Help: I keep getting assinged to server 171.64.122.137
chodaboy19
Post by chodaboy19 »
If I enter my username in the configuration I am always assigned server 171.64.122.137 which seems to be down. If I enter something else for my username then I get assigned to a working server. Is there a way to reset which server I am assigned to? Thank you for your help.
Re: Help: I keep getting assinged to server 171.64.122.137
Welcome to the Foldingforum, chodaboy19.
First, I've never seen a situation where entering a specific name had anything to do with the server being assigned. Which client are you using and how are you configuring the name? Are you using special characters or just numbers/letters/underscore.
Server 171.64.122.137 is, indeed down so being assigned to it is clearly a problem.
Have you found FAHlog.txt? If so, it would probably be helpful if you pasted it into your next post. If not, we'll help you find it.
chodaboy19
I am using version FAH v6.30-win32-SMP
I am entering my name as "chodaboy19"
Here is the log:
--- Opening Log file [November 23 05:10:57 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: C:\Users\Downloads\FAH6.30-win32-SMP
Executable: fah6
Arguments: -advmethods -verbosity 9 -smp
[05:10:57] - Ask before connecting: No
[05:10:57] - User name: chodaboy19 (Team 14)
[05:10:57] - User ID: 748C5A3F7C1F03BA
[05:10:57] - Machine ID: 1
[05:10:57]
[05:10:57] Loaded queue successfully.
[05:10:57] - Preparing to get new work unit...
[05:10:57] Cleaning up work directory
[05:10:57] - Autosending finished units... [November 23 05:10:57 UTC]
[05:10:57] + Attempting to get work packet
[05:10:57] Trying to send all finished work units
[05:10:57] Passkey found
[05:10:57] + No unsent completed units remaining.
[05:10:57] - Autosend completed
[05:10:57] - Will indicate memory of 4000 MB
[05:10:57] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[05:10:57] - Connecting to assignment server
[05:10:57] Connecting to http://assign.stanford.edu:8080/
[05:10:58] Posted data.
[05:10:58] Initial: 40AB; - Successful: assigned to (171.64.122.137).
[05:10:58] + News From Folding@Home: Welcome to Folding@Home
[05:10:58] Loaded queue successfully.
[05:10:58] Sent data
[05:10:58] Connecting to http://171.64.122.137:8080/
[05:11:19] - Couldn't send HTTP request to server
[05:11:19] + Could not connect to Work Server
[05:11:19] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[05:11:31] + Attempting to get work packet
[05:11:31] Passkey found
[05:11:31] - Will indicate memory of 4000 MB
[05:11:31] - Connecting to assignment server
[05:11:31] Connecting to http://assign.stanford.edu:8080/
[05:11:31] Posted data.
[05:11:31] Initial: 40AB; - Successful: assigned to (171.64.122.137).
[05:11:31] + News From Folding@Home: Welcome to Folding@Home
[05:11:31] Loaded queue successfully.
[05:11:31] Sent data
[05:11:31] Connecting to http://171.64.122.137:8080/
[05:11:52] - Couldn't send HTTP request to server
[05:11:52] + Could not connect to Work Server
[05:11:52] - Attempt #2  to get work failed, and no other work to do.
This is what happens when I just change the name:
Executable: fah6
[05:13:22] - Ask before connecting: No
[05:13:22] - User name: iatacs19 (Team 14)
[05:13:22] - User ID: 748C5A3F7C1F03BA
[05:13:22] - Machine ID: 1
[05:13:22]
[05:13:22] Loaded queue successfully.
[05:13:22] - Preparing to get new work unit...
[05:13:22] - Autosending finished units... [November 23 05:13:22 UTC]
[05:13:22] Cleaning up work directory
[05:13:22] Trying to send all finished work units
[05:13:22] + No unsent completed units remaining.
[05:13:22] + Attempting to get work packet
[05:13:22] - Autosend completed
[05:13:22] Passkey found
[05:13:22] - Will indicate memory of 4000 MB
[05:13:22] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[05:13:22] - Connecting to assignment server
[05:13:22] Connecting to http://assign.stanford.edu:8080/
[05:13:22] Posted data.
[05:13:22] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[05:13:22] + News From Folding@Home: Welcome to Folding@Home
[05:13:22] Sent data
[05:13:22] Connecting to http://171.64.65.56:8080/
[05:13:23] Posted data.
[05:13:23] Initial: 0000; - Receiving payload (expected size: 764149)
[05:13:25] - Downloaded at ~373 kB/s
[05:13:25] - Averaged speed for that direction ~616 kB/s
[05:13:25] + Received work.
[05:13:25] + Closed connections
[05:13:25]
[05:13:25] + Processing work unit
[05:13:25] Core required: FahCore_a3.exe
[05:13:25] Core found.
[05:13:25] Working on queue slot 02 [November 23 05:13:25 UTC]
[05:13:25] + Working ...
[05:13:25] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 8 -checkpoint 15 -verbose -lifeline 4640 -version 630'
[05:13:25]
[05:13:25] *------------------------------*
[05:13:25] Folding@Home Gromacs SMP Core
[05:13:25] Version 2.22 (Mar 12, 2010)
[05:13:25]
[05:13:25] Preparing to commence simulation
[05:13:25] - Looking at optimizations...
[05:13:25] - Created dyn
[05:13:25] - Files status OK
[05:13:26] - Expanded 763637 -> 1404481 (decompressed 183.9 percent)
[05:13:26] Called DecompressByteArray: compressed_data_size=763637 data_size=1404481, decompressed_data_size=1404481 diff=0
[05:13:26] - Digital signature verified
[05:13:26]
[05:13:26] Project: 6702 (Run 4, Clone 33, Gen 63)
[05:13:26]
[05:13:26] Assembly optimizations on if available.
[05:13:26] Entering M.D.
[05:13:32] Completed 0 out of 2000000 steps  (0%)
Thank you again for your help.
How are you changing the name? You should be using -config rather than editing one of the files. If you've been editing it, delete client.cfg entirely and restart the client, being sure to use the -smp flag.
chodaboy19
Yes, I am using the -configonly flag to change the name and test the download of the work units.
I have tried deleting everything and re-downloading the client, but if I enter the username "chodaboy19" I always get assigned to this particular server.
Same thing happens on my PS3, I can download the work units fine except when I enter the particular username. I am lost as to the reason behind this... Is there a way to reset that username somehow?
VijayPande
Pande Group Member
Post by VijayPande »
There is a known FAH trojan that assigns points to the name "chodaboy19". This donor name was banned some time ago due to this. Looking at the logs, that trojan is still alive.
Unfortunately, the only course of action here is for you to pick a different donorname. I'm sorry about this, but this is one of the cases where one person's action ruins the experience for another and we have to try to do what's best for the reputation of the project (i.e. banning trojans).
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
