Combine Points
Richb(GAP)
Combine Points
Post by Richb(GAP) »
Hey guys, I screwed up and wonder how I can fix it.
I am currently running a 8600 GTS card for folding. I tried for the heck of it to see if GPU3 would run on it. Well it did not. After completing a few quick percents it would error out and get a new work unit and do the same thing over and over. So I removed it completely and reinstalled GPU2. When I went and set up the user name, team and everything else I screwed up. Guess I wasn't paying much attention when I was keying in the user name as I left Anonymous in the box. So it was recording points as AnonymousRichb(GAP).
I didn't notice this until a few minutes ago when I checked my PPD. Normally I would stay around 2500 - 2600 a day. Every once in a while I would eclipse the 3000 mark. I noticed that I dropped big time to a little over a thousand. So I checked a few things and found out the screw up in the name setup on GPU2 when I installed it.
Is there a way that I can combine those two? I don't care about the individual days just would like to get credit for the work units that I did do.
--- Opening Log file [August 4 23:11:18 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\Richb\AppData\Roaming\Folding@home-gpu
[23:11:18] - Ask before connecting: No
[23:11:18] - User name: AnonymousRichb(GAP) (Team 53472)
[23:11:18] - User ID: 615E166236F36604
[23:11:18] - Machine ID: 2
[23:11:18]
[23:11:18] Loaded queue successfully.
[23:11:19] Initialization complete
[23:11:19] - Preparing to get new work unit...
[23:11:19] + Attempting to get work packet
[23:11:19] - Connecting to assignment server
[23:11:19] - Successful: assigned to (171.64.65.61).
[23:11:19] + News From Folding@Home: Welcome to Folding@Home
[23:11:19] Loaded queue successfully.
[23:11:21] + Closed connections
[23:11:21]
[23:11:21] + Processing work unit
[23:11:21] Core required: FahCore_11.exe
[23:11:21] Core found.
[23:11:21] Working on queue slot 07 [August 4 23:11:21 UTC]
[23:11:21] + Working ...
[23:11:21]
[23:11:21] *------------------------------*
[23:11:21] Folding@Home GPU Core
[23:11:21] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:11:21]
[23:11:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:11:21] Build host: amoeba
[23:11:21] Board Type: Nvidia
[23:11:21] Core      :
[23:11:21] Preparing to commence simulation
[23:11:21] - Looking at optimizations...
[23:11:21] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[23:11:21] - Created dyn
[23:11:21] - Files status OK
[23:11:21] - Expanded 73842 -> 383588 (decompressed 519.4 percent)
[23:11:21] Called DecompressByteArray: compressed_data_size=73842 data_size=383588, decompressed_data_size=383588 diff=0
[23:11:21] - Digital signature verified
[23:11:21]
[23:11:21] Project: 6600 (Run 0, Clone 838, Gen 36)
[23:11:21]
[23:11:21] Assembly optimizations on if available.
[23:11:21] Entering M.D.
[23:11:27] Tpr hash work/wudata_07.tpr:  4032900329 3883957712 1839842565 641051504 1043865462
[23:11:27]
[23:11:27] Calling fah_main args: 14 usage=100
[23:11:27]
[23:11:28] Working on Protein
[23:11:28] mdrun_gpu returned
[23:11:28] Going to send back what have done -- stepsTotalG=0
[23:11:28] Work fraction=0.0000 steps=0.
[23:11:32] logfile size=0 infoLength=0 edr=0 trr=25
[23:11:32] + Opened results file
[23:11:32] - Writing 637 bytes of core data to disk...
[23:11:32] Done: 125 -> 124 (compressed to 99.2 percent)
[23:11:32]   ... Done.
[23:11:32] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[23:11:32]
[23:11:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:11:35] CoreStatus = 7A (122)
[23:11:35] Sending work to server
[23:11:35] Project: 6600 (Run 0, Clone 838, Gen 36)
[23:11:35] + Attempting to send results [August 4 23:11:35 UTC]
[23:11:36] + Results successfully sent
[23:11:36] Thank you for your contribution to Folding@Home.
[23:11:40] - Preparing to get new work unit...
[23:11:40] + Attempting to get work packet
[23:11:40] - Connecting to assignment server
[23:11:40] - Successful: assigned to (171.64.65.61).
[23:11:40] + News From Folding@Home: Welcome to Folding@Home
[23:11:41] Loaded queue successfully.
[23:11:43] + Closed connections
[23:11:48]
[23:11:48] + Processing work unit
[23:11:48] Core required: FahCore_11.exe
[23:11:48] Core found.
[23:11:48] Working on queue slot 08 [August 4 23:11:48 UTC]
[23:11:48] + Working ...
[23:11:48]
[23:11:48] *------------------------------*
[23:11:48] Folding@Home GPU Core
[23:11:48] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:11:48]
[23:11:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:11:48] Build host: amoeba
[23:11:48] Board Type: Nvidia
[23:11:48] Core      :
[23:11:48] Preparing to commence simulation
[23:11:48] - Looking at optimizations...
[23:11:48] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[23:11:48] - Created dyn
[23:11:48] - Files status OK
[23:11:48] - Expanded 73764 -> 383588 (decompressed 520.0 percent)
[23:11:48] Called DecompressByteArray: compressed_data_size=73764 data_size=383588, decompressed_data_size=383588 diff=0
[23:11:48] - Digital signature verified
[23:11:48]
[23:11:48] Project: 6600 (Run 3, Clone 691, Gen 34)
[23:11:48]
[23:11:48] Assembly optimizations on if available.
[23:11:48] Entering M.D.
[23:11:54] Tpr hash work/wudata_08.tpr:  3429024766 969647070 4136075990 1626118438 3171636232
[23:11:54]
[23:11:54] Calling fah_main args: 14 usage=100
[23:11:54]
[23:11:54] Working on Protein
[23:11:57] Client config found, loading data.
[23:11:57] Starting GUI Server
[23:12:59] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Richb(GAP)...
[23:14:26] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=53472...
[23:16:17] Completed 1%
[23:20:40] Completed 2%
[23:25:01] Completed 3%
[23:29:25] Completed 4%
[23:33:52] Completed 5%
[23:38:19] Completed 6%
Folding@Home Client Shutdown.
--- Opening Log file [August 4 23:40:08 UTC]
[23:40:08] - Ask before connecting: No
[23:40:08] - User name: Richb(GAP) (Team 53472)
[23:40:08] - User ID: 615E166236F36604
[23:40:08] - Machine ID: 2
[23:40:08]
[23:40:09] Loaded queue successfully.
[23:40:09] Initialization complete
[23:40:09]
[23:40:09] + Processing work unit
[23:40:09] Core required: FahCore_11.exe
[23:40:09] Core found.
[23:40:09] Working on queue slot 08 [August 4 23:40:09 UTC]
[23:40:09] + Working ...
[23:40:09]
[23:40:09] *------------------------------*
[23:40:09] Folding@Home GPU Core
[23:40:09] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:40:09]
[23:40:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:40:09] Build host: amoeba
[23:40:09] Board Type: Nvidia
[23:40:09] Core      :
[23:40:09] Preparing to commence simulation
[23:40:09] - Looking at optimizations...
[23:40:09] - Files status OK
[23:40:09] - Expanded 73764 -> 383588 (decompressed 520.0 percent)
[23:40:09] Called DecompressByteArray: compressed_data_size=73764 data_size=383588, decompressed_data_size=383588 diff=0
[23:40:09] - Digital signature verified
[23:40:09]
[23:40:09] Project: 6600 (Run 3, Clone 691, Gen 34)
[23:40:09]
[23:40:09] Assembly optimizations on if available.
[23:40:09] Entering M.D.
[23:40:15] Will resume from checkpoint file
[23:40:15] Tpr hash work/wudata_08.tpr:  3429024766 969647070 4136075990 1626118438 3171636232
[23:40:15]
[23:40:15] Calling fah_main args: 14 usage=100
[23:40:15]
[23:40:15] Working on Protein
[23:40:17] Client config found, loading data.
[23:40:17] Starting GUI Server
[23:40:17] Resuming from checkpoint
[23:40:17] fcCheckPointResume: retreived and current tpr file hash:
[23:40:17]    0   3429024766   3429024766
[23:40:17]    1    969647070    969647070
[23:40:17]    2   4136075990   4136075990
[23:40:17]    3   1626118438   1626118438
[23:40:17]    4   3171636232   3171636232
[23:40:17] fcCheckPointResume: file hashes same.
[23:40:17] fcCheckPointResume: state restored.
[23:40:17] Verified work/wudata_08.log
[23:40:17] Verified work/wudata_08.edr
[23:40:17] Verified work/wudata_08.xtc
[23:40:17] Completed 6%
Re: Combine Points
Richb(GAP)
Re: Combine Points
Ah, now that is a bummer. I can see their point after reading that link. Still sucks though. Guess I'll have to be a little more careful next time.
patonb
Re: Combine Points
Post by patonb »
If it helps, in the long run, even 100k becomes meaningless in your overall points
