171.67.108.11 GPU vsp07v vvoelz full Accepting 2.32 11 0 180 26815 8025 1 1.6 70969 70969 6489 - - 18 - 914 23 2 10 1 171.64.122.86
171.67.108.25
171.67.108.25 0 1 W; W; 12, 12 6.119, 6.119 - 49, 49 64, 64 - - ; , 2, 2 F, A 8080G, 8080G 6.28.01 - 241 170 0 vvoelz 1 vsp07vCode: Select all
[22:25:29] Trying to send all finished work units
[22:25:29] + No unsent completed units remaining.
[22:25:29] - Preparing to get new work unit...
[22:25:29] Cleaning up work directory
[22:25:29] + Attempting to get work packet
[22:25:29] Passkey found
[22:25:29] - Will indicate memory of 4091 MB
[22:25:29] Gpu type=2 species=30.
[22:25:29] - Connecting to assignment server
[22:25:29] Connecting to http://assign-GPU.stanford.edu:8080/
[22:25:31] Posted data.
[22:25:31] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[22:25:31] + News From Folding@Home: Welcome to Folding@Home
[22:25:31] Loaded queue successfully.
[22:25:31] Gpu type=2 species=30.
[22:25:31] Sent data
[22:25:31] Connecting to http://171.67.108.11:8080/
[22:25:32] Posted data.
[22:25:32] Initial: 0000; - Receiving payload (expected size: 45926)
[22:25:34] - Downloaded at ~22 kB/s
[22:25:34] - Averaged speed for that direction ~16 kB/s
[22:25:34] + Received work.
[22:25:34] Trying to send all finished work units
[22:25:34] + No unsent completed units remaining.
[22:25:34] + Closed connections
[22:25:34]
[22:25:34] + Processing work unit
[22:25:34] Core required: FahCore_11.exe
[22:25:34] Core found.
[22:25:34] Working on queue slot 05 [August 29 22:25:34 UTC]
[22:25:34] + Working ...
[22:25:34] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -nice 19 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3584 -version 630'
[22:25:34]
[22:25:34] *------------------------------*
[22:25:34] Folding@Home GPU Core
[22:25:34] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[22:25:34]
[22:25:34] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:25:34] Build host: amoeba
[22:25:34] Board Type: Nvidia
[22:25:34] Core :
[22:25:34] Preparing to commence simulation
[22:25:34] - Looking at optimizations...
[22:25:34] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[22:25:34] - Created dyn
[22:25:34] - Files status OK
[22:25:34] - Expanded 45414 -> 251112 (decompressed 552.9 percent)
[22:25:34] Called DecompressByteArray: compressed_data_size=45414 data_size=251112, decompressed_data_size=251112 diff=0
[22:25:34] - Digital signature verified
[22:25:34]
[22:25:34] Project: 5769 (Run 10, Clone 377, Gen 586)
[22:25:34]
[22:25:34] Assembly optimizations on if available.
[22:25:34] Entering M.D.
[22:25:40] Tpr hash work/wudata_05.tpr: 2079194819 1474979315 3312798911 1829543316 3463957814
[22:25:40]
[22:25:40] Calling fah_main args: 14 usage=100
[22:25:40]
[22:25:40] Working on Protein
[22:25:41] Client config found, loading data.
[22:25:41] Starting GUI Server
[22:26:17] Completed 1%
Time-lapse
[23:25:53] Completed 100%
[23:25:53] Successful run
[23:25:53] DynamicWrapper: Finished Work Unit: sleep=10000
[23:26:03] Reserved 75800 bytes for xtc file; Cosm status=0
[23:26:03] Allocated 75800 bytes for xtc file
[23:26:03] - Reading up to 75800 from "work/wudata_05.xtc": Read 75800
[23:26:03] Read 75800 bytes from xtc file; available packet space=786354664
[23:26:03] xtc file hash check passed.
[23:26:03] Reserved 15168 15168 786354664 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[23:26:03] Allocated 15168 bytes for arc file
[23:26:03] - Reading up to 15168 from "work/wudata_05.trr": Read 15168
[23:26:03] Read 15168 bytes from arc file; available packet space=786339496
[23:26:03] trr file hash check passed.
[23:26:03] Allocated 560 bytes for edr file
[23:26:03] Read bedfile
[23:26:03] edr file hash check passed.
[23:26:03] Allocated 0 bytes for logfile
[23:26:03] Could not open/read logfile=<work/wudata_05.log>; Cosm status=-1
[23:26:03] GuardedRun: success in DynamicWrapper
[23:26:03] GuardedRun: done
[23:26:03] Run: GuardedRun completed.
[23:26:04] + Opened results file
[23:26:04] - Writing 92040 bytes of core data to disk...
[23:26:04] Done: 91528 -> 90181 (compressed to 98.5 percent)
[23:26:04] ... Done.
[23:26:04] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[23:26:04] Shutting down core
[23:26:04]
[23:26:04] Folding@home Core Shutdown: FINISHED_UNIT
[23:26:09] CoreStatus = 64 (100)
[23:26:09] Unit 5 finished with 99 percent of time to deadline remaining.
[23:26:09] Updated performance fraction: 0.988852
[23:26:09] Sending work to server
[23:26:09] Project: 5769 (Run 10, Clone 377, Gen 586)
[23:26:09] - Read packet limit of 540015616... Set to 524286976.
[23:26:09] + Attempting to send results [August 29 23:26:09 UTC]
[23:26:09] - Reading file work/wuresults_05.dat from core
[23:26:09] (Read 90693 bytes from disk)
[23:26:09] Gpu type=2 species=30.
[23:26:09] Connecting to http://171.67.108.11:8080/
[23:27:11] - Couldn't send HTTP request to server
[23:27:11] + Could not connect to Work Server (results)
[23:27:11] (171.67.108.11:8080)
[23:27:11] + Retrying using alternative port
[23:27:11] Connecting to http://171.67.108.11:80/
[23:27:34] ***** Got a SIGTERM signal (2)
[23:27:34] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [August 29 23:28:06 UTC]
Folding@Home Client Version 6.30r1
http://folding.stanford.edu
Launch directory: D:\F@H GPU3
Executable: D:\F@H GPU3\Folding@home-Win32-GPU.exe
Arguments: -send all -verbosity 9
[23:28:06] - Ask before connecting: No
[23:28:06] - User name: PantherX (Team 69411)
[23:28:06] - User ID: Guess
[23:28:06] - Machine ID: 2
[23:28:06]
[23:28:06] Gpu type=2 species=30.
[23:28:06] Loaded queue successfully.
[23:28:06] Attempting to return result(s) to server...
[23:28:06] Trying to send all finished work units
[23:28:06] Project: 5769 (Run 10, Clone 377, Gen 586)
[23:28:06] - Read packet limit of 540015616... Set to 524286976.
[23:28:06] + Attempting to send results [August 29 23:28:06 UTC]
[23:28:06] - Reading file work/wuresults_05.dat from core
[23:28:06] (Read 90693 bytes from disk)
[23:28:06] Connecting to http://171.67.108.11:8080/
[23:29:06] - Couldn't send HTTP request to server
[23:29:06] + Could not connect to Work Server (results)
[23:29:06] (171.67.108.11:8080)
[23:29:06] + Retrying using alternative port
[23:29:06] Connecting to http://171.67.108.11:80/
[23:30:12] - Couldn't send HTTP request to server
[23:30:12] + Could not connect to Work Server (results)
[23:30:12] (171.67.108.11:80)
[23:30:12] - Error: Could not transmit unit 05 (completed August 29) to work server.
[23:30:12] - 1 failed uploads of this unit.
[23:30:12] Keeping unit 05 in queue.
[23:30:12] + Sent 0 of 1 completed units to the server
[23:30:12] - Failed to send all units to server
[23:30:12] ***** Got a SIGTERM signal (2)
[23:30:12] Killing all core threads
--- Opening Log file [August 29 23:35:14 UTC]
[23:35:14] - Ask before connecting: No
[23:35:14] - User name: PantherX (Team 69411)
[23:35:14] - User ID: Guess
[23:35:14] - Machine ID: 2
[23:35:14]
[23:35:14] Gpu type=2 species=30.
[23:35:14] Loaded queue successfully.
[23:35:14] Attempting to return result(s) to server...
[23:35:14] Trying to send all finished work units
[23:35:14] Project: 5769 (Run 10, Clone 377, Gen 586)
[23:35:14] - Read packet limit of 540015616... Set to 524286976.
[23:35:14] + Attempting to send results [August 29 23:35:14 UTC]
[23:35:14] - Reading file work/wuresults_05.dat from core
[23:35:14] (Read 90693 bytes from disk)
[23:35:14] Connecting to http://171.67.108.11:8080/
[23:36:16] - Couldn't send HTTP request to server
[23:36:16] + Could not connect to Work Server (results)
[23:36:16] (171.67.108.11:8080)
[23:36:16] + Retrying using alternative port
[23:36:16] Connecting to http://171.67.108.11:80/
[23:37:21] - Couldn't send HTTP request to server
[23:37:21] + Could not connect to Work Server (results)
[23:37:21] (171.67.108.11:80)
[23:37:21] - Error: Could not transmit unit 05 (completed August 29) to work server.
[23:37:21] - 2 failed uploads of this unit.
[23:37:21] - Read packet limit of 540015616... Set to 524286976.
[23:37:21] + Attempting to send results [August 29 23:37:21 UTC]
[23:37:21] - Reading file work/wuresults_05.dat from core
[23:37:21] (Read 90693 bytes from disk)
[23:37:21] Gpu type=2 species=30.
[23:37:21] Connecting to http://171.67.108.25:8080/
[23:37:31] Posted data.
[23:37:31] Initial: 0000; - Uploaded at ~8 kB/s
[23:37:31] - Averaged speed for that direction ~6 kB/s
[23:37:31] - Server does not have record of this unit. Will try again later.
[23:37:31] Could not transmit unit 05 to Collection server; keeping in queue.
[23:37:31] + Sent 0 of 1 completed units to the server
[23:37:31] - Failed to send all units to server
[23:37:31] ***** Got a SIGTERM signal (2)
[23:37:31] Killing all core threads
--- Opening Log file [August 29 23:38:04 UTC]
[23:38:04] - Ask before connecting: No
[23:38:04] - User name: PantherX (Team 69411)
[23:38:04] - User ID: Guess
[23:38:04] - Machine ID: 2
[23:38:04]
[23:38:04] Gpu type=2 species=30.
[23:38:04] Loaded queue successfully.
[23:38:04] Attempting to return result(s) to server...
[23:38:04] Trying to send all finished work units
[23:38:04] Project: 5769 (Run 10, Clone 377, Gen 586)
[23:38:04] - Read packet limit of 540015616... Set to 524286976.
[23:38:04] + Attempting to send results [August 29 23:38:04 UTC]
[23:38:04] - Reading file work/wuresults_05.dat from core
[23:38:04] (Read 90693 bytes from disk)
[23:38:04] Connecting to http://171.67.108.11:8080/
[23:39:11] - Couldn't send HTTP request to server
[23:39:11] + Could not connect to Work Server (results)
[23:39:11] (171.67.108.11:8080)
[23:39:11] + Retrying using alternative port
[23:39:11] Connecting to http://171.67.108.11:80/
[23:40:16] - Couldn't send HTTP request to server
[23:40:16] + Could not connect to Work Server (results)
[23:40:16] (171.67.108.11:80)
[23:40:16] - Error: Could not transmit unit 05 (completed August 29) to work server.
[23:40:16] - 3 failed uploads of this unit.
[23:40:16] - Read packet limit of 540015616... Set to 524286976.
[23:40:16] + Attempting to send results [August 29 23:40:16 UTC]
[23:40:16] - Reading file work/wuresults_05.dat from core
[23:40:16] (Read 90693 bytes from disk)
[23:40:16] Gpu type=2 species=30.
[23:40:16] Connecting to http://171.67.108.25:8080/
[23:40:26] Posted data.
[23:40:27] Initial: 0000; - Uploaded at ~8 kB/s
[23:40:27] - Averaged speed for that direction ~6 kB/s
[23:40:27] - Server does not have record of this unit. Will try again later.
[23:40:27] Could not transmit unit 05 to Collection server; keeping in queue.
[23:40:27] + Sent 0 of 1 completed units to the server
[23:40:27] - Failed to send all units to server
[23:40:27] ***** Got a SIGTERM signal (2)
[23:40:27] Killing all core threads
Folding@Home Client Shutdown.Code: Select all
C:\Users\PantherX\Desktop>tracert 171.67.108.11
Tracing route to vsp07v.Stanford.EDU [171.67.108.11]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 11g_ADSL2+_Router.local.lan [192.168.1.1]
2 60 ms 68 ms 66 ms ERX-3.awalnet.net.sa [212.93.193.12]
3 152 ms 74 ms 67 ms 212.93.203.193
4 67 ms 61 ms 70 ms gx.awalnet.net.sa [212.93.211.1]
5 69 ms 58 ms 70 ms 84-235-108-22.saudi.net.sa [84.235.108.22]
6 74 ms 66 ms 68 ms 84-235-120-17.igw.com.sa [84.235.120.17]
7 283 ms 327 ms 250 ms sl-gw31-nyc-11-0-0.sprintlink.net [144.232.234.181]
8 248 ms 269 ms 266 ms sl-crs1-nyc-0-2-0-0.sprintlink.net [144.232.13.33]
9 346 ms 260 ms 258 ms te-4-2-0.edge1.NewYork1.level3.net [4.68.111.157]
10 * 241 ms 274 ms vlan99.csw4.NewYork1.Level3.net [4.68.16.254]
11 258 ms 264 ms 272 ms ae-92-92.ebr2.NewYork1.Level3.net [4.69.148.45]
12 310 ms 345 ms 323 ms ae-2-2.ebr4.SanJose1.Level3.net [4.69.135.185]
13 331 ms 340 ms 327 ms ae-74-74.csw2.SanJose1.Level3.net [4.69.134.246]
14 353 ms 439 ms 419 ms ae-21-79.car1.SanJose1.Level3.net [4.68.18.67]
15 329 ms 329 ms 331 ms CENIC.car1.SanJose1.Level3.net [4.53.16.186]
16 357 ms 337 ms 333 ms isp-stan--isp-svl-ge.cenic.net [137.164.23.46]
17 314 ms 336 ms 330 ms boundarya-rtr.Stanford.EDU [68.65.168.33]
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
