P11229R0C0G43
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
P11229R0C0G43
Post by jimerickson »
client hangs at 13%
9211 [09:45:55] *------------------------------*
9212 [09:45:55] Folding@Home GPU Core -- Beta
9213 [09:45:55] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
9214 [09:45:55]
9215 [09:45:55] Build host: SimbiosNvdWin7
9216 [09:45:55] Board Type: Nvidia
9217 [09:45:55] Core      :
9218 [09:45:55] Preparing to commence simulation
9219 [09:45:55] - Looking at optimizations...
9220 [09:45:55] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
9221 [09:45:55] - Created dyn
9222 [09:45:55] - Files status OK
9223 [09:45:55] sizeof(CORE_PACKET_HDR) = 512 file=<>
9224 [09:45:55] - Expanded 18901 -> 76495 (decompressed 404.7 percent)
9225 [09:45:55] Called DecompressByteArray: compressed_data_size=18901 data_size=76495, decompressed_data_size=76495 diff=0
9226 [09:45:55] - Digital signature verified
9227 [09:45:55]
9228 [09:45:55] Project: 11229 (Run 0, Clone 0, Gen 43)
9229 [09:45:55]
9230 [09:45:55] Assembly optimizations on if available.
9231 [09:45:55] Entering M.D.
9232 [09:46:01] Tpr hash work/wudata_08.tpr:  903292506 2545191240 3417436218 31100430 3595489622
9233 [09:46:01] Working on 264 Fs_coil
9234 [09:46:01] Client config found, loading data.
9235 [09:46:02] Starting GUI Server
9236 [09:47:20] Completed 1%
9237 [09:48:37] Completed 2%
9238 [09:49:55] Completed 3%
9239 [09:51:13] Completed 4%
9240 [09:52:31] Completed 5%
9241 [09:53:49] Completed 6%
9242 [09:55:07] Completed 7%
9243 [09:56:24] Completed 8%
9244 [09:57:42] Completed 9%
9245 [09:59:01] Completed 10%
9246 [10:00:18] Completed 11%
9247 [10:01:36] Completed 12%
9248 [10:02:54] Completed 13%
9249
9250 Folding@Home Client Shutdown.]
ChelseaOilman
Re: P11229R0C0G43
Post by ChelseaOilman »
Someone else has finished that WU already for full credit, so it's probably not an issue with the WU.
Hi xxxxxxxxxx (team xxxxxx),
Your WU (P11229 R0 C0 G43) was added to the stats database on 2010-09-12 03:07:40 for 912 points of credit.
jimerickson
Re: P11229R0C0G43
thanks for the info ChelseaOilman. it has downloaded another unit and i am folding again.
