I just started playing with F@H. I noticed it on my PS3 when I was trying to find a config setting.
I have many Windows machines (3.11-Win7 pro), an Apple MBP with Snow Leopard, a few 32-bit Linux machines, and a couple of PS3's (and a couple CP/M machines + a couple DOS machines still running daily
None of my suitable machines have high end graphic cards, but all are multi-core.
I started with a slim PS3, which takes about 5-6 hours to finish a WU. AOK.
Then I tried to run it with the MBP. Even though the computer is always on and plugged in, it appears to only run F@H when I'm actively using the computer. It might not finish before the deadline listed.
OK, now the question: How do I monitor how much real F@H work is getting done regardless of platform? If I want to leave 2-3 computers running, I'd like to know which ones would yield the most "bang-for-da-buck". I think I can figure out the power usage by using a UPS monitoring program (for PS3, run computer+PS3, record watts, run computer solo, subtract).
