ATI GPU, cant upload / cant get new WU sinse 2300U
Mactin
Post by Mactin »
My ATI GPU client has been trying to upload a completed WU sinse 2300U and cant get a new one.
Could someone at PG check/reboot/fix the server, please ? Ouch, it's sunday.
P5-133XL
Machine #2:
Machine 3:
Re: ATI GPU, cant upload / cant get new WU sinse 2300U
Post by P5-133XL »
You can check the server status yourself: http://fah-web.stanford.edu/serverstat.html
Just look in your log to find the ip address and compare it against the above list.
You can also do a connection self test by simply typing in the ip address in your broswer. You should get an "OK" response if your connection is good.
If the server is having a problem then post a message in : viewforum.php?f=18
Edit by Mod: Topic moved . . . but we still need to know which server(s) you're having trouble with.
I've made a guess about which server is causing the problem and notified the appropriate people, but Mactin, you've been around long enough to know how to supply enough information to facilitate prompt help. See the "Do this first" post in this forum.
Mactin
Post by Mactin »
I know Bruce, I'm sorry.
I was in a hurry to catch a flight for a little business trip and wanted to make sure my folding rigs at home where up-and-running before I left and "oups" there it was. I just took 2 minutes to write about it.
Sinse the GPU client is incompatible with Windows remote access, once I'm gone I cant do anything to fix them.
I'll be back later tonight, but I see everything is A1 at this time.
Thanks
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
While the GPU client is incompatible with Microsoft's remote access program there are other free remote access programs that work fine like realVNC.
rhavern
Post by rhavern »
...or logmein
Folding since 1 WU=1 point
