Project: 2633 (Run 7, Clone 3, Gen 9)
noprob
Hardware configuration: borgs
Post by noprob »
and another one bites the dust...
[04:38:06] Project: 2633 (Run 7, Clone 3, Gen 9)
[04:38:06]
[04:38:06] Assembly optimizations on if available.
[04:38:06] Entering M.D.
[04:38:12] Using Gromacs checkpoints
[04:38:12] Resuming from checkpoint
[04:38:12] Verified work/wudata_07.log
[04:38:12] Verified work/wudata_07.trr
[04:38:12] Verified work/wudata_07.xtc
[04:38:12] Verified work/wudata_07.edr
[04:38:13] Completed 10100 out of 625000 steps  (1%)
[04:42:21] Completed 12500 out of 625000 steps  (2%)
[04:53:08] Completed 18750 out of 625000 steps  (3%)
[05:04:12] Completed 25000 out of 625000 steps  (4%)
[05:15:12] Completed 31250 out of 625000 steps  (5%)
[05:26:42] Completed 37500 out of 625000 steps  (6%)
[05:36:37] mdrun returned 255
[05:36:37] Going to send back what have done -- stepsTotalG=625000
[05:36:37] Work fraction=0.0689 steps=625000.
[05:36:41] logfile size=30121 infoLength=30121 edr=0 trr=25
[05:36:41] logfile size: 30121 info=30121 bed=0 hdr=25
[05:36:41] - Writing 30659 bytes of core data to disk...
[05:36:41]   ... Done.
[05:36:41]
[05:36:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:36:43] CoreStatus = 7A (122)
[05:36:43] Sending work to server
[05:36:43] Project: 2633 (Run 7, Clone 3, Gen 9)
just posting as I noticed this WU P2633 seems to be having problems.
This is my first SMP2 WU that didn't finish.
sortofageek
Re: Project: 2633 (Run 7, Clone 3, Gen 9)
Post by sortofageek »
You received a partial credit.
Hi noprob (team 12072),
Your WU (P2633 R7 C3 G9) was added to the stats database on 2010-08-29 23:20:54 for 16.2 points of credit.
You probably need to look elsewhere for the issue, however, because another folder successfully completed this WU for full credit. It apparently was not a bad WU.
noprob
Post by noprob »
sortofageek wrote:You probably need to look elsewhere for the issue.
Thank You.
I have an over clocked dual core cpu that I will now slow down and should just set to the default setting of the cpu.
I was going to bump it up some more,but will not do so now.
again Thx. for the heads up on this good WU.
*EDIT
I have set the dual core cpu to default settings and hope this will make things right concerning any future P2633 WU(s) and any further WU(s).
sortofageek
No trouble at all, glad to help where we can. Good choice to back off on the overclock.
