help finding progress
hi ive been folding sinds yesterday and finsished 1 works so i registered here and was looking for my stats but caNT FIND THEM ANYWHERE.
im in the bitgamer group team number 97103
can anyone help me?
can anyone help me?
noprob
- Hardware configuration: borgs
Re: help finding progress
You can use the official stat search at Stanford Team Statistics or Donor Statistics I also use EOC search to locate team and user information.
fold on
fold on
still cant find myself.....
Your Teams Official Stats: http://fah-web.stanford.edu/cgi-bin/mai ... mnum=97103
For further information, please post the FAHlog so an admin/mod can check the WU (Work Unit)
Zagen30
I assume this is you: http://fah-web.stanford.edu/cgi-bin/mai ... name=Praiz
thak alot mate. dont know how you did it:P
but i couldn't.
cheers,
but i couldn't.
cheers,
Zagen30
I just went to the Donor Statistics page that noprob linked to above and typed in "praiz". You might want to bookmark your stats page for future reference.
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
The client also creates the MyFolding.html file among other data files such as client.cfg when you've configured the client. Said .html file contains links to your personal and team stats as well.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
thanks alot again, i tried to find mysef at the donor page but couldn't.
happy folding to you!!!
Go to this page: fah-web.stanford.edu/cgi-bin/main.py?qtype=userstatsPraiz wrote:thanks alot again, i tried to find mysef at the donor page but couldn't.
In the textbox under "Name is exactly" type your folding nickname, in your case "Praiz" and click Search button.
You should see single result which is your stats.
. . . unless somebody else has used the name "Praiz" which, although rather unlikely, can happen. When more than one person uses the same name, you have to use your passkey to differentiate one set of results from another.yahavbr wrote:Go to this page: fah-web.stanford.edu/cgi-bin/main.py?qtype=userstatsPraiz wrote:thanks alot again, i tried to find mysef at the donor page but couldn't.
Good to know.. and what happens when there is no passkey to any of the persons using the same name? Is there any unique ID generated on the F@H server?bruce wrote:. . . unless somebody else has used the name "Praiz" which, although rather unlikely, can happen. When more than one person uses the same name, you have to use your passkey to differentiate one set of results from another.yahavbr wrote:Go to this page: fah-web.stanford.edu/cgi-bin/main.py?qtype=userstatsPraiz wrote:thanks alot again, i tried to find mysef at the donor page but couldn't.
No. They cannot be sorted out, although if they happen to be on different teams, that might work, too.yahavbr wrote:Good to know.. and what happens when there is no passkey to any of the persons using the same name? Is there any unique ID generated on the F@H server?
Early FAH stats didn't enforce any kind of uniqueness on the donors. The passkey was developed to provide that sort of uniqueness, but it's still optional.
I just found out something interesting:bruce wrote:No. They cannot be sorted out, although if they happen to be on different teams, that might work, too.yahavbr wrote:Good to know.. and what happens when there is no passkey to any of the persons using the same name? Is there any unique ID generated on the F@H server?
F@H console wrote:[08:38:06] - User name: Shadow_Wizard (Team 12912)
[08:38:06] - User ID: 64D63EB00316CDA
[08:38:06] - Machine ID: 1
What is this "User ID"? Is it per machine or per user?
MtM
http://fahwiki.net/index.php/UserID
UserID is generated from MachinID and CpuID, ít's diffrent per client therefore and is used by the collection servers to ensure work is turned in from the same person as it's been handed out to.
