:37:09] Initial: 7CA9; + 2437120 bytes downloaded
[01:37:10] Initial: 3EA3; + 2447360 bytes downloaded
[01:37:10] Initial: 44AC; + 2457600 bytes downloaded
[01:37:10] Initial: 4E9A; + 2467840 bytes downloaded
[01:37:10] Initial: 9E43; + 2478080 bytes downloaded
[01:37:10] Initial: 5A57; + 2488320 bytes downloaded
[01:37:10] Initial: 2425; + 2498560 bytes downloaded
[01:37:10] Initial: D602; + 2508800 bytes downloaded
[01:37:10] Initial: 5AAD; + 2519040 bytes downloaded
[01:37:10] Initial: 4142; + 2529280 bytes downloaded
[01:37:10] Initial: 2C77; + 2539520 bytes downloaded
[01:37:10] Initial: 9279; + 2549760 bytes downloaded
[01:37:10] Initial: 11E3; + 2560000 bytes downloaded
[01:37:11] Initial: 2C8E; + 2570240 bytes downloaded
[01:37:11] Initial: 598D; + 2580480 bytes downloaded
[01:37:11] Initial: 8E47; + 2590720 bytes downloaded
[01:37:11] Initial: B10D; + 2600960 bytes downloaded
[01:37:11] Initial: 09D0; + 2611200 bytes downloaded
[01:37:11] Initial: F417; + 2621440 bytes downloaded
[01:37:11] Initial: 92E6; + 2631680 bytes downloaded
[01:37:11] Initial: 795D; + 2641920 bytes downloaded
[01:37:11] Initial: 2EEE; + 2652160 bytes downloaded
[01:37:11] Initial: BA3B; + 2662400 bytes downloaded
[01:37:11] Initial: 0404; + 2672640 bytes downloaded
[01:37:11] Initial: 4809; + 2682880 bytes downloaded
[01:37:11] Initial: 4BE5; + 2693120 bytes downloaded
[01:37:11] Initial: A3BF; + 2703360 bytes downloaded
[01:37:11] Initial: 3ABE; + 2711113 bytes downloaded
[01:37:12] Verifying core Core_a3.fah...
[01:37:12] Signature is VALID
[01:37:12]
[01:37:12] Trying to unzip core FahCore_a3.exe
[01:37:12] Decompressed FahCore_a3.exe (9325056 bytes) successfully
[01:37:17] + Core successfully engaged
[01:37:17] Deleting current work unit & continuing...
[01:37:32] Trying to send all finished work units
[01:37:32] + No unsent completed units remaining.
[01:37:32] - Preparing to get new work unit...
[01:37:32] Cleaning up work directory
[01:37:35] + Attempting to get work packet
[01:37:35] Passkey found
[01:37:35] - Will indicate memory of 12279 MB
[01:37:35] - Connecting to assignment server
[01:37:35] Connecting to http://assign.stanford.edu:8080/
[01:37:39] Posted data.
[01:37:39] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:37:39] + News From Folding@Home: Welcome to Folding@Home
[01:37:40] Loaded queue successfully.
[01:37:40] Sent data
[01:37:40] Connecting to http://171.67.108.22:8080/
[01:37:41] Posted data.
[01:37:41] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[01:37:42] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[01:37:55] + Attempting to get work packet
[01:37:55] Passkey found
[01:37:55] - Will indicate memory of 12279 MB
[01:37:55] - Connecting to assignment server
[01:37:55] Connecting to http://assign.stanford.edu:8080/
[01:37:56] Posted data.
[01:37:56] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:37:56] + News From Folding@Home: Welcome to Folding@Home
[01:37:56] Loaded queue successfully.
[01:37:56] Sent data
[01:37:56] Connecting to http://171.67.108.22:8080/
[01:37:57] Posted data.
[01:37:57] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[01:37:58] - Attempt #2  to get work failed, and no other work to do.
[01:38:12] + Attempting to get work packet
[01:38:12] Passkey found
[01:38:12] - Will indicate memory of 12279 MB
[01:38:12] - Connecting to assignment server
[01:38:12] Connecting to http://assign.stanford.edu:8080/
[01:38:13] Posted data.
[01:38:13] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:38:13] + News From Folding@Home: Welcome to Folding@Home
[01:38:14] Loaded queue successfully.
[01:38:14] Sent data
[01:38:14] Connecting to http://171.67.108.22:8080/
[01:38:15] Posted data.
[01:38:15] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[01:38:16] - Attempt #3  to get work failed, and no other work to do.
[01:38:45] + Attempting to get work packet
[01:38:45] Passkey found
[01:38:45] - Will indicate memory of 12279 MB
[01:38:45] - Connecting to assignment server
[01:38:45] Connecting to http://assign.stanford.edu:8080/
[01:38:46] Posted data.
[01:38:46] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:38:46] + News From Folding@Home: Welcome to Folding@Home
[01:38:46] Loaded queue successfully.
[01:38:46] Sent data
[01:38:46] Connecting to http://171.67.108.22:8080/
[01:38:47] Posted data.
[01:38:47] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[01:38:48] - Attempt #4  to get work failed, and no other work to do.
[01:39:37] + Attempting to get work packet
[01:39:37] Passkey found
[01:39:37] - Will indicate memory of 12279 MB
[01:39:37] - Connecting to assignment server
[01:39:37] Connecting to http://assign.stanford.edu:8080/
[01:39:38] Posted data.
[01:39:38] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:39:38] + News From Folding@Home: Welcome to Folding@Home
[01:39:38] Loaded queue successfully.
[01:39:38] Sent data
[01:39:38] Connecting to http://171.67.108.22:8080/
[01:39:51] Posted data.
[01:39:51] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:41:09] - Downloaded at ~333 kB/s
[01:41:09] - Averaged speed for that direction ~323 kB/s
[01:41:09] + Received work.
[01:41:09] + Closed connections
[01:41:14]
[01:41:14] + Processing work unit
[01:41:14] Core required: FahCore_a3.exe
[01:41:14] Core found.
[01:41:14] Working on queue slot 09 [November 26 01:41:14 UTC]
[01:41:14] + Working ...
[01:41:14] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:41:15]
[01:41:15] *------------------------------*
[01:41:15] Folding@Home Gromacs SMP Core
[01:41:15] Version 2.22 (Mar 12, 2010)
[01:41:15]
[01:41:15] Preparing to commence simulation
[01:41:15] - Assembly optimizations manually forced on.
[01:41:15] - Not checking prior termination.
[01:41:20] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:41:20] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:41:20] - Digital signature verified
[01:41:20]
[01:41:20] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:41:20]
[01:41:20] Assembly optimizations on if available.
[01:41:20] Entering M.D.
[01:41:29] Completed 0 out of 250000 steps  (0%)
[01:41:37] CoreStatus = C0000005 (-1073741819)
[01:41:37] Client-core communications error: ERROR 0xc0000005
[01:41:37] Deleting current work unit & continuing...
[01:41:51] Trying to send all finished work units
[01:41:51] + No unsent completed units remaining.
[01:41:51] - Preparing to get new work unit...
[01:41:51] Cleaning up work directory
[01:41:54] + Attempting to get work packet
[01:41:54] Passkey found
[01:41:54] - Will indicate memory of 12279 MB
[01:41:54] - Connecting to assignment server
[01:41:54] Connecting to http://assign.stanford.edu:8080/
[01:41:55] Posted data.
[01:41:55] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:41:55] + News From Folding@Home: Welcome to Folding@Home
[01:41:55] Loaded queue successfully.
[01:41:55] Sent data
[01:41:55] Connecting to http://171.67.108.22:8080/
[01:42:06] Posted data.
[01:42:06] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:43:11] - Downloaded at ~400 kB/s
[01:43:11] - Averaged speed for that direction ~338 kB/s
[01:43:11] + Received work.
[01:43:11] + Closed connections
[01:43:16]
[01:43:16] + Processing work unit
[01:43:16] Core required: FahCore_a3.exe
[01:43:16] Core found.
[01:43:16] Working on queue slot 00 [November 26 01:43:16 UTC]
[01:43:16] + Working ...
[01:43:16] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:43:16]
[01:43:16] *------------------------------*
[01:43:16] Folding@Home Gromacs SMP Core
[01:43:16] Version 2.22 (Mar 12, 2010)
[01:43:16]
[01:43:16] Preparing to commence simulation
[01:43:16] - Assembly optimizations manually forced on.
[01:43:16] - Not checking prior termination.
[01:43:21] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:43:21] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:43:22] - Digital signature verified
[01:43:22]
[01:43:22] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:43:22]
[01:43:22] Assembly optimizations on if available.
[01:43:22] Entering M.D.
[01:43:30] Completed 0 out of 250000 steps  (0%)
[01:43:43] CoreStatus = C0000005 (-1073741819)
[01:43:43] Client-core communications error: ERROR 0xc0000005
[01:43:43] Deleting current work unit & continuing...
[01:43:57] Trying to send all finished work units
[01:43:57] + No unsent completed units remaining.
[01:43:57] - Preparing to get new work unit...
[01:43:57] Cleaning up work directory
[01:44:00] + Attempting to get work packet
[01:44:00] Passkey found
[01:44:00] - Will indicate memory of 12279 MB
[01:44:00] - Connecting to assignment server
[01:44:00] Connecting to http://assign.stanford.edu:8080/
[01:44:01] Posted data.
[01:44:01] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:44:01] + News From Folding@Home: Welcome to Folding@Home
[01:44:01] Loaded queue successfully.
[01:44:01] Sent data
[01:44:01] Connecting to http://171.67.108.22:8080/
[01:44:11] Posted data.
[01:44:11] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:45:22] - Downloaded at ~366 kB/s
[01:45:22] - Averaged speed for that direction ~344 kB/s
[01:45:22] + Received work.
[01:45:22] + Closed connections
[01:45:27]
[01:45:27] + Processing work unit
[01:45:27] Core required: FahCore_a3.exe
[01:45:27] Core found.
[01:45:27] Working on queue slot 01 [November 26 01:45:27 UTC]
[01:45:27] + Working ...
[01:45:27] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:45:27]
[01:45:27] *------------------------------*
[01:45:27] Folding@Home Gromacs SMP Core
[01:45:27] Version 2.22 (Mar 12, 2010)
[01:45:27]
[01:45:27] Preparing to commence simulation
[01:45:27] - Assembly optimizations manually forced on.
[01:45:27] - Not checking prior termination.
[01:45:32] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:45:32] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:45:33] - Digital signature verified
[01:45:33]
[01:45:33] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:45:33]
[01:45:33] Assembly optimizations on if available.
[01:45:33] Entering M.D.
[01:45:41] Completed 0 out of 250000 steps  (0%)
[01:45:51] CoreStatus = C0000005 (-1073741819)
[01:45:51] Client-core communications error: ERROR 0xc0000005
[01:45:51] - Attempting to download new core...
[01:45:51] + Downloading new core: FahCore_a3.exe
[01:45:51] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[01:45:52] Initial: AFDE; + 10240 bytes downloaded
[01:45:52] Initial: D8B1; + 20480 bytes downloaded
[01:45:52] Initial: 7D98; + 30720 bytes downloaded
[01:45:53] Initial: FB47; + 40960 bytes downloaded
[01:45:53] Initial: C727; + 51200 bytes downloaded
[01:45:53] Initial: 3959; + 61440 bytes downloaded
[01:45:53] Initial: E18D; + 71680 bytes downloaded
[01:45:53] Initial: FBC5; + 81920 bytes downloaded
[01:45:53] Initial: 7A39; + 92160 bytes downloaded
[01:45:53] Initial: 058D; + 102400 bytes downloaded
[01:45:53] Initial: A3E7; + 112640 bytes downloaded
[01:45:53] Initial: 6096; + 122880 bytes downloaded
[01:45:53] Initial: 2128; + 133120 bytes downloaded
[01:45:54] Initial: 1374; + 143360 bytes downloaded
[01:45:54] Initial: B12D; + 153600 bytes downloaded
[01:45:54] Initial: 539B; + 163840 bytes downloaded
[01:45:54] Initial: 85C3; + 174080 bytes downloaded
[01:45:54] Initial: A8E1; + 184320 bytes downloaded
[01:45:54] Initial: 0E78; + 194560 bytes downloaded
[01:45:54] Initial: 6477; + 204800 bytes downloaded
[01:45:54] Initial: 841E; + 215040 bytes downloaded
[01:45:54] Initial: 23C5; + 225280 bytes downloaded
[01:45:54] Initial: CA03; + 235520 bytes downloaded
[01:45:54] Initial: 1B65; + 245760 bytes downloaded
[01:45:54] Initial: 503A; + 256000 bytes downloaded
[01:45:54] Initial: 03CC; + 266240 bytes downloaded
[01:45:54] Initial: 9431; + 276480 bytes downloaded
[01:45:54] Initial: 0AF7; + 286720 bytes downloaded
[01:45:54] Initial: 73A8; + 296960 bytes downloaded
[01:45:54] Initial: DEDA; + 307200 bytes downloaded
[01:45:54] Initial: DB5F; + 317440 bytes downloaded
[01:45:54] Initial: B179; + 327680 bytes downloaded
[01:45:54] Initial: 9D7C; + 337920 bytes downloaded
[01:45:54] Initial: 70B0; + 348160 bytes downloaded
[01:45:54] Initial: CB0F; + 358400 bytes downloaded
[01:45:54] Initial: 7E46; + 368640 bytes downloaded
[01:45:54] Initial: A3B5; + 378880 bytes downloaded
[01:45:54] Initial: 6585; + 389120 bytes downloaded
[01:45:54] Initial: 396A; + 399360 bytes downloaded
[01:45:54] Initial: BFDA; + 409600 bytes downloaded
[01:45:54] Initial: 3CED; + 419840 bytes downloaded
[01:45:54] Initial: 7494; + 430080 bytes downloaded
[01:45:54] Initial: 752B; + 440320 bytes downloaded
[01:45:54] Initial: 19AC; + 450560 bytes downloaded
[01:45:54] Initial: 4E9D; + 460800 bytes downloaded
[01:45:54] Initial: C22D; + 471040 bytes downloaded
[01:45:54] Initial: 1287; + 481280 bytes downloaded
[01:45:54] Initial: 3203; + 491520 bytes downloaded
[01:45:55] Initial: B49B; + 501760 bytes downloaded
[01:45:55] Initial: 4104; + 512000 bytes downloaded
[01:45:55] Initial: 8DF1; + 522240 bytes downloaded
[01:45:55] Initial: DCC1; + 532480 bytes downloaded
[01:45:55] Initial: 7141; + 542720 bytes downloaded
[01:45:55] Initial: 5CF5; + 552960 bytes downloaded
[01:45:55] Initial: 4F40; + 563200 bytes downloaded
[01:45:55] Initial: 81E1; + 573440 bytes downloaded
[01:45:55] Initial: 1376; + 583680 bytes downloaded
[01:45:55] Initial: 70DF; + 593920 bytes downloaded
[01:45:55] Initial: 284C; + 604160 bytes downloaded
[01:45:55] Initial: 1D76; + 614400 bytes downloaded
[01:45:55] Initial: 775F; + 624640 bytes downloaded
[01:45:55] Initial: 422A; + 634880 bytes downloaded
[01:45:55] Initial: E836; + 645120 bytes downloaded
[01:45:55] Initial: 6E43; + 655360 bytes downloaded
[01:45:55] Initial: B979; + 665600 bytes downloaded
[01:45:55] Initial: 8530; + 675840 bytes downloaded
[01:45:55] Initial: 1FF8; + 686080 bytes downloaded
[01:45:55] Initial: 0C0C; + 696320 bytes downloaded
[01:45:55] Initial: 83B0; + 706560 bytes downloaded
[01:45:55] Initial: 6FB5; + 716800 bytes downloaded
[01:45:55] Initial: 949A; + 727040 bytes downloaded
[01:45:56] Initial: 9F7A; + 737280 bytes downloaded
[01:45:56] Initial: 13C6; + 747520 bytes downloaded
[01:45:56] Initial: 2FD0; + 757760 bytes downloaded
[01:45:56] Initial: 6BFE; + 768000 bytes downloaded
[01:45:56] Initial: 8C0F; + 778240 bytes downloaded
[01:45:56] Initial: 916D; + 788480 bytes downloaded
[01:45:56] Initial: A005; + 798720 bytes downloaded
[01:45:56] Initial: 028E; + 808960 bytes downloaded
[01:45:56] Initial: 27F6; + 819200 bytes downloaded
[01:45:56] Initial: B25A; + 829440 bytes downloaded
[01:45:56] Initial: D7FD; + 839680 bytes downloaded
[01:45:56] Initial: 96A1; + 849920 bytes downloaded
[01:45:56] Initial: B7AA; + 860160 bytes downloaded
[01:45:56] Initial: 7EE0; + 870400 bytes downloaded
[01:45:56] Initial: 23D9; + 880640 bytes downloaded
[01:45:56] Initial: 2772; + 890880 bytes downloaded
[01:45:56] Initial: 923D; + 901120 bytes downloaded
[01:45:56] Initial: 65B5; + 911360 bytes downloaded
[01:45:56] Initial: CCC0; + 921600 bytes downloaded
[01:45:56] Initial: 4E70; + 931840 bytes downloaded
[01:45:56] Initial: 4ECA; + 942080 bytes downloaded
[01:45:56] Initial: D737; + 952320 bytes downloaded
[01:45:56] Initial: 80C5; + 962560 bytes downloaded
[01:45:56] Initial: 15A4; + 972800 bytes downloaded
[01:45:56] Initial: ADB7; + 983040 bytes downloaded
[01:45:56] Initial: A2B0; + 993280 bytes downloaded
[01:45:56] Initial: 3EAC; + 1003520 bytes downloaded
[01:45:56] Initial: E831; + 1013760 bytes downloaded
[01:45:56] Initial: FF75; + 1024000 bytes downloaded
[01:45:56] Initial: BCC4; + 1034240 bytes downloaded
[01:45:56] Initial: CA0C; + 1044480 bytes downloaded
[01:45:56] Initial: D751; + 1054720 bytes downloaded
[01:45:56] Initial: EC51; + 1064960 bytes downloaded
[01:45:56] Initial: 9CC1; + 1075200 bytes downloaded
[01:45:57] Initial: 755D; + 1085440 bytes downloaded
[01:45:57] Initial: 59F8; + 1095680 bytes downloaded
[01:45:57] Initial: BF6C; + 1105920 bytes downloaded
[01:45:57] Initial: 4774; + 1116160 bytes downloaded
[01:45:57] Initial: FE4B; + 1126400 bytes downloaded
[01:45:57] Initial: CEB0; + 1136640 bytes downloaded
[01:45:57] Initial: BF2F; + 1146880 bytes downloaded
[01:45:57] Initial: BEAC; + 1157120 bytes downloaded
[01:45:57] Initial: 1251; + 1167360 bytes downloaded
[01:45:57] Initial: 4BC0; + 1177600 bytes downloaded
[01:45:57] Initial: 9648; + 1187840 bytes downloaded
[01:45:57] Initial: 1CDC; + 1198080 bytes downloaded
[01:45:57] Initial: 2821; + 1208320 bytes downloaded
[01:45:57] Initial: F0E5; + 1218560 bytes downloaded
[01:45:57] Initial: 03E1; + 1228800 bytes downloaded
[01:45:57] Initial: 1E3E; + 1239040 bytes downloaded
[01:45:57] Initial: AA8F; + 1249280 bytes downloaded
[01:45:57] Initial: C847; + 1259520 bytes downloaded
[01:45:57] Initial: A745; + 1269760 bytes downloaded
[01:45:57] Initial: 70CD; + 1280000 bytes downloaded
[01:45:57] Initial: 0339; + 1290240 bytes downloaded
[01:45:57] Initial: 239F; + 1300480 bytes downloaded
[01:45:57] Initial: 3633; + 1310720 bytes downloaded
[01:45:57] Initial: 715C; + 1320960 bytes downloaded
[01:45:57] Initial: B308; + 1331200 bytes downloaded
[01:45:57] Initial: 1199; + 1341440 bytes downloaded
[01:45:57] Initial: 7DCF; + 1351680 bytes downloaded
[01:45:57] Initial: 719D; + 1361920 bytes downloaded
[01:45:57] Initial: F8C6; + 1372160 bytes downloaded
[01:45:57] Initial: 503B; + 1382400 bytes downloaded
[01:45:57] Initial: 5F95; + 1392640 bytes downloaded
[01:45:57] Initial: 93DF; + 1402880 bytes downloaded
[01:45:57] Initial: 1E07; + 1413120 bytes downloaded
[01:45:57] Initial: 1C4B; + 1423360 bytes downloaded
[01:45:57] Initial: 6DE6; + 1433600 bytes downloaded
[01:45:57] Initial: B321; + 1443840 bytes downloaded
[01:45:57] Initial: C64F; + 1454080 bytes downloaded
[01:45:57] Initial: 69D1; + 1464320 bytes downloaded
[01:45:57] Initial: 51CA; + 1474560 bytes downloaded
[01:45:57] Initial: 8994; + 1484800 bytes downloaded
[01:45:57] Initial: 96C7; + 1495040 bytes downloaded
[01:45:57] Initial: 0EFD; + 1505280 bytes downloaded
[01:45:57] Initial: FF02; + 1515520 bytes downloaded
[01:45:57] Initial: 376F; + 1525760 bytes downloaded
[01:45:57] Initial: A151; + 1536000 bytes downloaded
[01:45:57] Initial: 813A; + 1546240 bytes downloaded
[01:45:57] Initial: B595; + 1556480 bytes downloaded
[01:45:58] Initial: 1BDB; + 1566720 bytes downloaded
[01:45:58] Initial: 2A28; + 1576960 bytes downloaded
[01:45:58] Initial: 1997; + 1587200 bytes downloaded
[01:45:58] Initial: AA47; + 1597440 bytes downloaded
[01:45:58] Initial: 1A68; + 1607680 bytes downloaded
[01:45:58] Initial: B6A4; + 1617920 bytes downloaded
[01:45:58] Initial: 555E; + 1628160 bytes downloaded
[01:45:58] Initial: C1ED; + 1638400 bytes downloaded
[01:45:58] Initial: 7CBC; + 1648640 bytes downloaded
[01:45:58] Initial: BD98; + 1658880 bytes downloaded
[01:45:58] Initial: 28F3; + 1669120 bytes downloaded
[01:45:58] Initial: 4587; + 1679360 bytes downloaded
[01:45:58] Initial: 2645; + 1689600 bytes downloaded
[01:45:58] Initial: A441; + 1699840 bytes downloaded
[01:45:58] Initial: 53E2; + 1710080 bytes downloaded
[01:45:58] Initial: 430C; + 1720320 bytes downloaded
[01:45:58] Initial: FA09; + 1730560 bytes downloaded
[01:45:58] Initial: C140; + 1740800 bytes downloaded
[01:45:58] Initial: 67D7; + 1751040 bytes downloaded
[01:45:58] Initial: 5028; + 1761280 bytes downloaded
[01:45:58] Initial: 1B33; + 1771520 bytes downloaded
[01:45:58] Initial: 75F2; + 1781760 bytes downloaded
[01:45:58] Initial: D64F; + 1792000 bytes downloaded
[01:45:58] Initial: 483D; + 1802240 bytes downloaded
[01:45:58] Initial: 2C13; + 1812480 bytes downloaded
[01:45:58] Initial: 43E1; + 1822720 bytes downloaded
[01:45:58] Initial: 2D30; + 1832960 bytes downloaded
[01:45:58] Initial: AA8A; + 1843200 bytes downloaded
[01:45:58] Initial: 4456; + 1853440 bytes downloaded
[01:45:58] Initial: 0523; + 1863680 bytes downloaded
[01:45:58] Initial: E639; + 1873920 bytes downloaded
[01:45:58] Initial: A985; + 1884160 bytes downloaded
[01:45:58] Initial: 2AD1; + 1894400 bytes downloaded
[01:45:58] Initial: 3ED9; + 1904640 bytes downloaded
[01:45:58] Initial: AC85; + 1914880 bytes downloaded
[01:45:58] Initial: 97AE; + 1925120 bytes downloaded
[01:45:58] Initial: 2936; + 1935360 bytes downloaded
[01:45:58] Initial: E147; + 1945600 bytes downloaded
[01:45:58] Initial: D38E; + 1955840 bytes downloaded
[01:45:58] Initial: DCFC; + 1966080 bytes downloaded
[01:45:58] Initial: CBE5; + 1976320 bytes downloaded
[01:45:58] Initial: 9377; + 1986560 bytes downloaded
[01:45:58] Initial: 8E96; + 1996800 bytes downloaded
[01:45:58] Initial: 5B37; + 2007040 bytes downloaded
[01:45:58] Initial: B496; + 2017280 bytes downloaded
[01:45:59] Initial: 329D; + 2027520 bytes downloaded
[01:45:59] Initial: A6DF; + 2037760 bytes downloaded
[01:45:59] Initial: 48CD; + 2048000 bytes downloaded
[01:45:59] Initial: 9976; + 2058240 bytes downloaded
[01:45:59] Initial: C763; + 2068480 bytes downloaded
[01:45:59] Initial: 391D; + 2078720 bytes downloaded
[01:45:59] Initial: 5D6E; + 2088960 bytes downloaded
[01:45:59] Initial: 06D0; + 2099200 bytes downloaded
[01:45:59] Initial: 5559; + 2109440 bytes downloaded
[01:45:59] Initial: 2135; + 2119680 bytes downloaded
[01:45:59] Initial: 4571; + 2129920 bytes downloaded
[01:45:59] Initial: 655C; + 2140160 bytes downloaded
[01:45:59] Initial: 33D3; + 2150400 bytes downloaded
[01:45:59] Initial: A251; + 2160640 bytes downloaded
[01:45:59] Initial: 0A61; + 2170880 bytes downloaded
[01:45:59] Initial: ADC5; + 2181120 bytes downloaded
[01:45:59] Initial: F636; + 2191360 bytes downloaded
[01:45:59] Initial: 1299; + 2201600 bytes downloaded
[01:45:59] Initial: C6AF; + 2211840 bytes downloaded
[01:45:59] Initial: AC63; + 2222080 bytes downloaded
[01:45:59] Initial: 815E; + 2232320 bytes downloaded
[01:45:59] Initial: FD1C; + 2242560 bytes downloaded
[01:45:59] Initial: 3509; + 2252800 bytes downloaded
[01:45:59] Initial: 4624; + 2263040 bytes downloaded
[01:45:59] Initial: 0A23; + 2273280 bytes downloaded
[01:45:59] Initial: 52D0; + 2283520 bytes downloaded
[01:45:59] Initial: 0721; + 2293760 bytes downloaded
[01:45:59] Initial: 9160; + 2304000 bytes downloaded
[01:45:59] Initial: 2342; + 2314240 bytes downloaded
[01:45:59] Initial: 6AB8; + 2324480 bytes downloaded
[01:45:59] Initial: D2CB; + 2334720 bytes downloaded
[01:45:59] Initial: FF0F; + 2344960 bytes downloaded
[01:45:59] Initial: 1301; + 2355200 bytes downloaded
[01:45:59] Initial: 2C98; + 2365440 bytes downloaded
[01:45:59] Initial: 251C; + 2375680 bytes downloaded
[01:45:59] Initial: D3EA; + 2385920 bytes downloaded
[01:45:59] Initial: 6A9A; + 2396160 bytes downloaded
[01:45:59] Initial: 5CD3; + 2406400 bytes downloaded
[01:45:59] Initial: 7E55; + 2416640 bytes downloaded
[01:45:59] Initial: 03A5; + 2426880 bytes downloaded
[01:45:59] Initial: 7CA9; + 2437120 bytes downloaded
[01:45:59] Initial: 3EA3; + 2447360 bytes downloaded
[01:45:59] Initial: 44AC; + 2457600 bytes downloaded
[01:45:59] Initial: 4E9A; + 2467840 bytes downloaded
[01:45:59] Initial: 9E43; + 2478080 bytes downloaded
[01:45:59] Initial: 5A57; + 2488320 bytes downloaded
[01:45:59] Initial: 2425; + 2498560 bytes downloaded
[01:45:59] Initial: D602; + 2508800 bytes downloaded
[01:45:59] Initial: 5AAD; + 2519040 bytes downloaded
[01:45:59] Initial: 4142; + 2529280 bytes downloaded
[01:46:00] Initial: 2C77; + 2539520 bytes downloaded
[01:46:00] Initial: 9279; + 2549760 bytes downloaded
[01:46:00] Initial: 11E3; + 2560000 bytes downloaded
[01:46:00] Initial: 2C8E; + 2570240 bytes downloaded
[01:46:00] Initial: 598D; + 2580480 bytes downloaded
[01:46:00] Initial: 8E47; + 2590720 bytes downloaded
[01:46:00] Initial: B10D; + 2600960 bytes downloaded
[01:46:00] Initial: 09D0; + 2611200 bytes downloaded
[01:46:00] Initial: F417; + 2621440 bytes downloaded
[01:46:00] Initial: 92E6; + 2631680 bytes downloaded
[01:46:00] Initial: 795D; + 2641920 bytes downloaded
[01:46:00] Initial: 2EEE; + 2652160 bytes downloaded
[01:46:00] Initial: BA3B; + 2662400 bytes downloaded
[01:46:00] Initial: 0404; + 2672640 bytes downloaded
[01:46:00] Initial: 4809; + 2682880 bytes downloaded
[01:46:00] Initial: 4BE5; + 2693120 bytes downloaded
[01:46:00] Initial: A3BF; + 2703360 bytes downloaded
[01:46:00] Initial: 3ABE; + 2711113 bytes downloaded
[01:46:00] Verifying core Core_a3.fah...
[01:46:00] Signature is VALID
[01:46:00]
[01:46:00] Trying to unzip core FahCore_a3.exe
[01:46:00] Decompressed FahCore_a3.exe (9325056 bytes) successfully
[01:46:05] + Core successfully engaged
[01:46:06] Deleting current work unit & continuing...
[01:46:20] Trying to send all finished work units
[01:46:20] + No unsent completed units remaining.
[01:46:20] - Preparing to get new work unit...
[01:46:20] Cleaning up work directory
[01:46:24] + Attempting to get work packet
[01:46:24] Passkey found
[01:46:24] - Will indicate memory of 12279 MB
[01:46:24] - Connecting to assignment server
[01:46:24] Connecting to http://assign.stanford.edu:8080/
[01:46:26] Posted data.
[01:46:26] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:46:26] + News From Folding@Home: Welcome to Folding@Home
[01:46:26] Loaded queue successfully.
[01:46:26] Sent data
[01:46:26] Connecting to http://171.67.108.22:8080/
[01:46:27] Posted data.
[01:46:27] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[01:46:28] - Attempt #1  to get work failed, and no other work to do.
[01:46:37] + Attempting to get work packet
[01:46:37] Passkey found
[01:46:37] - Will indicate memory of 12279 MB
[01:46:37] - Connecting to assignment server
[01:46:37] Connecting to http://assign.stanford.edu:8080/
[01:46:39] Posted data.
[01:46:39] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:46:39] + News From Folding@Home: Welcome to Folding@Home
[01:46:39] Loaded queue successfully.
[01:46:39] Sent data
[01:46:39] Connecting to http://171.67.108.22:8080/
[01:46:52] Posted data.
[01:46:52] Initial: 0000; - Receiving payload (expected size: 26642699)
[01:47:59] - Downloaded at ~388 kB/s
[01:47:59] - Averaged speed for that direction ~352 kB/s
[01:47:59] + Received work.
[01:47:59] + Closed connections
[01:48:04]
[01:48:04] + Processing work unit
[01:48:04] Core required: FahCore_a3.exe
[01:48:04] Core found.
[01:48:04] Working on queue slot 02 [November 26 01:48:04 UTC]
[01:48:04] + Working ...
[01:48:04] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4444 -version 630'
[01:48:04]
[01:48:04] *------------------------------*
[01:48:04] Folding@Home Gromacs SMP Core
[01:48:04] Version 2.22 (Mar 12, 2010)
[01:48:04]
[01:48:04] Preparing to commence simulation
[01:48:04] - Assembly optimizations manually forced on.
[01:48:04] - Not checking prior termination.
[01:48:09] - Expanded 26642187 -> 33009261 (decompressed 123.8 percent)
[01:48:09] Called DecompressByteArray: compressed_data_size=26642187 data_size=33009261, decompressed_data_size=33009261 diff=0
[01:48:10] - Digital signature verified
[01:48:10]
[01:48:10] Project: 2685 (Run 2, Clone 5, Gen 49)
[01:48:10]
[01:48:10] Assembly optimizations on if available.
[01:48:10] Entering M.D.
[01:48:18] Completed 0 out of 250000 steps  (0%)
[01:48:28] CoreStatus = C0000005 (-1073741819)
[01:48:28] Client-core communications error: ERROR 0xc0000005
[01:48:28] Deleting current work unit & continuing...
[01:48:41] Killing all core threads
[01:48:41] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[01:48:41] ***** Got a SIGTERM signal (2)
--- Opening Log file [November 26 02:25:23 UTC]
[02:25:23] - Ask before connecting: No
[02:25:23] - User name: DigitalFX (Team 33)
[02:25:23] - User ID: AE604F034D9882E
[02:25:23] - Machine ID: 8
[02:25:23]
[02:25:23] Loaded queue successfully.
[02:25:23]
[02:25:23] - Autosending finished units... [November 26 02:25:23 UTC]
[02:25:23] + Processing work unit
[02:25:23] Trying to send all finished work units
[02:25:23] Core required: FahCore_a3.exe
[02:25:23] + No unsent completed units remaining.
[02:25:23] Core found.
[02:25:23] - Autosend completed
[02:25:23] Working on queue slot 02 [November 26 02:25:23 UTC]
[02:25:23] + Working ...
[02:25:23] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4828 -version 630'
[02:25:23]
[02:25:23] *------------------------------*
[02:25:23] Folding@Home Gromacs SMP Core
[02:25:23] Version 2.22 (Mar 12, 2010)
[02:25:23]
[02:25:23] Preparing to commence simulation
[02:25:23] - Assembly optimizations manually forced on.
[02:25:23] - Not checking prior termination.
[02:25:23] Error: Missing work file=<>
[02:25:23]
[02:25:23] Folding@home Core Shutdown: MISSING_WORK_FILES
[02:25:27] CoreStatus = 74 (116)
[02:25:27] The core could not find the work files specified. Removing from queue
[02:25:27] Deleting current work unit & continuing...
[02:25:31] Trying to send all finished work units
[02:25:31] + No unsent completed units remaining.
[02:25:31] - Preparing to get new work unit...
[02:25:31] Cleaning up work directory
[02:25:35] + Attempting to get work packet
[02:25:35] Passkey found
[02:25:35] - Will indicate memory of 12279 MB
[02:25:35] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[02:25:35] - Connecting to assignment server
[02:25:35] Connecting to http://assign.stanford.edu:8080/
[02:25:36] Posted data.
[02:25:36] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:25:36] + News From Folding@Home: Welcome to Folding@Home
[02:25:36] Loaded queue successfully.
[02:25:36] Sent data
[02:25:36] Connecting to http://171.67.108.22:8080/
[02:25:38] Posted data.
[02:25:38] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[02:25:39] - Attempt #1  to get work failed, and no other work to do.
[02:25:48] + Attempting to get work packet
[02:25:48] Passkey found
[02:25:48] - Will indicate memory of 12279 MB
[02:25:48] - Connecting to assignment server
[02:25:48] Connecting to http://assign.stanford.edu:8080/
[02:25:49] Posted data.
[02:25:49] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:25:49] + News From Folding@Home: Welcome to Folding@Home
[02:25:49] Loaded queue successfully.
[02:25:49] Sent data
[02:25:49] Connecting to http://171.67.108.22:8080/
[02:25:50] Posted data.
[02:25:50] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[02:25:51] - Attempt #2  to get work failed, and no other work to do.
[02:25:53] Killing all core threads
[02:25:53] Could not get process id information.  Please kill core process manually
[02:25:53] ***** Got a SIGTERM signal (2)
I CHANGED MACHINE ID AT THIS POINT.
--- Opening Log file [November 26 02:29:51 UTC]
[02:29:51] - Ask before connecting: No
[02:29:51] - User name: DigitalFX (Team 33)
[02:29:51] - User ID: AE604F034D9882E
[02:29:51] - Machine ID: 9
[02:29:51]
[02:29:51] Loaded queue successfully.
[02:29:51] - Preparing to get new work unit...
[02:29:51] - Autosending finished units... [November 26 02:29:51 UTC]
[02:29:51] Cleaning up work directory
[02:29:51] Trying to send all finished work units
[02:29:51] + Attempting to get work packet
[02:29:51] + No unsent completed units remaining.
[02:29:51] Passkey found
[02:29:51] - Autosend completed
[02:29:51] - Will indicate memory of 12279 MB
[02:29:51] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[02:29:51] - Connecting to assignment server
[02:29:51] Connecting to http://assign.stanford.edu:8080/
[02:29:52] Posted data.
[02:29:52] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:29:52] + News From Folding@Home: Welcome to Folding@Home
[02:29:53] Loaded queue successfully.
[02:29:53] Sent data
[02:29:53] Connecting to http://171.67.108.22:8080/
[02:30:03] Posted data.
[02:30:03] Initial: 0000; - Receiving payload (expected size: 24827357)
[02:31:05] - Downloaded at ~391 kB/s
[02:31:05] - Averaged speed for that direction ~360 kB/s
[02:31:05] + Received work.
[02:31:05] + Closed connections
[02:31:05]
[02:31:05] + Processing work unit
[02:31:05] Core required: FahCore_a3.exe
[02:31:05] Core found.
[02:31:05] Working on queue slot 03 [November 26 02:31:05 UTC]
[02:31:05] + Working ...
[02:31:05] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 24 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2384 -version 630'
[02:31:05]
[02:31:05] *------------------------------*
[02:31:05] Folding@Home Gromacs SMP Core
[02:31:05] Version 2.22 (Mar 12, 2010)
[02:31:05]
[02:31:05] Preparing to commence simulation
[02:31:05] - Assembly optimizations manually forced on.
[02:31:05] - Not checking prior termination.
[02:31:10] - Expanded 24826845 -> 30791309 (decompressed 124.0 percent)
[02:31:10] Called DecompressByteArray: compressed_data_size=24826845 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:31:10] - Digital signature verified
[02:31:10]
[02:31:10] Project: 2684 (Run 13, Clone 14, Gen 27)
[02:31:10]
[02:31:10] Assembly optimizations on if available.
[02:31:10] Entering M.D.
[02:31:19] Completed 0 out of 250000 steps  (0%)
Re: Project: 2685 (Run 2, Clone 5, Gen 49)
There's a lot of reports of EUE for this WU in the DB. I marked it as bad.
MIBW
Post by MIBW »
Ok, thanks!
lol - what are the odds that I get my first ever bad unit 2 mins after I touch a new machine for the first time in a week?!
codysluder
Post by codysluder »
Hmmm. With those odds does it make sense for you to buy a lottery ticket this week or not? :P
