*So, what exactly does it do and how?
It's replaces the standard console window ( dos prompt ) with the view from the top image. From there, and from the system tray you can control the client ( stop/start ). It offers information about progress, eta, current protein and the recent wu history ( only from queue in this revision ) and ppd.
Console clients and console's running as service are supported, download the zipped executable and drop it in the folder of the client. Does not support renamed clients!
What is not supported!
Does not alter the standard behaviour of clients, will not configure gpu clients to run as service, will not succesfully install smp2 6.30+ as service if not started as admin ( vista/win7 -> right click fTray.exe - run as admin ).
Will be extended upon in the near future, see google code page for details.
Support for evaluation will be given through this thread or google code page, bug reports can be given on both locations and should include the following details:
- Client type and version
- Operating system
- Complete fahlog
- Installed .net version (3.5 is required)
- Description of event with if possible screenshots if behaviour is repeatable
Feature request are welcom.
Mod Note: Per author, this is no longer an active project.
