Project: 11179 (Run 5, Clone 1, Gen 11)
theo343
Hardware configuration: Home Network:
ADSL 12Mbps - 807 / 14.439
USRobotics 8port 10/100/1000
All computers connected with TP CAT5
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
removed - (8800GTS-512MB@724/1810/972)
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xGPU2 v6.20 R1 Core 1.18/1.19
1xSMP v6.23 Beta R1
HC2:
AM2+ x4 Phenom 9950@3GHz
2GB Crucial Ballistix PC2-5300
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
3xGPU2 v6.20 R1 Core 1.18
1xSMP v6.23 Beta R1
HC3: (not folding atm and outdated)
X2 6000+@Stock
HD3850OC-512MB@783MHz
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*GPU2 v6.12 Beta8 Core 1.04
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
8800GT-256MB@702/1755/900
4GB PC6400
Tagan 480W
Vista Ultimate 32bit SP1
FW 178.24
1xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
OC2:
E8400@stock
2x8800GT-512MB@stock
8GB PC3-8500
Corsair HX520
Vista Business 64bit
FW178.24
2xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
Post by theo343 »
It seems it wont get uploaded after finished and the server replies that it doesnt know about this WU. Then my client goes into (remission) a series of errors.
[20:04:19] - Server does not have record of this unit. Will try again later.
[18:00:00] Project: 11179 (Run 5, Clone 1, Gen 11)
[18:00:00]
[18:00:00] Assembly optimizations on if available.
[18:00:00] Entering M.D.
[18:00:06] Tpr hash work/wudata_06.tpr:  581637694 3111703682 1297376654 3815604558 378191717
[18:00:06] Working on ALZHEIMER'S DISEASE AMYLOID
[18:00:06] Client config found, loading data.
[18:00:06] Starting GUI Server
[18:01:20] Completed 1%
[20:02:04] Completed 99%
[20:03:21] Completed 100%
[20:03:21] Finished fah_main
[20:03:21]
[20:03:21] Successful run
[20:03:21] DynamicWrapper: Finished Work Unit: sleep=10000
[20:03:31] Reserved 2451912 bytes for xtc file; Cosm status=0
[20:03:31] Allocated 2451912 bytes for xtc file
[20:03:31] - Reading up to 2451912 from "work/wudata_06.xtc": Read 2451912
[20:03:31] Read 2451912 bytes from xtc file; available packet space=783978552
[20:03:31] xtc file hash check passed.
[20:03:31] Reserved 76080 76080 783978552 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[20:03:31] Allocated 76080 bytes for arc file
[20:03:31] - Reading up to 76080 from "work/wudata_06.trr": Read 76080
[20:03:31] Read 76080 bytes from arc file; available packet space=783902472
[20:03:31] trr file hash check passed.
[20:03:31] Allocated 544 bytes for edr file
[20:03:31] Read bedfile
[20:03:31] edr file hash check passed.
[20:03:31] Allocated 121700 bytes for logfile
[20:03:31] Read logfile
[20:03:31] GuardedRun: success in DynamicWrapper
[20:03:31] GuardedRun: done
[20:03:31] Run: GuardedRun completed.
[20:03:35] + Opened results file
[20:03:35] - Writing 2650748 bytes of core data to disk...
[20:03:36] Done: 2650236 -> 2494466 (compressed to 94.1 percent)
[20:03:36]   ... Done.
[20:03:36] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[20:03:36] Shutting down core
[20:03:36]
[20:03:36] Folding@home Core Shutdown: FINISHED_UNIT
[20:03:38] CoreStatus = 64 (100)
[20:03:38] Unit 6 finished with 100 percent of time to deadline remaining.
[20:03:38] Updated performance fraction: 0.996957
[20:03:38] Sending work to server
[20:03:38] Project: 11179 (Run 5, Clone 1, Gen 11)
[20:03:38] - Read packet limit of 540015616... Set to 524286976.
[20:03:38] + Attempting to send results [October 18 20:03:38 UTC]
[20:03:38] - Reading file work/wuresults_06.dat from core
[20:03:38]   (Read 2494978 bytes from disk)
[20:03:38] Gpu type=2 species=30.
[20:03:38] Connecting to http://171.67.108.31:8080/
[20:04:19] Posted data.
[20:04:19] Initial: 0000; - Uploaded at ~59 kB/s
[20:04:19] - Averaged speed for that direction ~56 kB/s
[20:04:19] - Error: Could not transmit unit 06 (completed October 18) to work server.
[20:04:19] - 1 failed uploads of this unit.
[20:04:19]   Keeping unit 06 in queue.
[20:04:19] Trying to send all finished work units
[20:04:19] Project: 11179 (Run 5, Clone 1, Gen 11)
[20:04:19] - Read packet limit of 540015616... Set to 524286976.
[20:04:19] + Attempting to send results [October 18 20:04:19 UTC]
[20:04:19] - Reading file work/wuresults_06.dat from core
[20:04:19]   (Read 2494978 bytes from disk)
[20:04:19] Gpu type=2 species=30.
[20:04:19] Connecting to http://171.67.108.31:8080/
[20:04:54] Posted data.
[20:04:54] Initial: 0000; - Uploaded at ~69 kB/s
[20:04:54] - Averaged speed for that direction ~59 kB/s
[20:04:54] - Server does not have record of this unit. Will try again later.
[20:04:54] - Error: Could not transmit unit 06 (completed October 18) to work server.
[20:04:54] - 2 failed uploads of this unit.
[20:04:54] - Read packet limit of 540015616... Set to 524286976.
[20:04:54] + Attempting to send results [October 18 20:04:54 UTC]
[20:04:54] - Reading file work/wuresults_06.dat from core
[20:04:54]   (Read 2494978 bytes from disk)
[20:04:54] Gpu type=2 species=30.
[20:04:54] Connecting to http://171.67.108.26:8080/
[20:05:30] Posted data.
[20:05:30] Initial: 0000; - Uploaded at ~67 kB/s
[20:05:30] - Averaged speed for that direction ~60 kB/s
[20:05:30] - Server does not have record of this unit. Will try again later.
[20:05:30]   Could not transmit unit 06 to Collection server; keeping in queue.
[20:05:30] + Sent 0 of 1 completed units to the server
[20:05:30] - Preparing to get new work unit...
[20:05:30] Cleaning up work directory
[20:05:30] + Attempting to get work packet
[20:05:30] Passkey found
[20:05:30] - Will indicate memory of 12279 MB
[20:05:30] Gpu type=2 species=30.
[20:05:30] - Connecting to assignment server
[20:05:30] Connecting to http://assign-GPU.stanford.edu:8080/
[20:05:32] Posted data.
[20:05:32] Initial: 40AB; - Successful: assigned to (171.64.65.61).
[20:05:32] + News From Folding@Home: Welcome to Folding@Home
[20:05:32] Loaded queue successfully.
[20:05:32] Gpu type=2 species=30.
[20:05:32] Sent data
[20:05:32] Connecting to http://171.64.65.61:8080/
[20:05:33] Posted data.
[20:05:33] Initial: 0000; - Receiving payload (expected size: 74292)
[20:05:34] - Downloaded at ~72 kB/s
[20:05:34] - Averaged speed for that direction ~54 kB/s
[20:05:34] + Received work.
[20:05:34] Trying to send all finished work units
[20:05:34] Project: 11179 (Run 5, Clone 1, Gen 11)
[20:05:34] - Read packet limit of 540015616... Set to 524286976.
[20:05:34] + Attempting to send results [October 18 20:05:34 UTC]
[20:05:34] - Reading file work/wuresults_06.dat from core
[20:05:34]   (Read 2494978 bytes from disk)
[20:05:34] Gpu type=2 species=30.
[20:05:34] Connecting to http://171.67.108.31:8080/
[20:06:09] Posted data.
[20:06:09] Initial: 0000; - Uploaded at ~69 kB/s
[20:06:09] - Averaged speed for that direction ~62 kB/s
[20:06:09] - Server does not have record of this unit. Will try again later.
[20:06:09] - Error: Could not transmit unit 06 (completed October 18) to work server.
[20:06:09] - 3 failed uploads of this unit.
[20:06:09] - Read packet limit of 540015616... Set to 524286976.
[20:06:09] + Attempting to send results [October 18 20:06:09 UTC]
[20:06:09] - Reading file work/wuresults_06.dat from core
[20:06:09]   (Read 2494978 bytes from disk)
[20:06:09] Gpu type=2 species=30.
[20:06:09] Connecting to http://171.67.108.26:8080/
[20:06:54] Posted data.
[20:06:54] Initial: 0000; - Uploaded at ~54 kB/s
[20:06:54] - Averaged speed for that direction ~60 kB/s
[20:06:54] - Server does not have record of this unit. Will try again later.
[20:06:54]   Could not transmit unit 06 to Collection server; keeping in queue.
[20:06:54] + Sent 0 of 1 completed units to the server
[20:06:54] + Closed connections
[20:06:54]
[20:06:54] + Processing work unit
[20:06:54] Core required: FahCore_11.exe
[20:06:54] Core not found.
[20:06:54] - Core is not present or corrupted.
[20:06:54] - Attempting to download new core...
[20:06:54] + Downloading new core: FahCore_11.exe
[20:06:54] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:06:56] Initial: AFDE; + 10240 bytes downloaded
[20:06:59] Initial: CADE; + 665067 bytes downloaded
[20:06:59] Verifying core Core_11.fah...
[20:06:59] Signature is VALID
[20:06:59]
[20:06:59] Trying to unzip core FahCore_11.exe
[20:06:59] Decompressed FahCore_11.exe (1908736 bytes) successfully
[20:07:04] + Core successfully engaged
[20:07:09]
[20:07:09] + Processing work unit
[20:07:09] Core required: FahCore_11.exe
[20:07:09] Core found.
[20:07:09] Working on queue slot 07 [October 18 20:07:09 UTC]
[20:07:09] + Working ...
[20:07:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:07:09]
[20:07:09] *------------------------------*
[20:07:09] Folding@Home GPU Core
[20:07:09] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:07:09]
[20:07:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:07:09] Build host: amoeba
[20:07:09] Board Type: Nvidia
[20:07:09] Core      :
[20:07:09] Preparing to commence simulation
[20:07:09] - Looking at optimizations...
[20:07:09] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[20:07:09] - Created dyn
[20:07:09] - Files status OK
[20:07:09] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:07:09] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:07:09] - Digital signature verified
[20:07:09]
[20:07:09] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:07:09]
[20:07:09] Assembly optimizations on if available.
[20:07:09] Entering M.D.
[20:07:15] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:07:15]
[20:07:15] Calling fah_main args: 14 usage=100
[20:07:15]
[20:07:19] CoreStatus = 63 (99)
[20:07:19] + Error starting Folding@Home core.
[20:07:24]
[20:07:24] + Processing work unit
[20:07:24] Core required: FahCore_11.exe
[20:07:24] Core found.
[20:07:24] Working on queue slot 07 [October 18 20:07:24 UTC]
[20:07:24] + Working ...
[20:07:24] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:07:24]
[20:07:24] *------------------------------*
[20:07:24] Folding@Home GPU Core
[20:07:24] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:07:24]
[20:07:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:07:24] Build host: amoeba
[20:07:24] Board Type: Nvidia
[20:07:24] Core      :
[20:07:24] Preparing to commence simulation
[20:07:24] - Ensuring status. Please wait.
[20:07:34] - Looking at optimizations...
[20:07:34] - Working with standard loops on this execution.
[20:07:34] - Previous termination of core was improper.
[20:07:34] - Files status OK
[20:07:34] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:07:34] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:07:34] - Digital signature verified
[20:07:34]
[20:07:34] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:07:34]
[20:07:34] Entering M.D.
[20:07:40] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:07:40]
[20:07:40] Calling fah_main args: 14 usage=100
[20:07:40]
[20:07:43] CoreStatus = 63 (99)
[20:07:43] + Error starting Folding@Home core.
[20:07:48]
[20:07:48] + Processing work unit
[20:07:48] Core required: FahCore_11.exe
[20:07:48] Core found.
[20:07:48] Working on queue slot 07 [October 18 20:07:48 UTC]
[20:07:48] + Working ...
[20:07:48] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:07:48]
[20:07:48] *------------------------------*
[20:07:48] Folding@Home GPU Core
[20:07:48] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:07:48]
[20:07:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:07:48] Build host: amoeba
[20:07:48] Board Type: Nvidia
[20:07:48] Core      :
[20:07:48] Preparing to commence simulation
[20:07:48] - Ensuring status. Please wait.
[20:07:57] - Looking at optimizations...
[20:07:57] - Working with standard loops on this execution.
[20:07:57] - Previous termination of core was improper.
[20:07:57] - Going to use standard loops.
[20:07:57] - Files status OK
[20:07:57] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:07:57] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:07:57] - Digital signature verified
[20:07:57]
[20:07:57] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:07:57]
[20:07:57] Entering M.D.
[20:08:03] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:08:03]
[20:08:03] Calling fah_main args: 14 usage=100
[20:08:03]
[20:08:06] CoreStatus = 63 (99)
[20:08:06] + Error starting Folding@Home core.
[20:08:06] - Attempting to download new core...
[20:08:06] + Downloading new core: FahCore_11.exe
[20:08:06] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:08:07] Initial: AFDE; + 10240 bytes downloaded
[20:08:10] Initial: CADE; + 665067 bytes downloaded
[20:08:10] Verifying core Core_11.fah...
[20:08:10] Signature is VALID
[20:08:10]
[20:08:10] Trying to unzip core FahCore_11.exe
[20:08:10] - Couldn't open file FahCore_11.exe
[20:08:10] + Error: Could not extract core
[20:08:10] + Core download error (#2), waiting before retry...
[20:08:19] + Downloading new core: FahCore_11.exe
[20:08:19] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:08:20] Initial: AFDE; + 10240 bytes downloaded
[20:08:24] Initial: CADE; + 665067 bytes downloaded
[20:08:24] Verifying core Core_11.fah...
[20:08:24] Signature is VALID
[20:08:24]
[20:08:24] Trying to unzip core FahCore_11.exe
[20:08:24] - Couldn't open file FahCore_11.exe
[20:08:24] + Error: Could not extract core
[20:08:24] + Core download error (#3), waiting before retry...
[20:08:47] + Downloading new core: FahCore_11.exe
[20:08:47] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:08:48] Initial: AFDE; + 10240 bytes downloaded
[20:08:51] Initial: CADE; + 665067 bytes downloaded
[20:08:51] Verifying core Core_11.fah...
[20:08:51] Signature is VALID
[20:08:51]
[20:08:51] Trying to unzip core FahCore_11.exe
[20:08:51] - Couldn't open file FahCore_11.exe
[20:08:51] + Error: Could not extract core
[20:08:51] + Core download error (#4), waiting before retry...
[20:09:24] + Downloading new core: FahCore_11.exe
[20:09:24] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:09:33] Initial: AFDE; + 10240 bytes downloaded
[20:09:36] Initial: CADE; + 665067 bytes downloaded
[20:09:36] Verifying core Core_11.fah...
[20:09:36] Signature is VALID
[20:09:36]
[20:09:36] Trying to unzip core FahCore_11.exe
[20:09:36] Decompressed FahCore_11.exe (1908736 bytes) successfully
[20:09:41] + Core successfully engaged
[20:09:46]
[20:09:46] + Processing work unit
[20:09:46] Core required: FahCore_11.exe
[20:09:46] Core found.
[20:09:46] Working on queue slot 07 [October 18 20:09:46 UTC]
[20:09:46] + Working ...
[20:09:46] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:09:46]
[20:09:46] *------------------------------*
[20:09:46] Folding@Home GPU Core
[20:09:46] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:09:46]
[20:09:46] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:09:46] Build host: amoeba
[20:09:46] Board Type: Nvidia
[20:09:46] Core      :
[20:09:46] Preparing to commence simulation
[20:09:46] - Ensuring status. Please wait.
[20:09:56] - Looking at optimizations...
[20:09:56] - Working with standard loops on this execution.
[20:09:56] - Previous termination of core was improper.
[20:09:56] - Going to use standard loops.
[20:09:56] - Files status OK
[20:09:56] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:09:56] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:09:56] - Digital signature verified
[20:09:56]
[20:09:56] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:09:56]
[20:09:56] Entering M.D.
[20:10:02] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:10:02]
[20:10:02] Calling fah_main args: 14 usage=100
[20:10:02]
[20:10:04] CoreStatus = 63 (99)
[20:10:04] + Error starting Folding@Home core.
[20:10:09]
[20:10:09] + Processing work unit
[20:10:09] Core required: FahCore_11.exe
[20:10:09] Core found.
[20:10:09] Working on queue slot 07 [October 18 20:10:09 UTC]
[20:10:09] + Working ...
[20:10:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:10:09]
[20:10:09] *------------------------------*
[20:10:09] Folding@Home GPU Core
[20:10:09] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:10:09]
[20:10:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:10:09] Build host: amoeba
[20:10:09] Board Type: Nvidia
[20:10:09] Core      :
[20:10:09] Preparing to commence simulation
[20:10:09] - Ensuring status. Please wait.
[20:10:19] - Looking at optimizations...
[20:10:19] - Working with standard loops on this execution.
[20:10:19] - Previous termination of core was improper.
[20:10:19] - Going to use standard loops.
[20:10:19] - Files status OK
[20:10:19] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:10:19] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:10:19] - Digital signature verified
[20:10:19]
[20:10:19] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:10:19]
[20:10:19] Entering M.D.
[20:10:25] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:10:25]
[20:10:25] Calling fah_main args: 14 usage=100
[20:10:25]
[20:10:28] CoreStatus = 63 (99)
[20:10:28] + Error starting Folding@Home core.
[20:10:33]
[20:10:33] + Processing work unit
[20:10:33] Core required: FahCore_11.exe
[20:10:33] Core found.
[20:10:33] Working on queue slot 07 [October 18 20:10:33 UTC]
[20:10:33] + Working ...
[20:10:33] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:10:33]
[20:10:33] *------------------------------*
[20:10:33] Folding@Home GPU Core
[20:10:33] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:10:33]
[20:10:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:10:33] Build host: amoeba
[20:10:33] Board Type: Nvidia
[20:10:33] Core      :
[20:10:33] Preparing to commence simulation
[20:10:33] - Ensuring status. Please wait.
[20:10:42] - Looking at optimizations...
[20:10:42] - Working with standard loops on this execution.
[20:10:42] - Previous termination of core was improper.
[20:10:42] - Going to use standard loops.
[20:10:42] - Files status OK
[20:10:42] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:10:42] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:10:42] - Digital signature verified
[20:10:42]
[20:10:42] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:10:42]
[20:10:42] Entering M.D.
[20:10:48] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:10:48]
[20:10:48] Calling fah_main args: 14 usage=100
[20:10:48]
[20:10:51] CoreStatus = 63 (99)
[20:10:51] + Error starting Folding@Home core.
[20:10:51] - Attempting to download new core...
[20:10:51] + Downloading new core: FahCore_11.exe
[20:10:51] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:10:52] Initial: AFDE; + 10240 bytes downloaded
[20:10:54] Initial: CADE; + 665067 bytes downloaded
[20:10:54] Verifying core Core_11.fah...
[20:10:54] Signature is VALID
[20:10:54]
[20:10:54] Trying to unzip core FahCore_11.exe
[20:10:54] - Couldn't open file FahCore_11.exe
[20:10:54] + Error: Could not extract core
[20:10:54] + Core download error (#2), waiting before retry...
[20:11:06] + Downloading new core: FahCore_11.exe
[20:11:06] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:11:07] Initial: AFDE; + 10240 bytes downloaded
[20:11:07] Initial: E027; + 20480 bytes downloaded
[20:11:07] Initial: 8EE5; + 30720 bytes downloaded
[20:11:07] Initial: 9838; + 40960 bytes downloaded
[20:11:07] Initial: D615; + 51200 bytes downloaded
[20:11:08] Initial: CAA5; + 61440 bytes downloaded
[20:11:08] Initial: 3354; + 71680 bytes downloaded
[20:11:08] Initial: 6FF7; + 81920 bytes downloaded
[20:11:08] Initial: 5BA3; + 92160 bytes downloaded
[20:11:08] Initial: 23F0; + 102400 bytes downloaded
[20:11:08] Initial: C043; + 112640 bytes downloaded
[20:11:08] Initial: 2DB2; + 122880 bytes downloaded
[20:11:08] Initial: E434; + 133120 bytes downloaded
[20:11:08] Initial: 321F; + 143360 bytes downloaded
[20:11:08] Initial: 93B0; + 153600 bytes downloaded
[20:11:08] Initial: 245F; + 163840 bytes downloaded
[20:11:08] Initial: 6150; + 174080 bytes downloaded
[20:11:08] Initial: A664; + 184320 bytes downloaded
[20:11:08] Initial: 6EF8; + 194560 bytes downloaded
[20:11:08] Initial: 65A4; + 204800 bytes downloaded
[20:11:08] Initial: F31D; + 215040 bytes downloaded
[20:11:08] Initial: AD3D; + 225280 bytes downloaded
[20:11:08] Initial: FEF9; + 235520 bytes downloaded
[20:11:08] Initial: 9A18; + 245760 bytes downloaded
[20:11:08] Initial: F515; + 256000 bytes downloaded
[20:11:08] Initial: 7CD9; + 266240 bytes downloaded
[20:11:08] Initial: 0905; + 276480 bytes downloaded
[20:11:09] Initial: D379; + 286720 bytes downloaded
[20:11:09] Initial: 4E51; + 296960 bytes downloaded
[20:11:09] Initial: B099; + 307200 bytes downloaded
[20:11:09] Initial: 4645; + 317440 bytes downloaded
[20:11:09] Initial: D03A; + 327680 bytes downloaded
[20:11:09] Initial: 1144; + 337920 bytes downloaded
[20:11:09] Initial: 9388; + 348160 bytes downloaded
[20:11:09] Initial: 34A4; + 358400 bytes downloaded
[20:11:09] Initial: BD67; + 368640 bytes downloaded
[20:11:09] Initial: 0594; + 378880 bytes downloaded
[20:11:09] Initial: AFD1; + 389120 bytes downloaded
[20:11:09] Initial: 1A2A; + 399360 bytes downloaded
[20:11:09] Initial: 59F1; + 409600 bytes downloaded
[20:11:09] Initial: 2512; + 419840 bytes downloaded
[20:11:09] Initial: 74B1; + 430080 bytes downloaded
[20:11:09] Initial: 94F2; + 440320 bytes downloaded
[20:11:09] Initial: D8E0; + 450560 bytes downloaded
[20:11:09] Initial: 01A4; + 460800 bytes downloaded
[20:11:09] Initial: BCAF; + 471040 bytes downloaded
[20:11:09] Initial: B064; + 481280 bytes downloaded
[20:11:09] Initial: 3236; + 491520 bytes downloaded
[20:11:09] Initial: 3291; + 501760 bytes downloaded
[20:11:09] Initial: 6A7F; + 512000 bytes downloaded
[20:11:09] Initial: 61F7; + 522240 bytes downloaded
[20:11:09] Initial: F17C; + 532480 bytes downloaded
[20:11:09] Initial: 4E88; + 542720 bytes downloaded
[20:11:09] Initial: 7111; + 552960 bytes downloaded
[20:11:09] Initial: 1568; + 563200 bytes downloaded
[20:11:09] Initial: 9B04; + 573440 bytes downloaded
[20:11:09] Initial: 783B; + 583680 bytes downloaded
[20:11:09] Initial: 2FC8; + 593920 bytes downloaded
[20:11:09] Initial: E6E7; + 604160 bytes downloaded
[20:11:09] Initial: E7AB; + 614400 bytes downloaded
[20:11:09] Initial: D677; + 624640 bytes downloaded
[20:11:09] Initial: 5C98; + 634880 bytes downloaded
[20:11:09] Initial: 7BEE; + 645120 bytes downloaded
[20:11:09] Initial: D127; + 655360 bytes downloaded
[20:11:09] Initial: CADE; + 665067 bytes downloaded
[20:11:09] Verifying core Core_11.fah...
[20:11:09] Signature is VALID
[20:11:09]
[20:11:09] Trying to unzip core FahCore_11.exe
[20:11:09] - Couldn't open file FahCore_11.exe
[20:11:09] + Error: Could not extract core
[20:11:09] + Core download error (#3), waiting before retry...
[20:11:28] + Downloading new core: FahCore_11.exe
[20:11:28] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:11:29] Initial: AFDE; + 10240 bytes downloaded
[20:11:29] Initial: E027; + 20480 bytes downloaded
[20:11:30] Initial: 8EE5; + 30720 bytes downloaded
[20:11:30] Initial: 9838; + 40960 bytes downloaded
[20:11:30] Initial: D615; + 51200 bytes downloaded
[20:11:30] Initial: CAA5; + 61440 bytes downloaded
[20:11:30] Initial: 3354; + 71680 bytes downloaded
[20:11:30] Initial: 6FF7; + 81920 bytes downloaded
[20:11:30] Initial: 5BA3; + 92160 bytes downloaded
[20:11:30] Initial: 23F0; + 102400 bytes downloaded
[20:11:30] Initial: C043; + 112640 bytes downloaded
[20:11:30] Initial: 2DB2; + 122880 bytes downloaded
[20:11:30] Initial: E434; + 133120 bytes downloaded
[20:11:31] Initial: 321F; + 143360 bytes downloaded
[20:11:31] Initial: 93B0; + 153600 bytes downloaded
[20:11:31] Initial: 245F; + 163840 bytes downloaded
[20:11:31] Initial: 6150; + 174080 bytes downloaded
[20:11:31] Initial: A664; + 184320 bytes downloaded
[20:11:31] Initial: 6EF8; + 194560 bytes downloaded
[20:11:31] Initial: 65A4; + 204800 bytes downloaded
[20:11:31] Initial: F31D; + 215040 bytes downloaded
[20:11:31] Initial: AD3D; + 225280 bytes downloaded
[20:11:31] Initial: FEF9; + 235520 bytes downloaded
[20:11:31] Initial: 9A18; + 245760 bytes downloaded
[20:11:31] Initial: F515; + 256000 bytes downloaded
[20:11:31] Initial: 7CD9; + 266240 bytes downloaded
[20:11:31] Initial: 0905; + 276480 bytes downloaded
[20:11:31] Initial: D379; + 286720 bytes downloaded
[20:11:31] Initial: 4E51; + 296960 bytes downloaded
[20:11:31] Initial: B099; + 307200 bytes downloaded
[20:11:31] Initial: 4645; + 317440 bytes downloaded
[20:11:31] Initial: D03A; + 327680 bytes downloaded
[20:11:31] Initial: 1144; + 337920 bytes downloaded
[20:11:31] Initial: 9388; + 348160 bytes downloaded
[20:11:31] Initial: 34A4; + 358400 bytes downloaded
[20:11:31] Initial: BD67; + 368640 bytes downloaded
[20:11:31] Initial: 0594; + 378880 bytes downloaded
[20:11:31] Initial: AFD1; + 389120 bytes downloaded
[20:11:31] Initial: 1A2A; + 399360 bytes downloaded
[20:11:31] Initial: 59F1; + 409600 bytes downloaded
[20:11:31] Initial: 2512; + 419840 bytes downloaded
[20:11:31] Initial: 74B1; + 430080 bytes downloaded
[20:11:31] Initial: 94F2; + 440320 bytes downloaded
[20:11:31] Initial: D8E0; + 450560 bytes downloaded
[20:11:32] Initial: 01A4; + 460800 bytes downloaded
[20:11:32] Initial: BCAF; + 471040 bytes downloaded
[20:11:32] Initial: B064; + 481280 bytes downloaded
[20:11:32] Initial: 3236; + 491520 bytes downloaded
[20:11:32] Initial: 3291; + 501760 bytes downloaded
[20:11:32] Initial: 6A7F; + 512000 bytes downloaded
[20:11:32] Initial: 61F7; + 522240 bytes downloaded
[20:11:32] Initial: F17C; + 532480 bytes downloaded
[20:11:32] Initial: 4E88; + 542720 bytes downloaded
[20:11:32] Initial: 7111; + 552960 bytes downloaded
[20:11:32] Initial: 1568; + 563200 bytes downloaded
[20:11:32] Initial: 9B04; + 573440 bytes downloaded
[20:11:32] Initial: 783B; + 583680 bytes downloaded
[20:11:32] Initial: 2FC8; + 593920 bytes downloaded
[20:11:32] Initial: E6E7; + 604160 bytes downloaded
[20:11:32] Initial: E7AB; + 614400 bytes downloaded
[20:11:32] Initial: D677; + 624640 bytes downloaded
[20:11:32] Initial: 5C98; + 634880 bytes downloaded
[20:11:32] Initial: 7BEE; + 645120 bytes downloaded
[20:11:32] Initial: D127; + 655360 bytes downloaded
[20:11:32] Initial: CADE; + 665067 bytes downloaded
[20:11:32] Verifying core Core_11.fah...
[20:11:32] Signature is VALID
[20:11:32]
[20:11:32] Trying to unzip core FahCore_11.exe
[20:11:32] - Couldn't open file FahCore_11.exe
[20:11:32] + Error: Could not extract core
[20:11:32] + Core download error (#4), waiting before retry...
[20:12:04] + Downloading new core: FahCore_11.exe
[20:12:04] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:12:05] Initial: AFDE; + 10240 bytes downloaded
[20:12:06] Initial: E027; + 20480 bytes downloaded
[20:12:06] Initial: 8EE5; + 30720 bytes downloaded
[20:12:06] Initial: 9838; + 40960 bytes downloaded
[20:12:06] Initial: D615; + 51200 bytes downloaded
[20:12:06] Initial: CAA5; + 61440 bytes downloaded
[20:12:06] Initial: 3354; + 71680 bytes downloaded
[20:12:06] Initial: 6FF7; + 81920 bytes downloaded
[20:12:06] Initial: 5BA3; + 92160 bytes downloaded
[20:12:07] Initial: 23F0; + 102400 bytes downloaded
[20:12:07] Initial: C043; + 112640 bytes downloaded
[20:12:07] Initial: 2DB2; + 122880 bytes downloaded
[20:12:07] Initial: E434; + 133120 bytes downloaded
[20:12:07] Initial: 321F; + 143360 bytes downloaded
[20:12:07] Initial: 93B0; + 153600 bytes downloaded
[20:12:07] Initial: 245F; + 163840 bytes downloaded
[20:12:07] Initial: 6150; + 174080 bytes downloaded
[20:12:07] Initial: A664; + 184320 bytes downloaded
[20:12:07] Initial: 6EF8; + 194560 bytes downloaded
[20:12:07] Initial: 65A4; + 204800 bytes downloaded
[20:12:07] Initial: F31D; + 215040 bytes downloaded
[20:12:07] Initial: AD3D; + 225280 bytes downloaded
[20:12:07] Initial: FEF9; + 235520 bytes downloaded
[20:12:07] Initial: 9A18; + 245760 bytes downloaded
[20:12:07] Initial: F515; + 256000 bytes downloaded
[20:12:07] Initial: 7CD9; + 266240 bytes downloaded
[20:12:07] Initial: 0905; + 276480 bytes downloaded
[20:12:07] Initial: D379; + 286720 bytes downloaded
[20:12:07] Initial: 4E51; + 296960 bytes downloaded
[20:12:07] Initial: B099; + 307200 bytes downloaded
[20:12:07] Initial: 4645; + 317440 bytes downloaded
[20:12:07] Initial: D03A; + 327680 bytes downloaded
[20:12:07] Initial: 1144; + 337920 bytes downloaded
[20:12:08] Initial: 9388; + 348160 bytes downloaded
[20:12:08] Initial: 34A4; + 358400 bytes downloaded
[20:12:08] Initial: BD67; + 368640 bytes downloaded
[20:12:08] Initial: 0594; + 378880 bytes downloaded
[20:12:08] Initial: AFD1; + 389120 bytes downloaded
[20:12:08] Initial: 1A2A; + 399360 bytes downloaded
[20:12:08] Initial: 59F1; + 409600 bytes downloaded
[20:12:08] Initial: 2512; + 419840 bytes downloaded
[20:12:08] Initial: 74B1; + 430080 bytes downloaded
[20:12:08] Initial: 94F2; + 440320 bytes downloaded
[20:12:08] Initial: D8E0; + 450560 bytes downloaded
[20:12:08] Initial: 01A4; + 460800 bytes downloaded
[20:12:08] Initial: BCAF; + 471040 bytes downloaded
[20:12:08] Initial: B064; + 481280 bytes downloaded
[20:12:08] Initial: 3236; + 491520 bytes downloaded
[20:12:08] Initial: 3291; + 501760 bytes downloaded
[20:12:08] Initial: 6A7F; + 512000 bytes downloaded
[20:12:08] Initial: 61F7; + 522240 bytes downloaded
[20:12:08] Initial: F17C; + 532480 bytes downloaded
[20:12:08] Initial: 4E88; + 542720 bytes downloaded
[20:12:08] Initial: 7111; + 552960 bytes downloaded
[20:12:08] Initial: 1568; + 563200 bytes downloaded
[20:12:08] Initial: 9B04; + 573440 bytes downloaded
[20:12:08] Initial: 783B; + 583680 bytes downloaded
[20:12:08] Initial: 2FC8; + 593920 bytes downloaded
[20:12:08] Initial: E6E7; + 604160 bytes downloaded
[20:12:08] Initial: E7AB; + 614400 bytes downloaded
[20:12:08] Initial: D677; + 624640 bytes downloaded
[20:12:08] Initial: 5C98; + 634880 bytes downloaded
[20:12:08] Initial: 7BEE; + 645120 bytes downloaded
[20:12:08] Initial: D127; + 655360 bytes downloaded
[20:12:08] Initial: CADE; + 665067 bytes downloaded
[20:12:08] Verifying core Core_11.fah...
[20:12:08] Signature is VALID
[20:12:08]
[20:12:08] Trying to unzip core FahCore_11.exe
[20:12:08] - Couldn't open file FahCore_11.exe
[20:12:08] + Error: Could not extract core
[20:12:08] + Core download error (#5), waiting before retry...
[20:12:55] + Downloading new core: FahCore_11.exe
[20:12:55] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:12:56] Initial: AFDE; + 10240 bytes downloaded
[20:12:57] Initial: E027; + 20480 bytes downloaded
[20:12:57] Initial: 8EE5; + 30720 bytes downloaded
[20:12:57] Initial: 9838; + 40960 bytes downloaded
[20:12:57] Initial: D615; + 51200 bytes downloaded
[20:12:57] Initial: CAA5; + 61440 bytes downloaded
[20:12:57] Initial: 3354; + 71680 bytes downloaded
[20:12:57] Initial: 6FF7; + 81920 bytes downloaded
[20:12:57] Initial: 5BA3; + 92160 bytes downloaded
[20:12:57] Initial: 23F0; + 102400 bytes downloaded
[20:12:57] Initial: C043; + 112640 bytes downloaded
[20:12:58] Initial: 2DB2; + 122880 bytes downloaded
[20:12:58] Initial: E434; + 133120 bytes downloaded
[20:12:58] Initial: 321F; + 143360 bytes downloaded
[20:12:58] Initial: 93B0; + 153600 bytes downloaded
[20:12:58] Initial: 245F; + 163840 bytes downloaded
[20:12:58] Initial: 6150; + 174080 bytes downloaded
[20:12:58] Initial: A664; + 184320 bytes downloaded
[20:12:58] Initial: 6EF8; + 194560 bytes downloaded
[20:12:58] Initial: 65A4; + 204800 bytes downloaded
[20:12:58] Initial: F31D; + 215040 bytes downloaded
[20:12:58] Initial: AD3D; + 225280 bytes downloaded
[20:12:58] Initial: FEF9; + 235520 bytes downloaded
[20:12:58] Initial: 9A18; + 245760 bytes downloaded
[20:12:58] Initial: F515; + 256000 bytes downloaded
[20:12:58] Initial: 7CD9; + 266240 bytes downloaded
[20:12:58] Initial: 0905; + 276480 bytes downloaded
[20:12:58] Initial: D379; + 286720 bytes downloaded
[20:12:58] Initial: 4E51; + 296960 bytes downloaded
[20:12:58] Initial: B099; + 307200 bytes downloaded
[20:12:58] Initial: 4645; + 317440 bytes downloaded
[20:12:58] Initial: D03A; + 327680 bytes downloaded
[20:12:58] Initial: 1144; + 337920 bytes downloaded
[20:12:58] Initial: 9388; + 348160 bytes downloaded
[20:12:58] Initial: 34A4; + 358400 bytes downloaded
[20:12:58] Initial: BD67; + 368640 bytes downloaded
[20:12:58] Initial: 0594; + 378880 bytes downloaded
[20:12:58] Initial: AFD1; + 389120 bytes downloaded
[20:12:58] Initial: 1A2A; + 399360 bytes downloaded
[20:12:59] Initial: 59F1; + 409600 bytes downloaded
[20:12:59] Initial: 2512; + 419840 bytes downloaded
[20:12:59] Initial: 74B1; + 430080 bytes downloaded
[20:12:59] Initial: 94F2; + 440320 bytes downloaded
[20:12:59] Initial: D8E0; + 450560 bytes downloaded
[20:12:59] Initial: 01A4; + 460800 bytes downloaded
[20:12:59] Initial: BCAF; + 471040 bytes downloaded
[20:12:59] Initial: B064; + 481280 bytes downloaded
[20:12:59] Initial: 3236; + 491520 bytes downloaded
[20:12:59] Initial: 3291; + 501760 bytes downloaded
[20:12:59] Initial: 6A7F; + 512000 bytes downloaded
[20:12:59] Initial: 61F7; + 522240 bytes downloaded
[20:12:59] Initial: F17C; + 532480 bytes downloaded
[20:12:59] Initial: 4E88; + 542720 bytes downloaded
[20:12:59] Initial: 7111; + 552960 bytes downloaded
[20:12:59] Initial: 1568; + 563200 bytes downloaded
[20:12:59] Initial: 9B04; + 573440 bytes downloaded
[20:12:59] Initial: 783B; + 583680 bytes downloaded
[20:12:59] Initial: 2FC8; + 593920 bytes downloaded
[20:12:59] Initial: E6E7; + 604160 bytes downloaded
[20:12:59] Initial: E7AB; + 614400 bytes downloaded
[20:12:59] Initial: D677; + 624640 bytes downloaded
[20:12:59] Initial: 5C98; + 634880 bytes downloaded
[20:12:59] Initial: 7BEE; + 645120 bytes downloaded
[20:12:59] Initial: D127; + 655360 bytes downloaded
[20:12:59] Initial: CADE; + 665067 bytes downloaded
[20:12:59] Verifying core Core_11.fah...
[20:12:59] Signature is VALID
[20:12:59]
[20:12:59] Trying to unzip core FahCore_11.exe
[20:12:59] Decompressed FahCore_11.exe (1908736 bytes) successfully
[20:13:04] + Core successfully engaged
[20:13:09]
[20:13:09] + Processing work unit
[20:13:09] Core required: FahCore_11.exe
[20:13:09] Core found.
[20:13:09] Working on queue slot 07 [October 18 20:13:09 UTC]
[20:13:09] + Working ...
[20:13:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:13:09]
[20:13:09] *------------------------------*
[20:13:09] Folding@Home GPU Core
[20:13:09] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:13:09]
[20:13:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:13:09] Build host: amoeba
[20:13:09] Board Type: Nvidia
[20:13:09] Core      :
[20:13:09] Preparing to commence simulation
[20:13:09] - Ensuring status. Please wait.
[20:13:19] - Looking at optimizations...
[20:13:19] - Working with standard loops on this execution.
[20:13:19] - Previous termination of core was improper.
[20:13:19] - Going to use standard loops.
[20:13:19] - Files status OK
[20:13:19] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:13:19] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:13:19] - Digital signature verified
[20:13:19]
[20:13:19] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:13:19]
[20:13:19] Entering M.D.
[20:13:25] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:13:25]
[20:13:25] Calling fah_main args: 14 usage=100
[20:13:25]
[20:13:27] CoreStatus = 63 (99)
[20:13:27] + Error starting Folding@Home core.
[20:13:32]
[20:13:32] + Processing work unit
[20:13:32] Core required: FahCore_11.exe
[20:13:32] Core found.
[20:13:32] Working on queue slot 07 [October 18 20:13:32 UTC]
[20:13:32] + Working ...
[20:13:32] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:13:32]
[20:13:32] *------------------------------*
[20:13:32] Folding@Home GPU Core
[20:13:32] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:13:32]
[20:13:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:13:32] Build host: amoeba
[20:13:32] Board Type: Nvidia
[20:13:32] Core      :
[20:13:32] Preparing to commence simulation
[20:13:32] - Ensuring status. Please wait.
[20:13:42] - Looking at optimizations...
[20:13:42] - Working with standard loops on this execution.
[20:13:42] - Previous termination of core was improper.
[20:13:42] - Going to use standard loops.
[20:13:42] - Files status OK
[20:13:42] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:13:42] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:13:42] - Digital signature verified
[20:13:42]
[20:13:42] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:13:42]
[20:13:42] Entering M.D.
[20:13:48] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:13:48]
[20:13:48] Calling fah_main args: 14 usage=100
[20:13:48]
[20:13:50] CoreStatus = 63 (99)
[20:13:50] + Error starting Folding@Home core.
[20:13:55]
[20:13:55] + Processing work unit
[20:13:55] Core required: FahCore_11.exe
[20:13:55] Core found.
[20:13:55] Working on queue slot 07 [October 18 20:13:55 UTC]
[20:13:55] + Working ...
[20:13:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:13:56]
[20:13:56] *------------------------------*
[20:13:56] Folding@Home GPU Core
[20:13:56] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:13:56]
[20:13:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:13:56] Build host: amoeba
[20:13:56] Board Type: Nvidia
[20:13:56] Core      :
[20:13:56] Preparing to commence simulation
[20:13:56] - Ensuring status. Please wait.
[20:14:05] - Looking at optimizations...
[20:14:05] - Working with standard loops on this execution.
[20:14:05] Examination of work files indicates 8 consecutive improper terminations of core.
[20:14:05] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:14:05] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:14:05] - Digital signature verified
[20:14:05]
[20:14:05] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:14:05]
[20:14:05] Entering M.D.
[20:14:11] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:14:11]
[20:14:11] Calling fah_main args: 14 usage=100
[20:14:11]
[20:14:14] CoreStatus = 63 (99)
[20:14:14] + Error starting Folding@Home core.
[20:14:14] - Attempting to download new core...
[20:14:14] + Downloading new core: FahCore_11.exe
[20:14:14] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:14:15] Initial: AFDE; + 10240 bytes downloaded
[20:14:15] Initial: E027; + 20480 bytes downloaded
[20:14:15] Initial: 8EE5; + 30720 bytes downloaded
[20:14:15] Initial: 9838; + 40960 bytes downloaded
[20:14:15] Initial: D615; + 51200 bytes downloaded
[20:14:16] Initial: CAA5; + 61440 bytes downloaded
[20:14:16] Initial: 3354; + 71680 bytes downloaded
[20:14:16] Initial: 6FF7; + 81920 bytes downloaded
[20:14:16] Initial: 5BA3; + 92160 bytes downloaded
[20:14:16] Initial: 23F0; + 102400 bytes downloaded
[20:14:16] Initial: C043; + 112640 bytes downloaded
[20:14:16] Initial: 2DB2; + 122880 bytes downloaded
[20:14:16] Initial: E434; + 133120 bytes downloaded
[20:14:16] Initial: 321F; + 143360 bytes downloaded
[20:14:16] Initial: 93B0; + 153600 bytes downloaded
[20:14:16] Initial: 245F; + 163840 bytes downloaded
[20:14:16] Initial: 6150; + 174080 bytes downloaded
[20:14:16] Initial: A664; + 184320 bytes downloaded
[20:14:16] Initial: 6EF8; + 194560 bytes downloaded
[20:14:16] Initial: 65A4; + 204800 bytes downloaded
[20:14:16] Initial: F31D; + 215040 bytes downloaded
[20:14:16] Initial: AD3D; + 225280 bytes downloaded
[20:14:17] Initial: FEF9; + 235520 bytes downloaded
[20:14:17] Initial: 9A18; + 245760 bytes downloaded
[20:14:17] Initial: F515; + 256000 bytes downloaded
[20:14:17] Initial: 7CD9; + 266240 bytes downloaded
[20:14:17] Initial: 0905; + 276480 bytes downloaded
[20:14:17] Initial: D379; + 286720 bytes downloaded
[20:14:17] Initial: 4E51; + 296960 bytes downloaded
[20:14:17] Initial: B099; + 307200 bytes downloaded
[20:14:17] Initial: 4645; + 317440 bytes downloaded
[20:14:17] Initial: D03A; + 327680 bytes downloaded
[20:14:17] Initial: 1144; + 337920 bytes downloaded
[20:14:17] Initial: 9388; + 348160 bytes downloaded
[20:14:17] Initial: 34A4; + 358400 bytes downloaded
[20:14:17] Initial: BD67; + 368640 bytes downloaded
[20:14:17] Initial: 0594; + 378880 bytes downloaded
[20:14:17] Initial: AFD1; + 389120 bytes downloaded
[20:14:17] Initial: 1A2A; + 399360 bytes downloaded
[20:14:17] Initial: 59F1; + 409600 bytes downloaded
[20:14:17] Initial: 2512; + 419840 bytes downloaded
[20:14:17] Initial: 74B1; + 430080 bytes downloaded
[20:14:17] Initial: 94F2; + 440320 bytes downloaded
[20:14:17] Initial: D8E0; + 450560 bytes downloaded
[20:14:17] Initial: 01A4; + 460800 bytes downloaded
[20:14:17] Initial: BCAF; + 471040 bytes downloaded
[20:14:17] Initial: B064; + 481280 bytes downloaded
[20:14:17] Initial: 3236; + 491520 bytes downloaded
[20:14:17] Initial: 3291; + 501760 bytes downloaded
[20:14:17] Initial: 6A7F; + 512000 bytes downloaded
[20:14:17] Initial: 61F7; + 522240 bytes downloaded
[20:14:17] Initial: F17C; + 532480 bytes downloaded
[20:14:17] Initial: 4E88; + 542720 bytes downloaded
[20:14:17] Initial: 7111; + 552960 bytes downloaded
[20:14:17] Initial: 1568; + 563200 bytes downloaded
[20:14:17] Initial: 9B04; + 573440 bytes downloaded
[20:14:17] Initial: 783B; + 583680 bytes downloaded
[20:14:17] Initial: 2FC8; + 593920 bytes downloaded
[20:14:17] Initial: E6E7; + 604160 bytes downloaded
[20:14:17] Initial: E7AB; + 614400 bytes downloaded
[20:14:17] Initial: D677; + 624640 bytes downloaded
[20:14:17] Initial: 5C98; + 634880 bytes downloaded
[20:14:17] Initial: 7BEE; + 645120 bytes downloaded
[20:14:17] Initial: D127; + 655360 bytes downloaded
[20:14:17] Initial: CADE; + 665067 bytes downloaded
[20:14:17] Verifying core Core_11.fah...
[20:14:17] Signature is VALID
[20:14:17]
[20:14:17] Trying to unzip core FahCore_11.exe
[20:14:17] - Couldn't open file FahCore_11.exe
[20:14:17] + Error: Could not extract core
[20:14:17] + Core download error (#2), waiting before retry...
[20:14:22] + Downloading new core: FahCore_11.exe
[20:14:22] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:14:23] Initial: AFDE; + 10240 bytes downloaded
[20:14:26] Initial: CADE; + 665067 bytes downloaded
[20:14:26] Verifying core Core_11.fah...
[20:14:26] Signature is VALID
[20:14:26]
[20:14:26] Trying to unzip core FahCore_11.exe
[20:14:26] - Couldn't open file FahCore_11.exe
[20:14:26] + Error: Could not extract core
[20:14:26] + Core download error (#3), waiting before retry...
[20:14:47] + Downloading new core: FahCore_11.exe
[20:14:47] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:14:48] Initial: AFDE; + 10240 bytes downloaded
[20:14:51] Initial: CADE; + 665067 bytes downloaded
[20:14:51] Verifying core Core_11.fah...
[20:14:51] Signature is VALID
[20:14:51]
[20:14:51] Trying to unzip core FahCore_11.exe
[20:14:51] - Couldn't open file FahCore_11.exe
[20:14:51] + Error: Could not extract core
[20:14:51] + Core download error (#4), waiting before retry...
[20:15:19] + Downloading new core: FahCore_11.exe
[20:15:19] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:15:20] Initial: AFDE; + 10240 bytes downloaded
[20:15:23] Initial: CADE; + 665067 bytes downloaded
[20:15:23] Verifying core Core_11.fah...
[20:15:23] Signature is VALID
[20:15:23]
[20:15:23] Trying to unzip core FahCore_11.exe
[20:15:23] Decompressed FahCore_11.exe (1908736 bytes) successfully
[20:15:28] + Core successfully engaged
[20:15:33]
[20:15:33] + Processing work unit
[20:15:33] Core required: FahCore_11.exe
[20:15:33] Core found.
[20:15:33] Working on queue slot 07 [October 18 20:15:33 UTC]
[20:15:33] + Working ...
[20:15:33] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:15:33]
[20:15:33] *------------------------------*
[20:15:33] Folding@Home GPU Core
[20:15:33] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:15:33]
[20:15:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:15:33] Build host: amoeba
[20:15:33] Board Type: Nvidia
[20:15:33] Core      :
[20:15:33] Preparing to commence simulation
[20:15:33] - Ensuring status. Please wait.
[20:15:43] - Looking at optimizations...
[20:15:43] - Working with standard loops on this execution.
[20:15:43] Examination of work files indicates 8 consecutive improper terminations of core.
[20:15:43] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:15:43] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:15:43] - Digital signature verified
[20:15:43]
[20:15:43] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:15:43]
[20:15:43] Entering M.D.
[20:15:49] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:15:49]
[20:15:49] Calling fah_main args: 14 usage=100
[20:15:49]
[20:15:51] CoreStatus = 63 (99)
[20:15:51] + Error starting Folding@Home core.
[20:15:56]
[20:15:56] + Processing work unit
[20:15:56] Core required: FahCore_11.exe
[20:15:56] Core found.
[20:15:56] Working on queue slot 07 [October 18 20:15:56 UTC]
[20:15:56] + Working ...
[20:15:56] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:15:57]
[20:15:57] *------------------------------*
[20:15:57] Folding@Home GPU Core
[20:15:57] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:15:57]
[20:15:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:15:57] Build host: amoeba
[20:15:57] Board Type: Nvidia
[20:15:57] Core      :
[20:15:57] Preparing to commence simulation
[20:15:57] - Ensuring status. Please wait.
[20:16:06] - Looking at optimizations...
[20:16:06] - Working with standard loops on this execution.
[20:16:06] Examination of work files indicates 8 consecutive improper terminations of core.
[20:16:06] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:16:06] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:16:06] - Digital signature verified
[20:16:06]
[20:16:06] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:16:06]
[20:16:06] Entering M.D.
[20:16:12] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:16:12]
[20:16:12] Calling fah_main args: 14 usage=100
[20:16:12]
[20:16:15] CoreStatus = 63 (99)
[20:16:15] + Error starting Folding@Home core.
[20:16:20]
[20:16:20] + Processing work unit
[20:16:20] Core required: FahCore_11.exe
[20:16:20] Core found.
[20:16:20] Working on queue slot 07 [October 18 20:16:20 UTC]
[20:16:20] + Working ...
[20:16:20] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:16:20]
[20:16:20] *------------------------------*
[20:16:20] Folding@Home GPU Core
[20:16:20] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:16:20]
[20:16:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:16:20] Build host: amoeba
[20:16:20] Board Type: Nvidia
[20:16:20] Core      :
[20:16:20] Preparing to commence simulation
[20:16:20] - Ensuring status. Please wait.
[20:16:29] - Looking at optimizations...
[20:16:29] - Working with standard loops on this execution.
[20:16:29] Examination of work files indicates 8 consecutive improper terminations of core.
[20:16:29] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:16:29] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:16:29] - Digital signature verified
[20:16:29]
[20:16:29] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:16:29]
[20:16:29] Entering M.D.
[20:16:35] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:16:35]
[20:16:35] Calling fah_main args: 14 usage=100
[20:16:35]
[20:16:38] CoreStatus = 63 (99)
[20:16:38] + Error starting Folding@Home core.
[20:16:38] - Attempting to download new core...
[20:16:38] + Downloading new core: FahCore_11.exe
[20:16:38] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:16:39] Initial: AFDE; + 10240 bytes downloaded
[20:16:41] Initial: CADE; + 665067 bytes downloaded
[20:16:41] Verifying core Core_11.fah...
[20:16:41] Signature is VALID
[20:16:41]
[20:16:41] Trying to unzip core FahCore_11.exe
[20:16:42] - Couldn't open file FahCore_11.exe
[20:16:42] + Error: Could not extract core
[20:16:42] + Core download error (#2), waiting before retry...
[20:16:59] + Downloading new core: FahCore_11.exe
[20:16:59] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:17:00] Initial: AFDE; + 10240 bytes downloaded
20:17:03] Initial: D127; + 655360 bytes downloaded
[20:17:03] Initial: CADE; + 665067 bytes downloaded
[20:17:03] Verifying core Core_11.fah...
[20:17:03] Signature is VALID
[20:17:03]
[20:17:03] Trying to unzip core FahCore_11.exe
[20:17:03] - Couldn't open file FahCore_11.exe
[20:17:03] + Error: Could not extract core
[20:17:03] + Core download error (#3), waiting before retry...
[20:17:24] + Downloading new core: FahCore_11.exe
[20:17:24] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[20:17:25] Initial: AFDE; + 10240 bytes downloaded
[20:17:29] Initial: CADE; + 665067 bytes downloaded
[20:17:29] Verifying core Core_11.fah...
[20:17:29] Signature is VALID
[20:17:29]
[20:17:29] Trying to unzip core FahCore_11.exe
[20:17:29] Decompressed FahCore_11.exe (1908736 bytes) successfully
[20:17:34] + Core successfully engaged
[20:17:39]
[20:17:39] + Processing work unit
[20:17:39] Core required: FahCore_11.exe
[20:17:39] Core found.
[20:17:39] Working on queue slot 07 [October 18 20:17:39 UTC]
[20:17:39] + Working ...
[20:17:39] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:17:39]
[20:17:39] *------------------------------*
[20:17:39] Folding@Home GPU Core
[20:17:39] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:17:39]
[20:17:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:17:39] Build host: amoeba
[20:17:39] Board Type: Nvidia
[20:17:39] Core      :
[20:17:39] Preparing to commence simulation
[20:17:39] - Ensuring status. Please wait.
[20:17:48] - Looking at optimizations...
[20:17:48] - Working with standard loops on this execution.
[20:17:48] Examination of work files indicates 8 consecutive improper terminations of core.
[20:17:48] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:17:48] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:17:48] - Digital signature verified
[20:17:48]
[20:17:48] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:17:48]
[20:17:48] Entering M.D.
[20:17:54] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:17:54]
[20:17:54] Calling fah_main args: 14 usage=100
[20:17:54]
[20:17:57] CoreStatus = 63 (99)
[20:17:57] + Error starting Folding@Home core.
[20:18:02]
[20:18:02] + Processing work unit
[20:18:02] Core required: FahCore_11.exe
[20:18:02] Core found.
[20:18:02] Working on queue slot 07 [October 18 20:18:02 UTC]
[20:18:02] + Working ...
[20:18:02] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:18:02]
[20:18:02] *------------------------------*
[20:18:02] Folding@Home GPU Core
[20:18:02] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:18:02]
[20:18:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:18:02] Build host: amoeba
[20:18:02] Board Type: Nvidia
[20:18:02] Core      :
[20:18:02] Preparing to commence simulation
[20:18:02] - Ensuring status. Please wait.
[20:18:12] - Looking at optimizations...
[20:18:12] - Working with standard loops on this execution.
[20:18:12] Examination of work files indicates 8 consecutive improper terminations of core.
[20:18:12] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:18:12] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:18:12] - Digital signature verified
[20:18:12]
[20:18:12] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:18:12]
[20:18:12] Entering M.D.
[20:18:18] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:18:18]
[20:18:18] Calling fah_main args: 14 usage=100
[20:18:18]
[20:18:20] CoreStatus = 63 (99)
[20:18:20] + Error starting Folding@Home core.
[20:18:25]
[20:18:25] + Processing work unit
[20:18:25] Core required: FahCore_11.exe
[20:18:25] Core found.
[20:18:25] Working on queue slot 07 [October 18 20:18:25 UTC]
[20:18:25] + Working ...
[20:18:25] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 8852 -version 630'
[20:18:25]
[20:18:25] *------------------------------*
[20:18:25] Folding@Home GPU Core
[20:18:25] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:18:25]
[20:18:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:18:25] Build host: amoeba
[20:18:25] Board Type: Nvidia
[20:18:25] Core      :
[20:18:25] Preparing to commence simulation
[20:18:25] - Ensuring status. Please wait.
[20:18:35] - Looking at optimizations...
[20:18:35] - Working with standard loops on this execution.
[20:18:35] Examination of work files indicates 8 consecutive improper terminations of core.
[20:18:35] - Expanded 73780 -> 383588 (decompressed 519.9 percent)
[20:18:35] Called DecompressByteArray: compressed_data_size=73780 data_size=383588, decompressed_data_size=383588 diff=0
[20:18:35] - Digital signature verified
[20:18:35]
[20:18:35] Project: 6603 (Run 4, Clone 362, Gen 312)
[20:18:35]
[20:18:35] Entering M.D.
[20:18:41] Tpr hash work/wudata_07.tpr:  306369223 1978399786 2250204051 2072793231 2875320550
[20:18:41]
[20:18:41] Calling fah_main args: 14 usage=100
[20:18:41]
[20:18:43] CoreStatus = 63 (99)
[20:18:43] + Error starting Folding@Home core.
[20:18:43]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[20:18:43] (To wake it up early, quit the application and restart it.)
[20:18:43] If problems persist, please visit our website at http://folding.stanford.edu for help.
[20:18:43] + Sleeping...
[21:59:29] - Autosending finished units... [October 18 21:59:29 UTC]
[21:59:29] Trying to send all finished work units
[21:59:29] Project: 11179 (Run 5, Clone 1, Gen 11)
[21:59:29] - Read packet limit of 540015616... Set to 524286976.
[21:59:29] + Attempting to send results [October 18 21:59:29 UTC]
[21:59:29] - Reading file work/wuresults_06.dat from core
[21:59:29]   (Read 2494978 bytes from disk)
[21:59:29] Gpu type=2 species=30.
[21:59:29] Connecting to http://171.67.108.31:8080/
[22:00:07] Posted data.
[22:00:07] Initial: 0000; - Uploaded at ~64 kB/s
[22:00:07] - Averaged speed for that direction ~61 kB/s
[22:00:07] + Results successfully sent
[22:00:07] Thank you for your contribution to Folding@Home.
[22:00:07] + Number of Units Completed: 385
[22:00:07] + Sent 1 of 1 completed units to the server
[22:00:07] - Autosend completed
[04:00:07] - Autosending finished units... [October 19 04:00:07 UTC]
[04:00:07] Trying to send all finished work units
[04:00:07] + No unsent completed units remaining.
[04:00:07] - Autosend completed
[09:11:26] ***** Got a SIGTERM signal (2)
[09:11:26] Killing all core threads
Folding@Home Client Shutdown.
Re: Project: 11179 (Run 5, Clone 1, Gen 11)
The WU Project: 11179 (Run 5, Clone 1, Gen 11) has successfully been uploaded. Near the end of the FAHlog:
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
*refrase*
No, that section of the FAHlog is from your above post.
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
It was? darn sorry, i have to recheck hehe
It was just so weird why the CS would discard it for almost 2 hours. And as you can see the client got all kinds of problems after that.
Complaining about the CS is useless since that feature isn't fully implemented yet.
I did go through the FAHlog and noticed a lot of errors but I am not sure of the cause. Maybe is you give us a brief description of the hardware and if any changes that took place,we can help you. BTW the uploading attempts will not have any negative impact on the Client AFAIK.
theo343
Hardware configuration: Home Network:
ADSL 12Mbps - 807 / 14.439
USRobotics 8port 10/100/1000
All computers connected with TP CAT5
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
removed - (8800GTS-512MB@724/1810/972)
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xGPU2 v6.20 R1 Core 1.18/1.19
1xSMP v6.23 Beta R1
HC2:
AM2+ x4 Phenom 9950@3GHz
2GB Crucial Ballistix PC2-5300
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
3xGPU2 v6.20 R1 Core 1.18
1xSMP v6.23 Beta R1
HC3: (not folding atm and outdated)
X2 6000+@Stock
HD3850OC-512MB@783MHz
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*GPU2 v6.12 Beta8 Core 1.04
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
8800GT-256MB@702/1755/900
4GB PC6400
Tagan 480W
Vista Ultimate 32bit SP1
FW 178.24
1xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
OC2:
E8400@stock
2x8800GT-512MB@stock
8GB PC3-8500
Corsair HX520
Vista Business 64bit
FW178.24
2xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
Post by theo343 »
Why does the CS discard it for 2 hours if that feature isnt fully implemented yet? Sounds like a feature that shouldnt be implemented until it is fiinished?
W3520
POV GTX 480
Mist 1kW
12GB RAM (as seen in the log)
The only change that took place was that earlier that day the GPU WUs stopped getting dealt out (globally). But then i didnt know this was happening to all of the folders so i tried removing the switch -advmethods (which didnt help) and then put on (-forcegpu nvidia_g80) and then i got WUs again. That was many hours and WUs before this happened. There hasnt been any changes in hardware or software, just folding along happily for weeks.
What happened (in the log) after that WU had trouble getting accepted by the CS has never happened before on this computer.
sortofageek
Post by sortofageek »
Just FYI, that WU was completed and credited to a folder. I can't tell if that was you since you didn't show the part of the log with your user name and team number.
codysluder
Post by codysluder »
theo343 wrote:Why does the CS discard it for 2 hours if that feature isnt fully implemented yet? Sounds like a feature that shouldnt be implemented until it is fiinished?
The CS's used to work fine. Then the Pande Group started talking about a better version of server code. Naturally a new version of the server code has to go through a variety of steps to be fully debugged but eventually that means running a couple of servers with the new code and the others with the old code. I have a VERY strong suspicion that the old CS code doesn't work with the new WS code. I do know that it is impossible to upgrade all the servers at the same time, so the transition is problematic, especially if it takes a long time. (Have you ever seen a major upgrade that didn't take longer than expected, especially if you have to keep running FAH while the upgrade progresses.)
It sounds like there is hope, though. See item 2: viewtopic.php?f=16&t=16375&p=162524#p162524
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
sortofageek wrote:Just FYI, that WU was completed and credited to a folder. I can't tell if that was you since you didn't show the part of the log with your user name and team number.
It's in my signature. But PantherX showed me from my own log a part that I had missed whereit uploaded sucessfully a long time after the first errors.
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
I just got a hint of this from Dr. Pande in another thread earlier today and I wasnt aware of this before then. I will read the thread.
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
That was in fact the thread i was referring to and took part of earlier today. I understand what your saying and do not disagree on that.
