[21:20:45] *------------------------------*
[21:20:45] Folding@Home Gromacs Core
[21:20:45] Version 1.90 (March 8, 2006)
[21:20:45]
[21:20:45] Preparing to commence simulation
[21:20:45] - Assembly optimizations manually forced on.
[21:20:45] - Not checking prior termination.
[21:20:45] - Expanded 504156 -> 2510713 (decompressed 498.0 percent)
[21:20:45] - Starting from initial work packet
[21:20:45]
[21:20:45] Project: 6505 (Run 17, Clone 81, Gen 73)
[21:20:45]
[21:20:45] Assembly optimizations on if available.
[21:20:45] Entering M.D.
[21:20:52] Protein: 1CFC_A_18 in water
[21:20:52]
[21:20:52] Writing local files
[21:20:52] Extra SSE boost OK.
EDIT: Nope, got to 33% & died.
[21:20:45]
[21:20:45]
[21:20:45]
[21:20:45]
[21:20:52]
[21:20:52] Completed 0 out of 250000 steps (0%)
[21:30:34] Writing local files
[21:30:34] Completed 2500 out of 250000 steps (1%)
[21:40:10] Writing local files
[21:40:10] Completed 5000 out of 250000 steps (2%)
[21:50:08] Writing local files
[21:50:08] Completed 7500 out of 250000 steps (3%)
[22:00:19] Writing local files
[22:00:19] Completed 10000 out of 250000 steps (4%)
[22:02:55] - Autosending finished units...
[22:02:55] Trying to send all finished work units
[22:02:55] + No unsent completed units remaining.
[22:02:55] - Autosend completed
[22:09:19] Writing local files
[22:09:19] Completed 12500 out of 250000 steps (5%)
[22:18:40] Writing local files
[22:18:40] Completed 15000 out of 250000 steps (6%)
[22:28:17] Writing local files
[22:28:17] Completed 17500 out of 250000 steps (7%)
[22:37:38] Writing local files
[22:37:38] Completed 20000 out of 250000 steps (8%)
[22:47:07] Writing local files
[22:47:07] Completed 22500 out of 250000 steps (9%)
[22:56:13] Writing local files
[22:56:13] Completed 25000 out of 250000 steps (10%)
[23:05:40] Writing local files
[23:05:40] Completed 27500 out of 250000 steps (11%)
[23:15:43] Writing local files
[23:15:43] Completed 30000 out of 250000 steps (12%)
[23:25:43] Writing local files
[23:25:43] Completed 32500 out of 250000 steps (13%)
[23:35:35] Writing local files
[23:35:35] Completed 35000 out of 250000 steps (14%)
[23:45:42] Writing local files
[23:45:42] Completed 37500 out of 250000 steps (15%)
[23:55:25] Writing local files
[23:55:25] Completed 40000 out of 250000 steps (16%)
[00:04:49] Writing local files
[00:04:49] Completed 42500 out of 250000 steps (17%)
[00:13:30] Writing local files
[00:13:30] Completed 45000 out of 250000 steps (18%)
[00:22:39] Writing local files
[00:22:39] Completed 47500 out of 250000 steps (19%)
[00:32:10] Writing local files
[00:32:10] Completed 50000 out of 250000 steps (20%)
[00:41:24] Writing local files
[00:41:24] Completed 52500 out of 250000 steps (21%)
[00:50:44] Writing local files
[00:50:44] Completed 55000 out of 250000 steps (22%)
[00:59:59] Writing local files
[00:59:59] Completed 57500 out of 250000 steps (23%)
[01:09:19] Writing local files
[01:09:19] Completed 60000 out of 250000 steps (24%)
[01:19:04] Writing local files
[01:19:04] Completed 62500 out of 250000 steps (25%)
[01:27:49] ***** Got an Activate signal (2)
[01:27:49]
[01:27:49] Folding@home Core Shutdown: INTERRUPTED
[01:27:49] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [August 20 01:29:55] [Had to reboot due to Kernal Update]
# Linux Console Edition #######################################################
Folding@Home Client Version 6.02
http://folding.stanford.edu
Launch directory: /home/santafe/FAH1
Executable: ./fah6
Arguments: -local -forceasm -verbosity 9
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[01:29:55] - Ask before connecting: No
[01:29:55] - User name: Santa_Fe (Team 4)
[01:29:55] - User ID: xxxxxxxxxxxxxx
[01:29:55] - Machine ID: 1
[01:29:55]
[01:29:55] Loaded queue successfully.
[01:29:55] - Autosending finished units...
[01:29:55]
[01:29:55] Trying to send all finished work units
[01:29:55] + Processing work unit
[01:29:55] + No unsent completed units remaining.
[01:29:55] Core required: FahCore_78.exe
[01:29:55] - Autosend completed
[01:29:55] Core found.
[01:29:55] Working on Unit 05 [August 20 01:29:55]
[01:29:55] + Working ...
[01:29:55] - Calling './FahCore_78.exe -dir work/ -suffix 05 -checkpoint 30 -forceasm -verbose -lifeline 1419 -version 602'
[01:29:55]
[01:29:55] *------------------------------*
[01:29:55] Folding@Home Gromacs Core
[01:29:55] Version 1.90 (March 8, 2006)
[01:29:55]
[01:29:55] Preparing to commence simulation
[01:29:55] - Assembly optimizations manually forced on.
[01:29:55] - Not checking prior termination.
[01:29:56] - Expanded 504156 -> 2510713 (decompressed 498.0 percent)
[01:29:56]
[01:29:56] Project: 6505 (Run 17, Clone 81, Gen 73)
[01:29:56]
[01:29:56] Assembly optimizations on if available.
[01:29:56] Entering M.D.
[01:30:16] (Starting from checkpoint)
[01:30:16] Protein: 1CFC_A_18 in water
[01:30:16]
[01:30:16] Writing local files
[01:30:16] Completed 62500 out of 250000 steps (25%)
[01:30:16] Extra SSE boost OK.
[01:40:12] Writing local files
[01:40:12] Completed 65000 out of 250000 steps (26%)
[01:49:54] Writing local files
[01:49:54] Completed 67500 out of 250000 steps (27%)
[01:58:46] Writing local files
[01:58:46] Completed 70000 out of 250000 steps (28%)
[02:08:12] Writing local files
[02:08:12] Completed 72500 out of 250000 steps (29%)
[02:17:44] Writing local files
[02:17:44] Completed 75000 out of 250000 steps (30%)
[02:27:05] Writing local files
[02:27:05] Completed 77500 out of 250000 steps (31%)
[02:36:41] Writing local files
[02:36:41] Completed 80000 out of 250000 steps (32%)
[02:47:11] Writing local files
[02:47:11] Completed 82500 out of 250000 steps (33%)
[02:53:15] CoreStatus = 0 (0)
[02:53:15] Client-core communications error: ERROR 0x0
[02:53:15] Deleting current work unit & continuing...
[02:54:23] Trying to send all finished work units
[02:54:23] + No unsent completed units remaining.
[02:54:23] - Preparing to get new work unit...
[02:54:23] + Attempting to get work packet
[02:54:23] - Will indicate memory of 1000 MB
[02:54:23] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 6, Stepping: 2
[02:54:23] - Connecting to assignment server
[02:54:23] Connecting to http://assign.stanford.edu:8080/
[02:54:23] Posted data.
[02:54:23] Initial: 4A81; - Successful: assigned to (129.74.85.15).
[02:54:23] + News From Folding@Home: Welcome to Folding@Home
[02:54:23] Loaded queue successfully.
[02:54:23] Connecting to http://129.74.85.15:8080/
[02:54:23] Initial: 0000; - Receiving payload (expected size: 78430)
[02:54:24] - Downloaded at ~76 kB/s
[02:54:24] - Averaged speed for that direction ~301 kB/s
[02:54:24] + Received work.
[02:54:24] + Closed connections
[02:54:29]
[02:54:29] + Processing work unit
[02:54:29] Core required: FahCore_b4.exe
[02:54:29] Core found.
[02:54:29] Working on Unit 06 [August 20 02:54:29]
[02:54:29] + Working ...
[02:54:29] - Calling './FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 30 -forceasm -verbose -lifeline 1419 -version 602'
[02:54:30] *********************** Log Started 20/Aug/2010 02:54:30 ***********************
[02:54:30] ************************** ProtoMol Folding@Home Core **************************
[02:54:30] Version: 25
[02:54:30] Type: 180
[02:54:30] Core: ProtoMol
[02:54:30] Website: http://folding.stanford.edu/
[02:54:30] Copyright: (c) 2009 Stanford University
[02:54:30] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:54:30] Args: -dir work/ -suffix 06 -checkpoint 30 -forceasm -verbose -lifeline
[02:54:30] 1419 -version 602
[02:54:30] ************************************ Build *************************************
[02:54:30] Date: May 11 2010
[02:54:30] Time: 19:14:45
[02:54:30] Revision: 1818
[02:54:30] Compiler: Intel(R) C++ g++ 4.1 mode 1110
[02:54:30] Options: -std=gnu++98 -mia32 -O3 -funroll-loops
[02:54:30] -axSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 -restrict
[02:54:30] Defines: NDEBUG _REENTRANT HAVE_GEEKINFO HAVE_PTHREADS HAVE_PTHREADS
[02:54:30] HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_LAPACK
[02:54:30] Platform: Linux 2.4.27-3-386
[02:54:30] Bits: 32
[02:54:30] Mode: Release
[02:54:30] ************************************ System ************************************
[02:54:30] OS: Linux 2.6.32-24-generic i686
[02:54:30] CPU: Intel(R) Pentium(R) D CPU 3.00GHz
[02:54:30] CPU ID: GenuineIntel Family 15 Model 6 Stepping 2
[02:54:30] CPUs: 2 Logical, 1 Physical
[02:54:30] Memory: 1001 MB
[02:54:30] Threads: Linux
[02:54:30] ********************************************************************************
[02:54:30] Project: 10033 (Run 1289, Clone 0, Gen 13)
[02:54:30] Unit: 0x000000190001329c4bd49e0d00014292
[02:54:30] User: 0x00000000000000000000000000000000
[02:54:30] Machine: 1
[02:54:30] Reading tar file par_all27_prot_lipid.inp
[02:54:30] Reading tar file scpismQuartic.inp
[02:54:30] Reading tar file ww.pdb
[02:54:30] Reading tar file ww.psf
[02:54:30] Reading tar file checkpt
[02:54:30] Reading tar file ww.976.pos
[02:54:30] Reading tar file ww.976.vel
[02:54:30] Reading tar file protomol.conf
[02:54:30] Reading tar file core.xml
[02:54:30] Digital signatures verified
[02:54:31] GUI Server started
[02:54:31] Completed 0 out of 499375 steps (0%)
[03:08:10] Completed 5000 out of 499375 steps (1%)
