Project: 6515 (Run 8, Clone 1, Gen 55), ERROR 0x8b
DeeGee
Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10
Post by DeeGee »
I'm starting to wonder if my linux machine has some hardware problems... Or then there just has been bad WU's around.
[04:07:34] Completed 247500 out of 250000 steps  (99%)
[04:28:49] Writing local files
[04:28:49] Completed 250000 out of 250000 steps  (100%)
[04:28:50] Writing final coordinates.
[04:28:50] Past main M.D. loop
[04:29:50]
[04:29:50] Finished Work Unit:
[04:29:50] - Reading up to 622152 from "work/wudata_02.arc": Read 622152
[04:29:50] - Reading up to 241600 from "work/wudata_02.xtc": Read 241600
[04:29:50] goefile size: 0
[04:29:50] logfile size: 62262
[04:29:50] Leaving Run
[04:29:50] - Writing 982274 bytes of core data to disk...
[04:29:50] Done: 981762 -> 874978 (compressed to 89.1 percent)
[04:29:50]   ... Done.
[04:29:51] - Shutting down core
[04:29:51]
[04:29:51] Folding@home Core Shutdown: FINISHED_UNIT
[04:29:52] CoreStatus = 64 (100)
[04:29:52] Sending work to server
[04:29:52] Project: 6511 (Run 14, Clone 6, Gen 51)
[04:29:52] - Read packet limit of 540015616... Set to 524286976.
[04:29:52] + Attempting to send results [September 18 04:29:52 UTC]
[04:29:57] + Results successfully sent
[04:29:57] Thank you for your contribution to Folding@Home.
[04:29:57] + Number of Units Completed: 211
[04:29:58] - Preparing to get new work unit...
[04:29:58] Cleaning up work directory
[04:29:58] + Attempting to get work packet
[04:29:58] Passkey found
[04:29:58] - Connecting to assignment server
[04:29:59] - Successful: assigned to (171.64.65.62).
[04:29:59] + News From Folding@Home: Welcome to Folding@Home
[04:29:59] Loaded queue successfully.
[04:30:03] + Closed connections
[04:30:03]
[04:30:03] + Processing work unit
[04:30:03] Core required: FahCore_78.exe
[04:30:03] Core found.
[04:30:03] Working on queue slot 03 [September 18 04:30:03 UTC]
[04:30:03] + Working ...
[04:30:03]
[04:30:03] *------------------------------*
[04:30:03] Folding@Home Gromacs Core
[04:30:03] Version 1.90 (March 8, 2006)
[04:30:03]
[04:30:03] Preparing to commence simulation
[04:30:03] - Looking at optimizations...
[04:30:03] - Created dyn
[04:30:03] - Files status OK
[04:30:04] - Expanded 507122 -> 2515965 (decompressed 496.1 percent)
[04:30:04] - Starting from initial work packet
[04:30:04]
[04:30:04] Project: 6515 (Run 8, Clone 1, Gen 55)
[04:30:04]
[04:30:04] Assembly optimizations on if available.
[04:30:04] Entering M.D.
[04:30:10] Protein: 1CFC_A_9 in water
[04:30:10]
[04:30:10] Writing local files
[04:30:10] Extra SSE boost OK.
[04:30:10] Completed 0 out of 250000 steps  (0%)
[04:38:54] Writing local files
[04:38:55] Completed 2500 out of 250000 steps  (1%)
[04:47:39] Writing local files
[04:47:39] Completed 5000 out of 250000 steps  (2%)
[04:56:24] Writing local files
[04:56:24] Completed 7500 out of 250000 steps  (3%)
[05:05:07] Writing local files
[05:05:07] Completed 10000 out of 250000 steps  (4%)
[05:13:51] Writing local files
[05:13:51] Completed 12500 out of 250000 steps  (5%)
[05:22:35] Writing local files
[05:22:35] Completed 15000 out of 250000 steps  (6%)
[05:31:19] Writing local files
[05:31:19] Completed 17500 out of 250000 steps  (7%)
[05:40:03] Writing local files
[05:40:03] Completed 20000 out of 250000 steps  (8%)
[05:48:46] Writing local files
[05:48:46] Completed 22500 out of 250000 steps  (9%)
[05:57:29] Writing local files
[05:57:29] Completed 25000 out of 250000 steps  (10%)
[06:06:14] Writing local files
[06:06:14] Completed 27500 out of 250000 steps  (11%)
[06:14:59] Writing local files
[06:14:59] Completed 30000 out of 250000 steps  (12%)
[06:23:44] Writing local files
[06:23:44] Completed 32500 out of 250000 steps  (13%)
[06:32:31] Writing local files
[06:32:31] Completed 35000 out of 250000 steps  (14%)
[06:41:18] Writing local files
[06:41:18] Completed 37500 out of 250000 steps  (15%)
[06:50:04] Writing local files
[06:50:04] Completed 40000 out of 250000 steps  (16%)
[06:58:51] Writing local files
[06:58:51] Completed 42500 out of 250000 steps  (17%)
[07:07:38] Writing local files
[07:07:38] Completed 45000 out of 250000 steps  (18%)
[07:16:26] Writing local files
[07:16:26] Completed 47500 out of 250000 steps  (19%)
[07:25:12] Writing local files
[07:25:12] Completed 50000 out of 250000 steps  (20%)
[07:33:59] Writing local files
[07:33:59] Completed 52500 out of 250000 steps  (21%)
[07:42:43] Writing local files
[07:42:43] Completed 55000 out of 250000 steps  (22%)
[07:51:26] Writing local files
[07:51:26] Completed 57500 out of 250000 steps  (23%)
[08:00:10] Writing local files
[08:00:10] Completed 60000 out of 250000 steps  (24%)
[08:08:55] Writing local files
[08:08:55] Completed 62500 out of 250000 steps  (25%)
[08:17:39] Writing local files
[08:17:39] Completed 65000 out of 250000 steps  (26%)
[08:18:12] CoreStatus = 8B (139)
[08:18:12] Client-core communications error: ERROR 0x8b
[08:18:12] This is a sign of more serious problems, shutting down.
Re: Project: 6515 (Run 8, Clone 1, Gen 55), ERROR 0x8b
There are two reports of EUE ... it's a bit too early to conclude, but the odds are not good.
DeeGee
Post by DeeGee »
Seems the same exact workunit got sent to me again and it also errored with the same message at the same point...
Ok. The WU (P6515,R8,C1,G55) has now been reported as a bad WU.
