Somethings up with this server, someone else is reporting similar issues below.
viewtopic.php?f=18&t=16012
My GPU's can't get work either.
171.67.108.200 Couldn't get work instructions.
Blasphemous Cannibal
MtM
Re: 171.67.108.200 Couldn't get work instructions.
WU's available -> 0Blasphemous Cannibal wrote:Somethings up with this server, someone else is reporting similar issues below.
Edit: since when does an AS server needs wu's available..
What exactly is your problem? What client? Why post that you can't get wu's and only reference an as server?
sortofageek
Could we see a log, please?
171.67.108.200 appears to be a server for classic WUs. Server status page shows no WUs available.
But you mention GPUs not getting work, so I'm confused.
It would help if you start one thread for each server you are reporting, post relevant logs and error messages. I confuse easily.
sortofageek
I did contact Pande Group about that server just in case, but we need to see the logs. I suspect that isn't the work server.
Edit: Since 171.67.108.200 is an Assignment Server (AS), it would not be expected to distribute work units.
MtM
Log file for AS server shows nothing strange, I think he ment smp but started a new thread since he got confused about the AS server IP.
I can't find an Gpu server which is down, is out of available work units, is not accepting new requests. All seems fine.
Edit: also OP is having some issues with gpu client in general, so was doing some testing and I recon he misconfigured the client which is why he could not get work units.
OP has a completely unrelated, specific issue with a beta client. OP knows how to configure his clients for your information.MtM wrote:Edit: also OP is having some issues with gpu client in general, so was doing some testing and I recon he misconfigured the client which is why he could not get work units.
Please see the link on the link I attached above.
viewtopic.php?f=16&t=16014#p158827
Clearly, some type of server issue caused a loss of work allocation for a period of time time last night.
sortofageek
In the first post in this topic, you said ...
That link is to a topic about a server which distributes SMP WUs, not GPU WUs. For a brief period it had no work units to distribute. People reported. 7im notified Pande Group. Pande Group quickly responded and all was well again.
In this thread, you reported 171.67.108.200 as an issue in regard to "Couldn't get work instructions." What we're trying to point out here is that 171.67.108.200 is only an Assignment Server and, thus, would never distribute work. We would need more information to be able to help you in a situation like that.
To report a problem like that here, please include the IP address of the Work Server (WS) with which you are having a problem. Please also post the relevant logs. We can help better that way.
Thank you and TIA,
sorto'
Thank you and TIA,
sorto'
