[14:14:41] - Preparing to get new work unit...
[14:14:41] Cleaning up work directory
[14:14:41] + Attempting to get work packet
[14:14:41] Passkey found
[14:14:41] - Will indicate memory of 6077 MB
[14:14:41] Gpu type=1 species=4.
[14:14:41] - Connecting to assignment server
[14:14:41] Connecting to http://assign-GPU.stanford.edu:8080/
[14:14:42] Posted data.
[14:14:42] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[14:14:42] + News From Folding@Home: Welcome to Folding@Home
[14:14:42] Loaded queue successfully.
[14:14:42] Gpu type=1 species=4.
[14:14:42] Sent data
[14:14:42] Connecting to http://171.64.65.102:8080/
[14:14:43] Posted data.
[14:14:43] Initial: 0000; - Receiving payload (expected size: 99085)
[14:14:44] - Downloaded at ~96 kB/s
[14:14:44] - Averaged speed for that direction ~71 kB/s
[14:14:44] + Received work.
[14:14:44] Trying to send all finished work units
[14:14:44] + No unsent completed units remaining.
[14:14:44] + Closed connections
[14:14:44]
[14:14:44] + Processing work unit
[14:14:45] Core required: FahCore_11.exe
[14:14:45] Core found.
[14:14:45] Working on queue slot 08 [August 4 14:14:45 UTC]
[14:14:45] + Working ...
[14:14:45] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -nice 19 -nocpulock -checkpoint 30 -forceasm -verbose -lifeline 2848 -version 630'
[14:14:45]
[14:14:45] *------------------------------*
[14:14:45] Folding@Home GPU Core - Beta
[14:14:45] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:14:45]
[14:14:45] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:14:45] Build host: amoeba
[14:14:45] Board Type: AMD
[14:14:45] Core :
[14:14:45] Preparing to commence simulation
[14:14:45] - Assembly optimizations manually forced on.
[14:14:45] - Not checking prior termination.
[14:14:45] - Expanded 98573 -> 492188 (decompressed 499.3 percent)
[14:14:45] Called DecompressByteArray: compressed_data_size=98573 data_size=492188, decompressed_data_size=492188 diff=0
[14:14:45] - Digital signature verified
[14:14:45]
[14:14:45] Project: 5734 (Run 2, Clone 118, Gen 271)
[14:14:45]
[14:14:45] Assembly optimizations on if available.
[14:14:45] Entering M.D.
[14:14:51] Tpr hash work/wudata_08.tpr: 2040651525 112967386 3137296450 3033120647 70094422
[14:14:51] mdrun_gpu returned
[14:14:51] Going to send back what have done -- stepsTotalG=0
[14:14:51] Work fraction=0.0000 steps=0.
[14:14:55] logfile size=5690 infoLength=5690 edr=0 trr=25
[14:14:55] - Writing 6228 bytes of core data to disk...
[14:14:55] Done: 5716 -> 2250 (compressed to 39.3 percent)
[14:14:55] ... Done.
[14:14:55]
[14:14:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:14:59] CoreStatus = 7A (122)
[14:14:59] Sending work to server
[14:14:59] Project: 5734 (Run 2, Clone 118, Gen 271)
[14:14:59] - Read packet limit of 540015616... Set to 524286976.
[14:14:59] + Attempting to send results [August 4 14:14:59 UTC]
[14:14:59] - Reading file work/wuresults_08.dat from core
[14:14:59] (Read 2762 bytes from disk)
[14:14:59] Gpu type=1 species=4.
[14:14:59] Connecting to http://171.64.65.102:8080/
[14:15:00] Posted data.
[14:15:00] Initial: 0000; - Uploaded at ~3 kB/s
[14:15:00] - Averaged speed for that direction ~18 kB/s
[14:15:00] + Results successfully sent
[14:15:00] Thank you for your contribution to Folding@Home.
