Project 10022 (Run 573, Clone 0, Gen 24)
johnph77
Post by johnph77 »
[05:05:57] Completed 344600 out of 499375 steps (69%)
[05:08:43] WARNING: Caught signal SIGSEGV(11) on PID 3320
[05:08:44] WARNING: Unexpected exit from science code
[05:08:44] Saving result file logfile_04.txt
[05:08:44] Saving result file checkpt
[05:08:44] Saving result file checkpt.crc
[05:08:44] Saving result file log.txt
[05:08:47] Saving result file protomol.conf
[05:08:47] Saving result file ww.2035.pos
[05:08:47] Saving result file ww.2035.vel
[05:08:47] Saving result file ww.dcd
[05:08:48] Folding@home Core Shutdown: BAD_WORK_UNIT
[05:08:51] CoreStatus = 72 (114)
[05:08:51] Sending work to server
[05:08:51] Project: 10022 (Run 573, Clone 0, Gen 24)
[05:08:51] - Read packet limit of 540015616... Set to 524286976.
[05:08:51] + Attempting to send results [September 7 05:08:51 UTC]
[05:08:52] - Couldn't send HTTP request to server
[05:08:52] + Could not connect to Work Server (results)
[05:08:52] (129.74.85.15:8080)
[05:08:52] + Retrying using alternative port
[05:08:53] - Couldn't send HTTP request to server
[05:08:53] + Could not connect to Work Server (results)
[05:08:53] (129.74.85.15:80)
[05:08:53] - Error: Could not transmit unit 04 (completed September 7) to work server.
[05:08:53] Keeping unit 04 in queue.
[05:08:53] Project: 10022 (Run 573, Clone 0, Gen 24)
These results were eventually sent. No problem.
Given sufficient thrust, pigs fly just fine.
Re: Project 10022 (Run 573, Clone 0, Gen 24)
Someone else completed this WU successfully.
