171.67.108.22
One_Box
171.67.108.22
Post by One_Box »
Have been trying to upload project 6601 most of day and keep getting a status 503 message in the log file : -
+ Attempting to send results [August 3 16:24:00 UTC]
[16:24:00] Gpu type=2 species=30.
[16:24:00] - Couldn't send HTTP request to server
[16:24:00] (Got status 503)
[16:24:00] + Could not connect to Work Server (results)
[16:24:00] (171.67.108.25:8080)
[16:24:00] + Retrying using alternative port
[16:24:01] - Couldn't send HTTP request to server
[16:24:01] (Got status 503)
[16:24:01] + Could not connect to Work Server (results)
[16:24:01] (171.67.108.25:80)
[16:24:01] Could not transmit unit 03 to Collection server; keeping in queue.
From what I can see, the server info page is not showing an error, do I have a problem or is it Stanford?
Re: 503 error from 171.67.108.25
171.67.108.25 is a collection server ... and it often shows 503 errors because it's always overloaded ...
Nothing is wrong, but I would worry more about the main work server (which should be mentioned before the CS in your log) ...
The server, VSPG10x was down this morning, and has been rebooted. It's back up now. But it may take a few hours to catch up with the work load. Same issue as this thread: http://foldingforum.org/viewtopic.php?f ... 13&start=0
One_Box
Post by One_Box »
Thank you for your explanation of the 503 code. I could see the main work server was down, but did not realise the implication for the collection server.
I shall know in future, just getting back up to speed with FAH.
WU sent without problem this morning. :)
Dirtscience
171.67.108.22
Post by Dirtscience »
Finished first windows bigadv 7 hrs ago, middle of the night for me. 35 failed attempts to upload.
logfile:
12:19:10] - Ask before connecting: No
[12:19:10] - User name: xxxxxxx
[12:19:10] - User ID:xxxxxxxxxxx
[12:19:10] - Machine ID: 16
[12:19:10]
[12:19:10] Loaded queue successfully.
[12:19:10] Attempting to return result(s) to server...
[12:19:10] Project: 2684 (Run 13, Clone 15, Gen 5)
[12:19:10] - Read packet limit of 540015616... Set to 524286976.
[12:19:10] + Attempting to send results [August 4 12:19:10 UTC]
[12:21:42] - Couldn't send HTTP request to server
[12:21:42] + Could not connect to Work Server (results)
[12:21:42] (171.67.108.22:8080)
[12:21:42] + Retrying using alternative port
[12:27:32] - Couldn't send HTTP request to server
[12:27:32] + Could not connect to Work Server (results)
[12:27:32] (171.67.108.22:80)
[12:27:32] - Error: Could not transmit unit 01 (completed August 4) to work server.
[12:27:32] - Read packet limit of 540015616... Set to 524286976.
I dont see a problem with the servers.
If the deadline hasnt expired it will soon.
Any suggestions will be welcome.
Thanks
Mark
Dirtscience
Re: 171.67.108.22
Seems to be on my side. I switched to my secondary DSL line unit seems to be uploading now. Never had any problems uploading or downloading gpu units so I didnt think it would be a firewall problem but will look into the config on both lines thanks to any who read or reply to this.
Mark
Re: 171.67.108.22
Welcome to the F@H Forum Dirtscience,
Can you post your FAHLog from when the WU was finished successfully? That is important to determined what exactly happened. Also when you paste your FAHLog, make sure you use the Code tags (click the code button) so that the log appears like this: (part of the FAHLog that I earlier mentioned)
[10:03:44] Completed 247500 out of 250000 steps  (99%)
[10:53:06] Completed 250000 out of 250000 steps  (100%)
[10:53:18] DynamicWrapper: Finished Work Unit: sleep=10000
[10:53:28]
[10:53:28] Finished Work Unit:
[10:53:28] - Reading up to 52629024 from "work/wudata_01.trr": Read 52629024
[10:53:31] trr file hash check passed.
[10:53:31] - Reading up to 47053200 from "work/wudata_01.xtc": Read 47053200
[10:53:32] xtc file hash check passed.
[10:53:32] edr file hash check passed.
[10:53:32] logfile size: 211478
[10:53:32] Leaving Run
[10:53:33] - Writing 100061646 bytes of core data to disk...
[10:53:35]   ... Done.
[10:53:47] - Shutting down core
[10:53:47]
[10:53:47] Folding@home Core Shutdown: FINISHED_UNIT
[10:53:51] CoreStatus = 64 (100)
[10:53:51] Unit 1 finished with 41 percent of time to deadline remaining.
[10:53:51] Updated performance fraction: 0.408162
[10:53:51] Sending work to server
[10:53:51] Project: 2684 (Run 6, Clone 12, Gen 13)
[10:53:51] + Attempting to send results [August 3 10:53:51 UTC]
[10:53:51] - Reading file work/wuresults_01.dat from core
[10:53:51]   (Read 100061646 bytes from disk)
[10:53:51] Connecting to http://171.67.108.22:8080/
[13:13:35] Posted data.
[13:13:35] Initial: 0000; - Uploaded at ~11 kB/s
[13:13:40] - Averaged speed for that direction ~11 kB/s
[13:13:40] + Results successfully sent
Also, what kind of hardware do you have and the internet connection you have. If you have crossed the Preferred Deadline, you will only get base points. If you have crossed the Final Deadline, you won't get any points so it is better to simply delete the WU and move on as it is useless to waste your and Standfords' resources.
Dirtscience
Re: 171.67.108.22
Thanks for you help PantherX
My computer is:
i7 920 @ 4.01 GHZ
6 gigs ddr3 tripple channel
2X GTX 470's (not used wile folding bigadv) (Yet :D )
average tpf no longer than 44 min
04:36:36] Completed 242500 out of 250000 steps  (97%)
[05:18:31] Completed 245000 out of 250000 steps  (98%)
[06:00:26] Completed 247500 out of 250000 steps  (99%)
[06:42:19] Completed 250000 out of 250000 steps  (100%)
I did read and understand the post on folding with hyperthreading vs real cores. My TPF was well under the min so I let her rip. Machine temps were stable
part of the log as requested
[06:42:41] Finished Work Unit:
[06:42:41] - Reading up to 52629024 from "work/wudata_01.trr": Read 52629024
[06:42:42] trr file hash check passed.
[06:42:42] - Reading up to 47019352 from "work/wudata_01.xtc": Read 47019352
[06:42:42] xtc file hash check passed.
[06:42:42] edr file hash check passed.
[06:42:42] logfile size: 210384
[06:42:42] Leaving Run
[06:42:46] - Writing 100026704 bytes of core data to disk...
[06:42:47]   ... Done.
[06:43:13] - Shutting down core
[06:43:13]
[06:43:13] Folding@home Core Shutdown: FINISHED_UNIT
[06:43:21] CoreStatus = 64 (100)
[06:43:21] Unit 1 finished with 48 percent of time to deadline remaining.
[06:43:21] Updated performance fraction: 0.483900
[06:43:21] Sending work to server
[06:43:21] Project: 2684 (Run 13, Clone 15, Gen 5)
[06:43:21] + Attempting to send results [August 4 06:43:21 UTC]
[06:43:21] - Reading file work/wuresults_01.dat from core
[06:43:21]   (Read 100026704 bytes from disk)
[06:43:21] Connecting to http://171.67.108.22:8080/
[06:49:07] - Couldn't send HTTP request to server
[06:49:07] + Could not connect to Work Server (results)
[06:49:07]     (171.67.108.22:8080)
[06:49:07] + Retrying using alternative port
[06:49:07] Connecting to http://171.67.108.22:80/
[06:54:56] - Couldn't send HTTP request to server
[06:54:56] + Could not connect to Work Server (results)
[06:54:56]     (171.67.108.22:80)
[06:54:56] - Error: Could not transmit unit 01 (completed August 4) to work server.
[06:54:56] - 1 failed uploads of this unit.
[06:54:56]   Keeping unit 01 in queue.
[06:54:56] Trying to send all finished work units
[06:54:56] Project: 2684 (Run 13, Clone 15, Gen 5)
[06:54:56] + Attempting to send results [August 4 06:54:56 UTC]
[06:54:56] - Reading file work/wuresults_01.dat from core
[06:54:56]   (Read 100026704 bytes from disk)
[06:54:56] Connecting to http://171.67.108.22:8080/
[06:57:17] - Couldn't send HTTP request to server
[06:57:17] + Could not connect to Work Server (results)
[06:57:17]     (171.67.108.22:8080)
[06:57:17] + Retrying using alternative port
[06:57:17] Connecting to http://171.67.108.22:80/
[06:59:40] - Couldn't send HTTP request to server
[06:59:40] + Could not connect to Work Server (results)
[06:59:40]     (171.67.108.22:80)
[06:59:40] - Error: Could not transmit unit 01 (completed August 4) to work server.
[06:59:40] - 2 failed uploads of this unit.
[12:03:03] + Attempting to send results [August 4 12:03:03 UTC]
[12:03:03] - Reading file work/wuresults_01.dat from core
[12:03:03]   (Read 100026704 bytes from disk)
[12:03:03] Connecting to http://171.67.108.22:8080/
[12:05:22] - Couldn't send HTTP request to server
[12:05:22] + Could not connect to Work Server (results)
[12:05:22]     (171.67.108.22:8080)
[12:05:22] + Retrying using alternative port
[12:05:22] Connecting to http://171.67.108.22:80/
[12:07:44] - Couldn't send HTTP request to server
[12:07:44] + Could not connect to Work Server (results)
[12:07:44]     (171.67.108.22:80)
[12:07:44] - Error: Could not transmit unit 01 (completed August 4) to work server.
[12:07:44] - 34 failed uploads of this unit.
The unit did upload when I switched DSL lines. I have 2 LInes in My house both are 7 Mpbs downstream/ 896 Kbps upstream
Mr.Nosmo
Hardware configuration: i7-980X@4200 (AirCooled) w/6GB DDR3-1600 (8-8-8-20), 200GB Vertex2 SSD & 3xGTS-250 w/22" Eizo Monitors.
Re: 171.67.108.22
Post by Mr.Nosmo »
I also have a issue......
I have tried to reset (turn off and then on) my router and I have rebooted my workstation, but still can't upload.....
[05:05:21] Completed 250000 out of 250000 steps  (100%)
[05:05:33] DynamicWrapper: Finished Work Unit: sleep=10000
[05:05:43]
[05:05:43] Finished Work Unit:
[05:05:43] - Reading up to 56480736 from "work/wudata_07.trr": Read 56480736
[05:05:43] trr file hash check passed.
[05:05:43] - Reading up to 50412788 from "work/wudata_07.xtc": Read 50412788
[05:05:44] xtc file hash check passed.
[05:05:44] edr file hash check passed.
[05:05:44] logfile size: 205022
[05:05:44] Leaving Run
[05:05:44] - Writing 107266486 bytes of core data to disk...
[05:05:45]   ... Done.
[05:05:49] - Shutting down core
[05:05:49]
[05:05:49] Folding@home Core Shutdown: FINISHED_UNIT
[05:05:53] CoreStatus = 64 (100)
[05:05:53] Unit 7 finished with 72 percent of time to deadline remaining.
[05:05:53] Updated performance fraction: 0.874526
[05:05:53] Sending work to server
[05:05:53] Project: 2685 (Run 4, Clone 5, Gen 12)
[05:05:53] + Attempting to send results [August 5 05:05:53 UTC]
[05:05:53] - Reading file work/wuresults_07.dat from core
[05:05:53]   (Read 107266486 bytes from disk)
[05:05:53] Connecting to http://171.67.108.22:8080/
[05:05:53] - Couldn't send HTTP request to server
[05:05:53]   (Got status 503)
[05:05:53] + Could not connect to Work Server (results)
[05:05:53]     (171.67.108.22:8080)
[05:05:53] + Retrying using alternative port
[05:05:53] Connecting to http://171.67.108.22:80/
[05:05:54] - Couldn't send HTTP request to server
[05:05:54]   (Got status 503)
[05:05:54] + Could not connect to Work Server (results)
[05:05:54]     (171.67.108.22:80)
[05:05:54] - Error: Could not transmit unit 07 (completed August 5) to work server.
[05:05:54] - 1 failed uploads of this unit.
[05:05:54]   Keeping unit 07 in queue.
[05:05:54] Trying to send all finished work units
[05:05:54] Project: 2685 (Run 4, Clone 5, Gen 12)
[05:05:54] + Attempting to send results [August 5 05:05:54 UTC]
[05:05:54] - Reading file work/wuresults_07.dat from core
[05:05:54]   (Read 107266486 bytes from disk)
[05:05:54] Connecting to http://171.67.108.22:8080/
[05:05:54]     (171.67.108.22:8080)
[05:05:54] + Retrying using alternative port
[05:05:54] Connecting to http://171.67.108.22:80/
[05:05:55] - Error: Could not transmit unit 07 (completed August 5) to work server.
[05:05:55] - 2 failed uploads of this unit.
[05:05:55] + Attempting to send results [August 5 05:05:55 UTC]
[05:05:55] - Reading file work/wuresults_07.dat from core
[05:05:55]   (Read 107266486 bytes from disk)
[05:05:55] Connecting to http://171.67.108.25:8080/
[05:05:55] - Couldn't send HTTP request to server
[05:05:55]   (Got status 503)
[05:05:55] + Could not connect to Work Server (results)
[05:05:55]     (171.67.108.25:8080)
[05:05:55] + Retrying using alternative port
[05:05:55] Connecting to http://171.67.108.25:80/
[05:05:55]     (171.67.108.25:80)
[05:05:55]   Could not transmit unit 07 to Collection server; keeping in queue.
[05:05:55] + Sent 0 of 1 completed units to the server
[05:05:55] - Preparing to get new work unit...
[05:05:55] Cleaning up work directory
[05:05:56] + Attempting to get work packet
[05:05:56] Passkey found
[05:05:56] - Will indicate memory of 6135 MB
[05:05:56] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[05:05:56] - Connecting to assignment server
[05:05:56] Connecting to http://assign.stanford.edu:8080/
[05:05:57] Posted data.
[05:05:57] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:05:57] + News From Folding@Home: Welcome to Folding@Home
[05:05:57] Loaded queue successfully.
[05:05:57] Sent data
[05:05:57] Connecting to http://171.67.108.22:8080/
[05:05:57] - Couldn't send HTTP request to server
[05:05:57]   (Got status 503)
[05:05:57] + Could not connect to Work Server
[05:05:57] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[05:06:17] + Attempting to get work packet
[05:06:17] Passkey found
[05:06:17] - Will indicate memory of 6135 MB
[05:06:17] - Connecting to assignment server
[05:06:17] Connecting to http://assign.stanford.edu:8080/
[05:06:18] Posted data.
[05:06:18] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:06:18] + News From Folding@Home: Welcome to Folding@Home
[05:06:18] Loaded queue successfully.
[05:06:18] Sent data
[05:06:18] Connecting to http://171.67.108.22:8080/
[05:06:19] - Couldn't send HTTP request to server
[05:06:19]   (Got status 503)
[05:06:19] + Could not connect to Work Server
[05:06:19] - Attempt #2  to get work failed, and no other work to do.
[05:06:32] + Attempting to get work packet
[05:06:32] Passkey found
[05:06:32] - Will indicate memory of 6135 MB
[05:06:32] - Connecting to assignment server
[05:06:32] Connecting to http://assign.stanford.edu:8080/
[05:06:33] Posted data.
[05:06:33] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:06:33] + News From Folding@Home: Welcome to Folding@Home
[05:06:34] Loaded queue successfully.
[05:06:34] Sent data
[05:06:34] Connecting to http://171.67.108.22:8080/
[05:06:34] - Couldn't send HTTP request to server
[05:06:34]   (Got status 503)
[05:06:34] + Could not connect to Work Server
[05:06:34] - Attempt #3  to get work failed, and no other work to do.
[05:06:57] + Attempting to get work packet
[05:06:57] Passkey found
[05:06:57] - Will indicate memory of 6135 MB
[05:06:57] - Connecting to assignment server
[05:06:57] Connecting to http://assign.stanford.edu:8080/
[05:06:58] Posted data.
[05:06:58] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:06:58] + News From Folding@Home: Welcome to Folding@Home
[05:06:59] Loaded queue successfully.
[05:06:59] Sent data
[05:06:59] Connecting to http://171.67.108.22:8080/
[05:06:59] - Couldn't send HTTP request to server
[05:06:59]   (Got status 503)
[05:06:59] + Could not connect to Work Server
[05:06:59] - Attempt #4  to get work failed, and no other work to do.
[05:07:46] + Attempting to get work packet
[05:07:46] Passkey found
[05:07:46] - Will indicate memory of 6135 MB
[05:07:46] - Connecting to assignment server
[05:07:46] Connecting to http://assign.stanford.edu:8080/
[05:07:47] Posted data.
[05:07:47] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:07:47] + News From Folding@Home: Welcome to Folding@Home
[05:07:47] Loaded queue successfully.
[05:07:47] Sent data
[05:07:47] Connecting to http://171.67.108.22:8080/
[05:07:48] - Couldn't send HTTP request to server
[05:07:48]   (Got status 503)
[05:07:48] + Could not connect to Work Server
[05:07:48] - Attempt #5  to get work failed, and no other work to do.
[05:09:20] + Attempting to get work packet
[05:09:20] Passkey found
[05:09:20] - Will indicate memory of 6135 MB
[05:09:20] - Connecting to assignment server
[05:09:20] Connecting to http://assign.stanford.edu:8080/
[05:09:21] Posted data.
[05:09:21] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:09:21] + News From Folding@Home: Welcome to Folding@Home
[05:09:21] Loaded queue successfully.
[05:09:21] Sent data
[05:09:21] Connecting to http://171.67.108.22:8080/
[05:09:22] - Couldn't send HTTP request to server
[05:09:22]   (Got status 503)
[05:09:22] + Could not connect to Work Server
[05:09:22] - Attempt #6  to get work failed, and no other work to do.
[05:12:08] + Attempting to get work packet
[05:12:08] Passkey found
[05:12:08] - Will indicate memory of 6135 MB
[05:12:08] - Connecting to assignment server
[05:12:08] Connecting to http://assign.stanford.edu:8080/
[05:12:10] Posted data.
[05:12:10] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:12:10] + News From Folding@Home: Welcome to Folding@Home
[05:12:10] Loaded queue successfully.
[05:12:10] Sent data
[05:12:10] Connecting to http://171.67.108.22:8080/
[05:12:10] - Couldn't send HTTP request to server
[05:12:10]   (Got status 503)
[05:12:10] + Could not connect to Work Server
[05:12:10] - Attempt #7  to get work failed, and no other work to do.
[05:17:42] + Attempting to get work packet
[05:17:42] Passkey found
[05:17:42] - Will indicate memory of 6135 MB
[05:17:42] - Connecting to assignment server
[05:17:42] Connecting to http://assign.stanford.edu:8080/
[05:17:44] Posted data.
[05:17:44] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:17:44] + News From Folding@Home: Welcome to Folding@Home
[05:17:44] Loaded queue successfully.
[05:17:44] Sent data
[05:17:44] Connecting to http://171.67.108.22:8080/
[05:17:44] - Couldn't send HTTP request to server
[05:17:44]   (Got status 503)
[05:17:44] + Could not connect to Work Server
[05:17:44] - Attempt #8  to get work failed, and no other work to do.
[05:28:28] + Attempting to get work packet
[05:28:28] Passkey found
[05:28:28] - Will indicate memory of 6135 MB
[05:28:28] - Connecting to assignment server
[05:28:28] Connecting to http://assign.stanford.edu:8080/
[05:28:29] Posted data.
[05:28:29] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:28:29] + News From Folding@Home: Welcome to Folding@Home
[05:28:29] Loaded queue successfully.
[05:28:29] Sent data
[05:28:29] Connecting to http://171.67.108.22:8080/
[05:28:29] - Couldn't send HTTP request to server
[05:28:29]   (Got status 503)
[05:28:29] + Could not connect to Work Server
[05:28:29] - Attempt #9  to get work failed, and no other work to do.
--- Opening Log file [August 5 05:37:26 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: C:\Folding@Home\CPU
Executable: C:\Folding@Home\CPU\F@Hv6.29.exe
Arguments: -local -verbosity 9 -smp 12 -bigadv
[05:37:26] - Ask before connecting: No
[05:37:26] - User name: Mr.Nosmo (Team 96644)
[05:37:26] - User ID: "REMOVED MY ME"
[05:37:26] - Machine ID: 1
[05:37:26]
[05:37:26] Loaded queue successfully.
[05:37:26] - Preparing to get new work unit...
[05:37:26] - Autosending finished units... [August 5 05:37:26 UTC]
[05:37:26] Cleaning up work directory
[05:37:26] Trying to send all finished work units
[05:37:26] Project: 2685 (Run 4, Clone 5, Gen 12)
[05:37:26] + Attempting to get work packet
[05:37:26] Passkey found
[05:37:26] + Attempting to send results [August 5 05:37:26 UTC]
[05:37:26] - Will indicate memory of 6135 MB
[05:37:26] - Reading file work/wuresults_07.dat from core
[05:37:26] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[05:37:26] - Connecting to assignment server
[05:37:26] Connecting to http://assign.stanford.edu:8080/
[05:37:27]   (Read 107266486 bytes from disk)
[05:37:27] Connecting to http://171.67.108.22:8080/
[05:37:27] - Couldn't send HTTP request to server
[05:37:27]   (Got status 503)
[05:37:27] + Could not connect to Work Server (results)
[05:37:27]     (171.67.108.22:8080)
[05:37:27] + Retrying using alternative port
[05:37:27] Connecting to http://171.67.108.22:80/
[05:37:27] Posted data.
[05:37:27] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:37:27] + News From Folding@Home: Welcome to Folding@Home
[05:37:27] Loaded queue successfully.
[05:37:27] Sent data
[05:37:27]     (171.67.108.22:80)
[05:37:27] - Error: Could not transmit unit 07 (completed August 5) to work server.
[05:37:27] - 3 failed uploads of this unit.
[05:37:27] + Attempting to send results [August 5 05:37:27 UTC]
[05:37:27] - Reading file work/wuresults_07.dat from core
[05:37:28]   (Read 107266486 bytes from disk)
[05:37:28] Connecting to http://171.67.108.25:8080/
[05:37:28] - Couldn't send HTTP request to server
[05:37:28]   (Got status 503)
[05:37:28] + Could not connect to Work Server
[05:37:28] - Attempt #1  to get work failed, and no other work to do.
[05:37:34] + Attempting to get work packet
[05:37:34] Passkey found
[05:37:34] - Will indicate memory of 6135 MB
[05:37:34] - Connecting to assignment server
[05:37:34] Connecting to http://assign.stanford.edu:8080/
[05:37:37] Posted data.
[05:37:37] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:37:37] + News From Folding@Home: Welcome to Folding@Home
[05:37:37] Loaded queue successfully.
[05:37:37] Sent data
[05:37:37] Connecting to http://171.67.108.22:8080/
[05:37:39] - Couldn't send HTTP request to server
[05:37:39]   (Got status 503)
[05:37:39] + Could not connect to Work Server
[05:37:39] - Attempt #2  to get work failed, and no other work to do.
[05:37:59] Posted data.
[05:37:59] Initial: 0000; + Could not connect to Work Server (results)
[05:37:59]     (171.67.108.25:8080)
[05:37:59] + Retrying using alternative port
[05:37:59] Connecting to http://171.67.108.25:80/
[05:38:00] + Attempting to get work packet
[05:38:00] Passkey found
[05:38:00] - Will indicate memory of 6135 MB
[05:38:00] - Connecting to assignment server
[05:38:00] Connecting to http://assign.stanford.edu:8080/
[05:38:02] Posted data.
[05:38:02] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[05:38:02] + News From Folding@Home: Welcome to Folding@Home
[05:38:02] Loaded queue successfully.
[05:38:02] Sent data
[05:38:02] Connecting to http://171.67.108.22:8080/
[05:38:03] - Couldn't send HTTP request to server
[05:38:03]   (Got status 503)
[05:38:03] + Could not connect to Work Server
[05:38:03] - Attempt #3  to get work failed, and no other work to do.
[05:38:24] + Attempting to get work packet
[05:38:24] Passkey found
[05:38:24] - Will indicate memory of 6135 MB
[05:38:24] - Connecting to assignment server
[05:38:24] Connecting to http://assign.stanford.edu:8080/
[05:38:33] Posted data.
[05:38:33] Initial: 0000; + Could not connect to Work Server (results)
[05:38:33]     (171.67.108.25:80)
[05:38:33]   Could not transmit unit 07 to Collection server; keeping in queue.
[05:38:33] + Sent 0 of 1 completed units to the server
[05:38:33] - Autosend completed
[05:38:36] - Could not CosmHTTPOpen
[05:38:36] + Could not connect to Assignment Server
[05:38:36] Connecting to http://assign2.stanford.edu:80/
[05:38:37] Posted data.
[05:38:37] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[05:38:37] + News From Folding@Home: Welcome to Folding@Home
[05:38:37] Loaded queue successfully.
[05:38:37] Sent data
[05:38:37] Connecting to http://171.64.65.54:80/
[05:38:39] Posted data.
[05:38:39] Initial: 0000; - Receiving payload (expected size: 1779218)
[05:38:44] - Downloaded at ~347 kB/s
[05:38:44] - Averaged speed for that direction ~297 kB/s
[05:38:44] + Received work.
[05:38:44] + Closed connections
[05:38:44]
[05:38:44] + Processing work unit
[05:38:44] Core required: FahCore_a3.exe
[05:38:44] Core found.
[05:38:44] Working on queue slot 08 [August 5 05:38:44 UTC]
[05:38:44] + Working ...
[05:38:44] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 12 -nocpulock -checkpoint 15 -verbose -lifeline 5132 -version 630'
[05:38:44]
[05:38:44] *------------------------------*
[05:38:44] Folding@Home Gromacs SMP Core
[05:38:44] Version 2.22 (Mar 12, 2010)
[05:38:44]
[05:38:44] Preparing to commence simulation
[05:38:44] - Looking at optimizations...
[05:38:44] - Created dyn
[05:38:44] - Files status OK
[05:38:44] - Expanded 1778706 -> 2059833 (decompressed 115.8 percent)
[05:38:44] Called DecompressByteArray: compressed_data_size=1778706 data_size=2059833, decompressed_data_size=2059833 diff=0
[05:38:44] - Digital signature verified
[05:38:44]
[05:38:44] Project: 6024 (Run 0, Clone 134, Gen 247)
[05:38:44]
[05:38:44] Assembly optimizations on if available.
[05:38:44] Entering M.D.
[05:38:50] Completed 0 out of 500000 steps  (0%)
[05:41:23] Completed 5000 out of 500000 steps  (1%)
[05:43:23] Completed 10000 out of 500000 steps  (2%)
CougTek
Re: 171.67.108.22
Post by CougTek »
I also have problems to send my finished unit to this server. I cannot connect to it with a Net browser either. It is frustrating as it took me 3 days and a half to complete this unit (project 2684). I'm within the prefered deadline. I've been able to obtain a new work unit, but not to send the finished one.
This is a plain Windows 7 install without third party firewall. I tried to reboot the computer and to reset the router. The problem isn't on my side. We're a bunch not to be able to connect to 171.67.108.22. There IS a problem with the server and it is not showing on the server status page.
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
The server is accepting work units (I'm watching successful accepts). There were posts in some other threads about people with problems uploading large work units to our servers. You might want to check those.
Re: 171.67.108.22
I am saving some serious issues with this server:
Uploading starts fine but suddenly, it terminates the connection and then it starts all over again.
Downloading a new WU is not possible as the Server doesn't give me any bandwidth.
I have kept my internet connection idle yet I still can't upload or download the WU despite me getting the "receiving payload" message. I have been trying to upload from 15:00 UTC and now have only 7 hours for deadline. My connection needs ~2.5 hours to upload so I hope that this gets sorted out soon. I have restarted the Client with -send all and am hoping that it gets uploaded and credited with bonus.
FAHlog:
--- Opening Log file [August 8 15:07:53 UTC]
Launch directory: D:\F@H SMP2
Executable: D:\F@H SMP2\Folding@home-Win32-x86.exe
Arguments: -smp 7 -bigadv -verbosity 9
[15:07:53] - Ask before connecting: No
[15:07:53] - User name: PantherX (Team 69411)
[15:07:53] - User ID:
[15:07:53] - Machine ID: 1
[15:07:53]
[15:07:53] Loaded queue successfully.
[15:07:53] - Preparing to get new work unit...
[15:07:53] - Autosending finished units... [August 8 15:07:53 UTC]
[15:07:53] Cleaning up work directory
[15:07:53] Trying to send all finished work units
[15:07:53] + Attempting to get work packet
[15:07:53] Project: 2684 (Run 13, Clone 13, Gen 7)
[15:07:53] Passkey found
[15:07:53] - Will indicate memory of 4091 MB
[15:07:53] + Attempting to send results [August 8 15:07:53 UTC]
[15:07:53] - Detect CPU.[15:07:53] - Reading file work/wuresults_04.dat from core
 Vendor: GenuineIntel, Family: 6, Model: 14, Stepping: 5
[15:07:54]   (Read 100099497 bytes from disk)
[15:07:54] - Connecting to assignment server
[15:07:54] Connecting to http://171.67.108.22:8080/
[15:07:54] Connecting to http://assign.stanford.edu:8080/
[15:07:55] Posted data.
[15:07:55] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[15:07:55] + News From Folding@Home: Welcome to Folding@Home
[15:07:55] Loaded queue successfully.
[15:07:55] Sent data
[15:07:55] Connecting to http://171.67.108.22:8080/
[15:08:41] Posted data.
[15:08:41] Initial: 0000; - Receiving payload (expected size: 30334341)
[15:59:05] + Could not get Work unit data from Work Server
[15:59:05] - Attempt #1  to get work failed, and no other work to do.
[15:59:11] + Attempting to get work packet
[15:59:11] Passkey found
[15:59:11] - Will indicate memory of 4091 MB
[15:59:11] - Connecting to assignment server
[15:59:11] Connecting to http://assign.stanford.edu:8080/
[15:59:22] Posted data.
[15:59:22] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[15:59:22] + News From Folding@Home: Welcome to Folding@Home
[15:59:23] Loaded queue successfully.
[15:59:23] Sent data
[15:59:23] Connecting to http://171.67.108.22:8080/
[16:00:19] Posted data.
[16:00:19] Initial: 0000; - Receiving payload (expected size: 30331439)
[16:10:50] + Could not get Work unit data from Work Server
[16:10:50] - Attempt #2  to get work failed, and no other work to do.
[16:11:11] + Attempting to get work packet
[16:11:11] Passkey found
[16:11:11] - Will indicate memory of 4091 MB
[16:11:11] - Connecting to assignment server
[16:11:11] Connecting to http://assign.stanford.edu:8080/
[16:11:12] Posted data.
[16:11:12] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[16:11:12] + News From Folding@Home: Welcome to Folding@Home
[16:11:12] Loaded queue successfully.
[16:11:12] Sent data
[16:11:12] Connecting to http://171.67.108.22:8080/
[16:11:40] - Couldn't send HTTP request to server
[16:11:40] + Could not connect to Work Server (results)
[16:11:40]     (171.67.108.22:8080)
[16:11:40] + Retrying using alternative port
[16:11:40] Connecting to http://171.67.108.22:80/
[16:11:51] Posted data.
[16:11:51] Initial: 0000; - Receiving payload (expected size: 30329792)
[16:47:45] + Could not get Work unit data from Work Server
[16:47:45] - Attempt #3  to get work failed, and no other work to do.
[16:48:11] + Attempting to get work packet
[16:48:11] Passkey found
[16:48:11] - Will indicate memory of 4091 MB
[16:48:11] - Connecting to assignment server
[16:48:11] Connecting to http://assign.stanford.edu:8080/
[16:48:23] Posted data.
[16:48:23] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[16:48:23] + News From Folding@Home: Welcome to Folding@Home
[16:48:23] Loaded queue successfully.
[16:48:23] Sent data
[16:48:23] Connecting to http://171.67.108.22:8080/
[16:48:44] Posted data.
[16:48:44] Initial: 0000; - Receiving payload (expected size: 24820972)
[16:50:15] + Could not get Work unit data from Work Server
[16:50:15] - Attempt #4  to get work failed, and no other work to do.
[16:51:07] + Attempting to get work packet
[16:51:07] Passkey found
[16:51:07] - Will indicate memory of 4091 MB
[16:51:07] - Connecting to assignment server
[16:51:07] Connecting to http://assign.stanford.edu:8080/
[16:51:31] Posted data.
[16:51:31] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[16:51:31] + News From Folding@Home: Welcome to Folding@Home
[16:51:31] Loaded queue successfully.
[16:51:31] Sent data
[16:51:31] Connecting to http://171.67.108.22:8080/
[16:51:37] - Couldn't send HTTP request to server
[16:51:37] + Could not connect to Work Server (results)
[16:51:37]     (171.67.108.22:80)
[16:51:37] - Error: Could not transmit unit 04 (completed August 8) to work server.
[16:51:37] - 3 failed uploads of this unit.
[16:51:37] + Attempting to send results [August 8 16:51:37 UTC]
[16:51:37] - Reading file work/wuresults_04.dat from core
[16:51:38]   (Read 100099497 bytes from disk)
[16:51:38] Connecting to http://171.67.108.25:8080/
[16:51:40] - Couldn't send HTTP request to server
[16:51:40]   (Got status 503)
[16:51:40] + Could not connect to Work Server (results)
[16:51:40]     (171.67.108.25:8080)
[16:51:40] + Retrying using alternative port
[16:51:40] Connecting to http://171.67.108.25:80/
[16:51:42] - Couldn't send HTTP request to server
[16:51:42]   (Got status 503)
[16:51:42] + Could not connect to Work Server (results)
[16:51:42]     (171.67.108.25:80)
[16:51:42]   Could not transmit unit 04 to Collection server; keeping in queue.
[16:51:42] + Sent 0 of 1 completed units to the server
[16:51:42] - Autosend completed
[16:52:14] Posted data.
[16:52:25] Initial: 0000; - Receiving payload (expected size: 30326125)
[16:53:55] + Could not get Work unit data from Work Server
[16:53:55] - Attempt #5  to get work failed, and no other work to do.
[16:55:23] + Attempting to get work packet
[16:55:23] Passkey found
[16:55:23] - Will indicate memory of 4091 MB
[16:55:23] - Connecting to assignment server
[16:55:23] Connecting to http://assign.stanford.edu:8080/
[16:55:24] Posted data.
[16:55:24] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[16:55:24] + News From Folding@Home: Welcome to Folding@Home
[16:55:24] Loaded queue successfully.
[16:55:24] Sent data
[16:55:24] Connecting to http://171.67.108.22:8080/
[16:55:36] Posted data.
[16:55:39] Initial: 0000; - Receiving payload (expected size: 24825791)
[16:58:15] + Could not get Work unit data from Work Server
[16:58:15] - Attempt #6  to get work failed, and no other work to do.
[17:01:02] + Attempting to get work packet
[17:01:02] Passkey found
[17:01:02] - Will indicate memory of 4091 MB
[17:01:02] - Connecting to assignment server
[17:01:02] Connecting to http://assign.stanford.edu:8080/
[17:01:03] Posted data.
[17:01:03] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[17:01:03] + News From Folding@Home: Welcome to Folding@Home
[17:01:04] Loaded queue successfully.
[17:01:04] Sent data
[17:01:04] Connecting to http://171.67.108.22:8080/
[17:01:14] Posted data.
[17:01:14] Initial: 0000; - Receiving payload (expected size: 25476631)
[17:02:40] + Could not get Work unit data from Work Server
[17:02:40] - Attempt #7  to get work failed, and no other work to do.
[17:08:06] + Attempting to get work packet
[17:08:06] Passkey found
[17:08:06] - Will indicate memory of 4091 MB
[17:08:06] - Connecting to assignment server
[17:08:06] Connecting to http://assign.stanford.edu:8080/
[17:08:07] Posted data.
[17:08:07] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[17:08:07] + News From Folding@Home: Welcome to Folding@Home
[17:08:07] Loaded queue successfully.
[17:08:07] Sent data
[17:08:07] Connecting to http://171.67.108.22:8080/
[17:08:22] Posted data.
[17:08:34] Initial: 0000; - Receiving payload (expected size: 26600536)
[17:11:00] + Could not get Work unit data from Work Server
[17:11:00] - Attempt #8  to get work failed, and no other work to do.
[17:12:56] Killing all core threads
[17:12:56] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[17:12:56] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [August 8 17:13:05 UTC]
Arguments: -send all -verbosity 9
[17:13:05] - Ask before connecting: No
[17:13:05] - User name: PantherX (Team 69411)
[17:13:05] - User ID:
[17:13:05] - Machine ID: 1
[17:13:05]
[17:13:05] Loaded queue successfully.
[17:13:05] Deleting incompletely fetched item (4) from queue position #5
[17:13:05] - Warning: Could not delete all work unit files (5): Core file absent
[17:13:05] Attempting to return result(s) to server...
[17:13:05] Trying to send all finished work units
[17:13:05] Project: 2684 (Run 13, Clone 13, Gen 7)
[17:13:05] - Read packet limit of 540015616... Set to 524286976.
[17:13:05] + Attempting to send results [August 8 17:13:05 UTC]
[17:13:05] - Reading file work/wuresults_04.dat from core
[17:13:05]   (Read 100099497 bytes from disk)
[17:13:05] Connecting to http://171.67.108.22:8080/
Re: 171.67.108.22
Apparently, The WU has been submitted after 6 hours. At least it was 4 hours before the Preferred Deadline so I am still happy to receive ~57000 Credits instead of the base points :D Now back to folding another bigadv WU :eugeek:
caintry_boy
Post by caintry_boy »
Been trying to connect to this server to upload results all afternoon, no joy... :( Must be down again.....
Error 503 means the server is NOT down, but it is overloaded. Once the traffic gets to the point that the server cannot handle any more, some people do get through and others are rejected with a 503.
It should be noted that you didn't follow the instructions in the "Do this first" post. You're reporting a problem with a Collection Server, not a Work Server and we can't do anything about server 171.67.108.25. We need to know what's happening to the OTHER server that you didn't report.
