--- Opening Log file [August 25 07:50:36 UTC]
                          http://folding.stanford.edu
Launch directory:
Executable: Folding@home-Win32-x86.exe
Arguments: -oneunit -advmethods -forceasm -verbosity 9
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[07:50:36] - Ask before connecting: No
[07:50:36] - User name: Napoleon (Team 191980)
[07:50:36] - User ID:
[07:50:36] - Machine ID: 1
[07:50:36]
[07:50:36] Loaded queue successfully.
[07:50:36] - Preparing to get new work unit...
[07:50:36] + Attempting to get work packet
[07:50:36] - Will indicate memory of 512 MB
[07:50:36] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 4, Stepping: 9
[07:50:36] - Connecting to assignment server
[07:50:36] Connecting to http://assign.stanford.edu:8080/
[07:50:36] - Autosending finished units... [August 25 07:50:36 UTC]
[07:50:36] Trying to send all finished work units
[07:50:36] + No unsent completed units remaining.
[07:50:36] - Autosend completed
[07:50:38] Posted data.
[07:50:38] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[07:50:38] + News From Folding@Home: Welcome to Folding@Home
[07:50:38] Loaded queue successfully.
[07:50:38] Connecting to http://171.64.65.62:8080/
[07:50:39] Posted data.
[07:50:39] Initial: 0000; - Receiving payload (expected size: 515764)
[07:50:43] - Downloaded at ~125 kB/s
[07:50:43] - Averaged speed for that direction ~126 kB/s
[07:50:43] + Received work.
[07:50:43] + Closed connections
[07:50:43]
[07:50:43] + Processing work unit
[07:50:43] Core required: FahCore_78.exe
[07:50:43] Core found.
[07:50:43] Working on queue slot 06 [August 25 07:50:43 UTC]
[07:50:43] + Working ...
[07:50:43] - Calling '.\FahCore_78.exe -dir work/ -suffix 06 -priority 96 -checkpoint 30 -forceasm -verbose -lifeline 2492 -version 623'
[07:50:43]
[07:50:43] *------------------------------*
[07:50:43] Folding@Home Gromacs Core
[07:50:43] Version 1.90 (March 8, 2006)
[07:50:43]
[07:50:43] Preparing to commence simulation
[07:50:43] - Assembly optimizations manually forced on.
[07:50:43] - Not checking prior termination.
[07:50:43] - Expanded 515252 -> 2529861 (decompressed 490.9 percent)
[07:50:43] - Starting from initial work packet
[07:50:43]
[07:50:43] Project: 6503 (Run 10, Clone 210, Gen 81)
[07:50:43]
[07:50:43] Assembly optimizations on if available.
[07:50:43] Entering M.D.
[07:50:50] Protein: TR462_B_11 in water
[07:50:50]
[07:50:50] Writing local files
[07:50:51] Extra SSE boost OK.
[07:50:51] Writing local files
[07:50:51] Completed 0 out of 250000 steps  (0%)
[08:02:37] Writing local files
[08:02:37] Completed 2500 out of 250000 steps  (1%)
[08:14:19] Writing local files
[08:14:19] Completed 5000 out of 250000 steps  (2%)
[08:26:02] Writing local files
[08:26:02] Completed 7500 out of 250000 steps  (3%)
[08:37:43] Writing local files
[08:37:44] Completed 10000 out of 250000 steps  (4%)
[08:49:27] Writing local files
[08:49:27] Completed 12500 out of 250000 steps  (5%)
[09:01:08] Writing local files
[09:01:09] Completed 15000 out of 250000 steps  (6%)
[09:12:51] Writing local files
[09:12:51] Completed 17500 out of 250000 steps  (7%)
[09:24:34] Writing local files
[09:24:34] Completed 20000 out of 250000 steps  (8%)
[09:36:16] Writing local files
[09:36:16] Completed 22500 out of 250000 steps  (9%)
[09:47:58] Writing local files
[09:47:58] Completed 25000 out of 250000 steps  (10%)
[09:59:41] Writing local files
[09:59:41] Completed 27500 out of 250000 steps  (11%)
[10:11:22] Writing local files
[10:11:22] Completed 30000 out of 250000 steps  (12%)
[10:23:04] Writing local files
[10:23:04] Completed 32500 out of 250000 steps  (13%)
[10:34:45] Writing local files
[10:34:45] Completed 35000 out of 250000 steps  (14%)
[10:46:28] Writing local files
[10:46:28] Completed 37500 out of 250000 steps  (15%)
[10:58:11] Writing local files
[10:58:11] Completed 40000 out of 250000 steps  (16%)
[11:09:54] Writing local files
[11:09:54] Completed 42500 out of 250000 steps  (17%)
[11:20:09] Gromacs cannot continue further.
[11:20:09] Going to send back what have done.
[11:20:09] logfile size: 16267
[11:20:09] - Writing 16803 bytes of core data to disk...
[11:20:09] Done: 16291 -> 4366 (compressed to 26.8 percent)
[11:20:09]   ... Done.
[11:20:09]
[11:20:09] Folding@home Core Shutdown: EARLY_UNIT_END
[11:20:13] CoreStatus = 72 (114)
[11:20:13] Sending work to server
[11:20:13] Project: 6503 (Run 10, Clone 210, Gen 81)
[11:20:13] - Read packet limit of 540015616... Set to 524286976.
[11:20:13] + Attempting to send results [August 25 11:20:13 UTC]
[11:20:13] - Reading file work/wuresults_06.dat from core
[11:20:13]   (Read 4878 bytes from disk)
[11:20:13] Connecting to http://171.64.65.62:8080/
[11:20:14] Posted data.
[11:20:14] Initial: 0000; - Uploaded at ~5 kB/s
[11:20:14] - Averaged speed for that direction ~48 kB/s
[11:20:14] + Results successfully sent
[11:20:14] Thank you for your contribution to Folding@Home.
[11:20:18] Trying to send all finished work units
[11:20:18] + No unsent completed units remaining.
[11:20:18] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[11:20:18] Killing all core threads
Folding@Home Client Shutdown.
