Hi all,
Just curious what means Mnbf/s and ns/day?
Other question: how long must to stay tuned for description of project 6012? It is nearing his end (just 102 WU's to go)...
What means Mnbf/s, ns/day?
- Hardware configuration: AMD Phenom II 940 Black Edition, 4GB RAM, Ubuntu 9.10 for SMP.
AMD Athlon XP 2400, 512MB RAM, Win XP+SP3 (and some other Intel P4-2,8 PC's for "classic" folding).
AMD Athlon64 3200 "Venice", 1GB RAM, Win XP+SP3, GeForce 9500GT for GPU and classic folding. - Location: Commuter between Herrenberg/Germany and Satu Mare/Romania
Re: What means Mnbf/s, ns/day?
Not sure abuot Mnbf/s. ns/day is nanoseconds/day. Are you getting that 102 WUs left figure from the server stats page regarding server 130.237.232.140? A) that server handles multiple projects, so there'd be X number of WUs remaining across all the projects it carries, and B) the next timestep of each particular trajectory is generated from the previous completed timestep, so there are almost always more WUs being generated as finished ones are turned in.
- Hardware configuration: Intel Core i7-920 @3350MHz
Foxconn Renaissance
3x2048 Samsung M378B5673FH0-CH9 @9-9-9-19
Gainward GTX470 1280M GDDR5 320B (was 1024MB DDR3 Gigabyte GV-N250OC-1GI)
E-MU 1212M
St-Lab A-400 PCI-E SATA RAID
TP-LINK TG-3468 Gigabit NIC
2xSamsung HD752LJ (RAID0)
HL-DT-ST DVDRAM GSA-H42N ATA
Thermaltake ToughPower 600W <W0103RE>
Windows 7 Ultimate x64 - Location: Russia
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Umm, nanoseconds per day? When I previously checked, there were a fixed amount of seconds per day: 24(h/day) *60(min/h) *60(s/min) = 86400(s/day). That would amount to 86400*10^9(ns/day), still a fixed value. Am I missing something here? What would be the purpose of such a non-unit?
EDIT: Describes the performance of simulating a particular protein folding, how many ns / day get simulated, maybe? Apparently I managed to misfold a brain cell or two on yesterday's pub crawl.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
Yes, it's the amount of simulated time that is being calculated.
Some atomic processes happen at the femto-second time frame (10^-15) so it takes a lot of work to simulate a single nano-second (10>-9) of motion. Many of the folding processes being simulated actually happen at the micro- (10^-6) to milli-second (10^-3) range. So it takes a lot of WUs to create a single trajectory, and statistically speaking, it takes a lot of trajectories to characterize the folding process of a single protein.
Proteins with relatively few atoms fold faster than proteins with a larger number of atoms, so the relationship between simulated time and clock time varies, but the unit of ns/day is a useful way to describe what's happening scientifically with that particular protein.
In case you wondered, FAH is a HUGE undertaking.
