171.64.65.102 Reject
				RAH
 - Hardware configuration: 1. C2Q 8200@2880 / W7Pro64 / SMP2 / 2 GPU - GTS250/GTS450
2. C2D 6300@3600 / XPsp3 / SMP2 / 1 GPU - GT240 - Location: Florida
171.64.65.102
Server is in reject mode.
Could a mod pass the info to correct peoples.
Thanks you
Thanks you
				Bobcat
 - Hardware configuration: i7-860 2.8 GHz, 4 GB RAM, 1 TB HD, Win7 64-bit
Sapphire (ATI) 5670 825 MHz, 1 GB DDR5 RAM - Location: New Jersey
Re: 171.64.65.102 Reject
Chronic problems continue with 171.64.65.102.  It seems that half the time, the server is rejecting connections.  Can anyone see what's going on and fix this?  It's used with the ATI GPU WUs.
[12:53:10] Folding@home Core Shutdown: FINISHED_UNIT
[12:53:12] CoreStatus = 64 (100)
[12:53:12] Sending work to server
[12:53:12] Project: 5737 (Run 2, Clone 630, Gen 67)
[12:53:12] + Attempting to send results [December 15 12:53:12 UTC]
[12:53:12] Gpu type=1 species=4.
[12:53:13] - Couldn't send HTTP request to server
[12:53:13] + Could not connect to Work Server (results)
[12:53:13] (171.64.65.102:8080)
[12:53:13] + Retrying using alternative port
[12:53:15] - Couldn't send HTTP request to server
[12:53:15] + Could not connect to Work Server (results)
[12:53:15] (171.64.65.102:80)
[12:53:15] - Error: Could not transmit unit 06 (completed December 15) to work server.
[12:53:15] Keeping unit 06 in queue.
[12:53:15] Project: 5737 (Run 2, Clone 630, Gen 67)
[12:53:15] + Attempting to send results [December 15 12:53:15 UTC]
[12:53:15] Gpu type=1 species=4.
[12:53:16] - Couldn't send HTTP request to server
[12:53:16] + Could not connect to Work Server (results)
[12:53:16] (171.64.65.102:8080)
[12:53:16] + Retrying using alternative port
[12:53:17] - Couldn't send HTTP request to server
[12:53:17] + Could not connect to Work Server (results)
[12:53:17] (171.64.65.102:80)
[12:53:17] - Error: Could not transmit unit 06 (completed December 15) to work server.
[12:53:17] + Attempting to send results [December 15 12:53:17 UTC]
[12:53:17] Gpu type=1 species=4.
[12:53:18] - Couldn't send HTTP request to server
[12:53:18] (Got status 503)
[12:53:18] + Could not connect to Work Server (results)
[12:53:18] (171.67.108.17:8080)
[12:53:18] + Retrying using alternative port
[12:53:18] (171.67.108.17:80)
[12:53:18] Could not transmit unit 06 to Collection server; keeping in queue.
[12:53:18] - Preparing to get new work unit...
[12:53:18] Cleaning up work directory
[12:53:18] + Attempting to get work packet
[12:53:18] Passkey found
[12:53:18] Gpu type=1 species=4.
[12:53:18] - Connecting to assignment server
[12:53:19] + No appropriate work server was available; will try again in a bit.
[12:53:19] + Couldn't get work instructions.
[12:53:19] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[12:53:27] + Attempting to get work packet
[12:53:27] Passkey found
[12:53:27] Gpu type=1 species=4.
[12:53:27] - Connecting to assignment server
[12:53:28] + No appropriate work server was available; will try again in a bit.
[12:53:28] + Couldn't get work instructions.
[12:53:28] - Attempt #2 to get work failed, and no other work to do.
[12:53:40] + Attempting to get work packet
[12:53:40] Passkey found
[12:53:40] Gpu type=1 species=4.
[12:53:40] - Connecting to assignment server
[12:53:41] + No appropriate work server was available; will try again in a bit.
[12:53:41] + Couldn't get work instructions.
[12:53:41] - Attempt #3 to get work failed, and no other work to do.
[12:54:08] + Attempting to get work packet
[12:54:08] Passkey found
[12:54:08] Gpu type=1 species=4.
[12:54:08] - Connecting to assignment server
[12:54:09] + No appropriate work server was available; will try again in a bit.
[12:54:09] + Couldn't get work instructions.
[12:54:09] - Attempt #4 to get work failed, and no other work to do.
[12:54:52] + Attempting to get work packet
[12:54:52] Passkey found
[12:54:52] Gpu type=1 species=4.
[12:54:52] - Connecting to assignment server
[12:54:53] + No appropriate work server was available; will try again in a bit.
[12:54:53] + Couldn't get work instructions.
[12:54:53] - Attempt #5 to get work failed, and no other work to do.
[12:56:26] + Attempting to get work packet
[12:56:26] Passkey found
[12:56:26] Gpu type=1 species=4.
[12:56:26] - Connecting to assignment server
[12:56:27] + No appropriate work server was available; will try again in a bit.
[12:56:27] + Couldn't get work instructions.
[12:56:27] - Attempt #6 to get work failed, and no other work to do.
[12:59:16] + Attempting to get work packet
[12:59:16] Passkey found
[12:59:16] Gpu type=1 species=4.
[12:59:16] - Connecting to assignment server
[12:59:17] + No appropriate work server was available; will try again in a bit.
[12:59:17] + Couldn't get work instructions.
[12:59:17] - Attempt #7 to get work failed, and no other work to do.
This has been happening for me as well, all morning long.
				VijayPande
 - Pande Group Member
Thanks.  We're looking into it.
							Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
				Bobcat
Looks like we're alive again.
I realize that there will be problems from time to time, but it seems to me that 171.64.65.102 is in 'reject' mode way too often.
The server is in reject once again, as of Fri Jan 7 11:10:10 PST 2011
				GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Down again.
From Stanford Server Stats:
Folding@home server status
Report initiated on Sat Jan 15 19:15:10 PST 2011.
171.64.65.102 GPU vspg2v2 vvoelz full Reject
From my Log:
[02:58:30] + Attempting to send results [January 16 02:58:30 UTC]
[02:58:30] - Reading file work/wuresults_04.dat from core
[02:58:30] (Read 264899 bytes from disk)
[02:58:30] Gpu type=1 species=3.
[02:58:30] Connecting to http://171.64.65.102:8080/
[02:58:31] - Couldn't send HTTP request to server
[02:58:31] + Could not connect to Work Server (results)
[02:58:31] (171.64.65.102:8080)
[02:58:31] + Retrying using alternative port
[02:58:31] Connecting to http://171.64.65.102:80/
[02:58:32] - Couldn't send HTTP request to server
[02:58:32] + Could not connect to Work Server (results)
[02:58:32] (171.64.65.102:80)
[02:58:32] - Error: Could not transmit unit 04 (completed January 16) to work server.
From my Log:
				GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
Looks like it's back up. The Server stats aren't updated yet, though.
[03:42:17] + Attempting to get work packet
[03:42:17] Passkey found
[03:42:17] - Will indicate memory of 2047 MB
[03:42:17] Gpu type=1 species=3.
[03:42:17] - Connecting to assignment server
[03:42:17] Connecting to http://assign-GPU.stanford.edu:8080/
[03:42:17] Posted data.
[03:42:17] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[03:42:17] + News From Folding@Home: Welcome to Folding@Home
[03:42:17] Loaded queue successfully.
[03:42:17] Sent data
[03:42:17] Connecting to http://171.64.65.102:8080/
[03:42:18] Posted data.
[03:42:18] Initial: 0000; - Receiving payload (expected size: 97207)
[03:42:18] Conversation time very short, giving reduced weight in bandwidth avg
[03:42:18] - Downloaded at ~189 kB/s
[03:42:18] - Averaged speed for that direction ~183 kB/s
[03:42:18] + Received work.
[03:42:18] Trying to send all finished work units
[03:42:18] Project: 5738 (Run 2, Clone 636, Gen 107)
[03:42:18] - Read packet limit of 540015616... Set to 524286976.
				GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
It's down again - the 171.64.65.102 server log (http://fah-web.stanford.edu/logs/171.64.65.102.log.html) has been showing the status of REJECT since 1700 Stanford local time.
This is the main server for my class of ATI GPUs - and has been down a LOT.
GW.
BACK UP AT ~1820 - Downloaded new WU after trying for about 1 hr 20 minutes.
GW.
GW.
GW.
				Bobcat
Re: How to fix Systray client.cfg file?
Here we go again:
[09:39:18] + Attempting to send results [January 21 09:39:18 UTC]
[09:39:18] Gpu type=1 species=4.
[09:39:19] - Couldn't send HTTP request to server
[09:39:19] + Could not connect to Work Server (results)
[09:39:19] (171.64.65.102:8080)
[09:39:19] + Retrying using alternative port
[09:39:20] - Couldn't send HTTP request to server
[09:39:20] + Could not connect to Work Server (results)
[09:39:20] (171.64.65.102:80)
[09:39:20] - Error: Could not transmit unit 01 (completed January 21) to work server.
Pain in the #$%! I'm trying to see if I fixed everything and if I'll get the points. This is how the trouble started in the first place!
But I have to switch users, so I have to shut down the GPU client without the results being sent. It's unlikely I'll be able to turn it back on before the deadline. So PG doesn't get the results in time. Their loss, not mine.
Pain in the #$%! I think I'll just give up on the GPU client because they can't keep the servers working properly. I'm sick of this *^%$.
				Bobcat
It's dead again.  Dead again.  Dead again.  Dead again.  Dead again.  Dead again.  Dead again.  Dead again.  Dead again.  Dead again.
Someone put it out of its misery, please. Is there euthanasia for servers?
http://fah-web.stanford.edu/localinfo/contact.GPU.html
Dead from 01:10 PST to 03:50 PST.  Either it's set to automatically recover or somebody was working very strange hours at Stanford.
Yes, there is euthanasia for servers, but Stanford tends to keeps them on hospice care until the have the capacity to replace it.
				Bobcat
Note that this thread was started 3 months ago, and there are other threads about this server going back for well over a year(!), so 171.64.65.102 has been sick for a long time.  I'm just going to give up on GPU folding.  Between the problems of switching users with the GPU client and dealing with this screwed-up server, it's not worth the hassle.
If Stanford can't be bothered to keep their servers running, why should we bother to run-up our electric bills to do their work?
				Bobcat
171.64.65.102 is in reject mode again: http://fah-web.stanford.edu/localinfo/contact.GPU.html
