[02:55:04] - Preparing to get new work unit...
[02:55:04] Cleaning up work directory
[02:55:04] + Attempting to get work packet
[02:55:04] Passkey found
[02:55:04] - Will indicate memory of 6077 MB
[02:55:04] Gpu type=1 species=4.
[02:55:04] - Connecting to assignment server
[02:55:04] Connecting to http://assign-GPU.stanford.edu:8080/
[02:55:05] Posted data.
[02:55:05] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[02:55:05] + News From Folding@Home: Welcome to Folding@Home
[02:55:05] Loaded queue successfully.
[02:55:05] Gpu type=1 species=4.
[02:55:05] Sent data
[02:55:05] Connecting to http://171.64.65.102:8080/
[02:55:06] Posted data.
[02:55:06] Initial: 0000; - Receiving payload (expected size: 69025)
[02:55:07] - Downloaded at ~67 kB/s
[02:55:07] - Averaged speed for that direction ~69 kB/s
[02:55:07] + Received work.
[02:55:07] Trying to send all finished work units
[02:55:07] + No unsent completed units remaining.
[02:55:07] + Closed connections
[02:55:07]
[02:55:07] + Processing work unit
[02:55:07] Core required: FahCore_11.exe
[02:55:07] Core found.
[02:55:07] Working on queue slot 00 [August 13 02:55:07 UTC]
[02:55:07] + Working ...
[02:55:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -nice 19 -priority 96 -nocpulock -checkpoint 30 -forceasm -verbose -lifeline 2988 -version 630'
[02:55:07]
[02:55:07] *------------------------------*
[02:55:07] Folding@Home GPU Core - Beta
[02:55:07] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[02:55:07]
[02:55:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:55:07] Build host: amoeba
[02:55:07] Board Type: AMD
[02:55:07] Core      :
[02:55:07] Preparing to commence simulation
[02:55:07] - Assembly optimizations manually forced on.
[02:55:07] - Not checking prior termination.
[02:55:07] - Expanded 68513 -> 357580 (decompressed 521.9 percent)
[02:55:07] Called DecompressByteArray: compressed_data_size=68513 data_size=357580, decompressed_data_size=357580 diff=0
[02:55:07] - Digital signature verified
[02:55:07]
[02:55:07] Project: 5745 (Run 0, Clone 48, Gen 1137)
[02:55:07]
[02:55:07] Assembly optimizations on if available.
[02:55:07] Entering M.D.
[02:55:13] Tpr hash work/wudata_00.tpr:  962783139 1825688398 3151529912 3109941005 2000663038
[02:55:13] mdrun_gpu returned
[02:55:13] Going to send back what have done -- stepsTotalG=0
[02:55:13] Work fraction=0.0000 steps=0.
[02:55:17] logfile size=5726 infoLength=5726 edr=0 trr=25
[02:55:17] - Writing 6264 bytes of core data to disk...
[02:55:17] Done: 5752 -> 2260 (compressed to 39.2 percent)
[02:55:17]   ... Done.
[02:55:17]
[02:55:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:55:21] CoreStatus = 7A (122)
[02:55:21] Sending work to server
[02:55:21] Project: 5745 (Run 0, Clone 48, Gen 1137)
[02:55:21] - Read packet limit of 540015616... Set to 524286976.
[02:55:21] + Attempting to send results [August 13 02:55:21 UTC]
[02:55:21] - Reading file work/wuresults_00.dat from core
[02:55:21]   (Read 2772 bytes from disk)
[02:55:21] Gpu type=1 species=4.
[02:55:21] Connecting to http://171.64.65.102:8080/
[02:55:22] Posted data.
[02:55:22] Initial: 0000; - Uploaded at ~3 kB/s
[02:55:22] - Averaged speed for that direction ~21 kB/s
[02:55:22] + Results successfully sent
[02:55:22] Thank you for your contribution to Folding@Home.
