171.64.65.62 Reject Mode & 171.67.108.25 Status 503
brityank
Post by brityank »
Have two systems trying to send back completed WUs - both show the same info. Status sheet shows 171.64.65.62 is in Reject mode; 171.67.108.25 overloaded. Noted to give Pande Group a heads-up for the morning.
[07:00:01] + Attempting to send results [November 12 07:00:01 UTC]
[07:00:01] - Reading file work/wuresults_05.dat from core
[07:00:01]   (Read 415653 bytes from disk)
[07:00:01] Connecting to http://171.64.65.62:8080/
[07:00:02] - Couldn't send HTTP request to server
[07:00:02] + Could not connect to Work Server (results)
[07:00:02]     (171.64.65.62:8080)
[07:00:02] + Retrying using alternative port
[07:00:02] Connecting to http://171.64.65.62:80/
[07:00:03] - Couldn't send HTTP request to server
[07:00:03] + Could not connect to Work Server (results)
[07:00:03]     (171.64.65.62:80)
[07:00:03] - Error: Could not transmit unit 05 (completed November 12) to work server.
[07:00:03] - 1 failed uploads of this unit.
[07:00:03]   Keeping unit 05 in queue.
[07:00:03] Trying to send all finished work units
[07:00:03] Project: 6518 (Run 19, Clone 51, Gen 69)
[07:00:03] - Read packet limit of 540015616... Set to 524286976.
[07:00:03] + Attempting to send results [November 12 07:00:03 UTC]
[07:00:03] - Reading file work/wuresults_05.dat from core
[07:00:03]   (Read 415653 bytes from disk)
[07:00:03] Connecting to http://171.64.65.62:8080/
[07:00:04] - Couldn't send HTTP request to server
[07:00:04] + Could not connect to Work Server (results)
[07:00:04]     (171.64.65.62:8080)
[07:00:04] + Retrying using alternative port
[07:00:04] Connecting to http://171.64.65.62:80/
[07:00:05] - Couldn't send HTTP request to server
[07:00:05] + Could not connect to Work Server (results)
[07:00:05]     (171.64.65.62:80)
[07:00:05] - Error: Could not transmit unit 05 (completed November 12) to work server.
[07:00:05] - 2 failed uploads of this unit.
[07:00:05] - Read packet limit of 540015616... Set to 524286976.
[07:00:05] + Attempting to send results [November 12 07:00:05 UTC]
[07:00:05] - Reading file work/wuresults_05.dat from core
[07:00:05]   (Read 415653 bytes from disk)
[07:00:05] Connecting to http://171.67.108.25:8080/
[07:00:06] - Couldn't send HTTP request to server
[07:00:06]   (Got status 503)
[07:00:06] + Could not connect to Work Server (results)
[07:00:06]     (171.67.108.25:8080)
[07:00:06] + Retrying using alternative port
[07:00:06] Connecting to http://171.67.108.25:80/
[07:00:06]     (171.67.108.25:80)
[07:00:06]   Could not transmit unit 05 to Collection server; keeping in queue.
[07:00:06] + Sent 0 of 1 completed units to the server
Thanks. 8-)
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
brityank
Server Down _Again_ Re: 171.64.65.62
Post by brityank »
Seems someone walked by and kicked the server at 07:15PST. That held it up for a little more than 1 Hour, before it cratered again.
Can someone find the Problem in this server, instead of just dusting off the symptom, please? This Server has had problems for the last four to six months, and its backup rarely accepts any of its WUs. At least it happened before the weekend, unlike the last two I know of.
Re: 171.64.65.62 Reject Mode & 171.67.108.25 Status 503
Yep. It was in trouble between 08:50 and 12:50 but it has been fine since then, accepting a backlog of about 3000 WUs per hour until it began to catch up about 19:00 PST.
brityank
Post by brityank »
Thanks for the update, bruce - all seems OK now except for missing points.
Had Proj. 2494 (R144 C25 G7) go up on 11/11 for 905 Points, but it doesn't show in my totals. How can I verify that? Thanks for your help. :)
sortofageek
Post by sortofageek »
brityank wrote: Had Proj. 2494 (R144 C25 G7) go up on 11/11 for 905 Points, but it doesn't show in my totals. How can I verify that? Thanks for your help. :)
The database shows no data back on Project: 2494 (Run 144, Clone 25, Gen 7). The best place to ask this type of question is in the Issues With Specific WU Forum accompanied by the relevant logs.
brityank
Post by brityank »
sortofageek wrote:The database shows no data back on Project: 2494 (Run 144, Clone 25, Gen 7). The best place to ask this type of question is in the Issues With Specific WU Forum accompanied by the relevant logs.
Thanks, sortofageek - I'll put them up there.
Baowoulf
Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
Post by Baowoulf »
Seems like the server is having problems again. My latest finished WU, P6541 (Run 5, Clone 84, Gen 2), won't upload for a day or so. I'm hoping it's just needs a kickstart on Monday. CPU load went from 14 to 17 and the backup server isn't taking it either.
