HELP: Folding ONLY on 2nd card
Greetings all. I'm desperate. I've followed numerous guides and I'm just stuck. Any help is greatly appreciated. Thank you.
I'm running the GPU2 client....I have a GTX480 and a GT240 that is a PhysX card. EVGAx58 3xSLI mobo with dual x16 lanes, Windows7 Ult 64.
I'd like to have ONLY my GT240 fold.
I was able to get my first card folding no problem. The 2nd GPU program runs but nothing happens.
- Changed machine ID to everything else.. no luck
- added the -gpu 1 flag
- tried with/without -local -gpu 1 flag
- tried adding the -gpu 1 flag above the machine ID setting, in the Configure
- tried extending my desktop
- physx on/off
- gtx480 DVI'd into monitor, gt240 VGA'd into monitor at same time
-my slots are x16, x16, x8...... what if i swapped my 240 to #1 and moved my 480 to #2? just a crazy thought...
no error messages but i can run the first gpu, but not the second. doesnt matter if i run them at the same time or one at a time... only the 480 folds. am i missing something to get JUST the 240 to fold??
I hate to keep this going but since I don't really play PhysX games that often, I'd really love to use this GT240 that's in there.
- physx on/off
Re: HELP: Folding ONLY on 2nd card
Welcome to the F@H Forum KOBALT,
Please post your FAHlog here by using the code button. This is what I can understand from your situation:
You want GT 240 to fold but it won't
Your GTX 480 is folding but you don't want it to fold
You are using GPU2 Client
Please note that your GTX 480 can't fold on a GPU2 Client, it requires GPU3 BETA Client. We also need some more details of your system:
What Driver Version?
Are you using an SLI Bridge?
You are correct in understanding my issue.
Actually my 480 was able to fold on the GPU2(623file)... running the GPU3(632 file) version now. same thing.
258.96 WHQL drivers.
NO sli bridge.
NO sli bridge.
What happens if you use an SLI Bridge? Also, it is impossible for the GTX 480 to fold by using the GPU2 Client as the GTX 480 uses FahCore_15.exe which the GPU2 Client can't recognize.
the GT240 isn't SLI capable...
so... should I re-download the GPU2 client to make sure I did it right? Would the 240 run on the gpu3 client? IF so, could you provide the exact link so I dont screw it up?
This is the list of which client works with which GPU
GT 240 = GPU2 Client & GPU3 BETA Client
GTX 480 = GPU3 BETA Client
Visit this link and download either the Systray or Console version of 6.23 and install it on your system. You have to use either -gpu 0 OR -gpu 1 flag to correctly identify the GT 240 and then it can hopefully fold without any problems. If a problem does occur, please post your FAHlog.
Its working! had to add -local -gpu 1 in the Target
and
-gpu 1 in the field above Machine ID 3 in the Configure
I guess I had the wrong client or something... wowzers! REALLY APPRECIATE YOUR HELP! my card gives off a high pitched whine.. super loud... oh well.
the display says 200/ns day... dunno if thats good. not sure how to see my ppd.
here's my log
and
here's my log
--- Opening Log file [August 23 04:32:46 UTC]
Launch directory: C:\users\kobalt\appdata\roaming\folding@home-gpu2
Arguments: -gpu 1
[04:33:12] - Ask before connecting: No
[04:33:12] - User name: KOBALT (Team 37726)
[04:33:12] - User ID: 55D6BCBD2403F1CF
[04:33:12] - Machine ID: 3
[04:33:12]
[04:33:12] Work directory not found. Creating...
[04:33:12] Could not open work queue, generating new queue...
[04:33:13] Initialization complete
[04:33:13] - Preparing to get new work unit...
[04:33:13] + Attempting to get work packet
[04:33:13] - Connecting to assignment server
[04:33:13] - Successful: assigned to (171.64.65.106).
[04:33:13] + News From Folding@Home: Welcome to Folding@Home
[04:33:13] Loaded queue successfully.
[04:33:15] + Closed connections
[04:33:15]
[04:33:15] + Processing work unit
[04:33:15] Core required: FahCore_11.exe
[04:33:15] Core not found.
[04:33:15] - Core is not present or corrupted.
[04:33:15] - Attempting to download new core...
[04:33:15] + Downloading new core: FahCore_11.exe
[04:33:16] + 10240 bytes downloaded
[04:33:16] + 20480 bytes downloaded
[04:33:16] + 30720 bytes downloaded
[04:33:16] + 40960 bytes downloaded
[04:33:16] + 51200 bytes downloaded
[04:33:17] + 61440 bytes downloaded
[04:33:17] + 71680 bytes downloaded
[04:33:17] + 81920 bytes downloaded
[04:33:17] + 92160 bytes downloaded
[04:33:17] + 102400 bytes downloaded
[04:33:17] + 112640 bytes downloaded
[04:33:17] + 122880 bytes downloaded
[04:33:18] + 133120 bytes downloaded
[04:33:18] + 143360 bytes downloaded
[04:33:18] + 153600 bytes downloaded
[04:33:18] + 163840 bytes downloaded
[04:33:18] + 174080 bytes downloaded
[04:33:18] + 184320 bytes downloaded
[04:33:18] + 194560 bytes downloaded
[04:33:19] + 204800 bytes downloaded
[04:33:19] + 215040 bytes downloaded
[04:33:19] + 225280 bytes downloaded
[04:33:19] + 235520 bytes downloaded
[04:33:19] + 245760 bytes downloaded
[04:33:19] + 256000 bytes downloaded
[04:33:19] + 266240 bytes downloaded
[04:33:20] + 276480 bytes downloaded
[04:33:20] + 286720 bytes downloaded
[04:33:20] + 296960 bytes downloaded
[04:33:20] + 307200 bytes downloaded
[04:33:20] + 317440 bytes downloaded
[04:33:20] + 327680 bytes downloaded
[04:33:20] + 337920 bytes downloaded
[04:33:21] + 348160 bytes downloaded
[04:33:21] + 358400 bytes downloaded
[04:33:21] + 368640 bytes downloaded
[04:33:21] + 378880 bytes downloaded
[04:33:21] + 389120 bytes downloaded
[04:33:22] + 399360 bytes downloaded
[04:33:22] + 409600 bytes downloaded
[04:33:22] + 419840 bytes downloaded
[04:33:22] + 430080 bytes downloaded
[04:33:22] + 440320 bytes downloaded
[04:33:22] + 450560 bytes downloaded
[04:33:22] + 460800 bytes downloaded
[04:33:22] + 471040 bytes downloaded
[04:33:22] + 481280 bytes downloaded
[04:33:23] + 491520 bytes downloaded
[04:33:23] + 501760 bytes downloaded
[04:33:23] + 512000 bytes downloaded
[04:33:23] + 522240 bytes downloaded
[04:33:23] + 532480 bytes downloaded
[04:33:23] + 542720 bytes downloaded
[04:33:23] + 552960 bytes downloaded
[04:33:23] + 563200 bytes downloaded
[04:33:23] + 573440 bytes downloaded
[04:33:23] + 583680 bytes downloaded
[04:33:24] + 593920 bytes downloaded
[04:33:24] + 604160 bytes downloaded
[04:33:24] + 614400 bytes downloaded
[04:33:24] + 624640 bytes downloaded
[04:33:24] + 634880 bytes downloaded
[04:33:24] + 645120 bytes downloaded
[04:33:24] + 655360 bytes downloaded
[04:33:24] + 665067 bytes downloaded
[04:33:24] Verifying core Core_11.fah...
[04:33:24] Signature is VALID
[04:33:24]
[04:33:24] Trying to unzip core FahCore_11.exe
[04:33:24] Decompressed FahCore_11.exe (1908736 bytes) successfully
[04:33:29] + Core successfully engaged
[04:33:34]
[04:33:34] + Processing work unit
[04:33:34] Core required: FahCore_11.exe
[04:33:34] Core found.
[04:33:34] Working on queue slot 01 [August 23 04:33:34 UTC]
[04:33:34] + Working ...
[04:33:35]
[04:33:35] *------------------------------*
[04:33:35] Folding@Home GPU Core
[04:33:35] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:33:35]
[04:33:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:33:35] Build host: amoeba
[04:33:35] Board Type: Nvidia
[04:33:35] Core :
[04:33:35] Preparing to commence simulation
[04:33:35] - Looking at optimizations...
Reason: Added [code] tags
Regarding the high whine sound, it is not unusual and there isn't any harm to the GPU from what I have read. Technically it is called "Capacitor Whine" and usually occurs when your GPU is being stressed you can Google it to see some possible solutions.
appreciate your help. 4000PPD.. ill take it
Use HFM.net to monitor the client(s) and it will tell you the PPD, the status, etc.KOBALT wrote:not sure how to see my ppd.
