The keyboard stopped working. How do I stop the client (SMP2-A3; Win 7)? Which is better for WU, Shut Down, End Task or Close button on the console?
Thanks in advance.
Ctrl+C without keyboard. How?
derrickmcc
- Hardware configuration: 2 x GTX 460 (825/1600/1650)
AMD Athlon II X2 250 3.0Ghz
Kingston 2Gb DDR2 1066 Mhz
MSI K9A2 Platinum
Western Digital 500Gb Sata II
LiteOn DVD
Coolermaster 900W UCP
Antec 902
Windows XP SP3 - Location: Malvern, UK
Re: Ctrl+C without keyboard. How?
Try the Close button on the console, this will then tell the core to stop in an orderly fashion.
artoar_11
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
I stopped the client - Close button on the console. I changed the keyboard, but still does not work (WU survived). PS/2 port or something on the motherboard does not work. Now I have to buy a USB keyboard and go into BIOS to see what happens.
(This computer is in our office. Colleague is on vacation. I incorporated it a few days for FAH. There interference of "dark forces".
Well (at least under windows xp) there a such thing as "on screen keyboard" underneath accessories. Not sure how well that would work and if that is on windows 7 but it a option maybe you can take.
I didn't check, but I expect that on-screen keyboard is a permanent component. It's under "accessibility" which means it's intended for the handicapped. (Suppose your hands didn't work and you had to run Windows with eye motions and/or maybe a mouse that's adapted to your mouth.) Of course no-keyboard devices like the ipad/iphone have something similar that is intended for everybody.
I can confirm that on Windows 7 32 & 64 bit, On-Screen Keyboard is available:
Orb -> All Programs -> Accessories -> Ease of Access -> On-Screen Keyboard
I was able to successfully terminate my GPU3 Console Window using Crtl+C and it restarted without any problems.
