This work unit keeps trying to fold in one of my GPU3 clients and is getting unstable machine. I can't seem to get a different protein to fold. I deleted the queue.dat file several times and the work folder to no avail.
I copied it to a different GPU3 folder and also got unstable machine but this one picked up a different protein.
Project: 10633 (Run 127, Clone 0, Gen 7)
Re: Project: 10633 (Run 127, Clone 0, Gen 7)
Someone else completed this WU successfully, and it's the only report in the DB.
Apparently you have quite a number of GPUs folding. I assume your "different folder" was the same GPU with the same settings, right? And was it using the same MachineID?
The different folder was the same GPU with the same settings with a different MachineID. I created a new folder, copied the GPU3 files, and configured it. I got a different protein this time.bruce wrote:Apparently you have quite a number of GPUs folding. I assume your "different folder" was the same GPU with the same settings, right? And was it using the same MachineID?
