Got an issue I'd like some help with. I'm running a custom watercooling loop with a UPS. The one problem with the set up is that pump occasionally trips when the UPS kicks in and as a result the core temperatures rocket with no water circulating.
I use CoreTemp to manage my temperatures and the UPS software with my UPS is good but isn't integrated i.e. when it goes to battery mode it doesn't tell windows that. Both allow you to execute programmes though, for core temp, if the temperatures get above a certain level, and for the UPS software, when the battery engages.
Is there a way to write a batch script or something that will safely stop FAH when executed?
Oh forgot to add the important stuff, I'm running the SMP client on a win7 64bit i7
Many thanks.
k1wi
