171.64.65.54 and 171.67.108.25 on ports 8080 and 80
BrokenWolf
Post by BrokenWolf »
I am unable to upload some WU's to these 2 systems. One gets a 504 error and the other a 502. I do not get the OK when trying to access these systems via a web browser.
It would appear that 171.64.65.54 is down per the server status page.
Might we be able to get someone to give 'em a kick or 2?
Thank you,
BrokenWolf
lanbrown
Re: 171.64.65.54 and 171.67.108.25 on ports 8080 and 80
Post by lanbrown »
Same here and can't get anymore either.
[02:08:24] Completed 415000 out of 500000 steps  (83%)
[02:15:03] Completed 420000 out of 500000 steps  (84%)
[02:21:43] Completed 425000 out of 500000 steps  (85%)
[02:28:23] Completed 430000 out of 500000 steps  (86%)
[02:35:03] Completed 435000 out of 500000 steps  (87%)
[02:41:43] Completed 440000 out of 500000 steps  (88%)
[02:48:24] Completed 445000 out of 500000 steps  (89%)
[02:55:04] Completed 450000 out of 500000 steps  (90%)
[03:01:44] Completed 455000 out of 500000 steps  (91%)
[03:08:26] Completed 460000 out of 500000 steps  (92%)
[03:15:07] Completed 465000 out of 500000 steps  (93%)
[03:21:48] Completed 470000 out of 500000 steps  (94%)
[03:28:28] Completed 475000 out of 500000 steps  (95%)
[03:35:09] Completed 480000 out of 500000 steps  (96%)
[03:41:50] Completed 485000 out of 500000 steps  (97%)
[03:48:31] Completed 490000 out of 500000 steps  (98%)
[03:55:12] Completed 495000 out of 500000 steps  (99%)
[04:01:54] Completed 500000 out of 500000 steps  (100%)
[04:01:54] DynamicWrapper: Finished Work Unit: sleep=10000
[04:02:04]
[04:02:04] Finished Work Unit:
[04:02:04] - Reading up to 3697488 from "work/wudata_04.trr": Read 3697488
[04:02:04] trr file hash check passed.
[04:02:04] edr file hash check passed.
[04:02:04] logfile size: 57762
[04:02:04] Leaving Run
[04:02:08] - Writing 3790802 bytes of core data to disk...
[04:02:08]   ... Done.
[04:02:08] - Shutting down core
[04:02:08]
[04:02:08] Folding@home Core Shutdown: FINISHED_UNIT
[04:02:09] CoreStatus = 64 (100)
[04:02:09] Unit 4 finished with 92 percent of time to deadline remaining.
[04:02:09] Updated performance fraction: 0.902025
[04:02:09] Sending work to server
[04:02:09] Project: 6071 (Run 0, Clone 19, Gen 91)
[04:02:09] + Attempting to send results [July 29 04:02:09 UTC]
[04:02:09] - Reading file work/wuresults_04.dat from core
[04:02:09]   (Read 3790802 bytes from disk)
[04:02:09] Connecting to http://171.64.65.54:8080/
[04:05:18] - Couldn't send HTTP request to server
[04:05:18] + Could not connect to Work Server (results)
[04:05:18]     (171.64.65.54:8080)
[04:05:18] + Retrying using alternative port
[04:05:18] Connecting to http://171.64.65.54:80/
[04:08:27] - Couldn't send HTTP request to server
[04:08:27] + Could not connect to Work Server (results)
[04:08:27]     (171.64.65.54:80)
[04:08:27] - Error: Could not transmit unit 04 (completed July 29) to work server.
[04:08:27] - 1 failed uploads of this unit.
[04:08:27]   Keeping unit 04 in queue.
[04:08:27] Trying to send all finished work units
[04:08:27] Project: 6071 (Run 0, Clone 19, Gen 91)
[04:08:27] + Attempting to send results [July 29 04:08:27 UTC]
[04:08:27] - Reading file work/wuresults_04.dat from core
[04:08:27]   (Read 3790802 bytes from disk)
[04:08:27] Connecting to http://171.64.65.54:8080/
[04:11:36] - Couldn't send HTTP request to server
[04:11:36] + Could not connect to Work Server (results)
[04:11:36]     (171.64.65.54:8080)
[04:11:36] + Retrying using alternative port
[04:11:36] Connecting to http://171.64.65.54:80/
[04:14:45] - Couldn't send HTTP request to server
[04:14:45] + Could not connect to Work Server (results)
[04:14:45]     (171.64.65.54:80)
[04:14:45] - Error: Could not transmit unit 04 (completed July 29) to work server.
[04:14:45] - 2 failed uploads of this unit.
[04:14:45] + Attempting to send results [July 29 04:14:45 UTC]
[04:14:45] - Reading file work/wuresults_04.dat from core
[04:14:45]   (Read 3790802 bytes from disk)
[04:14:45] Connecting to http://171.67.108.25:8080/
[04:14:46] Posted data.
[04:14:46] Initial: 0000; + Could not connect to Work Server (results)
[04:14:46]     (171.67.108.25:8080)
[04:14:46] + Retrying using alternative port
[04:14:46] Connecting to http://171.67.108.25:80/
[04:14:47] Posted data.
[04:14:47] Initial: 0000; + Could not connect to Work Server (results)
[04:14:47]     (171.67.108.25:80)
[04:14:47]   Could not transmit unit 04 to Collection server; keeping in queue.
[04:14:47] + Sent 0 of 1 completed units to the server
[04:14:47] - Preparing to get new work unit...
[04:14:47] Cleaning up work directory
[04:14:47] + Attempting to get work packet
[04:14:47] Passkey found
[04:14:47] - Will indicate memory of 7471 MB
[04:14:47] - Connecting to assignment server
[04:14:47] Connecting to http://assign.stanford.edu:8080/
[04:14:48] Posted data.
[04:14:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:14:48] + Couldn't get work instructions.
[04:14:48] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[04:14:57] + Attempting to get work packet
[04:14:57] Passkey found
[04:14:57] - Will indicate memory of 7471 MB
[04:14:57] - Connecting to assignment server
[04:14:57] Connecting to http://assign.stanford.edu:8080/
[04:14:57] Posted data.
[04:14:57] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:14:57] + Couldn't get work instructions.
[04:14:57] - Attempt #2  to get work failed, and no other work to do.
[04:15:18] + Attempting to get work packet
[04:15:18] Passkey found
[04:15:18] - Will indicate memory of 7471 MB
[04:15:18] - Connecting to assignment server
[04:15:18] Connecting to http://assign.stanford.edu:8080/
[04:15:18] Posted data.
[04:15:18] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:15:18] + Couldn't get work instructions.
[04:15:18] - Attempt #3  to get work failed, and no other work to do.
[04:15:45] + Attempting to get work packet
[04:15:45] Passkey found
[04:15:45] - Will indicate memory of 7471 MB
[04:15:45] - Connecting to assignment server
[04:15:45] Connecting to http://assign.stanford.edu:8080/
[04:15:45] Posted data.
[04:15:45] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:15:45] + Couldn't get work instructions.
[04:15:45] - Attempt #4  to get work failed, and no other work to do.
[04:16:25] + Attempting to get work packet
[04:16:25] Passkey found
[04:16:25] - Will indicate memory of 7471 MB
[04:16:25] - Connecting to assignment server
[04:16:25] Connecting to http://assign.stanford.edu:8080/
[04:16:25] Posted data.
[04:16:25] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:16:25] + Couldn't get work instructions.
[04:16:25] - Attempt #5  to get work failed, and no other work to do.
[04:17:57] + Attempting to get work packet
[04:17:57] Passkey found
[04:17:57] - Will indicate memory of 7471 MB
[04:17:57] - Connecting to assignment server
[04:17:57] Connecting to http://assign.stanford.edu:8080/
[04:17:58] Posted data.
[04:17:58] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:17:58] + Couldn't get work instructions.
[04:17:58] - Attempt #6  to get work failed, and no other work to do.
BrokenWolf wrote:I am unable to upload some WU's to these 2 systems. One gets a 504 error and the other a 502. I do not get the OK when trying to access these systems via a web browser.
Thank you,
BrokenWolf
See the Stanford network issues announcement here: http://foldingforum.org/viewtopic.php?f=24&t=15450
Also said it should be fixed. Post again if it's not.
BrokenWolf
Thank you,
BrokenWolf
7im,
If you would please look at the times you would see that my post was @ 9:31pm. The posts you are referring to came out @ 10:21pm and 10:50pm. I saw those after they posted them up.
BW
heikosch
Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
Problems again:
[11:49:39]   (Got status 503)
[11:49:39] + Could not connect to Work Server (results)
[11:49:39]     (171.67.108.25:80)
[11:49:39]   Could not transmit unit 04 to Collection server; keeping in queue.
[11:49:39] + Sent 0 of 1 completed units to the server
Heiko
Image Image
heikosch
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
Finally the client decided to use the other server and the WU was sucessfully uploaded to 171.64.65.54:80. :-)
Heiko
Image Image
Mr.Nosmo
Hardware configuration: i7-980X@4200 (AirCooled) w/6GB DDR3-1600 (8-8-8-20), 200GB Vertex2 SSD & 3xGTS-250 w/22" Eizo Monitors.
Post by Mr.Nosmo »
I have the same problem:
[02:15:22] Completed 2000000 out of 2000000 steps (100%)
[02:15:22] DynamicWrapper: Finished Work Unit: sleep=10000
[02:15:32]
[02:15:32] Finished Work Unit:
[02:15:32] - Reading up to 687408 from "work/wudata_01.trr": Read 687408
[02:15:32] trr file hash check passed.
[02:15:32] - Reading up to 42624264 from "work/wudata_01.xtc": Read 42624264
[02:15:32] xtc file hash check passed.
[02:15:32] edr file hash check passed.
[02:15:32] logfile size: 278923
[02:15:32] Leaving Run
[02:15:34] - Writing 43592931 bytes of core data to disk...
[02:15:35] ... Done.
[02:15:36] - Shutting down core
[02:15:36]
[02:15:36] Folding@home Core Shutdown: FINISHED_UNIT
[02:15:38] CoreStatus = 64 (100)
[02:15:38] Unit 1 finished with 94 percent of time to deadline remaining.
[02:15:38] Updated performance fraction: 0.866353
[02:15:38] Sending work to server
[02:15:38] Project: 6701 (Run 74, Clone 26, Gen 23)
[02:15:38] + Attempting to send results [August 1 02:15:38 UTC]
[02:15:38] - Reading file work/wuresults_01.dat from core
[02:15:38] (Read 43592931 bytes from disk)
[02:15:38] Connecting to http://171.64.65.56:8080/
[02:15:38] - Couldn't send HTTP request to server
[02:15:38] (Got status 503)
[02:15:38] + Could not connect to Work Server (results)
[02:15:38] (171.64.65.56:8080)
[02:15:38] + Retrying using alternative port
[02:15:38] Connecting to http://171.64.65.56:80/
[02:15:39] - Couldn't send HTTP request to server
[02:15:39] (Got status 503)
[02:15:39] + Could not connect to Work Server (results)
[02:15:39] (171.64.65.56:80)
[02:15:39] - Error: Could not transmit unit 01 (completed August 1) to work server.
[02:15:39] - 1 failed uploads of this unit.
[02:15:39] Keeping unit 01 in queue.
[02:15:39] Trying to send all finished work units
[02:15:39] Project: 6701 (Run 74, Clone 26, Gen 23)
[02:15:39] + Attempting to send results [August 1 02:15:39 UTC]
[02:15:39] - Reading file work/wuresults_01.dat from core
[02:15:39] (Read 43592931 bytes from disk)
[02:15:39] Connecting to http://171.64.65.56:8080/
[02:15:39] (171.64.65.56:8080)
[02:15:39] + Retrying using alternative port
[02:15:39] Connecting to http://171.64.65.56:80/
[02:15:40] - Couldn't send HTTP request to server
[02:15:40] (Got status 503)
[02:15:40] + Could not connect to Work Server (results)
[02:15:40] (171.64.65.56:80)
[02:15:40] - Error: Could not transmit unit 01 (completed August 1) to work server.
[02:15:40] - 2 failed uploads of this unit.
[02:15:40] + Attempting to send results [August 1 02:15:40 UTC]
[02:15:40] - Reading file work/wuresults_01.dat from core
[02:15:40] (Read 43592931 bytes from disk)
[02:15:40] Connecting to http://171.67.108.25:8080/
[02:15:40] (171.67.108.25:8080)
[02:15:40] + Retrying using alternative port
[02:15:40] Connecting to http://171.67.108.25:80/
[02:15:41] - Couldn't send HTTP request to server
[02:15:41] (Got status 503)
[02:15:41] + Could not connect to Work Server (results)
[02:15:41] (171.67.108.25:80)
[02:15:41] Could not transmit unit 01 to Collection server; keeping in queue.
[02:15:41] + Sent 0 of 1 completed units to the server
[02:15:41] - Preparing to get new work unit...
[02:15:41] Cleaning up work directory
[02:15:41] + Attempting to get work packet
[02:15:41] Passkey found
[02:15:41] - Will indicate memory of 6135 MB
[02:15:41] - Connecting to assignment server
[02:15:41] Connecting to http://assign.stanford.edu:8080/
[02:15:43] Posted data.
[02:15:43] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:15:43] + News From Folding@Home: Welcome to Folding@Home
[02:15:43] Loaded queue successfully.
[02:15:43] Sent data
[02:15:43] Connecting to http://171.67.108.22:8080/
[02:15:52] Posted data.
[02:15:52] Initial: 0000; - Receiving payload (expected size: 26648651)
[02:16:36] - Downloaded at ~591 kB/s
[02:16:36] - Averaged speed for that direction ~400 kB/s
[02:16:36] + Received work.
[02:16:36] Trying to send all finished work units
[02:16:36] Project: 6701 (Run 74, Clone 26, Gen 23)
[02:16:36] + Attempting to send results [August 1 02:16:36 UTC]
[02:16:36] - Reading file work/wuresults_01.dat from core
[02:16:36] (Read 43592931 bytes from disk)
[02:16:36] Connecting to http://171.64.65.56:8080/
[02:16:37] - Couldn't send HTTP request to server
[02:16:37] (Got status 503)
[02:16:37] + Could not connect to Work Server (results)
[02:16:37] (171.64.65.56:8080)
[02:16:37] + Retrying using alternative port
[02:16:37] Connecting to http://171.64.65.56:80/
[02:16:37] (171.64.65.56:80)
[02:16:37] - Error: Could not transmit unit 01 (completed August 1) to work server.
[02:16:37] - 3 failed uploads of this unit.
[02:16:37] + Attempting to send results [August 1 02:16:37 UTC]
[02:16:37] - Reading file work/wuresults_01.dat from core
[02:16:37] (Read 43592931 bytes from disk)
[02:16:37] Connecting to http://171.67.108.25:8080/
[02:16:38] - Couldn't send HTTP request to server
[02:16:38] (Got status 503)
[02:16:38] + Could not connect to Work Server (results)
[02:16:38] (171.67.108.25:8080)
[02:16:38] + Retrying using alternative port
[02:16:38] Connecting to http://171.67.108.25:80/
[02:16:38] (171.67.108.25:80)
[02:16:38] Could not transmit unit 01 to Collection server; keeping in queue.
[02:16:38] + Sent 0 of 1 completed units to the server
[02:16:38] + Closed connections
[02:16:38]
[02:16:38] + Processing work unit
[02:16:38] Core required: FahCore_a3.exe
[02:16:38] Core found.
[02:16:38] Working on queue slot 02 [August 1 02:16:38 UTC]
[02:16:38] + Working ...
[02:16:38] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 12 -nocpulock -checkpoint 15 -verbose -lifeline 5272 -version 630'
[02:16:38]
[02:16:38] *------------------------------*
[02:16:38] Folding@Home Gromacs SMP Core
[02:16:38] Version 2.22 (Mar 12, 2010)
[02:16:38]
[02:16:38] Preparing to commence simulation
[02:16:38] - Looking at optimizations...
[02:16:38] - Created dyn
[02:16:38] - Files status OK
[02:16:43] - Expanded 26648139 -> 33000273 (decompressed 123.8 percent)
[02:16:43] Called DecompressByteArray: compressed_data_size=26648139 data_size=33000273, decompressed_data_size=33000273 diff=0
[02:16:43] - Digital signature verified
[02:16:43]
[02:16:43] Project: 2685 (Run 3, Clone 14, Gen 9)
[02:16:43]
[02:16:43] Assembly optimizations on if available.
[02:16:43] Entering M.D.
[02:16:52] Completed 0 out of 250000 steps (0%)
[02:41:23] Completed 2500 out of 250000 steps (1%)
k1wi
Post by k1wi »
Have been getting the same problem on and off today, restarting the client assigned me to a different server and got me a work unit but that work unit is complete, it's stuck on 171.67.108.22 again and I'm offsite :(
k1wi
