171.67.108.21 Reject / Returning to "normal-ish" :)
sswilson
- Hardware configuration: ASUS Crosshair IV Formula / AMD 1090T / 4X2 Gig GSkill Pi PC3-12800 / Corsair TX750W PSU / Sparkle GTX275 Plus / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Enzotech Luna WB / Dell Ultrasharp 2209WA
Gigabyte P35-DQ6 / Q6600 / 2X 1G 1066 Firestix / "Baked" XFX GTX 280 (RIP again :( ) / MSI GTS 450 Cyclone OC /PC P&C 750W Silencer / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Highspeed PC Tech Station / Samsung 931BF / BenQ Q9T4 - Location: Moncton, New Brunswick, Canada
Not completely sure if we should be reporting servers in Reject mode, or if somebody gets an "alarm" somewhere once the status page reports it as such.
171.67.108.21 Reject mode, Nvidia GPU has been attempting to pull from it for over half an hour.
Mod Note: See also this topic. ~sorto'
sswilson
Re: 171.67.108.21 Reject
Mods, Please disregard/delete. Just pulled a WU.
Re: 171.67.108.21 Reject / Resolved....
This isn't fully resolved. Server is full/accepting but CPU load is almost 4 and net load is at 170. I have multiple clients unable to get work.
[18:16:39] - Connecting to assignment server
[18:16:39] Connecting to http://assign-GPU.stanford.edu:8080/
[18:16:40] Posted data.
[18:16:40] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[18:16:40] + News From Folding@Home: Welcome to Folding@Home
[18:16:40] Loaded queue successfully.
[18:16:40] Connecting to http://171.67.108.21:8080/
[18:17:01] - Couldn't send HTTP request to server
[18:17:01] + Could not connect to Work Server
[18:17:01] - Attempt #5 to get work failed, and no other work to do.
Waiting before retry.-
sswilson
Re: 171.67.108.21 Reject / Maybe not resolved
Yep, back to being an issue again.........
sswilson
Finally pulled a WU again, but it took an hour.
Bobby-Uschi
- Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22" - Location: Deutschland
Today I have to wait a total of over three hours lost on new WUs.
Again, three machines are ...
Bob
] Folding@home Core Shutdown: FINISHED_UNIT
[22:58:39] CoreStatus = 64 (100)
[22:58:39] Unit 2 finished with 99 percent of time to deadline remaining.
[22:58:39] Updated performance fraction: 0.991010
[22:58:39] Sending work to server
[22:58:39] Project: 10512 (Run 5, Clone 691, Gen 23)
[22:58:39] - Read packet limit of 540015616... Set to 524286976.
[22:58:39] + Attempting to send results [September 23 22:58:39 UTC]
[22:58:39] - Reading file work/wuresults_02.dat from core
[22:58:39] (Read 139480 bytes from disk)
[22:58:39] Connecting to http://171.64.65.61:8080/
[22:58:45] Posted data.
[22:58:46] Initial: 0000; - Uploaded at ~19 kB/s
[22:58:46] - Averaged speed for that direction ~27 kB/s
[22:58:46] + Results successfully sent
[22:58:46] Thank you for your contribution to Folding@Home.
[22:58:46] + Number of Units Completed: 6188
[22:58:50] Trying to send all finished work units
[22:58:50] + No unsent completed units remaining.
[22:58:50] - Preparing to get new work unit...
[22:58:50] + Attempting to get work packet
[22:58:50] - Will indicate memory of 2046 MB
[22:58:50] - Connecting to assignment server
[22:58:50] Connecting to http://assign-GPU.stanford.edu:8080/
[22:58:51] Posted data.
[22:58:51] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:58:51] + News From Folding@Home: Welcome to Folding@Home
[22:58:51] Loaded queue successfully.
[22:58:51] Connecting to http://171.67.108.21:8080/
[23:00:55] Posted data.
[23:02:49] Initial: 00FA; + Could not connect to Work Server
[23:02:49] - Attempt #1 to get work failed, and no other work to do.
[23:03:04] + Attempting to get work packet
[23:03:04] - Will indicate memory of 2046 MB
[23:03:04] - Connecting to assignment server
[23:03:04] Connecting to http://assign-GPU.stanford.edu:8080/
[23:03:06] Posted data.
[23:03:06] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:03:06] + News From Folding@Home: Welcome to Folding@Home
[23:03:06] Loaded queue successfully.
[23:03:06] Connecting to http://171.67.108.21:8080/
[23:05:15] Posted data.
[23:07:51] Initial: 00FA; + Could not connect to Work Server
[23:07:51] - Attempt #2 to get work failed, and no other work to do.
[23:08:05] + Attempting to get work packet
[23:08:05] - Will indicate memory of 2046 MB
[23:08:05] - Connecting to assignment server
[23:08:05] Connecting to http://assign-GPU.stanford.edu:8080/
[23:08:06] Posted data.
[23:08:06] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:08:06] + News From Folding@Home: Welcome to Folding@Home
[23:08:06] Loaded queue successfully.
[23:08:06] Connecting to http://171.67.108.21:8080/
[23:10:06] Posted data.
[23:11:39] Initial: 00FA; + Could not connect to Work Server
[23:11:39] - Attempt #3 to get work failed, and no other work to do.
[23:12:01] + Attempting to get work packet
[23:12:01] - Will indicate memory of 2046 MB
[23:12:01] - Connecting to assignment server
[23:12:01] Connecting to http://assign-GPU.stanford.edu:8080/
[23:12:02] Posted data.
[23:12:02] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:12:02] + News From Folding@Home: Welcome to Folding@Home
[23:12:02] Loaded queue successfully.
[23:12:02] Connecting to http://171.67.108.21:8080/
[23:14:05] Posted data.
[23:15:59] Initial: 00FA; + Could not connect to Work Server
[23:15:59] - Attempt #4 to get work failed, and no other work to do.
[23:16:51] + Attempting to get work packet
[23:16:51] - Will indicate memory of 2046 MB
[23:16:51] - Connecting to assignment server
[23:16:51] Connecting to http://assign-GPU.stanford.edu:8080/
[23:16:52] Posted data.
[23:16:52] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:16:52] + News From Folding@Home: Welcome to Folding@Home
[23:16:52] Loaded queue successfully.
[23:16:52] Connecting to http://171.67.108.21:8080/
[23:18:56] Posted data.
[23:20:50] Initial: 00FA; + Could not connect to Work Server
[23:20:50] - Attempt #5 to get work failed, and no other work to do.
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
[05:08:46] + Attempting to send results [September 24 05:08:46 UTC]
[05:12:44] - Couldn't send HTTP request to server
[05:12:44] + Could not connect to Work Server (results)
[05:12:44] (171.67.108.21:8080)
[05:12:44] + Retrying using alternative port
[05:13:05] - Couldn't send HTTP request to server
[05:13:05] + Could not connect to Work Server (results)
[05:13:05] (171.67.108.21:80)
[05:13:05] - Error: Could not transmit unit 00 (completed September 23) to work server.4070 super
sortofageek
Re: 171.67.108.21 Reject / Recovering
The server has been restarted. See my message, last post in this topic.
It's definitely working a lot better. net load has now returned to normal-ish levels.
sortofageek
Thanks for letting us know.
