Help
Ex_Bay
Hardware configuration: 1. AMD Phenom 2, 2GB RAM, Windows XP pro (32 bit, SP3).
Nvida Gf-8500GT graphics.
2. AMD Athlon 64, 2GB RAM, Windows XP Pro (32 bit, SP2).
(Currently under construction.)
Help
Post by Ex_Bay »
Version: Folding@Home Client Version 5.03
PC. 2-core Phenom
Running Win XP (32 bit)
Problem:
[21:43:17] + Attempting to get work packet
[21:43:17] - Connecting to assignment server
[21:43:18] - Successful: assigned to (0.0.0.0).
[21:43:18] + News From Folding@Home: Welcome to Folding@Home
[21:43:18] Work Unit has an invalid address.
[21:43:18] - Error: Attempt #8 to get work failed, and no other work to do.
Waiting before retry.
I don't have a clue what's gone wrong.
Please put me right.
Thanks
XB
Zagen30
Re: Help
Post by Zagen30 »
Version 5.xx of the client is out-of-date and is only really recommended for machines running on pre-XP versions of Windows. It can only download certain projects, and as time goes on the number of projects that it can get has decreased, sometimes resulting in WU shortages. You should download version 6.23 and run that, or perhaps download the SMP client and take advantage of your multi-core processor if you leave your computer on most of the time. If you don't run your computer a lot, then I'd recommend installing a second copy of the classic client so that both cores will be put to use. http://folding.stanford.edu/English/Win ... 3]See here for more information on multi-client setup.
derrickmcc
Hardware configuration: 2 x GTX 460 (825/1600/1650)
AMD Athlon II X2 250 3.0Ghz
Kingston 2Gb DDR2 1066 Mhz
MSI K9A2 Platinum
Western Digital 500Gb Sata II
LiteOn DVD
Coolermaster 900W UCP
Antec 902
Windows XP SP3
Re: Help
Post by derrickmcc »
Hi XB, wekcome to the forum.
You appear to be running an old client, 5.03, the current classic client is 6.23 (and the current SMP client is 6.30).
The message saying you are assigned to server 0.0.0.0 means there is no WU available.
You could try shutting down and restarting your system, this may allow F@H to find a work server with some WU (work units) for you.
It may help to install the latest client, and to allow big units and advanced methods, as this will increase the potential pool of WU's available to be allocated to your system.
Re: Help
See this thread : viewtopic.php?f=4&t=10453
Ex_Bay
Re: Help
Post by Ex_Bay »
Zagen30 wrote:Version 5.xx of the client is out-of-date and is only really recommended for machines running on pre-XP versions of Windows. It can only download certain projects, and as time goes on the number of projects that it can get has decreased, sometimes resulting in WU shortages. You should download version 6.23 and run that, or perhaps download the SMP client and take advantage of your multi-core processor if you leave your computer on most of the time. If you don't run your computer a lot, then I'd recommend installing a second copy of the classic client so that both cores will be put to use. http://folding.stanford.edu/English/Win ... 3]See here for more information on multi-client setup.
Thanks, guys.
However, please don't use shorthand (SMP ?, multi client ?)
systray, console ?
My windows XP is not the 64-bit version
PS. I downloaded Folding@home-Win32-x86-systray.
It seems to deliver Folding@home503.
More later, when it's set itself up a bit.
Re: Help
Welcome to the F@H Forum Ex_Bay,
To get the latest F@H Classic Client, visit this site: (http://folding.stanford.edu/English/Download) You can choose to download the Systray Version or the Console Version, whichever you want. The Console Version is a no-nonsense Client Version. Both Clients will use the same FahCore to process the work so there isn't much difference. If you are using the Systray Version, please note that you shouldn't use the Viewer as it is known to be buggy and can crash your system. For monitoring the Client, please visit this tool list and download FahMon or HFM.NET
When you run the Classic Client, it will only use 1 Core hence your CPU Usage will be 50% If you want to donate more CPU Cycles to the F@H Program, you will have to install a second Classic Client by following this guide. Thus when you will be running 2 instances of Classic Clients, it will use 100% of your CPU. Please note that your day-to-day applications will run normally as the F@H Clients will use only free CPU Cycles. If a program wants CPU Cycles, it will give up the CPU Cycles.
Ex_Bay
Re: Help
Post by Ex_Bay »
I have downloaded the System Tray thing, version 6.23.
This is what's happened:-
[16:37:34] + Attempting to get work packet
[16:37:34] - Connecting to assignment server
[16:37:35] - Successful: assigned to (0.0.0.0).
[16:37:35] + News From Folding@Home: Welcome to Folding@Home
[16:37:35] Work Unit has an invalid address.
[16:37:35] - Error: Attempt #12 to get work failed, and no other work to do.
I'm getting really peeved with this. When I first got a PC onto Folding, it worked 'straight out of the box'. I now find myself drowning in a morass of short-hand confusion. I want to help, but most of the 'instructions' are written for experts, not dimboes like me.
codysluder
Re: Help
Post by codysluder »
Somehow you're confused. The "System Tray thing, version 6.23." does not issue the message "Successful: assigned to (0.0.0.0)." Scroll back in the log from that point and I suspect that it will say you're still looking at a log from V5. Maybe you didn't uninstall the old client or maybe the logs didn't get erased.
Right-click on the systray icon and look at the log from there. Is it the same one or a different one?
Ex_Bay
Re: Help
Post by Ex_Bay »
You are quite right; it took me a while to find it, but a v5 F@H was lurking. :)
It is now removed and I have both machines running now. :D
This is how things are currently:-
[16:52:57] Completed 2500000 out of 2500000 steps (100%)
[16:52:57] Writing final coordinates.
[16:52:57] Past main M.D. loop
[16:53:57]
[16:53:57] Finished Work Unit:
[16:53:57] - Reading up to 153648 from "work/wudata_02.arc": Read 153648
[16:53:57] - Reading up to 1242248 from "work/wudata_02.xtc": Read 1242248
[16:53:57] goefile size: 0
[16:53:57] Leaving Run
[16:53:57] - Writing 1439324 bytes of core data to disk...
[16:53:57] Done: 1438812 -> 1365552 (compressed to 94.9 percent)
[16:53:57] ... Done.
[16:53:57] - Shutting down core
[16:53:57]
[16:53:57] Folding@home Core Shutdown: FINISHED_UNIT
[16:54:01] CoreStatus = 64 (100)
[16:54:01] Sending work to server
[16:54:01] Project: 6331 (Run 6, Clone 478, Gen 12)
[16:54:01] - Read packet limit of 540015616... Set to 524286976.
[16:54:01] + Attempting to send results [July 30 16:54:01 UTC]
[16:54:02] - Couldn't send HTTP request to server
[16:54:02] + Could not connect to Work Server (results)
[16:54:02] (171.64.65.60:8080)
[16:54:02] + Retrying using alternative port
[16:54:03] - Couldn't send HTTP request to server
[16:54:03] + Could not connect to Work Server (results)
[16:54:03] (171.64.65.60:80)
[16:54:03] - Error: Could not transmit unit 02 (completed July 30) to work server.
[16:54:03] Keeping unit 02 in queue.
[16:54:03] Project: 6331 (Run 6, Clone 478, Gen 12)
[16:54:03] - Read packet limit of 540015616... Set to 524286976.
[16:54:03] + Attempting to send results [July 30 16:54:03 UTC]
[16:54:04] - Couldn't send HTTP request to server
[16:54:04] + Could not connect to Work Server (results)
[16:54:04] (171.64.65.60:8080)
[16:54:04] + Retrying using alternative port
[16:54:05] - Couldn't send HTTP request to server
[16:54:05] + Could not connect to Work Server (results)
[16:54:05] (171.64.65.60:80)
[16:54:05] - Error: Could not transmit unit 02 (completed July 30) to work server.
[16:54:05] - Read packet limit of 540015616... Set to 524286976.
[17:16:44] + Attempting to get work packet
[17:16:44] - Connecting to assignment server
[17:16:45] - Couldn't send HTTP request to server
[17:16:45] + Could not connect to Assignment Server
[17:16:46] - Couldn't send HTTP request to server
[17:16:46] + Could not connect to Assignment Server 2
[17:16:46] + Couldn't get work instructions.
[17:16:46] - Attempt #9 to get work failed, and no other work to do.
And the latest (Saturday lunchtime):-
[10:24:01] + Attempting to get work packet
[10:24:01] - Connecting to assignment server
[10:24:02] - Couldn't send HTTP request to server
[10:24:02] + Could not connect to Assignment Server
[10:24:03] - Couldn't send HTTP request to server
[10:24:03] + Could not connect to Assignment Server 2
[10:24:03] + Couldn't get work instructions.
[10:24:03] - Attempt #31 to get work failed, and no other work to do.
:cry:
XB
Ex_Bay
Re: Help
Post by Ex_Bay »
And I still cannot get it to work.
John_Weatherman
Re: Help
Post by John_Weatherman »
Have you managed to download more WUs or can you still not connect to Stanford?
Re: Help
Go to your browser and open the following.
http://assign.stanford.edu/
http://assign2.stanford.edu/
Each should show a blank white page with OK.
Ex_Bay
Re: Help
Post by Ex_Bay »
still no work units, but I got an OK on both pages.
Sorry to cause such grief.
Re: Help
If you get the "OK" messages from those servers but you get
that means you have a firewall which is blocking your FAH client from initiating a connection to the internet. Prove it to yourself by disabling your security software temporarily. Then figure out how to grant an exception to the client so it can initiate the connect. (Sometimes this software is called a firewall, sometimes anti-spyware, and sometimes its just part of a security suite.)
Ex_Bay
Re: Help
Post by Ex_Bay »
OK. Thanks.
I'll check it out.
Sunday Morning:
A complete re-installation following a strip-out and (hopefully) a clean-up. The Log file seems happy so far. :)
