The F@h Client creates a text file where it records all of its activities with a time-stamp. Please note that the time-stamp will be in GMT/UTC and not your Local Time and you can't change it. This file is useful when troubleshooting any F@h Client. If you are experiencing problems when trying to run the F@h Client, you may post your FAHlog here in the Forum so that others can view it and help you out.
Where Can I Find The FAHlog?
Depending on what Version of the F@h Client you have installed, method to access it will vary.
If you have installed the Systray Version:
Step 1: Right Click the F@h Icon (grey square)
Step 2: Go to Status (black rectangle)
Step 3: Click Log File (red rectangle)
Step 4: A window will appear where the FAHlog file appears
If you have installed the Console Version:
Step 1: Navigate to the folder were you have the F@h Client
Step 2: Locate "FAHlog" OR "FAHlog.txt" (Depends on the Windows setting)
Step 3: Double click the text file and a window will appear where the FAHlog file appears.
What Is FAHlog-Prev?
Once the FAHlog file size exceeds 50KB and you restart the F@h Client, it will make a new FAHlog file so the old FAHlog will be renamed to FAHlog-Prev while the new one will still be called FAHlog. Systray Version Clients will not be able to access the FAHlog-Prev file from the Menu so you have to browse to the folders' location and select "FAHlog-Prev" OR "FAHlog-Prev.txt" (Depends on the Windows setting).
How Do I Post My FAHlog/FAHlog-Prev?
You first have to be a member of this Forum to be able to post your FAHlog/FAHlog-Prev. If you are not a member, please
sign-up. Once you have created your account, please browse to the appropriate Sub-Forum to either post in a preexisting thread or create a new one. If a new thread is posted in the wrong Sub-Forum, it will be moved to an appropriate one by the Admins/Mods. If the new thread contains already present information, it may either be merged to the old one or locked, depending on the Admins/Mods decision.
Below are the steps on how to post your FAHlog/FAHlog-Prev:
Step 1: Locate the log file as mentioned above and copy its contents
Step 2: Click the Code Button (black rectangle) and Paste the contents inside the code tags (orange rectangle) so that your post looks like this:
Step 3: Click the preview button (purple rectangle) and the FAHlog will be displayed like this for us to view:
Step 4: After making sure that you have included all the relevant details, you can click the Submit button and your post will be posted.
Note: You should include the first part of the FAHlog as it contains valuable information on your Clients' set-up (as shown below). Due to Security/Privacy reasons, you may want to remove the User ID.  Also, you should keep your Passkey secure, but it is not printed in the FAHlog so that shouldn't be a problem.
Important section of FAHlog file that must be included:
--- Opening Log file [August 3 22:03:55 UTC]
                       Folding@Home Client Version 6.30r1
                          http://folding.stanford.edu
Launch directory: D:\F@H GPU3
Executable: D:\F@H GPU3\Folding@home-Win32-GPU.exe
Arguments: -advmethods -verbosity 9
[22:03:55] - Ask before connecting: No
[22:03:55] - User name:
[22:03:55] - User ID:
[22:03:55] - Machine ID: 2
 There is a character limit of 60000 characters per post and if your FAHlog contains more characters than that, you may want to edit it by removing some unimportant parts (as shown below) or by splitting up the FAHlog into two posts.
Unedited FAHLog:
--- Opening Log file [July 30 21:31:36 UTC]
Launch directory: D:\F@H SMP2
Executable: D:\F@H SMP2\Folding@home-Win32-x86.exe
Arguments: -smp 7 -bigadv -verbosity 9
[21:31:36] - Ask before connecting: No
[21:31:36] - User name:
[21:31:36] - User ID:
[21:31:36] - Machine ID: 1
[21:31:36]
[21:31:36] Loaded queue successfully.
[21:31:36] - Preparing to get new work unit...
[21:31:36] - Autosending finished units... [July 30 21:31:36 UTC]
[21:31:36] Cleaning up work directory
[21:31:36] Trying to send all finished work units
[21:31:36] + No unsent completed units remaining.
[21:31:36] - Autosend completed
[21:31:36] + Attempting to get work packet
[21:31:36] Passkey found
[21:31:36] - Will indicate memory of 4091 MB
[21:31:36] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 14, Stepping: 5
[21:31:36] - Connecting to assignment server
[21:31:36] Connecting to http://assign.stanford.edu:8080/
[21:31:38] Posted data.
[21:31:38] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[21:31:38] + News From Folding@Home: Welcome to Folding@Home
[21:31:38] Loaded queue successfully.
[21:31:38] Sent data
[21:31:38] Connecting to http://171.67.108.22:8080/
[21:31:47] Posted data.
[21:31:47] Initial: 0000; - Receiving payload (expected size: 24816226)
[21:40:22] - Downloaded at ~47 kB/s
[21:40:22] - Averaged speed for that direction ~47 kB/s
[21:40:22] + Received work.
[21:40:22] + Closed connections
[21:40:22]
[21:40:22] + Processing work unit
[21:40:22] Core required: FahCore_a3.exe
[21:40:22] Core not found.
[21:40:22] - Core is not present or corrupted.
[21:40:22] - Attempting to download new core...
[21:40:22] + Downloading new core: FahCore_a3.exe
[21:40:22] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[21:40:24] Initial: AFDE; + 10240 bytes downloaded
[21:40:24] Initial: D8B1; + 20480 bytes downloaded
[21:40:25] Initial: 7D98; + 30720 bytes downloaded
[21:40:25] Initial: FB47; + 40960 bytes downloaded
[21:40:25] Initial: C727; + 51200 bytes downloaded
[21:40:25] Initial: 3959; + 61440 bytes downloaded
[21:40:25] Initial: E18D; + 71680 bytes downloaded
[21:40:26] Initial: FBC5; + 81920 bytes downloaded
[21:40:26] Initial: 7A39; + 92160 bytes downloaded
[21:40:26] Initial: 058D; + 102400 bytes downloaded
[21:40:26] Initial: A3E7; + 112640 bytes downloaded
[21:40:26] Initial: 6096; + 122880 bytes downloaded
[21:40:27] Initial: 2128; + 133120 bytes downloaded
[21:40:27] Initial: 1374; + 143360 bytes downloaded
[21:40:27] Initial: B12D; + 153600 bytes downloaded
[21:40:27] Initial: 539B; + 163840 bytes downloaded
[21:40:27] Initial: 85C3; + 174080 bytes downloaded
[21:40:28] Initial: A8E1; + 184320 bytes downloaded
[21:40:28] Initial: 0E78; + 194560 bytes downloaded
[21:40:28] Initial: 6477; + 204800 bytes downloaded
[21:40:28] Initial: 841E; + 215040 bytes downloaded
[21:40:28] Initial: 23C5; + 225280 bytes downloaded
[21:40:29] Initial: CA03; + 235520 bytes downloaded
[21:40:29] Initial: 1B65; + 245760 bytes downloaded
[21:40:29] Initial: 503A; + 256000 bytes downloaded
[21:40:29] Initial: 03CC; + 266240 bytes downloaded
[21:40:29] Initial: 9431; + 276480 bytes downloaded
[21:40:30] Initial: 0AF7; + 286720 bytes downloaded
[21:40:30] Initial: 73A8; + 296960 bytes downloaded
[21:40:30] Initial: DEDA; + 307200 bytes downloaded
[21:40:30] Initial: DB5F; + 317440 bytes downloaded
[21:40:30] Initial: B179; + 327680 bytes downloaded
[21:40:31] Initial: 9D7C; + 337920 bytes downloaded
[21:40:31] Initial: 70B0; + 348160 bytes downloaded
[21:40:31] Initial: CB0F; + 358400 bytes downloaded
[21:40:31] Initial: 7E46; + 368640 bytes downloaded
[21:40:31] Initial: A3B5; + 378880 bytes downloaded
[21:40:32] Initial: 6585; + 389120 bytes downloaded
[21:40:32] Initial: 396A; + 399360 bytes downloaded
[21:40:32] Initial: BFDA; + 409600 bytes downloaded
[21:40:32] Initial: 3CED; + 419840 bytes downloaded
[21:40:32] Initial: 7494; + 430080 bytes downloaded
[21:40:33] Initial: 752B; + 440320 bytes downloaded
[21:40:33] Initial: 19AC; + 450560 bytes downloaded
[21:40:33] Initial: 4E9D; + 460800 bytes downloaded
[21:40:33] Initial: C22D; + 471040 bytes downloaded
[21:40:33] Initial: 1287; + 481280 bytes downloaded
[21:40:34] Initial: 3203; + 491520 bytes downloaded
[21:40:34] Initial: B49B; + 501760 bytes downloaded
[21:40:34] Initial: 4104; + 512000 bytes downloaded
[21:40:34] Initial: 8DF1; + 522240 bytes downloaded
[21:40:34] Initial: DCC1; + 532480 bytes downloaded
[21:40:35] Initial: 7141; + 542720 bytes downloaded
[21:40:35] Initial: 5CF5; + 552960 bytes downloaded
[21:40:35] Initial: 4F40; + 563200 bytes downloaded
[21:40:35] Initial: 81E1; + 573440 bytes downloaded
[21:40:35] Initial: 1376; + 583680 bytes downloaded
[21:40:36] Initial: 70DF; + 593920 bytes downloaded
[21:40:36] Initial: 284C; + 604160 bytes downloaded
[21:40:36] Initial: 1D76; + 614400 bytes downloaded
[21:40:36] Initial: 775F; + 624640 bytes downloaded
[21:40:36] Initial: 422A; + 634880 bytes downloaded
[21:40:37] Initial: E836; + 645120 bytes downloaded
[21:40:37] Initial: 6E43; + 655360 bytes downloaded
[21:40:37] Initial: B979; + 665600 bytes downloaded
[21:40:37] Initial: 8530; + 675840 bytes downloaded
[21:40:37] Initial: 1FF8; + 686080 bytes downloaded
[21:40:38] Initial: 0C0C; + 696320 bytes downloaded
[21:40:38] Initial: 83B0; + 706560 bytes downloaded
[21:40:38] Initial: 6FB5; + 716800 bytes downloaded
[21:40:38] Initial: 949A; + 727040 bytes downloaded
[21:40:38] Initial: 9F7A; + 737280 bytes downloaded
[21:40:38] Initial: 13C6; + 747520 bytes downloaded
[21:40:39] Initial: 2FD0; + 757760 bytes downloaded
[21:40:39] Initial: 6BFE; + 768000 bytes downloaded
[21:40:39] Initial: 8C0F; + 778240 bytes downloaded
[21:40:39] Initial: 916D; + 788480 bytes downloaded
[21:40:39] Initial: A005; + 798720 bytes downloaded
[21:40:40] Initial: 028E; + 808960 bytes downloaded
[21:40:40] Initial: 27F6; + 819200 bytes downloaded
[21:40:40] Initial: B25A; + 829440 bytes downloaded
[21:40:40] Initial: D7FD; + 839680 bytes downloaded
[21:40:40] Initial: 96A1; + 849920 bytes downloaded
[21:40:41] Initial: B7AA; + 860160 bytes downloaded
[21:40:41] Initial: 7EE0; + 870400 bytes downloaded
[21:40:41] Initial: 23D9; + 880640 bytes downloaded
[21:40:41] Initial: 2772; + 890880 bytes downloaded
[21:40:41] Initial: 923D; + 901120 bytes downloaded
[21:40:42] Initial: 65B5; + 911360 bytes downloaded
[21:40:42] Initial: CCC0; + 921600 bytes downloaded
[21:40:42] Initial: 4E70; + 931840 bytes downloaded
[21:40:42] Initial: 4ECA; + 942080 bytes downloaded
[21:40:42] Initial: D737; + 952320 bytes downloaded
[21:40:43] Initial: 80C5; + 962560 bytes downloaded
[21:40:43] Initial: 15A4; + 972800 bytes downloaded
[21:40:43] Initial: ADB7; + 983040 bytes downloaded
[21:40:43] Initial: A2B0; + 993280 bytes downloaded
[21:40:43] Initial: 3EAC; + 1003520 bytes downloaded
[21:40:44] Initial: E831; + 1013760 bytes downloaded
[21:40:44] Initial: FF75; + 1024000 bytes downloaded
[21:40:44] Initial: BCC4; + 1034240 bytes downloaded
[21:40:44] Initial: CA0C; + 1044480 bytes downloaded
[21:40:44] Initial: D751; + 1054720 bytes downloaded
[21:40:45] Initial: EC51; + 1064960 bytes downloaded
[21:40:45] Initial: 9CC1; + 1075200 bytes downloaded
[21:40:45] Initial: 755D; + 1085440 bytes downloaded
[21:40:45] Initial: 59F8; + 1095680 bytes downloaded
[21:40:45] Initial: BF6C; + 1105920 bytes downloaded
[21:40:46] Initial: 4774; + 1116160 bytes downloaded
[21:40:46] Initial: FE4B; + 1126400 bytes downloaded
[21:40:46] Initial: CEB0; + 1136640 bytes downloaded
[21:40:46] Initial: BF2F; + 1146880 bytes downloaded
[21:40:46] Initial: BEAC; + 1157120 bytes downloaded
[21:40:47] Initial: 1251; + 1167360 bytes downloaded
[21:40:47] Initial: 4BC0; + 1177600 bytes downloaded
[21:40:47] Initial: 9648; + 1187840 bytes downloaded
[21:40:47] Initial: 1CDC; + 1198080 bytes downloaded
[21:40:47] Initial: 2821; + 1208320 bytes downloaded
[21:40:48] Initial: F0E5; + 1218560 bytes downloaded
[21:40:48] Initial: 03E1; + 1228800 bytes downloaded
[21:40:48] Initial: 1E3E; + 1239040 bytes downloaded
[21:40:48] Initial: AA8F; + 1249280 bytes downloaded
[21:40:48] Initial: C847; + 1259520 bytes downloaded
[21:40:49] Initial: A745; + 1269760 bytes downloaded
[21:40:49] Initial: 70CD; + 1280000 bytes downloaded
[21:40:49] Initial: 0339; + 1290240 bytes downloaded
[21:40:49] Initial: 239F; + 1300480 bytes downloaded
[21:40:49] Initial: 3633; + 1310720 bytes downloaded
[21:40:50] Initial: 715C; + 1320960 bytes downloaded
[21:40:50] Initial: B308; + 1331200 bytes downloaded
[21:40:50] Initial: 1199; + 1341440 bytes downloaded
[21:40:50] Initial: 7DCF; + 1351680 bytes downloaded
[21:40:50] Initial: 719D; + 1361920 bytes downloaded
[21:40:51] Initial: F8C6; + 1372160 bytes downloaded
[21:40:51] Initial: 503B; + 1382400 bytes downloaded
[21:40:51] Initial: 5F95; + 1392640 bytes downloaded
[21:40:51] Initial: 93DF; + 1402880 bytes downloaded
[21:40:51] Initial: 1E07; + 1413120 bytes downloaded
[21:40:52] Initial: 1C4B; + 1423360 bytes downloaded
[21:40:52] Initial: 6DE6; + 1433600 bytes downloaded
[21:40:52] Initial: B321; + 1443840 bytes downloaded
[21:40:52] Initial: C64F; + 1454080 bytes downloaded
[21:40:52] Initial: 69D1; + 1464320 bytes downloaded
[21:40:53] Initial: 51CA; + 1474560 bytes downloaded
[21:40:53] Initial: 8994; + 1484800 bytes downloaded
[21:40:53] Initial: 96C7; + 1495040 bytes downloaded
[21:40:53] Initial: 0EFD; + 1505280 bytes downloaded
[21:40:53] Initial: FF02; + 1515520 bytes downloaded
[21:40:54] Initial: 376F; + 1525760 bytes downloaded
[21:40:54] Initial: A151; + 1536000 bytes downloaded
[21:40:54] Initial: 813A; + 1546240 bytes downloaded
[21:40:54] Initial: B595; + 1556480 bytes downloaded
[21:40:54] Initial: 1BDB; + 1566720 bytes downloaded
[21:40:55] Initial: 2A28; + 1576960 bytes downloaded
[21:40:55] Initial: 1997; + 1587200 bytes downloaded
[21:40:55] Initial: AA47; + 1597440 bytes downloaded
[21:40:55] Initial: 1A68; + 1607680 bytes downloaded
[21:40:55] Initial: B6A4; + 1617920 bytes downloaded
[21:40:56] Initial: 555E; + 1628160 bytes downloaded
[21:40:56] Initial: C1ED; + 1638400 bytes downloaded
[21:40:56] Initial: 7CBC; + 1648640 bytes downloaded
[21:40:56] Initial: BD98; + 1658880 bytes downloaded
[21:40:56] Initial: 28F3; + 1669120 bytes downloaded
[21:40:57] Initial: 4587; + 1679360 bytes downloaded
[21:40:57] Initial: 2645; + 1689600 bytes downloaded
[21:40:57] Initial: A441; + 1699840 bytes downloaded
[21:40:57] Initial: 53E2; + 1710080 bytes downloaded
[21:40:57] Initial: 430C; + 1720320 bytes downloaded
[21:40:58] Initial: FA09; + 1730560 bytes downloaded
[21:40:58] Initial: C140; + 1740800 bytes downloaded
[21:40:58] Initial: 67D7; + 1751040 bytes downloaded
[21:40:58] Initial: 5028; + 1761280 bytes downloaded
[21:40:58] Initial: 1B33; + 1771520 bytes downloaded
[21:40:59] Initial: 75F2; + 1781760 bytes downloaded
[21:40:59] Initial: D64F; + 1792000 bytes downloaded
[21:40:59] Initial: 483D; + 1802240 bytes downloaded
[21:40:59] Initial: 2C13; + 1812480 bytes downloaded
[21:40:59] Initial: 43E1; + 1822720 bytes downloaded
[21:41:00] Initial: 2D30; + 1832960 bytes downloaded
[21:41:00] Initial: AA8A; + 1843200 bytes downloaded
[21:41:00] Initial: 4456; + 1853440 bytes downloaded
[21:41:00] Initial: 0523; + 1863680 bytes downloaded
[21:41:00] Initial: E639; + 1873920 bytes downloaded
[21:41:01] Initial: A985; + 1884160 bytes downloaded
[21:41:01] Initial: 2AD1; + 1894400 bytes downloaded
[21:41:01] Initial: 3ED9; + 1904640 bytes downloaded
[21:41:01] Initial: AC85; + 1914880 bytes downloaded
[21:41:01] Initial: 97AE; + 1925120 bytes downloaded
[21:41:02] Initial: 2936; + 1935360 bytes downloaded
[21:41:02] Initial: E147; + 1945600 bytes downloaded
[21:41:02] Initial: D38E; + 1955840 bytes downloaded
[21:41:02] Initial: DCFC; + 1966080 bytes downloaded
[21:41:02] Initial: CBE5; + 1976320 bytes downloaded
[21:41:03] Initial: 9377; + 1986560 bytes downloaded
[21:41:03] Initial: 8E96; + 1996800 bytes downloaded
[21:41:03] Initial: 5B37; + 2007040 bytes downloaded
[21:41:03] Initial: B496; + 2017280 bytes downloaded
[21:41:03] Initial: 329D; + 2027520 bytes downloaded
[21:41:04] Initial: A6DF; + 2037760 bytes downloaded
[21:41:04] Initial: 48CD; + 2048000 bytes downloaded
[21:41:04] Initial: 9976; + 2058240 bytes downloaded
[21:41:04] Initial: C763; + 2068480 bytes downloaded
[21:41:04] Initial: 391D; + 2078720 bytes downloaded
[21:41:05] Initial: 5D6E; + 2088960 bytes downloaded
[21:41:05] Initial: 06D0; + 2099200 bytes downloaded
[21:41:05] Initial: 5559; + 2109440 bytes downloaded
[21:41:05] Initial: 2135; + 2119680 bytes downloaded
[21:41:05] Initial: 4571; + 2129920 bytes downloaded
[21:41:06] Initial: 655C; + 2140160 bytes downloaded
[21:41:06] Initial: 33D3; + 2150400 bytes downloaded
[21:41:06] Initial: A251; + 2160640 bytes downloaded
[21:41:06] Initial: 0A61; + 2170880 bytes downloaded
[21:41:06] Initial: ADC5; + 2181120 bytes downloaded
[21:41:07] Initial: F636; + 2191360 bytes downloaded
[21:41:07] Initial: 1299; + 2201600 bytes downloaded
[21:41:07] Initial: C6AF; + 2211840 bytes downloaded
[21:41:07] Initial: AC63; + 2222080 bytes downloaded
[21:41:07] Initial: 815E; + 2232320 bytes downloaded
[21:41:08] Initial: FD1C; + 2242560 bytes downloaded
[21:41:08] Initial: 3509; + 2252800 bytes downloaded
[21:41:08] Initial: 4624; + 2263040 bytes downloaded
[21:41:08] Initial: 0A23; + 2273280 bytes downloaded
[21:41:08] Initial: 52D0; + 2283520 bytes downloaded
[21:41:08] Initial: 0721; + 2293760 bytes downloaded
[21:41:09] Initial: 9160; + 2304000 bytes downloaded
[21:41:09] Initial: 2342; + 2314240 bytes downloaded
[21:41:09] Initial: 6AB8; + 2324480 bytes downloaded
[21:41:09] Initial: D2CB; + 2334720 bytes downloaded
[21:41:09] Initial: FF0F; + 2344960 bytes downloaded
[21:41:10] Initial: 1301; + 2355200 bytes downloaded
[21:41:10] Initial: 2C98; + 2365440 bytes downloaded
[21:41:10] Initial: 251C; + 2375680 bytes downloaded
[21:41:10] Initial: D3EA; + 2385920 bytes downloaded
[21:41:10] Initial: 6A9A; + 2396160 bytes downloaded
[21:41:11] Initial: 5CD3; + 2406400 bytes downloaded
[21:41:11] Initial: 7E55; + 2416640 bytes downloaded
[21:41:11] Initial: 03A5; + 2426880 bytes downloaded
[21:41:11] Initial: 7CA9; + 2437120 bytes downloaded
[21:41:11] Initial: 3EA3; + 2447360 bytes downloaded
[21:41:12] Initial: 44AC; + 2457600 bytes downloaded
[21:41:12] Initial: 4E9A; + 2467840 bytes downloaded
[21:41:12] Initial: 9E43; + 2478080 bytes downloaded
[21:41:12] Initial: 5A57; + 2488320 bytes downloaded
[21:41:12] Initial: 2425; + 2498560 bytes downloaded
[21:41:13] Initial: D602; + 2508800 bytes downloaded
[21:41:13] Initial: 5AAD; + 2519040 bytes downloaded
[21:41:13] Initial: 4142; + 2529280 bytes downloaded
[21:41:13] Initial: 2C77; + 2539520 bytes downloaded
[21:41:13] Initial: 9279; + 2549760 bytes downloaded
[21:41:14] Initial: 11E3; + 2560000 bytes downloaded
[21:41:14] Initial: 2C8E; + 2570240 bytes downloaded
[21:41:14] Initial: 598D; + 2580480 bytes downloaded
[21:41:14] Initial: 8E47; + 2590720 bytes downloaded
[21:41:14] Initial: B10D; + 2600960 bytes downloaded
[21:41:15] Initial: 09D0; + 2611200 bytes downloaded
[21:41:15] Initial: F417; + 2621440 bytes downloaded
[21:41:15] Initial: 92E6; + 2631680 bytes downloaded
[21:41:15] Initial: 795D; + 2641920 bytes downloaded
[21:41:15] Initial: 2EEE; + 2652160 bytes downloaded
[21:41:16] Initial: BA3B; + 2662400 bytes downloaded
[21:41:16] Initial: 0404; + 2672640 bytes downloaded
[21:41:16] Initial: 4809; + 2682880 bytes downloaded
[21:41:16] Initial: 4BE5; + 2693120 bytes downloaded
[21:41:16] Initial: A3BF; + 2703360 bytes downloaded
[21:41:17] Initial: 3ABE; + 2711113 bytes downloaded
[21:41:17] Verifying core Core_a3.fah...
[21:41:17] Signature is VALID
[21:41:17]
[21:41:17] Trying to unzip core FahCore_a3.exe
[21:41:17] Decompressed FahCore_a3.exe (9325056 bytes) successfully
[21:41:22] + Core successfully engaged
[21:41:28]
[21:41:28] + Processing work unit
[21:41:28] Core required: FahCore_a3.exe
[21:41:28] Core found.
[21:41:28] Working on queue slot 01 [July 30 21:41:28 UTC]
[21:41:28] + Working ...
[21:41:28] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 7 -checkpoint 15 -verbose -lifeline 4808 -version 630'
[21:41:28]
[21:41:28] *------------------------------*
[21:41:28] Folding@Home Gromacs SMP Core
[21:41:28] Version 2.22 (Mar 12, 2010)
[21:41:28]
[21:41:28] Preparing to commence simulation
[21:41:28] - Looking at optimizations...
[21:41:28] - Created dyn
[21:41:28] - Files status OK
[21:41:32] - Expanded 24815714 -> 30791309 (decompressed 124.0 percent)
[21:41:32] Called DecompressByteArray: compressed_data_size=24815714 data_size=30791309, decompressed_data_size=30791309 diff=0
[21:41:33] - Digital signature verified
[21:41:33]
[21:41:33] Project: 2684 (Run 6, Clone 12, Gen 13)
[21:41:33]
[21:41:33] Assembly optimizations on if available.
[21:41:33] Entering M.D.
[21:41:44] Completed 0 out of 250000 steps  (0%)
[22:33:36] Completed 2500 out of 250000 steps  (1%)
[23:24:53] Completed 5000 out of 250000 steps  (2%)
[00:16:47] Completed 7500 out of 250000 steps  (3%)
[01:08:12] Completed 10000 out of 250000 steps  (4%)
[01:59:38] Completed 12500 out of 250000 steps  (5%)
[02:50:58] Completed 15000 out of 250000 steps  (6%)
[03:31:36] - Autosending finished units... [July 31 03:31:36 UTC]
[03:31:36] Trying to send all finished work units
[03:31:36] + No unsent completed units remaining.
[03:31:36] - Autosend completed
[03:42:14] Completed 17500 out of 250000 steps  (7%)
[04:33:13] Completed 20000 out of 250000 steps  (8%)
[05:24:12] Completed 22500 out of 250000 steps  (9%)
[06:15:13] Completed 25000 out of 250000 steps  (10%)
[07:06:10] Completed 27500 out of 250000 steps  (11%)
[07:57:16] Completed 30000 out of 250000 steps  (12%)
[08:48:18] Completed 32500 out of 250000 steps  (13%)
[09:31:36] - Autosending finished units... [July 31 09:31:36 UTC]
[09:31:36] Trying to send all finished work units
[09:31:36] + No unsent completed units remaining.
[09:31:36] - Autosend completed
[09:39:21] Completed 35000 out of 250000 steps  (14%)
[10:30:29] Completed 37500 out of 250000 steps  (15%)
[11:21:35] Completed 40000 out of 250000 steps  (16%)
[12:12:50] Completed 42500 out of 250000 steps  (17%)
[13:04:04] Completed 45000 out of 250000 steps  (18%)
[13:55:34] Completed 47500 out of 250000 steps  (19%)
[14:47:13] Completed 50000 out of 250000 steps  (20%)
[15:31:36] - Autosending finished units... [July 31 15:31:36 UTC]
[15:31:36] Trying to send all finished work units
[15:31:36] + No unsent completed units remaining.
[15:31:36] - Autosend completed
[15:38:36] Completed 52500 out of 250000 steps  (21%)
[16:29:47] Completed 55000 out of 250000 steps  (22%)
[17:20:52] Completed 57500 out of 250000 steps  (23%)
[18:11:56] Completed 60000 out of 250000 steps  (24%)
[19:03:05] Completed 62500 out of 250000 steps  (25%)
[19:54:03] Completed 65000 out of 250000 steps  (26%)
[20:46:45] Completed 67500 out of 250000 steps  (27%)
[21:31:36] - Autosending finished units... [July 31 21:31:36 UTC]
[21:38:15] Completed 70000 out of 250000 steps  (28%)
[22:29:33] Completed 72500 out of 250000 steps  (29%)
[23:20:56] Completed 75000 out of 250000 steps  (30%)
[00:12:24] Completed 77500 out of 250000 steps  (31%)
[01:03:38] Completed 80000 out of 250000 steps  (32%)
[01:54:52] Completed 82500 out of 250000 steps  (33%)
[02:46:35] Completed 85000 out of 250000 steps  (34%)
[03:31:40] - Autosending finished units... [August 1 03:31:40 UTC]
[03:31:40] Trying to send all finished work units
[03:31:40] + No unsent completed units remaining.
[03:31:40] - Autosend completed
[03:37:48] Completed 87500 out of 250000 steps  (35%)
[04:28:54] Completed 90000 out of 250000 steps  (36%)
[05:19:27] Completed 92500 out of 250000 steps  (37%)
[06:10:17] Completed 95000 out of 250000 steps  (38%)
[07:02:29] Completed 97500 out of 250000 steps  (39%)
[07:53:44] Completed 100000 out of 250000 steps  (40%)
[08:44:50] Completed 102500 out of 250000 steps  (41%)
[09:31:40] - Autosending finished units... [August 1 09:31:40 UTC]
[09:31:40] Trying to send all finished work units
[09:31:40] + No unsent completed units remaining.
[09:31:40] - Autosend completed
[09:35:53] Completed 105000 out of 250000 steps  (42%)
[10:27:01] Completed 107500 out of 250000 steps  (43%)
[11:18:05] Completed 110000 out of 250000 steps  (44%)
[12:09:04] Completed 112500 out of 250000 steps  (45%)
[13:00:06] Completed 115000 out of 250000 steps  (46%)
[13:51:13] Completed 117500 out of 250000 steps  (47%)
[14:42:17] Completed 120000 out of 250000 steps  (48%)
[15:31:40] - Autosending finished units... [August 1 15:31:40 UTC]
[15:31:40] Trying to send all finished work units
[15:31:40] + No unsent completed units remaining.
[15:31:40] - Autosend completed
[15:33:42] Completed 122500 out of 250000 steps  (49%)
[16:25:00] Completed 125000 out of 250000 steps  (50%)
[17:15:48] Completed 127500 out of 250000 steps  (51%)
[18:06:48] Completed 130000 out of 250000 steps  (52%)
[18:57:58] Completed 132500 out of 250000 steps  (53%)
[19:49:06] Completed 135000 out of 250000 steps  (54%)
[20:40:01] Completed 137500 out of 250000 steps  (55%)
[21:31:28] Completed 140000 out of 250000 steps  (56%)
[21:31:40] - Autosending finished units... [August 1 21:31:40 UTC]
[21:31:40] Trying to send all finished work units
[21:31:40] + No unsent completed units remaining.
[21:31:40] - Autosend completed
[22:22:49] Completed 142500 out of 250000 steps  (57%)
[23:14:04] Completed 145000 out of 250000 steps  (58%)
[00:05:07] Completed 147500 out of 250000 steps  (59%)
[00:56:16] Completed 150000 out of 250000 steps  (60%)
[01:47:12] Completed 152500 out of 250000 steps  (61%)
[02:38:04] Completed 155000 out of 250000 steps  (62%)
[03:28:54] Completed 157500 out of 250000 steps  (63%)
[03:31:40] - Autosending finished units... [August 2 03:31:40 UTC]
[04:19:34] Completed 160000 out of 250000 steps  (64%)
[05:10:11] Completed 162500 out of 250000 steps  (65%)
[06:00:53] Completed 165000 out of 250000 steps  (66%)
[06:51:31] Completed 167500 out of 250000 steps  (67%)
[07:42:12] Completed 170000 out of 250000 steps  (68%)
[08:32:58] Completed 172500 out of 250000 steps  (69%)
[09:23:44] Completed 175000 out of 250000 steps  (70%)
[09:31:40] - Autosending finished units... [August 2 09:31:40 UTC]
[10:14:31] Completed 177500 out of 250000 steps  (71%)
[11:05:21] Completed 180000 out of 250000 steps  (72%)
[11:56:08] Completed 182500 out of 250000 steps  (73%)
[12:47:01] Completed 185000 out of 250000 steps  (74%)
[13:38:12] Completed 187500 out of 250000 steps  (75%)
[14:29:20] Completed 190000 out of 250000 steps  (76%)
[15:20:25] Completed 192500 out of 250000 steps  (77%)
[15:31:40] - Autosending finished units... [August 2 15:31:40 UTC]
[16:11:10] Completed 195000 out of 250000 steps  (78%)
[17:02:03] Completed 197500 out of 250000 steps  (79%)
[17:53:54] Completed 200000 out of 250000 steps  (80%)
[18:45:04] Completed 202500 out of 250000 steps  (81%)
[19:36:00] Completed 205000 out of 250000 steps  (82%)
[20:27:43] Completed 207500 out of 250000 steps  (83%)
[21:19:32] Completed 210000 out of 250000 steps  (84%)
[21:31:40] - Autosending finished units... [August 2 21:31:40 UTC]
[22:10:13] Completed 212500 out of 250000 steps  (85%)
[23:00:34] Completed 215000 out of 250000 steps  (86%)
[23:50:55] Completed 217500 out of 250000 steps  (87%)
[00:41:30] Completed 220000 out of 250000 steps  (88%)
[01:31:52] Completed 222500 out of 250000 steps  (89%)
[02:22:08] Completed 225000 out of 250000 steps  (90%)
[03:12:29] Completed 227500 out of 250000 steps  (91%)
[03:31:40] - Autosending finished units... [August 3 03:31:40 UTC]
[04:03:20] Completed 230000 out of 250000 steps  (92%)
[04:53:48] Completed 232500 out of 250000 steps  (93%)
[05:44:18] Completed 235000 out of 250000 steps  (94%)
[06:35:30] Completed 237500 out of 250000 steps  (95%)
[07:27:13] Completed 240000 out of 250000 steps  (96%)
[08:18:43] Completed 242500 out of 250000 steps  (97%)
[09:09:42] Completed 245000 out of 250000 steps  (98%)
[09:31:40] - Autosending finished units... [August 3 09:31:40 UTC]
[09:57:46] Killing all core threads
[09:57:46] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[09:57:46] ***** Got a SIGTERM signal (2)
The same FAHlog after editing: (It still contains all important information)
[21:31:36]
[21:40:22]
SNIP
[21:41:17]
[21:41:28]
[21:41:28]
[21:41:28]
[21:41:33]
[21:41:33]
SNIP
Folding@Home Client Shutdown.
