--- Opening Log file [October 26 08:59:17 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory:
Executable: Folding@home-Win32-x86
Arguments: -oneunit -advmethods -forceasm -verbosity 9
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[08:59:17] - Ask before connecting: No
[08:59:17] - User name: Napoleon (Team 191980)
[08:59:17] - User ID:
[08:59:17] - Machine ID: 1
[08:59:17]
[08:59:17] Loaded queue successfully.
[08:59:17] - Autosending finished units... [October 26 08:59:17 UTC]
[08:59:17] Trying to send all finished work units
[08:59:17] + No unsent completed units remaining.
[08:59:17] - Autosend completed
[08:59:17] - Preparing to get new work unit...
[08:59:17] Cleaning up work directory
[08:59:17] + Attempting to get work packet
[08:59:17] Passkey found
[08:59:17] - Will indicate memory of 512 MB
[08:59:17] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 4, Stepping: 9
[08:59:17] - Connecting to assignment server
[08:59:17] Connecting to http://assign.stanford.edu:8080/
[08:59:18] Posted data.
[08:59:18] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[08:59:18] + News From Folding@Home: Welcome to Folding@Home
[08:59:19] Loaded queue successfully.
[08:59:19] Sent data
[08:59:19] Connecting to http://171.64.65.62:8080/
[08:59:20] Posted data.
[08:59:20] Initial: 0000; - Receiving payload (expected size: 518443)
[08:59:23] - Downloaded at ~168 kB/s
[08:59:23] - Averaged speed for that direction ~179 kB/s
[08:59:23] + Received work.
[08:59:23] + Closed connections
[08:59:23]
[08:59:23] + Processing work unit
[08:59:23] Core required: FahCore_78.exe
[08:59:23] Core found.
[08:59:23] Working on queue slot 02 [October 26 08:59:23 UTC]
[08:59:23] + Working ...
[08:59:23] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -nice 19 -priority 96 -checkpoint 30 -forceasm -verbose -lifeline 2468 -version 630'
[08:59:23]
[08:59:23] *------------------------------*
[08:59:23] Folding@Home Gromacs Core
[08:59:23] Version 1.90 (March 8, 2006)
[08:59:23]
[08:59:23] Preparing to commence simulation
[08:59:23] - Assembly optimizations manually forced on.
[08:59:23] - Not checking prior termination.
[08:59:23] - Expanded 517931 -> 2531477 (decompressed 488.7 percent)
[08:59:23] - Starting from initial work packet
[08:59:23]
[08:59:23] Project: 6503 (Run 9, Clone 320, Gen 96)
[08:59:23]
[08:59:23] Assembly optimizations on if available.
[08:59:23] Entering M.D.
[08:59:30] Protein: TR462_B_10 in water
[08:59:30]
[08:59:30] Writing local files
[08:59:30] Extra SSE boost OK.
[08:59:30] Completed 0 out of 250000 steps  (0%)
[09:11:08] Writing local files
[09:11:08] Completed 2500 out of 250000 steps  (1%)
[09:22:45] Writing local files
[09:22:45] Completed 5000 out of 250000 steps  (2%)
[09:34:31] Writing local files
[09:34:31] Completed 7500 out of 250000 steps  (3%)
[09:46:09] Writing local files
[09:46:09] Completed 10000 out of 250000 steps  (4%)
[09:57:50] Writing local files
[09:57:50] Completed 12500 out of 250000 steps  (5%)
[10:09:29] Writing local files
[10:09:29] Completed 15000 out of 250000 steps  (6%)
[10:21:08] Writing local files
[10:21:08] Completed 17500 out of 250000 steps  (7%)
[10:32:47] Writing local files
[10:32:47] Completed 20000 out of 250000 steps  (8%)
[10:44:25] Writing local files
[10:44:25] Completed 22500 out of 250000 steps  (9%)
[10:56:03] Writing local files
[10:56:03] Completed 25000 out of 250000 steps  (10%)
[11:01:06] Gromacs cannot continue further.
[11:01:06] Going to send back what have done.
[11:01:06] logfile size: 12951
[11:01:06] - Writing 13487 bytes of core data to disk...
[11:01:06] Done: 12975 -> 4012 (compressed to 30.9 percent)
[11:01:06]   ... Done.
[11:01:06]
[11:01:06] Folding@home Core Shutdown: EARLY_UNIT_END
[11:01:09] CoreStatus = 72 (114)
[11:01:09] Sending work to server
[11:01:09] Project: 6503 (Run 9, Clone 320, Gen 96)
[11:01:09] - Read packet limit of 540015616... Set to 524286976.
[11:01:09] + Attempting to send results [October 26 11:01:09 UTC]
[11:01:09] - Reading file work/wuresults_02.dat from core
[11:01:09]   (Read 4524 bytes from disk)
[11:01:09] Connecting to http://171.64.65.62:8080/
[11:01:10] Posted data.
[11:01:10] Initial: 0000; - Uploaded at ~5 kB/s
[11:01:10] - Averaged speed for that direction ~46 kB/s
[11:01:10] + Results successfully sent
[11:01:10] Thank you for your contribution to Folding@Home.
[11:01:14] Trying to send all finished work units
[11:01:14] + No unsent completed units remaining.
[11:01:14] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[11:01:14] Killing all core threads
Folding@Home Client Shutdown.
