Project: 10632 (Run 64, Clone 54, Gen 2)
jesse's post was split from this ---> topic.
See also this topic.
I went on vacation and turned my machine off, now FAH won't run. Maybe it's the WU? I was folding for several weeks no problem. GTX 460, 258.59 driver, win 7 64, i7 940. GPU OCed but was very stable. I tried reinstall, no different.
[08:34:37] Project: 10632 (Run 64, Clone 54, Gen 2)
[08:34:37]
[08:34:37] Assembly optimizations on if available.
[08:34:37] Entering M.D.
[08:34:43] Tpr hash work/wudata_02.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[08:34:43] Working on 582 p2750_N68H_AM03
[08:34:43] Client config found, loading data.
[08:34:44] Starting GUI Server
[08:34:49] mdrun_gpu returned
[08:34:49] NANs detected on GPU
[08:34:49]
[08:34:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:34:52] CoreStatus = 7A (122)
[08:34:52] Sending work to server
[08:34:52] Project: 10632 (Run 64, Clone 54, Gen 2)
[08:34:52] - Read packet limit of 540015616... Set to 524286976.
[08:34:52] - Error: Could not get length of results file work/wuresults_02.dat
[08:34:52] - Error: Could not read unit 02 file. Removing from queue.
[08:34:52] - Preparing to get new work unit...
[08:34:52] Cleaning up work directory
[08:34:52] + Attempting to get work packet
[08:34:52] Gpu type=3 species=30.
[08:34:52] - Connecting to assignment server
[08:34:52] - Successful: assigned to (171.67.108.20).
[08:34:52] + News From Folding@Home: Welcome to Folding@Home
[08:34:52] Loaded queue successfully.
[08:34:52] + Closed connections
[08:34:57]
[08:34:57] + Processing work unit
[08:34:57] Core required: FahCore_15.exe
[08:34:57] Core found.
[08:34:57] Working on queue slot 03 [September 21 08:34:57 UTC]
[08:34:57] + Working ...
[08:34:58]
[08:34:58] *------------------------------*
[08:34:58] Folding@Home GPU Core -- Beta
[08:34:58] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[08:34:58]
[08:34:58] Build host: SimbiosNvdWin7
[08:34:58] Board Type: Nvidia
[08:34:58] Core :
[08:34:58] Preparing to commence simulation
[08:34:58] - Looking at optimizations...
[08:34:58] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[08:34:58] - Created dyn
[08:34:58] - Files status OK
[08:34:58] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:34:58] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[08:34:58] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[08:34:58] - Digital signature verified
[08:34:58]
[08:34:58] Project: 10632 (Run 64, Clone 54, Gen 2)
[08:34:58]
[08:34:58] Assembly optimizations on if available.
[08:34:58] Entering M.D.
[08:35:04] Tpr hash work/wudata_03.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[08:35:04] Working on 582 p2750_N68H_AM03
[08:35:04] Client config found, loading data.
[08:35:04] Starting GUI Server
[08:35:09] mdrun_gpu returned
[08:35:09] NANs detected on GPU
[08:35:09]
[08:35:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:35:12] CoreStatus = 7A (122)
[08:35:12] Sending work to server
[08:35:12] Project: 10632 (Run 64, Clone 54, Gen 2)
[08:35:12] - Read packet limit of 540015616... Set to 524286976.
[08:35:12] - Error: Could not get length of results file work/wuresults_03.dat
[08:35:12] - Error: Could not read unit 03 file. Removing from queue.
[08:35:12] EUE limit exceeded. Pausing 24 hours.
[08:34:37]
[08:34:49]
[08:34:57]
[08:34:58]
[08:34:58]
[08:34:58] Core :
[08:34:58]
[08:34:58]
[08:35:09]
sortofageek
Re: Project: 10632 (Run 64, Clone 54, Gen 2)
You may want to look elsewhere. Someone else completed that WU successfully and received full credit.
Hopefully, you didn't run temps too high with the OC'ing. An OC is logically the first thing to suspect when you have trouble folding. Good luck.
Please see the end of post here: http://foldingforum.org/viewtopic.php?f=59&t=16046
I've completely reinstalled FAH. It still tries to run this same WU and fails. I ran hundreds of WU on this machine while overclocked. memtestCL runs without error. I have all the Windows updates (as of last week). Maybe installing the Win updates caused a new problem? Or some interaction between WU and other s/w, h/w??? Did the other guy who ran this WU run core15? Win 7 64? GTX 460? 258.59 driver? If my machine truly became unstable then why doesn't memtestCL detect it? I would like to donate to FAH but I can't until this is fixed.
sortofageek
I have really told you all I can in terms of the WU itself and that is really what this forum is about.
I wish you the best in fixing this, but I can't help with a GPU as I have never folded with one.
merging
@jesse1919: Okay, I have never seen this "stubborn" WU ever, You are still gettting the same WU. Again, from your FAHlog:
[06:25:50] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:10] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:31] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:51] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:27:11] Project: 10632 (Run 64, Clone 54, Gen 2)
You have been assigned 10 times the same WU. A "normal" assign would be 6 times for GPU WUs then your Client moves on.
Sortofageek, I am ABSOLUTELY POSITIVELY certain that this WU is bad or at least partially to blame for my trouble. It now loaded a different WU and it is running no problem. I've run hundreds of other WUs without any problem. I didn't change anything on my machine since this morning and now it works. Apparently you can't assume that one successful run means a WU is "golden". Maybe the WU was working and then it became corrupted?
--- Opening Log file [September 22 06:21:17 UTC]
# Windows GPU Systray Edition #################################################
Folding@Home Client Version 6.30r2
http://folding.stanford.edu
Launch directory: C:\Users\user\AppData\Roaming\Folding@home-gpu
[06:21:17] Gpu type=3 species=30.
[06:21:38] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=50041...
[06:22:28] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=50400...
[06:22:39] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=40050...
[06:25:34] - Ask before connecting: No
[06:25:34] - User name: jesse1919 (Team 40051)
[06:25:34] - User ID: 3E9B90494F765B47
[06:25:34] - Machine ID: 2
[06:25:34]
[06:25:34] Work directory not found. Creating...
[06:25:34] Could not open work queue, generating new queue...
[06:25:34] Initialization complete
[06:25:34] - Preparing to get new work unit...
[06:25:34] Cleaning up work directory
[06:25:34] + Attempting to get work packet
[06:25:34] Gpu type=3 species=30.
[06:25:34] - Connecting to assignment server
[06:25:35] - Successful: assigned to (171.67.108.20).
[06:25:35] + News From Folding@Home: Welcome to Folding@Home
[06:25:35] Loaded queue successfully.
[06:25:35] Gpu type=3 species=30.
[06:25:36] + Closed connections
[06:25:36]
[06:25:36] + Processing work unit
[06:25:36] Core required: FahCore_15.exe
[06:25:36] Core not found.
[06:25:36] - Core is not present or corrupted.
[06:25:36] - Attempting to download new core...
[06:25:36] + Downloading new core: FahCore_15.exe
[06:25:36] + 10240 bytes downloaded
[06:25:36] + 20480 bytes downloaded
[06:25:36] + 30720 bytes downloaded
[06:25:36] + 40960 bytes downloaded
[06:25:36] + 51200 bytes downloaded
[06:25:36] + 61440 bytes downloaded
[06:25:36] + 71680 bytes downloaded
[06:25:36] + 81920 bytes downloaded
[06:25:36] + 92160 bytes downloaded
[06:25:36] + 102400 bytes downloaded
[06:25:36] + 112640 bytes downloaded
[06:25:36] + 122880 bytes downloaded
[06:25:36] + 133120 bytes downloaded
[06:25:36] + 143360 bytes downloaded
[06:25:36] + 153600 bytes downloaded
[06:25:36] + 163840 bytes downloaded
[06:25:36] + 174080 bytes downloaded
[06:25:36] + 184320 bytes downloaded
[06:25:36] + 194560 bytes downloaded
[06:25:36] + 204800 bytes downloaded
[06:25:36] + 215040 bytes downloaded
[06:25:36] + 225280 bytes downloaded
[06:25:36] + 235520 bytes downloaded
[06:25:36] + 245760 bytes downloaded
[06:25:36] + 256000 bytes downloaded
[06:25:37] + 266240 bytes downloaded
[06:25:37] + 276480 bytes downloaded
[06:25:37] + 286720 bytes downloaded
[06:25:37] + 296960 bytes downloaded
[06:25:37] + 307200 bytes downloaded
[06:25:37] + 317440 bytes downloaded
[06:25:37] + 327680 bytes downloaded
[06:25:37] + 337920 bytes downloaded
[06:25:37] + 348160 bytes downloaded
[06:25:37] + 358400 bytes downloaded
[06:25:37] + 368640 bytes downloaded
[06:25:37] + 378880 bytes downloaded
[06:25:37] + 389120 bytes downloaded
[06:25:37] + 399360 bytes downloaded
[06:25:37] + 409600 bytes downloaded
[06:25:37] + 419840 bytes downloaded
[06:25:37] + 430080 bytes downloaded
[06:25:37] + 440320 bytes downloaded
[06:25:37] + 450560 bytes downloaded
[06:25:37] + 460800 bytes downloaded
[06:25:37] + 471040 bytes downloaded
[06:25:37] + 481280 bytes downloaded
[06:25:37] + 491520 bytes downloaded
[06:25:37] + 501760 bytes downloaded
[06:25:37] + 512000 bytes downloaded
[06:25:37] + 522240 bytes downloaded
[06:25:37] + 532480 bytes downloaded
[06:25:37] + 542720 bytes downloaded
[06:25:37] + 552960 bytes downloaded
[06:25:37] + 563200 bytes downloaded
[06:25:37] + 573440 bytes downloaded
[06:25:37] + 583680 bytes downloaded
[06:25:37] + 593920 bytes downloaded
[06:25:37] + 604160 bytes downloaded
[06:25:37] + 614400 bytes downloaded
[06:25:38] + 624640 bytes downloaded
[06:25:38] + 634880 bytes downloaded
[06:25:38] + 645120 bytes downloaded
[06:25:38] + 655360 bytes downloaded
[06:25:38] + 665600 bytes downloaded
[06:25:38] + 675840 bytes downloaded
[06:25:38] + 686080 bytes downloaded
[06:25:38] + 696320 bytes downloaded
[06:25:38] + 706560 bytes downloaded
[06:25:38] + 716800 bytes downloaded
[06:25:38] + 727040 bytes downloaded
[06:25:38] + 737280 bytes downloaded
[06:25:38] + 747520 bytes downloaded
[06:25:38] + 757760 bytes downloaded
[06:25:38] + 768000 bytes downloaded
[06:25:38] + 778240 bytes downloaded
[06:25:38] + 788480 bytes downloaded
[06:25:38] + 798720 bytes downloaded
[06:25:38] + 808960 bytes downloaded
[06:25:38] + 819200 bytes downloaded
[06:25:38] + 829440 bytes downloaded
[06:25:38] + 839680 bytes downloaded
[06:25:38] + 849920 bytes downloaded
[06:25:38] + 860160 bytes downloaded
[06:25:38] + 870400 bytes downloaded
[06:25:38] + 880640 bytes downloaded
[06:25:38] + 890880 bytes downloaded
[06:25:38] + 901120 bytes downloaded
[06:25:38] + 911360 bytes downloaded
[06:25:38] + 921600 bytes downloaded
[06:25:38] + 931840 bytes downloaded
[06:25:38] + 942080 bytes downloaded
[06:25:38] + 952320 bytes downloaded
[06:25:38] + 962560 bytes downloaded
[06:25:38] + 972800 bytes downloaded
[06:25:38] + 983040 bytes downloaded
[06:25:39] + 993280 bytes downloaded
[06:25:39] + 1003520 bytes downloaded
[06:25:39] + 1013760 bytes downloaded
[06:25:39] + 1024000 bytes downloaded
[06:25:39] + 1034240 bytes downloaded
[06:25:39] + 1044480 bytes downloaded
[06:25:39] + 1054720 bytes downloaded
[06:25:39] + 1064960 bytes downloaded
[06:25:39] + 1075200 bytes downloaded
[06:25:39] + 1085440 bytes downloaded
[06:25:39] + 1095680 bytes downloaded
[06:25:39] + 1105920 bytes downloaded
[06:25:39] + 1116160 bytes downloaded
[06:25:39] + 1126400 bytes downloaded
[06:25:39] + 1136640 bytes downloaded
[06:25:39] + 1146880 bytes downloaded
[06:25:39] + 1157120 bytes downloaded
[06:25:39] + 1167360 bytes downloaded
[06:25:39] + 1177600 bytes downloaded
[06:25:39] + 1187840 bytes downloaded
[06:25:39] + 1198080 bytes downloaded
[06:25:39] + 1208320 bytes downloaded
[06:25:39] + 1218560 bytes downloaded
[06:25:39] + 1228800 bytes downloaded
[06:25:39] + 1239040 bytes downloaded
[06:25:39] + 1249280 bytes downloaded
[06:25:39] + 1259520 bytes downloaded
[06:25:39] + 1269760 bytes downloaded
[06:25:39] + 1280000 bytes downloaded
[06:25:39] + 1290240 bytes downloaded
[06:25:39] + 1300480 bytes downloaded
[06:25:39] + 1310720 bytes downloaded
[06:25:39] + 1320960 bytes downloaded
[06:25:39] + 1331200 bytes downloaded
[06:25:39] + 1341440 bytes downloaded
[06:25:40] + 1351680 bytes downloaded
[06:25:40] + 1361920 bytes downloaded
[06:25:40] + 1367545 bytes downloaded
[06:25:40] Verifying core Core_15.fah...
[06:25:40] Signature is VALID
[06:25:40]
[06:25:40] Trying to unzip core FahCore_15.exe
[06:25:40] Decompressed FahCore_15.exe (4136960 bytes) successfully
[06:25:45] + Core successfully engaged
[06:25:50]
[06:25:50] + Processing work unit
[06:25:50] Core required: FahCore_15.exe
[06:25:50] Core found.
[06:25:50] Working on queue slot 01 [September 22 06:25:50 UTC]
[06:25:50] + Working ...
[06:25:50]
[06:25:50] *------------------------------*
[06:25:50] Folding@Home GPU Core -- Beta
[06:25:50] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[06:25:50]
[06:25:50] Build host: SimbiosNvdWin7
[06:25:50] Board Type: Nvidia
[06:25:50] Core :
[06:25:50] Preparing to commence simulation
[06:25:50] - Looking at optimizations...
[06:25:50] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[06:25:50] - Created dyn
[06:25:50] - Files status OK
[06:25:50] sizeof(CORE_PACKET_HDR) = 512 file=<>
[06:25:50] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[06:25:50] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[06:25:50] - Digital signature verified
[06:25:50]
[06:25:50]
[06:25:50] Assembly optimizations on if available.
[06:25:50] Entering M.D.
[06:25:56] Tpr hash work/wudata_01.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[06:25:56] Working on 582 p2750_N68H_AM03
[06:25:57] Client config found, loading data.
[06:25:57] Starting GUI Server
[06:26:02] mdrun_gpu returned
[06:26:02] NANs detected on GPU
[06:26:02]
[06:26:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:26:04] CoreStatus = 7A (122)
[06:26:04] Sending work to server
[06:26:04] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:04] - Read packet limit of 540015616... Set to 524286976.
[06:26:04] - Error: Could not get length of results file work/wuresults_01.dat
[06:26:04] - Error: Could not read unit 01 file. Removing from queue.
[06:26:04] - Preparing to get new work unit...
[06:26:04] Cleaning up work directory
[06:26:04] + Attempting to get work packet
[06:26:04] Gpu type=3 species=30.
[06:26:04] - Connecting to assignment server
[06:26:05] - Successful: assigned to (171.67.108.20).
[06:26:05] + News From Folding@Home: Welcome to Folding@Home
[06:26:05] Loaded queue successfully.
[06:26:05] Gpu type=3 species=30.
[06:26:05] + Closed connections
[06:26:10]
[06:26:10] + Processing work unit
[06:26:10] Core required: FahCore_15.exe
[06:26:10] Core found.
[06:26:10] Working on queue slot 02 [September 22 06:26:10 UTC]
[06:26:10] + Working ...
[06:26:10]
[06:26:10] *------------------------------*
[06:26:10] Folding@Home GPU Core -- Beta
[06:26:10] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[06:26:10]
[06:26:10] Build host: SimbiosNvdWin7
[06:26:10] Board Type: Nvidia
[06:26:10] Core :
[06:26:10] Preparing to commence simulation
[06:26:10] - Looking at optimizations...
[06:26:10] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[06:26:10] - Created dyn
[06:26:10] - Files status OK
[06:26:10] sizeof(CORE_PACKET_HDR) = 512 file=<>
[06:26:10] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[06:26:10] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[06:26:10] - Digital signature verified
[06:26:10]
[06:26:10]
[06:26:10] Assembly optimizations on if available.
[06:26:10] Entering M.D.
[06:26:16] Tpr hash work/wudata_02.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[06:26:16] Working on 582 p2750_N68H_AM03
[06:26:16] Client config found, loading data.
[06:26:17] Starting GUI Server
[06:26:22] mdrun_gpu returned
[06:26:22] NANs detected on GPU
[06:26:22]
[06:26:22] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:26:25] CoreStatus = 7A (122)
[06:26:25] Sending work to server
[06:26:25] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:25] - Read packet limit of 540015616... Set to 524286976.
[06:26:25] - Error: Could not get length of results file work/wuresults_02.dat
[06:26:25] - Error: Could not read unit 02 file. Removing from queue.
[06:26:25] - Preparing to get new work unit...
[06:26:25] Cleaning up work directory
[06:26:25] + Attempting to get work packet
[06:26:25] Gpu type=3 species=30.
[06:26:25] - Connecting to assignment server
[06:26:25] - Successful: assigned to (171.67.108.20).
[06:26:25] + News From Folding@Home: Welcome to Folding@Home
[06:26:25] Loaded queue successfully.
[06:26:25] + Closed connections
[06:26:30]
[06:26:30] + Processing work unit
[06:26:30] Core required: FahCore_15.exe
[06:26:30] Core found.
[06:26:30] Working on queue slot 03 [September 22 06:26:30 UTC]
[06:26:30] + Working ...
[06:26:31]
[06:26:31] *------------------------------*
[06:26:31] Folding@Home GPU Core -- Beta
[06:26:31] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[06:26:31]
[06:26:31] Build host: SimbiosNvdWin7
[06:26:31] Board Type: Nvidia
[06:26:31] Core :
[06:26:31] Preparing to commence simulation
[06:26:31] - Looking at optimizations...
[06:26:31] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[06:26:31] - Created dyn
[06:26:31] - Files status OK
[06:26:31] sizeof(CORE_PACKET_HDR) = 512 file=<>
[06:26:31] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[06:26:31] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[06:26:31] - Digital signature verified
[06:26:31]
[06:26:31]
[06:26:31] Assembly optimizations on if available.
[06:26:31] Entering M.D.
[06:26:37] Tpr hash work/wudata_03.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[06:26:37] Working on 582 p2750_N68H_AM03
[06:26:37] Client config found, loading data.
[06:26:37] Starting GUI Server
[06:26:42] mdrun_gpu returned
[06:26:42] NANs detected on GPU
[06:26:42]
[06:26:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:26:45] CoreStatus = 7A (122)
[06:26:45] Sending work to server
[06:26:45] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:26:45] - Read packet limit of 540015616... Set to 524286976.
[06:26:45] - Error: Could not get length of results file work/wuresults_03.dat
[06:26:45] - Error: Could not read unit 03 file. Removing from queue.
[06:26:45] - Preparing to get new work unit...
[06:26:45] Cleaning up work directory
[06:26:45] + Attempting to get work packet
[06:26:45] Gpu type=3 species=30.
[06:26:45] - Connecting to assignment server
[06:26:45] - Successful: assigned to (171.67.108.20).
[06:26:45] + News From Folding@Home: Welcome to Folding@Home
[06:26:45] Loaded queue successfully.
[06:26:46] + Closed connections
[06:26:51]
[06:26:51] + Processing work unit
[06:26:51] Core required: FahCore_15.exe
[06:26:51] Core found.
[06:26:51] Working on queue slot 04 [September 22 06:26:51 UTC]
[06:26:51] + Working ...
[06:26:51]
[06:26:51] *------------------------------*
[06:26:51] Folding@Home GPU Core -- Beta
[06:26:51] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[06:26:51]
[06:26:51] Build host: SimbiosNvdWin7
[06:26:51] Board Type: Nvidia
[06:26:51] Core :
[06:26:51] Preparing to commence simulation
[06:26:51] - Looking at optimizations...
[06:26:51] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[06:26:51] - Created dyn
[06:26:51] - Files status OK
[06:26:51] sizeof(CORE_PACKET_HDR) = 512 file=<>
[06:26:51] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[06:26:51] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[06:26:51] - Digital signature verified
[06:26:51]
[06:26:51]
[06:26:51] Assembly optimizations on if available.
[06:26:51] Entering M.D.
[06:26:57] Tpr hash work/wudata_04.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[06:26:57] Working on 582 p2750_N68H_AM03
[06:26:57] Client config found, loading data.
[06:26:57] Starting GUI Server
[06:27:02] mdrun_gpu returned
[06:27:02] NANs detected on GPU
[06:27:02]
[06:27:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:27:05] CoreStatus = 7A (122)
[06:27:05] Sending work to server
[06:27:05] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:27:05] - Read packet limit of 540015616... Set to 524286976.
[06:27:05] - Error: Could not get length of results file work/wuresults_04.dat
[06:27:05] - Error: Could not read unit 04 file. Removing from queue.
[06:27:05] - Preparing to get new work unit...
[06:27:05] Cleaning up work directory
[06:27:05] + Attempting to get work packet
[06:27:05] Gpu type=3 species=30.
[06:27:05] - Connecting to assignment server
[06:27:05] - Successful: assigned to (171.67.108.20).
[06:27:05] + News From Folding@Home: Welcome to Folding@Home
[06:27:06] Loaded queue successfully.
[06:27:06] Gpu type=3 species=30.
[06:27:06] + Closed connections
[06:27:11]
[06:27:11] + Processing work unit
[06:27:11] Core required: FahCore_15.exe
[06:27:11] Core found.
[06:27:11] Working on queue slot 05 [September 22 06:27:11 UTC]
[06:27:11] + Working ...
[06:27:11]
[06:27:11] *------------------------------*
[06:27:11] Folding@Home GPU Core -- Beta
[06:27:11] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[06:27:11]
[06:27:11] Build host: SimbiosNvdWin7
[06:27:11] Board Type: Nvidia
[06:27:11] Core :
[06:27:11] Preparing to commence simulation
[06:27:11] - Looking at optimizations...
[06:27:11] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[06:27:11] - Created dyn
[06:27:11] - Files status OK
[06:27:11] sizeof(CORE_PACKET_HDR) = 512 file=<>
[06:27:11] - Expanded 28890 -> 163067 (decompressed 564.4 percent)
[06:27:11] Called DecompressByteArray: compressed_data_size=28890 data_size=163067, decompressed_data_size=163067 diff=0
[06:27:11] - Digital signature verified
[06:27:11]
[06:27:11]
[06:27:11] Assembly optimizations on if available.
[06:27:11] Entering M.D.
[06:27:17] Tpr hash work/wudata_05.tpr: 340940897 891960641 2345133736 2448745168 2148104977
[06:27:17] Working on 582 p2750_N68H_AM03
[06:27:17] Client config found, loading data.
[06:27:18] Starting GUI Server
[06:27:23] mdrun_gpu returned
[06:27:23] NANs detected on GPU
[06:27:23]
[06:27:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:27:25] CoreStatus = 7A (122)
[06:27:25] Sending work to server
[06:27:25] Project: 10632 (Run 64, Clone 54, Gen 2)
[06:27:25] - Read packet limit of 540015616... Set to 524286976.
[06:27:25] - Error: Could not get length of results file work/wuresults_05.dat
[06:27:25] - Error: Could not read unit 05 file. Removing from queue.
[06:27:25] EUE limit exceeded. Pausing 24 hours.
[06:43:48] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=jesse1919...
Folding@Home Client Shutdown.
--- Opening Log file [September 23 02:42:26 UTC]
[02:42:26] - Ask before connecting: No
[02:42:26] - User name: jesse1919 (Team 40051)
[02:42:26] - User ID: 3E9B90494F765B47
[02:42:26] - Machine ID: 2
[02:42:26]
[02:42:26] Gpu type=3 species=30.
[02:42:26] Loaded queue successfully.
[02:42:26] Initialization complete
[02:42:26] - Preparing to get new work unit...
[02:42:26] Cleaning up work directory
[02:42:26] + Attempting to get work packet
[02:42:26] - Connecting to assignment server
[02:42:27] - Successful: assigned to (171.67.108.20).
[02:42:27] + News From Folding@Home: Welcome to Folding@Home
[02:42:27] Loaded queue successfully.
[02:42:27] Gpu type=3 species=30.
[02:42:27] + Closed connections
[02:42:27]
[02:42:27] + Processing work unit
[02:42:27] Core required: FahCore_15.exe
[02:42:27] Core found.
[02:42:27] Working on queue slot 06 [September 23 02:42:27 UTC]
[02:42:27] + Working ...
[02:42:27]
[02:42:27] *------------------------------*
[02:42:27] Folding@Home GPU Core -- Beta
[02:42:27] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[02:42:27]
[02:42:27] Build host: SimbiosNvdWin7
[02:42:27] Board Type: Nvidia
[02:42:27] Core :
[02:42:27] Preparing to commence simulation
[02:42:27] - Looking at optimizations...
[02:42:27] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[02:42:27] - Created dyn
[02:42:27] - Files status OK
[02:42:27] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:42:27] - Expanded 43904 -> 163067 (decompressed 371.4 percent)
[02:42:27] Called DecompressByteArray: compressed_data_size=43904 data_size=163067, decompressed_data_size=163067 diff=0
[02:42:27] - Digital signature verified
[02:42:27]
[02:42:27] Project: 10632 (Run 49, Clone 50, Gen 21)
[02:42:27]
[02:42:27] Assembly optimizations on if available.
[02:42:27] Entering M.D.
[02:42:33] Tpr hash work/wudata_06.tpr: 280921638 2218236195 2562458967 3657403455 143969269
[02:42:34] Working on 582 p2750_N68H_AM03
[02:42:34] Client config found, loading data.
[02:42:34] Starting GUI Server
[02:43:26] Completed 1%
[02:44:18] Completed 2%
[02:45:10] Completed 3%
[02:46:02] Completed 4%
[02:46:54] Completed 5%
[02:47:47] Completed 6%
[02:48:39] Completed 7%
[02:49:31] Completed 8%
[02:50:23] Completed 9%
[02:51:15] Completed 10%
[02:52:07] Completed 11%
[02:52:59] Completed 12%
[02:53:51] Completed 13%
[02:54:43] Completed 14%
[02:55:36] Completed 15%
[02:56:28] Completed 16%
[02:57:21] Completed 17%
[02:58:13] Completed 18%
[02:59:05] Completed 19%
[02:59:58] Completed 20%
[03:00:50] Completed 21%
[03:01:43] Completed 22%
[03:02:35] Completed 23%
[03:03:28] Completed 24%
[03:04:20] Completed 25%
[03:05:12] Completed 26%
[03:06:05] Completed 27%
Re: GPU - UNSTABLE_MACHINE error
PantherX, yes it was a bad WU. It's finally running now after 2 days of trying to run the same bad WU. Thanks. Sortofageek said someone else ran it and got full credit.
Mod Note: If this post seems confusing, it was split from Saleen's thread. ~sorto'
MtM
jesse did you do a proper upgrade to fermi? Could it be that you treid to fold this wu with an old fahcore_15? Old meaning, a fahcore which was supposed to run on pre fermi cards?
Could be the same with saleen?
A wu with the same prcg are identical, it can not get corrupted ( maybe during transfer but the client checks this and downloads it again if needed ).
It looks like both you and Saleen have a configuration problem, and it is not the work units fault.
Sorry for that.
Sorry for that.
codysluder
Same WU being reported here viewtopic.php?f=59&t=16338 by a very frustrated B2K24
I thought they were to discontinue issuing 10632's until they figured out the problem of them keep being reissued after successful completions. It took 4 runs for (R91, C102, G 16) to complete on me
sortofageek
Project: 10632 (Run 64, Clone 54, Gen 2) has been stopped by the project manager. Thanks again to all who are reporting.
