Project: 10110 (Run 535, Clone 2, Gen 1)
patonb
Post by patonb »
Got this on my machine with my 8800gt. Don't fail too often so bI figured I'd report it
Corestatus = 72 (114) btw
sortofageek
Re: Project: 10110 (Run 535, Clone 2, Gen 1)
Post by sortofageek »
Thanks for your report. If you post the log, someone may be able to help you determine the problem. Project: 10110 (Run 535, Clone 2, Gen 1) has been completed and returned for full credit by another folder, so we can't call it a bad WU.
patonb
Post by patonb »
If its been done then it was my system.... 2 failures in hundreds of units doesn't give me to much concern.
The corestatus 72 was my concern.
sortofageek
I don't think anyone could even make an educated guess without the log. Make sure your startup contains the -verbosity 9 flag. If you continue to have trouble, please post a report which includes the relevant logs.
Fireball0236
Post by Fireball0236 »
According to the Wiki, CoreStatus 72 is either BAD_WORK_UNIT or EARLY_UNIT_END. But as sorfofageek said, a copy of your FAHlog would be much appreciated.
See this topic on where to find the logs and how to post them, in case you don't know:
viewtopic.php?p=160884#p160884
~ Fireball0236
patonb
Post by patonb »
sortofageek wrote:I don't think anyone could even make an educated guess without the log. Make sure your startup contains the -verbosity 9 flag. If you continue to have trouble, please post a report which includes the relevant logs.
I know my logs... been folding almost 4 yrs now. Like i said, first failed units in probably a thousand total ,on 5 clients.
Probably some quirk my card through with the unit. Not to worried... I have folded 3 of the wu series on my 3 gpus it seems, so my card burped.
The 72 code was my reason to post a check, cause i did see the wiki claiming bad unit.
patonb wrote:If its been done then it was my system.... 2 failures in hundreds of units doesn't give me to much concern.
Your system did report the error and it was reissued. As sortofageek said, it was completed by somebody else.
Hi patonb (team 12864),
Your WU (P10110 R535 C2 G1) was added to the stats database on 2010-11-09 13:14:37 for 0 points of credit.
Hi xxxxxx (team xxx6),
Your WU (P10110 R535 C2 G1) was added to the stats database on 2010-11-09 14:11:40 for 494 points of credit.
patonb
Post by patonb »
Wow right quick reissue eh, under an hour... hell it must have been kicked out imediately!
patonb wrote:Wow right quick reissue eh, under an hour... hell it must have been kicked out imediately!
Under an hour? Not necessarily. Stats are updated hourly, so all you can say is that it was under two hours. (It can be as much as 1.99 hours and still catch the next update. One WU uploads at 1:01 and goes into the stats just after 2:00. The next WU uploads at 02:59 and goes into the stats just after 3:00)
In this case: Days taken to complete WU: 0.08
patonb
Post by patonb »
Well i returned it at 13:14 and the other guy uploaded at 14:11 same day....
Very odd, now another card has thrown a corestaus 72 (114) on Project: 10110 (Run 184, Clone 3, Gen 6) after 16%. Its a gtx260...... very odd.
sortofageek
I don't see your log, so I don't know what you are seeing, but the database says ...
Your WU (P10110 R184 C3 G6) was added to the stats database on 2010-11-14 07:11:30 for 0 points of credit.
... and full credit for another folder on that one.
patonb
Post by patonb »
Here's my 2 logs, they say nothing, as I run systrays, verfbosity 9 isn't setable:
8800GT
[19:21:24] Project: 10110 (Run 535, Clone 2, Gen 1)
[19:21:24]
[19:21:24] Assembly optimizations on if available.
[19:21:24] Entering M.D.
[19:21:30] Tpr hash work/wudata_01.tpr:  1617781488 3572304092 649717533 2311063077 2735496986
[19:21:30]
[19:21:30] Calling fah_main args: 14 usage=100
[19:21:30]
[19:21:30] Working on 1174 p10110_ubiquitin_300K
[19:21:33] Client config found, loading data.
[19:21:33] Starting GUI Server
[19:23:08] Completed 1%
[19:24:43] Completed 2%
[19:26:18] Completed 3%
[19:27:53] Completed 4%
SNIP
[20:12:11] Completed 32%
[20:13:46] Completed 33%
[20:15:21] Completed 34%
[20:16:56] Completed 35%
[20:18:31] Completed 36%
[20:19:26] Run: exception thrown during GuardedRun
[20:19:26] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[20:19:26] Going to send back what have done -- stepsTotalG=10000000
[20:19:26] Work fraction=0.3658 steps=10000000.
[20:19:30] logfile size=16638 infoLength=16638 edr=0 trr=23
[20:19:30] + Opened results file
[20:19:30] - Writing 17174 bytes of core data to disk...
[20:19:30] Done: 16662 -> 4754 (compressed to 28.5 percent)
[20:19:30]   ... Done.
[20:19:30] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[20:19:30]
[20:19:30] Folding@home Core Shutdown: EARLY_UNIT_END
[20:19:32] CoreStatus = 72 (114)
[20:19:32] Sending work to server
[20:19:32] Project: 10110 (Run 535, Clone 2, Gen 1)
[20:19:32] + Attempting to send results [November 9 20:19:32 UTC]
[20:19:32] + Results successfully sent
[20:19:32] Thank you for your contribution to Folding@Home.
[20:19:36] - Preparing to get new work unit...
[20:19:36] + Attempting to get work packet
[20:19:36] - Connecting to assignment server
[20:19:37] - Successful: assigned to (171.64.65.71).
[20:19:37] + News From Folding@Home: Welcome to Folding@Home
[20:19:37] Loaded queue successfully.
[20:19:38] + Closed connections
[20:19:43]
GTX 260-216
[14:30:47] Sending work to server
[14:30:47] Project: 10112 (Run 532, Clone 0, Gen 94)
[14:30:47] + Attempting to send results [November 14 14:30:47 UTC]
[14:30:50] + Results successfully sent
[14:30:50] Thank you for your contribution to Folding@Home.
[14:30:50] + Number of Units Completed: 4307
[14:30:54] - Preparing to get new work unit...
[14:30:54] + Attempting to get work packet
[14:30:54] - Connecting to assignment server
[14:30:54] - Successful: assigned to (171.64.65.71).
[14:30:54] + News From Folding@Home: Welcome to Folding@Home
[14:30:55] Loaded queue successfully.
[14:30:56] + Closed connections
[14:30:56]
[14:30:56] + Processing work unit
[14:30:56] Core required: FahCore_11.exe
[14:30:56] Core found.
[14:30:56] Working on queue slot 01 [November 14 14:30:56 UTC]
[14:30:56] + Working ...
[14:30:56]
[14:30:56] *------------------------------*
[14:30:56] Folding@Home GPU Core
[14:30:56] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:30:56]
[14:30:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:30:56] Build host: amoeba
[14:30:56] Board Type: Nvidia
[14:30:56] Core      :
[14:30:56] Preparing to commence simulation
[14:30:56] - Looking at optimizations...
[14:30:56] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[14:30:56] - Created dyn
[14:30:56] - Files status OK
[14:30:56] - Expanded 83569 -> 427946 (decompressed 512.0 percent)
[14:30:56] Called DecompressByteArray: compressed_data_size=83569 data_size=427946, decompressed_data_size=427946 diff=0
[14:30:56] - Digital signature verified
[14:30:56]
[14:30:56] Project: 10110 (Run 184, Clone 3, Gen 6)
[14:30:56]
[14:30:56] Assembly optimizations on if available.
[14:30:56] Entering M.D.
[14:31:02] Tpr hash work/wudata_01.tpr:  1568389027 132936327 3967451102 1836134881 627154497
[14:31:02]
[14:31:02] Calling fah_main args: 14 usage=100
[14:31:02]
[14:31:02] Working on 1174 p10110_ubiquitin_300K
[14:31:04] Client config found, loading data.
[14:31:04] Starting GUI Server
[14:32:05] Completed 1%
[14:33:05] Completed 2%
[14:34:05] Completed 3%
[14:35:05] Completed 4%
[14:36:04] Completed 5%
[14:37:04] Completed 6%
[14:38:03] Completed 7%
[14:39:03] Completed 8%
[14:40:02] Completed 9%
[14:41:02] Completed 10%
[14:42:01] Completed 11%
[14:43:01] Completed 12%
[14:44:00] Completed 13%
[14:45:00] Completed 14%
[14:46:00] Completed 15%
[14:47:01] Completed 16%
[14:47:27] Run: exception thrown during GuardedRun
[14:47:27] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[14:47:27] Going to send back what have done -- stepsTotalG=10000000
[14:47:27] Work fraction=0.1640 steps=10000000.
[14:47:31] logfile size=11639 infoLength=11639 edr=0 trr=23
[14:47:31] + Opened results file
[14:47:31] - Writing 12175 bytes of core data to disk...
[14:47:31] Done: 11663 -> 4145 (compressed to 35.5 percent)
[14:47:31]   ... Done.
[14:47:31] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[14:47:31]
[14:47:31] Folding@home Core Shutdown: EARLY_UNIT_END
[14:47:34] CoreStatus = 72 (114)
[14:47:34] Sending work to server
[14:47:34] Project: 10110 (Run 184, Clone 3, Gen 6)
[14:47:34] + Attempting to send results [November 14 14:47:34 UTC]
[14:47:34] + Results successfully sent
[14:47:34] Thank you for your contribution to Folding@Home.
[14:47:38] - Preparing to get new work unit...
[14:47:38] + Attempting to get work packet
[14:47:38] - Connecting to assignment server
[14:47:39] - Successful: assigned to (171.64.65.71).
[14:47:39] + News From Folding@Home: Welcome to Folding@Home
[14:47:39] Loaded queue successfully.
[14:47:40] + Closed connections
Both units are 10110... I have completed them on all 3 cards according to hfm.net
 Project ID: 10110
 Core: GROGPU2
 Credit: 494
 Frames: 100
 Path: z:\Documents and Settings\KMC\Application Data\Folding@home-gpu\
 Number of Frames Observed: 300
 Min. Time / Frame : 00:01:31 - 4,690.3 PPD
 Avg. Time / Frame : 00:01:35 - 4,492.8 PPD
 Name: BFG GTX 260-216
 Path: \\beast\BFG GTX 260\
 Min. Time / Frame : 00:00:59 - 7,234.2 PPD
 Avg. Time / Frame : 00:00:59 - 7,234.2 PPD
 Name: XFX GTX 260-216
 Path: \\BEAST\Folding@home-gpu1\
 Min. Time / Frame : 00:00:57 - 7,488.0 PPD
 Avg. Time / Frame : 00:00:57 - 7,488.0 PPD
 Cur. Time / Frame : 00:00:58 - 7,358.9 PPD
 R3F. Time / Frame : 00:00:57 - 7,488.0 PPD
 All  Time / Frame : 00:00:57 - 7,488.0 PPD
 Eff. Time / Frame : 00:00:58 - 7,358.9 PPD
And am currently running 1 now, so Its odd as I don't toss errors but have now had 3 10110 wus go bad on 2 different cards. 2 corestatus 72s and 1 status 7A
I pride myself on a less than 1% eue rate, with EOC reports me almost 11000 wus done, and a pt total of almost 11million.
My only thoughtis older hardware on newer units.
patonb wrote:Here's my 2 logs, they say nothing, as I run systrays, verfbosity 9 isn't setable...
Not exactly sure what you mean but initially, I was using Systray GPU and was able to use -verbosity 9 flag (I assume that it was a typo in your post) in the Advance Parameter of the Client. Can you please elaborate?
patonb
Post by patonb »
^no, i meant what i wrote, guess i missed it... or set it wayyyyyyyy back and forgot about it....
AHHH nice i see how it goes...... learn something new all the time!
And set now.
