Project: 5741 (Run 2, Clone 25, Gen 48)
tinokun
Post by tinokun »
Unlike previous failures I've had, this one did generate and upload a results file.
Can a mod tell me if this WU has been completed by someone else?
[01:19:40] + Attempting to get work packet
[01:19:40] Passkey found
[01:19:40] - Will indicate memory of 6077 MB
[01:19:40] Gpu type=1 species=4.
[01:19:40] - Connecting to assignment server
[01:19:40] Connecting to http://assign-GPU.stanford.edu:8080/
[01:19:41] Posted data.
[01:19:41] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[01:19:41] + News From Folding@Home: Welcome to Folding@Home
[01:19:41] Loaded queue successfully.
[01:19:41] Gpu type=1 species=4.
[01:19:41] Sent data
[01:19:41] Connecting to http://171.64.65.102:8080/
[01:19:42] Posted data.
[01:19:42] Initial: 0000; - Receiving payload (expected size: 70811)
[01:19:43] - Downloaded at ~69 kB/s
[01:19:43] - Averaged speed for that direction ~59 kB/s
[01:19:43] + Received work.
[01:19:43] Trying to send all finished work units
[01:19:43] + No unsent completed units remaining.
[01:19:43] + Closed connections
[01:19:43]
[01:19:43] + Processing work unit
[01:19:43] Core required: FahCore_11.exe
[01:19:43] Core found.
[01:19:43] Working on queue slot 03 [August 1 01:19:43 UTC]
[01:19:43] + Working ...
[01:19:43] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -nice 19 -nocpulock -checkpoint 30
-verbose -lifeline 2148 -version 630'
[01:19:43]
[01:19:43] *------------------------------*
[01:19:43] Folding@Home GPU Core - Beta
[01:19:43] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:19:43]
[01:19:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 fo
r 80x86
[01:19:43] Build host: amoeba
[01:19:43] Board Type: AMD
[01:19:43] Core      :
[01:19:43] Preparing to commence simulation
[01:19:43] - Looking at optimizations...
[01:19:43] - Created dyn
[01:19:43] - Files status OK
[01:19:43] - Expanded 70299 -> 360060 (decompressed 512.1 percent)
[01:19:43] Called DecompressByteArray: compressed_data_size=70299 data_size=360060, decompressed
_data_size=360060 diff=0
[01:19:43] - Digital signature verified
[01:19:43]
[01:19:43] Project: 5741 (Run 2, Clone 25, Gen 48)
[01:19:43]
[01:19:43] Assembly optimizations on if available.
[01:19:43] Entering M.D.
[01:19:49] Tpr hash work/wudata_03.tpr:  2934023387 3442978187 799679463 345498561 1697456290
[01:19:50] mdrun_gpu returned
[01:19:50] Going to send back what have done -- stepsTotalG=0
[01:19:50] Work fraction=0.0000 steps=0.
[01:19:54] logfile size=5723 infoLength=5723 edr=0 trr=25
[01:19:54] - Writing 6261 bytes of core data to disk...
[01:19:54] Done: 5749 -> 2250 (compressed to 39.1 percent)
[01:19:54]   ... Done.
[01:19:54]
[01:19:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:19:57] CoreStatus = 7A (122)
[01:19:57] Sending work to server
[01:19:57] Project: 5741 (Run 2, Clone 25, Gen 48)
[01:19:57] - Read packet limit of 540015616... Set to 524286976.
[01:19:57] + Attempting to send results [August 1 01:19:57 UTC]
[01:19:57] - Reading file work/wuresults_03.dat from core
[01:19:57]   (Read 2762 bytes from disk)
[01:19:57] Gpu type=1 species=4.
[01:19:57] Connecting to http://171.64.65.102:8080/
[01:19:58] Posted data.
[01:19:58] Initial: 0000; - Uploaded at ~3 kB/s
[01:19:58] - Averaged speed for that direction ~22 kB/s
[01:19:58] + Results successfully sent
[01:19:58] Thank you for your contribution to Folding@Home.
Thanks.
Re: Project: 5741 (Run 2, Clone 25, Gen 48)
Oh my god ... the query almost crashed my browser with the number of results it returned :shock:
Time to mark this WU as a bad one since all reports are immediate EUEs.
